path: root/drivers/spi
2014-06-02Merge remote-tracking branch 'spi/topic/workqueue' into spi-nextMark Brown
2014-06-02Merge remote-tracking branches 'spi/topic/oom', 'spi/topic/pxa2xx', ↵Mark Brown
'spi/topic/rspi' and 'spi/topic/sirf' into spi-next
2014-06-02Merge remote-tracking branches 'spi/topic/dw', 'spi/topic/fsl', ↵Mark Brown
'spi/topic/fsl-espi' and 'spi/topic/id-const' into spi-next
2014-06-02Merge remote-tracking branches 'spi/topic/adi', 'spi/topic/atmel' and ↵Mark Brown
'spi/topic/cadence' into spi-next
2014-06-02Merge remote-tracking branch 'spi/topic/dt' into spi-nextMark Brown
2014-06-02Merge remote-tracking branch 'spi/topic/core' into spi-nextMark Brown
2014-06-02Merge remote-tracking branches 'spi/fix/qup' and 'spi/fix/topcliff-pch' into ↵Mark Brown
spi-linus
2014-06-02spi: rspi: Extract rspi_common_transfer()Geert Uytterhoeven
Extract the common parts of rspi_transfer_one(), rspi_rz_transfer_one(), and qspi_transfer_out_in() into the new function rspi_common_transfer(). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Add DMA support for RSPI on RZ/A1HGeert Uytterhoeven
Enable DMA support for RSPI on r7s72100 (RZ/A1H). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Add DMA support for QSPI on R-Car Gen2Geert Uytterhoeven
Enable DMA support for QSPI on R-Car Gen2, for Single, Dual, and Quad SPI Transfers. Performance figures for reading from a QSPI FLASH driven at 24.375 MHz on r8a7791/koelsch: - Single: 1.1 Mbps PIO, 23 Mbps DMA - Dual : 12.7 Mbps PIO, 48 Mbps DMA - Quad : 13 Mbps PIO, 70 Mbps DMA Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Absorb rspi_rz_transfer_out_in() into rspi_rz_transfer_one()Geert Uytterhoeven
2014-06-02spi: rspi: Merge rspi_*_dma() into rspi_dma_transfer()Geert Uytterhoeven
rspi_send_dma() and rspi_send_receive_dma() are very similar. Consolidate into a single function rspi_dma_transfer(), and add missing checks for dmaengine_submit() failures. Both sg_table pointer parameters can be NULL, as RSPI supports TX-only mode, and unidirectional DMA transfers will also be needed later for Dual/Quad DMA support. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Pass sg_tables instead of spi_tranfer to rspi_*_dma()Geert Uytterhoeven
The DMA routines only need access to the scatter-gather tables inside the spi_transfer structures, hence just pass those. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Move RSPI-specific setup out of DMA routinesGeert Uytterhoeven
Refactor RSPI (on SH) DMA handling to make it reusable for other RSPI implementations: - Call the DMA routines after configuring the TX Mode bit and after calling rspi_receive_init(), so these RSPI-specific operations can be removed from the DMA routines, - Absorb rspi_transfer_out_in() into rspi_transfer_one(). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Use SPI core DMA mapping frameworkGeert Uytterhoeven
Use the SPI core DMA mapping framework instead of our own. If available, DMA is used for transfers larger than the FIFO size (8 or 32 bytes). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: SPI DMA core needs both RX and TX DMA to functionGeert Uytterhoeven
The SPI DMA core framework needs both RX and TX DMA to function. As a preparation for converting the driver to use this framework, fall back to PIO if no DMA channel or only one DMA channel is available. This affects only RSPI, which could do DMA transfers for TX-only before. RSPI-RZ and QSPI (at least for Single SPI Transfers) will need both RX and TX DMA anyway. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Remove unneeded resource test in DMA setupGeert Uytterhoeven
The resource is know to exist, as rspi_probe() already mapped it. Remove the test, and just pass the resource. Pass the device pointer instead of the platform device pointer, as the latter is no longer needed. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Extract rspi_request_dma_chan()Geert Uytterhoeven
Setup of the receive and transmit DMA channels is very similar, so let's consolidate. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Don't consider DMA configuration failures fatalGeert Uytterhoeven
Fall back to PIO if DMA configuration failed. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Extract rspi_pio_transfer()Geert Uytterhoeven
The various PIO loops are very similar. Consolidate into a single function rspi_pio_transfer(). Both buffer pointers can be NULL, as RSPI supports TX-only mode, and Dual/Quad SPI Transfers are unidirectional. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Use core SPI_MASTER_MUST_[RT]X handlingGeert Uytterhoeven
RSPI needs dummy transfers to generate the SPI clock on receive. RSPI-RZ and QSPI always do both transmit and receive. Use the SPI core SPI_MASTER_MUST_RX/SPI_MASTER_MUST_TX infrastructure instead of checking for the presence of buffers and providing dummy data ourselves (for PIO), or providing a dummy buffer (for DMA). rspi_receive_dma() now provides full duplex DMA transfers on RSPI, and is renamed to rspi_send_receive_dma(). As the SPI core will always provide a TX buffer, the logic to choose between DMA send and DMA send/receive in rspi_transfer_one() now has to check for the presence of an RX buffer. Likewise for the DMA availability tests in rspi_is_dma(). The buffer tests in qspi_transfer_one() are now always true, so they're removed. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Remove unused 16-bit DMA supportGeert Uytterhoeven
The 16-bit DMA support doesn't fit well within the SPI core DMA framework, as it needs to manage its own double-sized temporary buffers, for handling the interleaved data. Remove it, as there is no in-tree board code that sets rspi_plat_data.dma_width_16bit. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Do not call rspi_receive_init() for TX-onlyGeert Uytterhoeven
Since commit 8449fd76deb9ac67a15a6fb8ead7bb4595d019d2 ("spi: rspi: Merge rspi_send_pio() and rspi_receive_pio()"), rspi_receive_init() is called for transmit-only transfers too, while this is not needed. Only call rspi_receive_init() when receiving, to preserve behavior on RSPI on SH. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-02spi: rspi: Extract rspi_wait_for_{tx_empty,rx_full}()Geert Uytterhoeven
2014-06-01spi/pxa2xx: fix runtime PM enabling orderAntonio Ospite
In commit 7dd62787334ac6e0e2a0ef3f20bb1936ac431b04 (spi/pxa2xx: Convert to core runtime PM) master->auto_runtime_pm was set to true. In this case pm_runtime_enable() must be called *before* spi_register_master(), otherwise the kernel hangs with this error message: spi_master spi0: Failed to power device: -13 A similar fix, but for spi/hspi, was applied in 268d76430d1b68c340687357ffd18b4b12d02269. Signed-off-by: Antonio Ospite <ao2@ao2.it> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-26spi/fsl-espi: fix rx_buf in fsl_espi_cmd_trans()/fsl_espi_rw_trans()Valentin Longchamp
By default for every espi transfer, the rx_buf is placed right after the tx_buf. This can lead to a buffer overflow when the size of both the TX and RX data cumulated is higher than the allocated 64K buffer for the transfer (this is the case when sending for instance a read command and reading 64K back, please see: http://article.gmane.org/gmane.linux.drivers.mtd/53411 ) This gets fixed by always setting the RX buffer pointer at the begining of the transfer buffer. [The driver shouldn't be doing the copy in the first place and instead sending directly from the supplied buffer but this is at least not worse than what's there -- broonie] Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-26spi: core: Ignore unsupported spi-[tr]x-bus-width property valuesGeert Uytterhoeven
Rejecting unsupported values of spi-tx-bus-width and spi-rx-bus-width may break compatibility with future DTs. Just ignore them, falling back to Single SPI Transfers. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-26spi: rspi: Round up division to avoid slave overclockingGeert Uytterhoeven
The calculation of the bit rate divider used a standard C division, which rounds down the quotient. This may lead to a higher bitrate than requested. Round up to avoid this. E.g. on Koelsch, the SPI flash (configured for 30 MHz) was driven at 48.75 MHz. After this patch it's driven at a safe 24.375 MHz. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-20spi: sirf: decrease the interrupt count and latency of PIO modeQipan Li
current PIO tranfer method be described as follows: 1. fill as much as bytes but no more than 256 bytes(fifo size) 2. enable oflow/uflow/txfifo_empty interrupt 3. isr process 3 interrupt signal, do complete works. 4. after isr done, if there are left bytes go into 1 else go into 5 5. transfer end by current PIO transfer method: 1. reduce interrupt counts in spi interrupt line. 2. reduce interrupt latency because no do data fill/fetch in isr. Signed-off-by: Qipan Li <Qipan.Li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-16spi/topcliff-pch: Fix Kconfig dependenciesJean Delvare
The spi-topcliff-pch driver is for a companion chip to the Intel Atom E600 series processors. These are 32-bit x86 processors so the driver is only needed on X86_32. Add COMPILE_TEST as an alternative, so that the driver can still be build-tested elsewhere. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-14spi: qup: Correct selection of FIFO/Block modeAndy Gross
This patch fixes the calculation for determining whether to use FIFO or BLOCK mode. Signed-off-by: Andy Gross <agross@codeaurora.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-13Merge remote-tracking branches 'spi/fix/pxa2xx' and 'spi/fix/qup' into spi-linusMark Brown
2014-05-13Merge remote-tracking branch 'spi/fix/core' into spi-linusMark Brown
2014-05-12spi/pxa2xx: Prevent DMA from transferring too many bytesMika Westerberg
In case we are doing DMA transfer and the size of the buffer is not multiple of 4 bytes the driver truncates that to 4-byte boundary and tries to handle remaining bytes using PIO. Or that is what it tried to do. What actually happens is that it calls ALIGN() to the buffer size which aligns it to the next 4-byte boundary (doesn't truncate). Doing this results 1-3 bytes extra to be transferred. Furthermore we handle remaining bytes using PIO which results one extra byte to be transferred. In worst case the driver transfers 4 extra bytes. While investigating this it turned out that the DMA hardware doesn't even have such limitation so we can solve this by dropping the code that tries to handle unaligned bytes. Reported-by: Chiau Ee Chew <chiau.ee.chew@intel.com> Reported-by: Hock Leong Kweh <hock.leong.kweh@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-12spi: dw: Remove unused dw_spi_cleanup functionAxel Lin
The dw_spi_cleanup() function was removed by commit c63f5da00845 "spi: dw: Don't call kfree for memory allocated by devm_kzalloc". commit ec37e8e1f0e3 "spi: dw: migrate to generic queue infrastructure" added dw_spi_cleanup() but never use it. So now I got below build warning: CC [M] drivers/spi/spi-dw.o drivers/spi/spi-dw.c:609:13: warning: 'dw_spi_cleanup' defined but not used [-Wunused-function] Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-07spi: tegra20-slink: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-07spi: tegra20-sflash: Make of_device_id array constJingoo Han
2014-05-07spi: tegra114: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-07spi: qup: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-07spi: spi-gpio: Make of_device_id array constJingoo Han
2014-05-07spi: fsl-dspi: Make of_device_id array constJingoo Han
2014-05-07spi: atmel: fix incorrect comparisonAlexandre Belloni
Found using smatch: drivers/spi/spi-atmel.c:878 atmel_spi_pump_pio_data() warn: unsigned 'as->current_remaining_bytes' is never less than zero. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-03spi: core: Don't destroy master queue if we fail to create itMark Brown
If we fail to create the master queue for some reason we should not attempt to clean it up since attempting to stop a kthread that was not created will hang and it's just generally bad practice. Unfortunately at present we call spi_destroy_queue() even in cases where the creation fails. Fix this by fixing the error handling in spi_master_initialize_queue() so that we only flag the master as queued or destroy the queue if creation succeeded. The change to the flag is done since the general master cleanup uses this to destroy the queue. Reported-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2014-05-03spi: qup: Fix return value checking for pm_runtime_get_sync()Axel Lin
pm_runtime_get_sync() returns 1 if !CONFIG_PM_RUNTIME. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-05-02spi: core: Protect DMA code by #ifdef CONFIG_HAS_DMAGeert Uytterhoeven
If NO_DMA=y: drivers/built-in.o: In function `spi_map_buf': spi.c:(.text+0x21bc60): undefined reference to `dma_map_sg' drivers/built-in.o: In function `spi_unmap_buf.isra.33': spi.c:(.text+0x21c32e): undefined reference to `dma_unmap_sg' make[3]: *** [vmlinux] Error 1 Protect the DMA code by #ifdef CONFIG_HAS_DMA to fix this: - Extract __spi_map_msg() from spi_map_msg(), - Provide dummy definitions of __spi_map_msg() and spi_unmap_msg() if !CONFIG_HAS_DMA. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-29spi: topcliff-pch: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-29spi: tle62x0: remove unnecessary OOM messagesJingoo Han
2014-04-29spi: sh-msiof: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-29spi: s3c64xx: remove unnecessary OOM messagesJingoo Han
2014-04-29spi: s3c24xx: remove unnecessary OOM messagesJingoo Han
