path: root/drivers/spi
2011-07-06spi/s3c64xx: Bug fix for SPI with different FIFO levelPadmavathi Venna
The existing macro fails for following scenarios. 1) S5P64X0 channel 1 2) S5PV210 channel 1 The FIFO data level supported in the above SoCs either 64 or 256 bytes depending on the channel. Because of this the TX_DONE is the 25 bit in the status register. The existing macro works for the following scenarios 1) S3C6410 all channels 2) S5PC100 all channels The FIFO data level supported in the above SoCs 64 bytes on all the channels. Because of this the TX_DONE is the 21 bit in the status register. So when we use the existing macro for the non-working SoCs it is not anding with the TX_DONE bit for transmission status check. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-06-17spi/bfin_spi: fix handling of default bits per word settingMike Frysinger
The default bits per word setting should be 8 bits, but since most of our devices have been explicitly setting this up, we didn't notice when the default stopped working. At the moment, any default transfers without an explicit bit size setting error out with: bfin-spi bfin-spi.0: transfer: unsupported bits_per_word So in the transfer logic, have a bits_per_word setting of 0 fall into the 8 bit transfer logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-13spi-pl022: Add missing return value updateVirupax Sadashivpetimath
Return error on out of range cpsdvsr value. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-03spi/omap2: fix uninitialized variableGovindraj.R
fixes below compilation warning. The variable doesn't actual ever get used uninitialized, but that's no reason to be sloppy. drivers/spi/omap2_mcspi.c: In function 'omap2_mcspi_txrx_dma': drivers/spi/omap2_mcspi.c:301: warning: 'elements' may be used uninitialized in this function Signed-off-by: Govindraj.R <govindraj.raja@ti.com> [grant.likely: amended description] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-27spi/spi_bfin_sport: new driver for a SPI bus via the Blackfin SPORT peripheralCliff Cai
The Blackfin SPORT peripheral is a pretty flexible device. With enough coaching, we can make it generate SPI compatible waveforms. This is desirable as the SPORT can run at much higher clock frequencies than the dedicated on-chip SPI peripheral, and it can do full duplex DMA. It also opens up the possibility of multiple SPI buses in case someone wants to dedicate a whole bus to a specific part that does not play well with others. Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26spi/tle620x: add missing device_remove_file()Axel Lin
This patch includes below fixes: 1. Add missing device_remove_file for dev_attr_status_show in tle62x0_remove. 2. Fix tle62x0_probe error handling: Currently, if the error happens when ptr > 0, gpio_attrs[0] is not properly remove. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (57 commits) regulator: Fix 88pm8607.c printk format warning input: Add support for Qualcomm PMIC8XXX power key input: Add Qualcomm pm8xxx keypad controller driver mfd: Add omap-usbhs runtime PM support mfd: Fix ASIC3 SD Host Controller Configuration size mfd: Fix omap_usbhs_alloc_children error handling mfd: Fix omap usbhs crash when rmmoding ehci or ohci mfd: Add ASIC3 LED support leds: Add ASIC3 LED support mfd: Update twl4030-code maintainer e-mail address mfd: Correct the name and bitmask for ab8500-gpadc BTempPullUp mfd: Add manual ab8500-gpadc batt temp activation for AB8500 3.0 mfd: Provide ab8500-core enumerators for chip cuts mfd: Check twl4030-power remove script error condition after i2cwrite mfd: Fix twl6030 irq definitions mfd: Add phoenix lite (twl6025) support to twl6030 mfd: Avoid to use constraint name in 88pm860x regulator driver mfd: Remove checking on max8925 regulator[0] mfd: Remove unused parameter from 88pm860x API mfd: Avoid to allocate 88pm860x static platform data ...
2011-05-26Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe fails spi/spi_s3c24xx: Use spi_bitbang_stop instead of spi_unregister_master in s3c24xx_spi_remove spi/spi_nuc900: Use spi_bitbang_stop instead of spi_unregister_master in nuc900_spi_remove spi/spi_tegra: use spi_unregister_master() instead of spi_master_put() spi/spi_sh: use spi_unregister_master instead of spi_master_put in remove path spi: Use void pointers for data in simple SPI I/O operations spi/pl022: use cpu_relax in the busy loop spi/pl022: mark driver non-experimental spi/pl022: timeout on polled transfer v2 spi/dw_spi: improve the interrupt mode with the batch ops spi/dw_spi: change poll mode transfer from byte ops to batch ops spi/dw_spi: remove the un-necessary flush() spi/dw_spi: unify the low level read/write routines
2011-05-26mfd: Use mfd cell platform_data for timberdale cells platform bitsSamuel Ortiz
With the addition of a device platform mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-24coldfire_qspi compile fixSteven King
The m68k/m68knommu merge broke the qspi build. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-20spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe failsViresh Kumar
If pl022_dma_probe fails, we can try to transfer data in polling or interrupt mode. Also, set platform_info->enable_dma to 0, so that no other code tries to use dma. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_s3c24xx: Use spi_bitbang_stop instead of spi_unregister_master in ↵Axel Lin
s3c24xx_spi_remove Calling spi_bitbang_stop() will also destroy bitbang->workqueue, which is created by calling spi_bitbang_start() in s3c24xx_spi_probe(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_nuc900: Use spi_bitbang_stop instead of spi_unregister_master in ↵Axel Lin
nuc900_spi_remove Calling spi_bitbang_stop() will also destroy bitbang->workqueue, which is created by calling spi_bitbang_start() in nuc900_spi_probe(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_tegra: use spi_unregister_master() instead of spi_master_put()Axel Lin
spi_master_put() should only be used in error handling. Once spi_register_master() returns success, we should call spi_unregister_master() instead. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/spi_sh: use spi_unregister_master instead of spi_master_put in remove pathAxel Lin
2011-05-20spi: Use void pointers for data in simple SPI I/O operationsMark Brown
Currently the simple SPI I/O operations all take pointers to u8 * buffers to operate on. This creates needless type compatibility issues and the underlying spi_transfer structure uses void pointers anyway so convert the API over to take void pointers too. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: use cpu_relax in the busy loopLinus Walleij
This relaxes the cpu in the polling busy-wait loop. Reported-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: mark driver non-experimentalLinus Walleij
This driver has no TODO, and is now used on several platforms: ARM, U300, Ux500, SPEAr and more. So drop the EXPERIMENTAL requirement. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: timeout on polled transfer v2Magnus Templing
This adds the missing handling of polling timeouts and deletes our last todo. Signed-off-by: Magnus Templing <magnus.templing@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> [Fixups from review by Wolfram Sang] Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20Merge commit 'v2.6.39' into spi/nextGrant Likely
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-11Merge branch 'spi/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/merge' of git://git.secretlab.ca/git/linux-2.6: dt/fsldma: fix build warning caused by of_platform_device changes spi: Fix race condition in stop_queue() gpio/pch_gpio: Fix output value of pch_gpio_direction_output() gpio/ml_ioh_gpio: Fix output value of ioh_gpio_direction_output() gpio/pca953x: fix error handling path in probe() call
2011-04-07spi: Fix race condition in stop_queue()Vasily Khoruzhick
There's a race condition in stop_queue() in some drivers - if drv_data->queue is empty, but drv_data->busy is still set (or opposite situation) stop_queue will return -EBUSY. So fix loop condition to check that both drv_data->queue is empty and drv_data->busy is not set. This patch affects following drivers: pxa2xx_spi spi_bfin5xx amba-pl022 dw_spi Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-30spi/dw_spi: improve the interrupt mode with the batch opsAlek Du
leverage the performance gain by change in low level read/write batch operations Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-30spi/dw_spi: change poll mode transfer from byte ops to batch opsAlek Du
Current poll transfer will read/write one word, then wait till the hw is non-busy, it's not efficient. This patch will try to read/write as many words as permitted by hardware FIFO depth. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-30spi/dw_spi: remove the un-necessary flush()Alek Du
The flush() is used to drain all the left data in rx fifo, currently is is always called together with disabling hw. But from spec, disabling hw will also reset all the fifo, so flush() is not needed. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-30spi/dw_spi: unify the low level read/write routinesFeng Tang
The original version has many duplicated codes for null/u8/u16 case, so unify them to make it cleaner Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-24Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: spi/pl022: Add loopback support for the SPI on 5500 spi/omap_mcspi: Fix broken last word xfer of/flattree: minor cleanups dt: eliminate OF_NO_DEEP_PROBE and test for NULL match table dt: protect against NULL matches passed to of_match_node() dt: Refactor of_platform_bus_probe()
2011-03-23spi/pl022: Add loopback support for the SPI on 5500Philippe Langlais
Extend the vendor data with a loopback field, and add new amba-pl022 vendor data for the DB5500 pl023, as the pl023 on db8500 and db5500 vary. Signed-off-by: Prajadevi H <prajadevi.h@stericsson.com> Signed-off-by: Philippe Langlais <philippe.langlais@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23spi/omap_mcspi: Fix broken last word xferJarkko Nikula
Commit adef658 "spi/omap_mcspi: catch xfers of non-multiple SPI word size" broke the transmission of last word in cases where access is multiple of word size and word size is 16 or 32 bits. Fix this by replacing the test "c > (word_len>>3)" in do-while loops with "c >= 'pointer increment size'". This ensures that the last word is transmitted in above case and still allow to break the loop and prevent variable c underflow in cases where word size != 'pointer increment size'. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Tested-by: Sourav Poddar<sourav.poddar@ti.com> Acked-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23mfd: mfd_cell is now implicitly available to timberdale driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Note that the mfd's platform_data is marked __devinitdata. This is still correct in all cases except for the timbgpio driver, whose remove hook has been changed to no longer reference the pdata. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-18Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/dw_spi: move dw_spi.h into drivers/spi spi/dw_spi: Fix missing header gpio/langwell: Clear edge bit before handling gpio/langwell: Simplify demux loop gpio/langwell: Convert irq name space gpio/langwell: Fix broken irq_eoi change. gpio; Make Intel chipset gpio drivers depend on x86 gpio/cs5535-gpio: Fix section mismatch spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devices spi/davinci: Support DMA transfers larger than 65535 words spi/davinci: Use correct length parameter to dma_map_single calls gpio: Use __devexit at necessary places gpio: add MODULE_DEVICE_TABLE to pch_gpio and ml_ioh_gpio gpio/mcp23s08: support mcp23s17 variant of_mmc_spi: add card detect irq support spi/omap_mcspi: catch xfers of non-multiple SPI word size spi/omap_mcspi: Off-by-one error in finding the right divisor gpio/pca953x: Fix wrong pointer type spi/pl022: rid dangling labels spi: add support for SuperH SPI ...
2011-03-18spi/dw_spi: move dw_spi.h into drivers/spiGrant Likely
include/linux/dw_spi.h only includes driver internal data. It doesn't expose a platform_data configuration structure or similar (at least nothing in-tree). This patch moves the header into drivers/spi so that the scope is limited to only the dw_spi_*.c driver files Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Feng Tang <feng.tang@intel.com> Cc: spi-devel-general@lists.sourceforge.net
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17Merge remote-tracking branch 'origin' into spi/nextGrant Likely
Pull in Linus' tree to pick up changes required for the langwell gpio fixes
2011-03-17Merge branches 'aaci', 'mmci-dma', 'pl' and 'pl011' into driversRussell King
2011-03-15Merge branch 'davinci-next-2' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci into devel-stable
2011-03-15spi: add ti-ssp spi master driverCyril Chemparathy
This patch adds an SPI master implementation that operates on top of an underlying TI-SSP port. Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-03-14Merge branch 'davinci-next' of ↵Russell King
2011-03-14spi/davinci: Support DMA transfers larger than 65535 wordsMichael Williamson
The current davinci SPI driver, in DMA mode, is limited to 65535 words for a single transfer. Modify the driver by configuring a 3 dimensional EDMA transfer to support up to 65535x65535 words. Signed-off-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-14spi/davinci: Use correct length parameter to dma_map_single callsMichael Williamson
The davinci spi driver provides an option to use DMA transfers for data. In the dma_map_single() call, the driver is passing the number of words to be transfered for the mapping size. It should be the number of bytes. Signed-off-by: Michael Williamson <michael.williamson@criticallink.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-12Merge commit 'v2.6.38-rc8' into spi/nextGrant Likely
Conflicts: drivers/spi/pxa2xx_spi_pci.c
2011-03-10Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable
2011-03-08spi_imx: Fix misspelled configuration variable SOC_IMX31Alberto Panizzo
This fix a kernel NULL pointer error while initialising SPI introduced by: 4d2f13be1e370a670c1cae20c194d5ce961e0fa5 Signed-off-by: Alberto Panizzo <alberto@amarulasolutions.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-07ARM: imx3x: clean up ARCH_MX3XRichard Zhao
Move to SOC_SOC_IMX3X. Leave ARCH_MX31/35 definitions there, in case some place prevent multi-soc single image. Signed-off-by: Richard Zhao <richard.zhao@freescale.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-07ARM: imx5x: clean up ARCH_MX5XRichard Zhao
Move to SOC_SOC_IMX5X. Leave only places which prevent multi-soc using ARCH_MX5X. Signed-off-by: Richard Zhao <richard.zhao@freescale.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-04spi/omap_mcspi: catch xfers of non-multiple SPI word sizeMichael Jones
If an SPI access was not a multiple of the SPI word size, the while() loop would spin and the rx/tx ptrs would be incremented indefinitely. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
