Having conditional around the of_match_table and the of_node pointers
turns out to make driver code use ugly #ifdef blocks. Drop the
conditionals and remove the #ifdef blocks from the affected drivers.
Also tidy up minor whitespace issues within the same hunks.
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (26 commits)
MIPS: Malta: enable Cirrus FB console
MIPS: add CONFIG_VIRTUALIZATION for virtio support
MIPS: Implement __read_mostly
MIPS: ath79: add common WMAC device for AR913X based boards
MIPS: ath79: Add initial support for the Atheros AP81 reference board
MIPS: ath79: add common SPI controller device
SPI: Add SPI controller driver for the Atheros AR71XX/AR724X/AR913X SoCs
MIPS: ath79: add common GPIO buttons device
MIPS: ath79: add common watchdog device
MIPS: ath79: add common GPIO LEDs device
MIPS: ath79: add initial support for the Atheros PB44 reference board
MIPS: ath79: utilize the MIPS multi-machine support
MIPS: ath79: add GPIOLIB support
MIPS: Add initial support for the Atheros AR71XX/AR724X/AR931X SoCs
MIPS: jump label: Add MIPS support.
MIPS: Use WARN() in uasm for better diagnostics.
MIPS: Optimize TLB handlers for Octeon CPUs
MIPS: Add LDX and LWX instructions to uasm.
MIPS: Use BBIT instructions in TLB handlers
MIPS: Declare uasm bbit0 and bbit1 functions.
The Atheros AR71XX/AR724X/AR913X SoCs have a built-in SPI controller. This
patch implements a driver for that.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: spi-devel-general@lists.sourceforge.net
Cc: linux-mips@linux-mips.org
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Luis R. Rodriguez <lrodriguez@atheros.com>
Cc: Cliff Holden <Cliff.Holden@Atheros.com>
Cc: Kathy Giori <Kathy.Giori@Atheros.com>
Patchwork: https://patchwork.linux-mips.org/patch/1960/
Without this fix reloading of the driver is impossible.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
clk_freq is used uninitialized in pl022_setup routine. This patch
fix compilation warning for using uninitialized variable
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
This patch enables the existing S3C64XX series SPI driver for S5P64X0
and removed dependency on EXPERIMENTAL because we don't need it now.
v3: Changed dependency of S3C64XX_DMA
v2: Removed dependency on EXPERIMENTAL
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
Acked-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
1. Change the Kconfig to include i.MX53
2. add devtype entry for i.MX53
Signed-off-by: Yong Shen <yong.shen@freescale.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
clk_get() returns a struct clk cookie to the driver and some platforms
may return NULL if they only support a single clock. clk_get() has only
failed if it returns a ERR_PTR() encoded pointer.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Some platforms have been known to return NULL from clk_get() if they
support only a single struct clk. Whilst tegra doesn't do this, make
the drivers consistent with others.
Acked-by: Russell King <linux@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
spi / PM: Support dev_pm_ops
PM: Prototype the pm_generic_ operations
PM / Runtime: Generic resume shouldn't set RPM_ACTIVE unconditionally
PM: Use dev_name() in core device suspend and resume routines
PM: Permit registration of parentless devices during system suspend
PM: Replace the device power.status field with a bit field
PM: Remove redundant checks from core device resume routines
PM: Use a different list of devices for each stage of device suspend
PM: Avoid compiler warning in pm_noirq_op()
PM: Use pm_wakeup_pending() in __device_suspend()
PM / Wakeup: Replace pm_check_wakeup_events() with pm_wakeup_pending()
PM: Prevent dpm_prepare() from returning errors unnecessarily
PM: Fix references to basic-pm-debugging.txt in drivers-testing.txt
PM / Runtime: Add synchronous runtime interface for interrupt handlers (v3)
PM / Hibernate: When failed, in_suspend should be reset
PM / Hibernate: hibernation_ops->leave should be checked too
Freezer: Fix a race during freezing of TASK_STOPPED tasks
PM: Use proper ccflag flag in kernel/power/Makefile
PM / Runtime: Fix comments to match runtime callback code
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits)
spi/omap: Fix DMA API usage in OMAP MCSPI driver
spi/imx: correct the test on platform_get_irq() return value
spi/topcliff: Typo fix threhold to threshold
spi/dw_spi Typo change diable to disable.
spi/fsl_espi: change the read behaviour of the SPIRF
spi/mpc52xx-psc-spi: move probe/remove to proper sections
spi/dw_spi: add DMA support
spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs
spi/dw_spi: Fix too short timeout in spi polling loop
spi/pl022: convert running variable
spi/pl022: convert busy flag to a bool
spi/pl022: pass the returned sglen to the DMA engine
spi/pl022: map the buffers on the DMA engine
spi/topcliff_pch: Fix data transfer issue
spi/imx: remove autodetection
spi/pxa2xx: pass of_node to spi device and set a parent device
spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.
spi/pxa2xx: Add chipselect support for Sodaville
spi/pxa2xx: Consider CE4100's FIFO depth
spi/pxa2xx: Add CE4100 support
Running the latest kernel on the 4430SDP board with DMA API debugging
enabled results in this:
WARNING: at lib/dma-debug.c:803 check_unmap+0x19c/0x6f0()
NULL NULL: DMA-API: device driver tries to free DMA memory it has not allocated
[device address=0x000000008129901a] [size=260 bytes]
Modules linked in:
Backtrace:
[<c003cbe0>] (dump_backtrace+0x0/0x10c) from [<c0278da8>] (dump_stack+0x18/0x1c)
r7:c1839dc0 r6:c0198578 r5:c0304b17 r4:00000323
[<c0278d90>] (dump_stack+0x0/0x1c) from [<c005b158>] (warn_slowpath_common+0x58/0x70)
[<c005b100>] (warn_slowpath_common+0x0/0x70) from [<c005b214>] (warn_slowpath_fmt+0x38/0x40)
r8:c1839e40 r7:00000000 r6:00000104 r5:00000000 r4:8129901a
[<c005b1dc>] (warn_slowpath_fmt+0x0/0x40) from [<c0198578>] (check_unmap+0x19c/0x6f0)
r3:c03110de r2:c0304e6b
[<c01983dc>] (check_unmap+0x0/0x6f0) from [<c0198cd8>] (debug_dma_unmap_page+0x74/0x80)
[<c0198c64>] (debug_dma_unmap_page+0x0/0x80) from [<c01d5ad8>] (omap2_mcspi_work+0x514/0xbf0)
[<c01d55c4>] (omap2_mcspi_work+0x0/0xbf0) from [<c006dfb0>] (process_one_work+0x294/0x400)
[<c006dd1c>] (process_one_work+0x0/0x400) from [<c006e50c>] (worker_thread+0x220/0x3f8)
[<c006e2ec>] (worker_thread+0x0/0x3f8) from [<c00738d0>] (kthread+0x88/0x90)
[<c0073848>] (kthread+0x0/0x90) from [<c005e924>] (do_exit+0x0/0x5fc)
r7:00000013 r6:c005e924 r5:c0073848 r4:c1829ee0
---[ end trace 1b75b31a2719ed20 ]---
I've no idea why this driver uses NULL for dma_unmap_single instead of
the &spi->dev that is laying around just waiting to be used in that
function - but it's an easy fix.
Also replace this comment with a FIXME comment:
/* Do DMA mapping "early" for better error reporting and
* dcache use. Note that if dma_unmap_single() ever starts
* to do real work on ARM, we'd need to clean up mappings
* for previous transfers on *ALL* exits of this loop...
as the comment is not true - we do work in dma_unmap() functions,
particularly on ARMv6 and above. I've corrected the existing unmap
functions but if any others are required they must be added ASAP.
The test "if (spi_imx->irq <= 0)" is not testing the IRQ value, but
the return value of platform_get_irq(). As platform_get_irq() can
return an error (-ENXIO) or the IRQ value it found, the test should be
"if (spi_imx->irq < 0)"
[grant.likely: Note: In general, Linux irq number 0 should also mean
no irq, but arm still allows devices to be assigned 0, and the imx
platform uses 0 for one of the spi devices, so this patch is needed
for the device to work]
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
After grabbing a msg from the msgq, the mcfqspi_work function calls
list_del_init on the mcfqspi->msgq which unintentionally deletes the rest
of the list before it can be processed. If qspi call was made using
spi_sync, this can result in a process hang.
Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
Acked-by: Steven King <sfking@fdwdc.com>
The user must read N bytes of SPIRF (1 <= N <= 4) that do not exceed the
amount of data in the receive FIFO, so read the SPIRF byte by byte when
the data in receive FIFO is less than 4 bytes.
On Simics, when read N bytes that exceed the amout of data in receive
FIFO, we can't read the data out, that is we can't clear the rx FIFO,
then the CPU will loop on the espi rx interrupt.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
When SPI wake up from OFF mode, CS is in the wrong state: force it to the
inactive state.
During the system life, I monitored the CS behavior using a oscilloscope.
I also activated debug in omap2_mcspi, so I saw when driver disable the clocks
and restore context when device is not used.Each time the CS was in the correct
state. It was only when system was put suspend to ram with off-mode activated
that on resume the CS was in wrong state( ie activated).
Changelog:
* Change from v1 to v2:
- Rebase on linus/master (after 2.6.37-rc1)
- Do some clean-up and fix indentation on both patches
- Add more explanations for patch 2
* Change from v2 to v3:
- Use directly resume function of spi_master instead of using function
- from spi_device as Grant Likely pointed it out.
- Force this transition explicitly for each CS used by a device.
* Change from v3 to v4:
- Patch clean-up according to Kevin Hilman and checkpatch.
- Now force CS to be in inactive state only if it was inactive when it was
suspended.
* Change from v4 to v5:
- Rebase on linus/master (after 2.6.37-rc3)
- Collapse some lines as pointed by Grant Likely
- Fix a spelling
* Change from v5 to v6:
- Rebase on linus/master (after 2.6.37-rc7)
- Use CONFIG_SUSPEND instead of CONFIG_PM
- Didn't use legacy PM methods anymore. Instead, add a struct dev_pm_ops and
add the resume method there.
- Fix multi-line comment style
* Change from v6 to v7:
- Rebase on linus/master (after 2.6.37-rc8)
- Drop an extra line
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
* 'spi' of git://git.linutronix.de/users/bigeasy/soda into spi/next
spi/pxa2xx: register driver properly
spi/pxa2xx: add support for shared IRQ handler
spi/pxa2xx: Use define for SSSR_TFL_MASK instead of plain numbers
arm/pxa2xx: reorgazine SSP and SPI header files
git://arago-project.org/git/projects/linux-davinci into spi/next
* 'for-grant' of git://arago-project.org/git/projects/linux-davinci into spi/next
spi: davinci: fix checkpatch errors
spi: davinci: whitespace cleanup
spi: davinci: remove unused variable 'pdata'
spi: davinci: set chip-select mode in SPIDEF only once
spi: davinci: enable both activation and deactivation of chip-selects
spi: davinci: remove unnecessary data transmit on CS disable
spi: davinci: enable GPIO lines to be used as chip selects
spi: davinci: simplify prescalar calculation
spi: davinci: remove 'wait_enable' platform data member
spi: davinci: make chip-slect specific parameters really chip-select specific
spi: davinci: consolidate setup of SPIFMTn in one function
spi: davinci: setup chip-select timers values only if timer enabled
spi: davinci: add support for wait enable timeouts
spi: davinci: remove unused members of davinci_spi_slave
spi: davinci: eliminate the single member structure davinci_spi_slave
spi: davinci: eliminate unnecessary update of davinci_spi->count
spi: davinci: simplify calculation of edma acount value
spi: davinci: check for NULL buffer pointer before using it
spi: davinci: remove unnecessary disable of SPI
spi: davinci: remove unnecessary 'count' variable in driver private data
spi: davinci: remove unnecessary completion variable initialization
spi: davinci: remove non-useful interrupt mode support
spi: davinci: simplify poll mode transfers
spi: davinci: add support for interrupt mode
spi: davinci: configure the invariable bits in spipc0 only once
spi: davinci: remove unnecessary function davinci_spi_bufs_prep()
spi: davinci: remove unnecessary call to davinci_spi_setup_transfer()
spi: davinci: do not store DMA channel information per chip select
spi: davinci: always start transmit DMA
spi: davinci: do not use temporary buffer if no transmit data provided
spi: davinci: always start receive DMA
spi: davinci: use edma_write_slot() to setup EDMA PaRAM slot
spi: davinci: fix DMA event generation stoppage
spi: davinci: fix EDMA CC errors at end of transfers
spi: davinci: handle DMA completion errors correctly
spi: davinci: remove usage of additional completion variables for DMA
spi: davinci: let DMA operation be specified on per-device basis
spi: davinci: remove non-useful "clk_internal" platform data
spi: davinci: enable and power-up SPI only when required
spi: davinci: setup the driver owner
spi: davinci: add additional comments
spi: davinci: add EF Johnson Technologies copyright
spi: davinci: removed unused #defines
spi: davinci: remove unnecessary typecast
spi: davinci: do not treat Tx interrupt being set as error
spi: davinci: do not allocate DMA channels during SPI device setup
spi: davinci: remove unnecessary private data member 'region_size'
spi: davinci: shorten variable names
spi: davinci: kconfig: add manufacturer name to prompt string
Allow SPI drivers to use runtime PM and other dev_pm_ops features by
implementing dev_pm_ops for the bus. The existing bus specific suspend
and resume functions will be called if a driver does not provide dev_pm_ops
allowing for transition to the new model.
* 'merge' of git://git.secretlab.ca/git/linux-2.6:
spi/mpc52xx-spi: fix annotation for remove()-pointer
spi/fsl_espi: fix wrong setting of the address in the command buffer
of/i2c: Fix request module by alias
powerpc/mpc5200: include fs.h in mpc52xx_gpt.c
Probe/remove should be in __devinit/__devexit. Found by a section-mismatch
warning. Also, copy do_remove() over to remove().
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Or else we can't operate on the right address when the trans length
is greater than 65535.
On Simics, when read N bytes that exceed the amount of data in receive
dw_spi driver in upstream only supports PIO mode, and this patch
will support it to cowork with the Designware dma controller used
on Intel Moorestown platform, at the same time it provides a general
framework to support dw_spi core to cowork with dma controllers on
other platforms
It has been tested with a Option GTM501L 3G modem and Infenion 60x60
modem. To use DMA mode, DMA controller 2 of Moorestown has to be enabled
Also change the dma interface suggested by Linus Walleij.
Signed-off-by: Feng Tang <feng.tang@intel.com>
[Typo fix and renames to match intel_mid_dma renaming]
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
The SPI polling loop timeout only works with HZ=100 as the loop was
actually too short.
Also add appropriate cpu_relax() in the busy wait loops...
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This variable is a bool but defined an int and defined completely
backwards. This makes the code more readable.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The sglen return by the dma_map_sg() should be passed to the DMA
engine, not the one passed in. If we one day have a DMA mapper
that can coalesce entries, this will bug due to a too large
number of entries being passed in.
Reported-by: Russell King <linux@arm.linux.org.uk>
The struct device for the DMA engine is the apropriate one to use
when mapping/unmapping buffers. This is because the memory which
is addressable by DMA is determined by the DMA engine rather than
the device.
It seems spi_topcliff_pch of linux-2.6.37-rc6 degraded by previous patch.
In fact, data transfer fails on evaluation board testing.
I found like the following register miss-setting line.
Using this patch, I have confirmed data transfer can work well.
Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com>
There are no machines in-tree that still use the driver
name as device name. So save a few bytes and remove it.
Acked-by: Jason Wang <jason77.wang@gmail.com>
This was fixed by David Lamparter in v2.6.36-rc5 3486008 ("spi: free
children in spi_unregister_master, not siblings") and broken again in
v2.6.37-rc1~2^2~4 during the merge of 2b9603a0 ("spi: enable
spi_board_info to be registered after spi_master").
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: David Lamparter <equinox@diac24.net>
Cc: Grant Likely <grant.likely@secretlab.ca>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
There is a possibility that the last word of a transaction will be lost
if data is not ready. Re-read in poll_transfer() to solve this issue
when poll_mode is enabled.
Verified on SPI touch screen device.
Signed-off-by: Major Lee <major_lee@wistron.com>
the of_node will auto-publish devices which are added to the device
tree.
After all TX bytes are sent, the driver spins while the SPI core is busy
and then it spins for a "short" period of time until RX bytes are
available.
On Sodavile the busy flag disappears pretty quick and after that it
takes approx ~130ms (sometimes less but not much) until there are bytes
available in the RX FIFO.
This patch removes the busy loop and modifies the RX threshould so we
get woken up once the remainings bytes arrived.
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
The SPI core on Sodaville supports chip selects. Its configuration
moved into the SSSR register at bit 0 and 1. Thus Sodaville can be hooked
up with up to 4 devices.
This patch ensures that the bits which are otherwiese reserved are only
touched on Sodaville and not on any other PXAs. Also it makes sure that
the status register does not lose the CS information while clearing the
ROR bit.
For PXA the default threshold is FIFO_DEPTH / 2. Adjust this value for
CE4100.
Sodaville's SPI controller is very much the same as in PXA25x. The
difference:
- The RX/TX FIFO is only 4 words deep instead of 16
- No DMA support
- The SPI controller offers a CS functionality
The PXA-SPI driver relies on some files / defines which are arm specific
and are within the ARM tree. The CE4100 SoC which is x86 has also the
SPI core.
This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to
include/linux where the CE4100 can access them.
This move got verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig
This is required in case the interrupt line is shared with other
devices.
passing argument 2 of 'dma_map_single' discards qualifiers from pointer target type
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
