path: root/drivers/spi
2014-08-31Merge remote-tracking branch 'spi/fix/sh-msiof' into spi-linusMark Brown
2014-08-31spi: sh-msiof: Fix transmit-only DMA transfersGeert Uytterhoeven
Fix tx/rx mixup, which broke transmit-only transfers. Introduced by commit 4240305f7cbdc7782aa8bc40cc702775d9ac0839 ("spi: sh-msiof: Fix leaking of unused DMA descriptors"). Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-30Merge remote-tracking branches 'spi/fix/au1550', 'spi/fix/davinci', ↵Mark Brown
'spi/fix/doc', 'spi/fix/dw', 'spi/fix/omap-mcspi', 'spi/fix/pxa2xx', 'spi/fix/rockchip' and 'spi/fix/rspi' into spi-linus
2014-08-29spi/rockchip: Avoid accidentally turning off the clockDoug Anderson
If our client is requesting a clock that is above the maximum clock then the following division will result in 0: rs->max_freq / rs->speed We'll then program 0 into the SPI_BAUDR register. The Rockchip TRM says: "If the value is 0, the serial output clock (sclk_out) is disabled." It's much better to end up with the fastest possible clock rather than a clock that is off, so enforce a minimum value. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-08-27spi: dw: fix kernel crash due to NULL pointer dereferenceAndy Shevchenko
The obvious fix after the commit d9c73bb8a3a5 "spi: dw: add support for gpio controlled chip select". This patch fixes the issue by using locally defined temporary variable. Fixes: d9c73bb8a3a5 (spi: dw: add support for gpio controlled chip select) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: <stable@vger.kernel.org>
2014-08-27spi: dw-pci: fix bug when regs left uninitializedAndy Shevchenko
The commit 04f421e7 "spi: dw: use managed resources" changes drivers to use managed functions, but seems wasn't properly tested in PCI case. The regs field of struct dw_spi left uninitialized. Thus, kernel crashes when tries to access to the SPI controller registers. This patch fixes the issue. Fixes: 04f421e7 (spi: dw: use managed resources) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-08-21spi: davinci: fix SPI_NO_CS functionalityGrygorii Strashko
The driver should not touch CS lines if SPI_NO_CS flag is set. This patch fixes it as this functionality was broken accidentally by commit a88e34ea213e1b ("spi: davinci: add support to configure gpio cs through dt"). Fixes: a88e34ea213e1b ("spi: davinci: add support to configure gpio cs through dt") Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-20spi/rockchip: fixup incorrect dma direction settingAddy Ke
Signed-off-by: Addy Ke <addy.ke@rock-chips.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-20spi/pxa2xx: Add ACPI ID for Intel BraswellAlan Cox
The SPI host controller is the same as used in Baytrail, only the ACPI ID is different so add this new ID to the list. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-08-19spi: spi-au1550: fix build failureManuel Lauss
Fix a build failure introduced with commit 30670539b86 (spi: au1550: Fix bug in deallocation of memory) Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-16spi: rspi: Fix leaking of unused DMA descriptorsGeert Uytterhoeven
If dmaengine_prep_slave_sg() or dmaengine_submit() fail, we may leak unused DMA descriptors. As per Documentation/dmaengine.txt, once a DMA descriptor has been obtained, it must be submitted. Hence: - First prepare and submit all DMA descriptors, - Prepare the SPI controller for DMA, - Start DMA by calling dma_async_issue_pending(), - Make sure to call dmaengine_terminate_all() on all descriptors that haven't completed. Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-16spi: sh-msiof: Fix leaking of unused DMA descriptorsGeert Uytterhoeven
2014-08-13spi: Add missing kerneldoc bitsThierry Reding
These are all arguments or fields that got added without updating the kerneldoc comments. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-11spi/omap-mcspi: Fix the spi task hangs waiting dma_rxJorge A. Ventura
The spi hangs waiting the completion of omap2_mcspi_rx_callback. Signed-off-by: Jorge A. Ventura <jorge.araujo.ventura@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-08-07Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for 3.17. It contains: - misc Cavium Octeon, BCM47xx, BCM63xx and Alchemy updates - MIPS ptrace updates and cleanups - various fixes that will also go to -stable - a number of cleanups and small non-critical fixes. - NUMA support for the Loongson 3. - more support for MSA - support for MAAR - various FP enhancements and fixes" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) MIPS: jz4740: remove unnecessary null test before debugfs_remove MIPS: Octeon: remove unnecessary null test before debugfs_remove_recursive MIPS: ZBOOT: implement stack protector in compressed boot phase MIPS: mipsreg: remove duplicate MIPS_CONF4_FTLBSETS_SHIFT MIPS: Bonito64: remove a duplicate define MIPS: Malta: initialise MAARs MIPS: Initialise MAARs MIPS: detect presence of MAARs MIPS: define MAAR register accessors & bits MIPS: mark MSA experimental MIPS: Don't build MSA support unless it can be used MIPS: consistently clear MSA flags when starting & copying threads MIPS: 16 byte align MSA vector context MIPS: disable preemption whilst initialising MSA MIPS: ensure MSA gets disabled during boot MIPS: fix read_msa_* & write_msa_* functions on non-MSA toolchains MIPS: fix MSA context for tasks which don't use FP first MIPS: init upper 64b of vector registers when MSA is first used MIPS: save/disable MSA in lose_fpu MIPS: preserve scalar FP CSR when switching vector context ...
2014-08-05Merge tag 'spi-v3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "A quiet release, more bug fixes than anything else. A few things do stand out though: - updates to several drivers to move towards the standard GPIO chip select handling in the core. - DMA support for the SH MSIOF driver. - support for Rockchip SPI controllers (their first mainline submission)" * tag 'spi-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (64 commits) spi: davinci: use spi_device.cs_gpio to store gpio cs per spi device spi: davinci: add support to configure gpio cs through dt spi/pl022: Explicitly truncate large bitmask spi/atmel: Fix pointer to int conversion warnings on 64 bit builds spi: davinci: fix to support more than 2 chip selects spi: topcliff-pch: don't hardcode PCI slot to get DMA device spi: orion: fix incorrect handling of cell-index DT property spi: orion: Fix error return code in orion_spi_probe() spi/rockchip: fix error return code in rockchip_spi_probe() spi/rockchip: remove redundant dev_err call in rockchip_spi_probe() spi/rockchip: remove duplicated include from spi-rockchip.c ARM: dts: fix the chip select gpios definition in the SPI nodes spi: s3c64xx: Update binding documentation spi: s3c64xx: use the generic SPI "cs-gpios" property spi: s3c64xx: Revert "spi: s3c64xx: Added provision for dedicated cs pin" spi: atmel: Use dmaengine_prep_slave_sg() API spi: topcliff-pch: Update error messages for dmaengine_prep_slave_sg() API spi: sh-msiof: Use correct device for DMA mapping with IOMMU spi: sh-msiof: Handle dmaengine_prep_slave_single() failures gracefully spi: rspi: Handle dmaengine_prep_slave_sg() failures gracefully ...
2014-08-04Merge remote-tracking branches 'spi/topic/sh', 'spi/topic/sh-msiof' and ↵Mark Brown
'spi/topic/topcliff-pch' into spi-next
2014-08-04Merge remote-tracking branches 'spi/topic/orion', 'spi/topic/pl022', ↵Mark Brown
'spi/topic/qup', 'spi/topic/rockchip' and 'spi/topic/rspi' into spi-next
2014-08-04Merge remote-tracking branches 'spi/topic/dw', 'spi/topic/efm32', ↵Mark Brown
'spi/topic/fsl' and 'spi/topic/omap-uwire' into spi-next
2014-08-04Merge remote-tracking branches 'spi/topic/adi-v3', 'spi/topic/atmel', ↵Mark Brown
'spi/topic/cleanup' and 'spi/topic/davinci' into spi-next
2014-08-04Merge remote-tracking branch 'spi/topic/core' into spi-nextMark Brown
2014-08-04Merge remote-tracking branches 'spi/fix/s3c64xx', 'spi/fix/samsung' and ↵Mark Brown
'spi/fix/xilinx' into spi-linus
2014-08-04Merge remote-tracking branches 'spi/fix/au1550', 'spi/fix/cadence', ↵Mark Brown
'spi/fix/omap2-mcspi' and 'spi/fix/orion' into spi-linus
2014-08-04Merge remote-tracking branch 'spi/fix/core' into spi-linusMark Brown
2014-08-01spi: davinci: use spi_device.cs_gpio to store gpio cs per spi deviceGrygorii Strashko
Rework Davinci SPI driver to store GPIO CS number in cs_gpio field of SPI device structure (spi_device) for both DT and non-DT cases. This will make Davinci SPI driver code simpler and allows to reuse more SPI core functionality. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-01spi: davinci: add support to configure gpio cs through dtMurali Karicheri
Currently driver supports only configuration of GPIO CS through platform data. This patch enhances the driver to configure GPIO CS through DT. Also update the DT binding documentation to reflect the availability of cs-gpios. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-01spi/pl022: Explicitly truncate large bitmaskMark Brown
When building on 64 bit architectures the use of bitwise negation generates constants larger than 32 bits which won't fit in u32s used to represent 32 bit register values on the device. Explicitly cast to let the compiler know that the higher bits are not significant and can be discarded. Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-01spi/atmel: Fix pointer to int conversion warnings on 64 bit buildsMark Brown
On 64 bit systems integers are generally still 32 bit but long values and pointers are usually 64 bit. GCC warns when casting a 64 bit pointer into a 32 bit integer so cast to a long instead in order to avoid warnings. Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-31spi: davinci: fix to support more than 2 chip selectsMurali Karicheri
Currently, the driver defines SPI_MAX_CHIPSELECT as 2 and use per device array bytes_per_word based on this. This breaks if num_chipselect per device is greater than 2. This patch fix this and allocate memory for this array based on num_chipselect. It's preparation patch to enable GPIO CS feature for Davinci SPI. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-31spi: topcliff-pch: don't hardcode PCI slot to get DMA deviceAndy Shevchenko
The DMA is a function 0 of the multifunction device where SPI host is attached. Thus, we may avoid to hardcode PCI slot number. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-30MIPS: Alchemy: remove au_read/write/syncManuel Lauss
replace au_read/write/sync with __raw_read/write and wmb. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/7465/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-07-28spi: orion: fix incorrect handling of cell-index DT propertyThomas Petazzoni
In commit f814f9ac5a81 ("spi/orion: add device tree binding"), Device Tree support was added to the spi-orion driver. However, this commit reads the "cell-index" property, without taking into account the fact that DT properties are big-endian encoded. Since most of the platforms using spi-orion with DT have apparently not used anything but cell-index = <0>, the problem was not visible. But as soon as one starts using cell-index = <1>, the problem becomes clearly visible, as the master->bus_num gets a wrong value (actually it gets the value 0, which conflicts with the first bus that has cell-index = <0>). This commit fixes that by using of_property_read_u32() to read the property value, which does the appropriate endianness conversion when needed. Fixes: f814f9ac5a81 ("spi/orion: add device tree binding") Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: <stable@vger.kernel.org> # v3.6+
2014-07-25clk: Support for clock parents and rates assigned from device treeSylwester Nawrocki
This patch adds helper functions to configure clock parents and rates as specified through 'assigned-clock-parents', 'assigned-clock-rates' DT properties for a clock provider or clock consumer device. The helpers are now being called by the bus code for the platform, I2C and SPI busses, before the driver probing and also in the clock core after registration of a clock provider. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-07-25spi: orion: Fix error return code in orion_spi_probe()Wei Yongjun
Fix to return a negative error code from the error handling case of orion_spi_reset() instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-25spi/rockchip: fix error return code in rockchip_spi_probe()Wei Yongjun
Fix to return -EINVAL from the error handling case instead of 0 when failed to get fifo length. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-25spi/rockchip: remove redundant dev_err call in rockchip_spi_probe()Wei Yongjun
There is a error message within devm_ioremap_resource already, so remove the dev_err call to avoid redundant error message. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-25spi/rockchip: remove duplicated include from spi-rockchip.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-17spi: s3c64xx: use the generic SPI "cs-gpios" propertyNaveen Krishna Chatradhi
The s3c64xx SPI driver uses a custom DT binding to specify the GPIO used to drive the chip select (CS) line instead of using the generic "cs-gpios" property already defined in: Documentation/devicetree/bindings/spi/spi-bus.txt. It's unfortunate that drivers are not using standard bindings and creating custom ones instead but in most cases this can't be changed without breaking Device Tree backward compatibility. But in the case of this driver, its DT binding has been broken for more than a year. Since after commit (dated June, 21 2013): 3146bee ("spi: s3c64xx: Added provision for dedicated cs pin") DT backward compatibility was broken and nobody noticed until now when the commit was reverted. So it seems to be safe to change the binding to use the standard SPI "cs-gpios" property instead of using a custom one just for this driver. This patch also allows boards that don't use a GPIO pin for the CS to work with the driver since the SPI core will take care of setting spi->cs_gpio to -ENOENT if a board wants to use the built in CS instead of a GPIO as explained in the SPI bus DT binding: Documentation/devicetree/bindings/spi/spi-bus.txt. For non-DT platforms, spi->cs_gpio will be set to -ENOENT as well unless they specify a GPIO pin in their platform data. So both native and GPIO chip select is also supported for legacy boards. The above use case was what motivated commit 3146bee which broke the DT binding backward compatibility in the first place. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> [javier.martinez@collabora.co.uk: split changes and improve commit message] Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-17spi: s3c64xx: Revert "spi: s3c64xx: Added provision for dedicated cs pin"Javier Martinez Canillas
This reverts commit 3146beec21b64f4551fcf0ac148381d54dc41b1b. This commit resulted in a DT backward compatibility breakage. Some devices use the native chip select (CS) instead of a GPIO pin to drive the CS line. But the SPI driver made it mandatory to specify a GPIO pin in the SPI device node controller-data. So, using the built-in CS was not possible with the driver. Commit 3146bee tried to fix that by adding a "cs-gpio" property which could be defined in the SPI device node to make the driver request the GPIO from the controller-data node. Unfortunately that changed the old DT binding semantics since now it's mandatory to have the "cs-gpio" property defined in the SPI device node in order to use a GPIO pin to drive the CS. As an example, a SPI device was defined before the commit with: spi@12d20000 { slave-node@0 { controller-data { cs-gpio = <&gpb1 2 0>; } } } and after the commit, the following DTS snippet must be used: spi@12d20000 { cs-gpio; slave-node@0 { controller-data { cs-gpio = <&gpb1 2 0>; } } } So, after commit 3146bee the driver does not look for the GPIO by default and it only looks for it if the top level "cs-gpio" property is defined while the default used to be the opposite. To always request the GPIO defined in the controller-data node. This means that old FDT that of course didn't have this added "cs-gpio" DT property in the SPI node broke after this change. The offending commit can't be reverted cleanly since more than a year have passed and other changes were made in the meantime but this patch partially reverts the driver to it's original state so old FDT can work again. This patch will break Device Trees that were relying on the new behavior of course but the patch should be reverted because: a) There aren't DTS in mainline that use this new property. b) They were relying on a behavior that broke DT compatibility. c) The new binding is awkard, needing two properties with the same name (cs-gpio) on different nodes is confusing at least. d) The new property was not added to the DT binding doc: Documentation/devicetree/bindings/spi/spi-samsung.txt Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-16spi: atmel: Use dmaengine_prep_slave_sg() APIGeert Uytterhoeven
Use the inline wrapper introduced by commit 16052827d98fbc13c31ebad560af4bd53e2b4dd5 ("dmaengine/dma_slave: introduce inline wrappers"). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-16spi: topcliff-pch: Update error messages for dmaengine_prep_slave_sg() APIGeert Uytterhoeven
Commit 16052827d98fbc13c31ebad560af4bd53e2b4dd5 ("dmaengine/dma_slave: introduce inline wrappers") changed the code to use the new API, but forgot to update the error messages. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> -- v2: - New Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-16spi: sh-msiof: Use correct device for DMA mapping with IOMMUGeert Uytterhoeven
To function correctly in the presence of an IOMMU, the DMA buffers must be mapped using the DMA channel's device instead of the MSIOF platform device's device. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-16spi: sh-msiof: Handle dmaengine_prep_slave_single() failures gracefullyGeert Uytterhoeven
As typically a shmobile SoC has less DMA channels than devices that can use DMA, we may want to prioritize access to the DMA channels in the future. This means that dmaengine_prep_slave_single() may start failing arbitrarily. Handle dmaengine_prep_slave_single() failures gracefully by falling back to PIO. This requires moving DMA-specific configuration of the MSIOF device after the call(s) to dmaengine_prep_slave_single(). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-16spi: rspi: Handle dmaengine_prep_slave_sg() failures gracefullyGeert Uytterhoeven
As typically a shmobile SoC has less DMA channels than devices that can use DMA, we may want to prioritize access to the DMA channels in the future. This means that dmaengine_prep_slave_sg() may start failing arbitrarily. Handle dmaengine_prep_slave_sg() failures gracefully by falling back to PIO. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-12Merge tag 's5p-cleanup-v2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup Merge "Samsung cleanup 2nd version for S5P SoCs for 3.17" from Kukjin Kim: Cleanup S5P SoCs for 3.17 - removing s5p64x0 SoCs and s5pc100 SoC in mainline because no more user and if it is required next time, it will be supported with DT. * tag 's5p-cleanup-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: video: fbdev: s3c-fb: remove s5pc100 related fimd and fb codes mtd: onenand: remove s5pc100 related onenand codes spi: s3c64xx: remove s5pc100 related spi codes gpio: samsung: remov s5pc100 related gpio codes ARM: S5PC100: no more support S5PC100 SoC video: fbdev: s3c-fb: remove s5p64x0 related fimd codes spi: s3c64xx: remove s5p64x0 related spi codes gpio: samsung: remove s5p64x0 related gpio codes ARM: S5P64X0: no more support S5P6440 and S5P6450 SoCs Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-13spi: s3c64xx: remove s5pc100 related spi codesKukjin Kim
This patch removes sp5c100 related spi because of no more support s5pc100 SoC. Cc: Mark Brown <broonie@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-11spi: cadence: Configure SPI clock in the prepare_message() callbackLars-Peter Clausen
Currently the cadence SPI driver does the SPI clock configuration (setup CPOL and CPHA) in the prepare_transfer_hardware() callback. The prepare_transfer_hardware() callback is only called though when the controller transitions from a idle state to a non-idle state. Such a transitions happens when the message queue goes from empty to non-empty. If multiple messages from different SPI slaves with different clock settings are in the message queue the clock settings will not be properly updated when switching from one slave device to another. Instead do the updating of the clock configuration in the prepare_message() callback which will be called for each individual message. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-11spi: cadence: Make sure that clock polarity changes are appliedLars-Peter Clausen
It seems that the cadence SPI controller does not immediately change the clock polarity setting when writing the CR register. Instead the change is delayed until the next transfer starts. This happens after the chip select line has already been asserted. As a result the first transfer after a clock polarity change will generate spurious clock transitions which typically results in the SPI slave not being able to properly understand the message. Toggling the ER register seems to cause the SPI controller to apply the clock polarity changes, so implement this as a workaround to fix the issue. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-07-11spi/rockchip: add compatible strings for RK3188 and RK3288Addy Ke
Suggested-by: Mark Brown <broonie@kernel.org> Signed-off-by: Addy Ke <addy.ke@rockchip.com> Signed-off-by: Mark Brown <broonie@linaro.org>
