path: root/drivers/ssb/Kconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09ssb: Implement SDIO host bus supportAlbert Herranz
Add support for communicating with a Sonics Silicon Backplane through a SDIO interface, as found in the Nintendo Wii WLAN daughter card. The Nintendo Wii WLAN card includes a custom Broadcom 4318 chip with a SDIO host interface. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27ssb: remove EXPERIMENTAL dependencies.Michael Buesch
ssb is not experimental anymore. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10SSB: hide empty sub menuMike Frysinger
If the target system cannot support SSB, then don't show the menu option as it'll simply be an empty submenu. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-27ssb, b43, b43legacy, b44: Rewrite SSB DMA APIMichael Buesch
This is a rewrite of the DMA API for SSB devices. This is needed, because the old (non-existing) "API" made too many bad assumptions on the API of the host-bus (PCI). This introduces an almost complete SSB-DMA-API that maps to the lowlevel bus-API based on the bustype. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08ssb: Add support for block-I/OMichael Buesch
This adds support for block based I/O to SSB. This is needed in order to efficiently support PIO data transfers to the card. The block-I/O support is only compiled, if it's selected by the weird driver that needs it. So there's no overhead for sane devices. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13ssb: Add SPROM/invariants support for PCMCIA devicesMichael Buesch
This adds support for reading/writing the SPROM invariants for PCMCIA based devices. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06ssb: Add Gigabit Ethernet driverMichael Buesch
This adds the Gigabit Ethernet driver for the SSB Gigabit Ethernet core. This driver actually is a frontend to the Tigon3 driver. So the real work is done by tg3. This device is used in the Linksys WRT350N. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28Use a separate config option for the b43 pci to ssb bridge.Alexey Zaytsev
The bridge code was unnecessary enabled by the b44 driver, but it prevents the bcm43xx driver from being loaded, as the bridge claims the same pci ids. Now we enable the birdge only if the b43{legacy} drivers are selected. Signed-off-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-20ssb: Fix watchdog access for devices without a chipcommonMichael Buesch
This fixes the SSB watchdog access for devices without a chipcommon. These devices have the watchdog on the extif. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-16[PATCH] ssb: fix build failureIngo Molnar
fix build failure if PCMCIA=m but SSB=y: drivers/built-in.o: In function `ssb_pcmcia_switch_coreidx': : undefined reference to `pcmcia_access_configuration_register' (fix symmetric bug for PCI too.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Michael Buesch <mb@bu3sch.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
