This fixes a context assertion in ssb that makes b44 print
out warnings on resume.
This fixes the following kernel oops:
http://www.kerneloops.org/oops.php?number=12732
http://www.kerneloops.org/oops.php?number=11410
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Now that we fixed the TPS flag assignment in commit
b63009b456c8d9abe684bdf8d4bd8f27eb040019
we don't need the workaround for the bcm44xx chip anymore.
drivers/net/ehea/ehea_main.c
drivers/net/wireless/iwlwifi/Kconfig
drivers/net/wireless/rt2x00/rt61pci.c
net/ipv4/inet_timewait_sock.c
net/ipv6/raw.c
net/mac80211/ieee80211_sta.c
This fixes the TPS flag handling for the SSB pcicore driver.
This fixes interrupts on some devices.
This adds the Gigabit Ethernet driver for the SSB
Gigabit Ethernet core. This driver actually is a frontend to
the Tigon3 driver. So the real work is done by tg3.
This device is used in the Linksys WRT350N.
This patch has added pcibios_enable_device() return value check.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Switch the SSB PCI core driver to the new SPROM data structure now that
the old one has been removed.
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Acked-by: Michael Buesch <mb@bu3sch.de>
We must pin all resources and make sure the PCI subsystem
won't relocate us, as the addresses are hardwired into hardware.
This fixes the pcicore driver to not die a horrible
crash death when inserting a cardbus card.
SSB is an SoC bus used in a number of embedded devices. The most
well-known of these devices is probably the Linksys WRT54G, but there
are others as well. The bus is also used internally on the BCM43xx
and BCM44xx devices from Broadcom.
This patch also includes support for SSB ID tables in modules, so
that SSB drivers can be loaded automatically.
