path: root/drivers/ssb/driver_pcicore.c
2015-05-20ssb: extend fix for PCI related silent reboots to all chipsetsRafał Miłecki
Recent fix for BCM4704 reboots has to be extended as the same problem affects Linksys WRT350N v1 (BCM4705). Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Reported-by: Daniel Gimpelevich <daniel@gimpelevich.san-francisco.ca.us> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-04-07ssb: add delay after PCI reset to fix SoC rebootsRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2013-03-06ssb: Convert ssb_printk to ssb_<level>Joe Perches
Use a more current logging style. Convert ssb_dbprint to ssb_dbg too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-03Drivers: ssb: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Michael Buesch <m@bues.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-01ssb: fix cardbus slot in hostmodeHauke Mehrtens
ssb supports one extra device on the cardbus. This results in two devices in total, one beeing the host controller itself and the other the external device connected to the hostcontroller over cardbus. This makes the cardbus slot work on the Linksys WRT150N. Reported-by: Aaron Z <aaronz@pls-net.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-12-08ssb: fix init regression with SoCsHauke Mehrtens
This fixes a Data bus error on some SoCs. The first fix for this problem did not solve it on all devices. commit 6ae8ec27868bfdbb815287bee8146acbefaee867 Author: Rafał Miłecki <zajec5@gmail.com> Date: Tue Jul 5 17:25:32 2011 +0200 ssb: fix init regression of hostmode PCI core In ssb_pcicore_fix_sprom_core_index() the sprom on the PCI core is accessed, but the sprom only exists when the ssb bus is connected over a PCI bus to the rest of the system and not when the SSB Bus is the main system bus. SoCs sometimes have a PCI host controller and there this code will not be executed, but there are some old SoCs with an PCI controller in client mode around and ssb_pcicore_fix_sprom_core_index() should not be called on these devices too. The PCI controller on these devices are unused, but without this fix it results in an Data bus error when it gets initialized. Cc: Michael Buesch <m@bues.ch> Cc: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31ssb: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or we will get things like this when we remove the implicit path: drivers/ssb/embedded.c:32: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/ssb/driver_chipcommon.c:432: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/ssb/driver_chipcommon_pmu.c:607: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/ssb/pcihost_wrapper.c:120: error: ‘THIS_MODULE’ undeclared (first use in this function) drivers/ssb/driver_pcicore.c:721: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’ drivers/ssb/driver_gige.c:249: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/bluetooth/l2cap_core.c
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-07ssb: fix init regression of hostmode PCI coreRafał Miłecki
Our workarounds seem to be clientmode PCI specific. Using SPROM workaround on SoC resulted in Oops: Data bus error, epc == 8017ed58, ra == 80225838 Oops[#1]: Cpu 0 $ 0 : 00000000 10008000 b8000000 00000001 $ 4 : 80293b5c 00000caa ffffffff 00000000 $ 8 : 0000000a 00000003 00000001 696d6d20 $12 : ffffffff 00000000 00000000 ffffffff $16 : 802d0140 b8004800 802c0000 00000000 $20 : 00000000 802c0000 00000000 802d04d4 $24 : 00000018 80151a00 $28 : 81816000 81817df8 8029bda0 80225838 Hi : 00000000 Lo : 00000000 epc : 8017ed58 ssb_ssb_read16+0x48/0x60 Not tainted ra : 80225838 ssb_pcicore_init+0x54/0x3b4 Reported-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Tested-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-22ssb: add __devinit to some functionsHauke Mehrtens
Two functions in ssb are using register_pci_controller() which is __devinit. The functions ssb_pcicore_init_hostmode() and ssb_gige_probe() should also be __devinit. This fixes the following warning: WARNING: vmlinux.o(.text+0x2727b8): Section mismatch in reference from the function ssb_pcicore_init_hostmode() to the function .devinit.text:register_pci_controller() The function ssb_pcicore_init_hostmode() references the function __devinit register_pci_controller(). This is often because ssb_pcicore_init_hostmode lacks a __devinit annotation or the annotation of register_pci_controller is wrong. WARNING: vmlinux.o(.text+0x273398): Section mismatch in reference from the function ssb_gige_probe() to the function .devinit.text:register_pci_controller() The function ssb_gige_probe() references the function __devinit register_pci_controller(). This is often because ssb_gige_probe lacks a __devinit annotation or the annotation of register_pci_controller is wrong. Reported-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-03ssb: fix PCI(e) driver regression causing oops on PCI cardsRafał Miłecki
We were incorrectly executing PCIe specific workarounds on PCI cards. This resulted in: Machine check in kernel mode. Caused by (from SRR1=149030): Transfer error ack signal Oops: Machine check, sig: 7 [#1] Reported-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11ssb: move ssb_commit_settings and export itRafał Miłecki
Commiting settings is possible on devices without PCI core (but with CC core). Export it for usage in drivers supporting other cores. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-28ssb: pci: early fix for SPROM core indexRafał Miłecki
2011-04-28ssb: pci: update PCIe workaroundsRafał Miłecki
2011-04-28ssb: pci: separate workaroundsRafał Miłecki
2011-04-25ssb: pci: trivial: correct amount of maximum retriesRafał Miłecki
2011-04-04ssb: pci: implement serdes workaroundRafał Miłecki
2011-04-04ssb: pci: implement mdio readingRafał Miłecki
2011-04-04ssb: pci: fix mdio writes on newer cores (rev 10+)Rafał Miłecki
2011-04-04ssb: pci: trivial: drop useless pointerRafał Miłecki
2010-04-12MIPS: Fix SSB PCIcore IO resource managementAndreas Ferber
The SSB PCIcore code reused the IO resource fixup code from the original 2.4.x Broadcom patch for BCM47xx based devices, which was a quick hack for doing PCI IO resource configuration back then (the boot loader doesn't configure PCI devices on this platform). However, this code is no longer necessary since the kernel now can do PCI resource management fine all by itself, so remove the old code. When removing the code, it becomes obvious that the mem_offset setting in the PCIcore driver was wrong, however this was masked by the fixup code before, except in a few cases involving yenta_socket. For BCM47xx, the correct offset is 0, and since this is the only device using PCIcore in host mode, the offset can simply be removed unconditionally. Signed-off-by: Andreas Ferber <af@chaos-agency.de> Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Markus Wigge <markus@cultcom.de> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1070/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-10-27ssb: Put host pointers into a unionMichael Buesch
This slightly shrinks the structure. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-07ssb-pcicore: Fix IRQ-vector init on embedded devicesMichael Buesch
On embedded devices we must not route the interrupts through the PCI core, if our host-bus is not PCI. Reported-by: Steve Brown <sbrown@cortland.com> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-04ssb: Fix context assertion in ssb_pcicore_dev_irqvecs_enableMichael Buesch
This fixes a context assertion in ssb that makes b44 print out warnings on resume. This fixes the following kernel oops: http://www.kerneloops.org/oops.php?number=12732 http://www.kerneloops.org/oops.php?number=11410 Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16ssb-pcicore: Remove b44 TPS flag workaroundMichael Buesch
Now that we fixed the TPS flag assignment in commit b63009b456c8d9abe684bdf8d4bd8f27eb040019 we don't need the workaround for the bcm44xx chip anymore. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-09ssb-pcicore: Fix IRQ TPS flag handlingLarry Finger
This fixes the TPS flag handling for the SSB pcicore driver. This fixes interrupts on some devices. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06ssb: Add Gigabit Ethernet driverMichael Buesch
This adds the Gigabit Ethernet driver for the SSB Gigabit Ethernet core. This driver actually is a frontend to the Tigon3 driver. So the real work is done by tg3. This device is used in the Linksys WRT350N. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-04ssb: Add pcibios_enable_device() return value checkYoichi Yuasa
This patch has added pcibios_enable_device() return value check. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28SSB PCI core driver: use new SPROM data structureAurelien Jarno
Switch the SSB PCI core driver to the new SPROM data structure now that the old one has been removed. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-20ssb: Fix support for PCI devices behind a SSB->PCI bridgeMichael Buesch
We must pin all resources and make sure the PCI subsystem won't relocate us, as the addresses are hardwired into hardware. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-20ssb: Fix pcicore cardbus modeMichael Buesch
This fixes the pcicore driver to not die a horrible crash death when inserting a cardbus card. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
