path: root/drivers/ssb
2012-12-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The MIPS bits for 3.8. This also includes a bunch fixes that were sitting in the linux-mips.org git tree for a long time. This pull request contains updates to several OCTEON drivers and the board support code for BCM47XX, BCM63XX, XLP, XLR, XLS, lantiq, Loongson1B, updates to the SSB bus support, MIPS kexec code and adds support for kdump. When pulling this, there are two expected merge conflicts in include/linux/bcma/bcma_driver_chipcommon.h which are trivial to resolve, just remove the conflict markers and keep both alternatives." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (90 commits) MIPS: PMC-Sierra Yosemite: Remove support. VIDEO: Newport Fix console crashes MIPS: wrppmc: Fix build of PCI code. MIPS: IP22/IP28: Fix build of EISA code. MIPS: RB532: Fix build of prom code. MIPS: PowerTV: Fix build. MIPS: IP27: Correct fucked grammar in ops-bridge.c MIPS: Highmem: Fix build error if CONFIG_DEBUG_HIGHMEM is disabled MIPS: Fix potencial corruption MIPS: Fix for warning from FPU emulation code MIPS: Handle COP3 Unusable exception as COP1X for FP emulation MIPS: Fix poweroff failure when HOTPLUG_CPU configured. MIPS: MT: Fix build with CONFIG_UIDGID_STRICT_TYPE_CHECKS=y MIPS: Remove unused smvp.h MIPS/EDAC: Improve OCTEON EDAC support. MIPS: OCTEON: Add definitions for OCTEON memory contoller registers. MIPS: OCTEON: Add OCTEON family definitions to octeon-model.h ata: pata_octeon_cf: Use correct byte order for DMA in when built little-endian. MIPS/OCTEON/ata: Convert pata_octeon_cf.c to use device tree. MIPS: Remove usage of CEVT_R4K_LIB config option. ...
2012-12-10ssb: use WARN in main.cCong Ding
Use WARN rather than printk followed by WARN_ON(1), for conciseness. Signed-off-by: Cong Ding <dinggnu@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06ssb: register watchdog driverHauke Mehrtens
Register the watchdog driver to the system if it is a SoC. Using the watchdog on a non SoC device, like a PCI card, will make the PCI card die when the timeout expired, but starting it again is not supported by ssb. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06ssb: extif: add methods for watchdog driverHauke Mehrtens
The watchdog driver wants to set the watchdog timeout in ms and not in ticks, add a method converting ms to ticks before setting the watchdog register. Return the ticks or millisecond the timer was set to in case the provided value was bigger than the max allowed value. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06ssb: extif: add check for max value before setting watchdog registerHauke Mehrtens
Prevent the watchdog register on the extif core to be set to a too high value. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06ssb: add methods for watchdog driverHauke Mehrtens
The watchdog driver wants to set the watchdog timeout in ms and not in ticks, which is depending on the SoC type and the clock. Calculate the number of ticks per millisecond and provide two functions for the watchdog driver. Also return the ticks or millisecond the timer was set to in case the provided value was bigger than the max allowed value. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06ssb: set the PMU watchdog if availableHauke Mehrtens
Some ssb based devices have a PMU and the PMU watchdog register should be used instead of the register in the chip common part, if the device has a PMU. This patch also calculates the maximal number the watchdog could be set to. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-06ssb: get alp clock from devices with PMUHauke Mehrtens
If there is a PMU in the device, get the alp clock from that part and do not assume 20000000. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-11-30ssb: extif: fix compile errorsHauke Mehrtens
If CONFIG_SSB_EMBEDDED or CONFIG_SSB_DRIVER_MIPS is set and CONFIG_SSB_DRIVER_EXTIF is not set, it will cause compile problems because of missing functions. This patch fixes these problems. The mips driver now also uses ssb_chipco_available() instead of checking bus->chipco.dev manually. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-11-21ssb: add GPIO driverHauke Mehrtens
Register a GPIO driver to access the GPIOs provided by the chip. The GPIOs of the SoC should always start at 0 and the other GPIOs could start at a random position. There is just one SoC in a system and when they start at 0 the number is predictable. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Patchwork: http://patchwork.linux-mips.org/patch/4591 Acked-by: Florian Fainelli <florian@openwrt.org>
2012-11-21ssb: add locking around gpio register accessesHauke Mehrtens
The GPIOs are access through some registers in the chip common core or over extif. We need locking around these GPIO accesses, all GPIOs are accessed through the same registers and parallel writes will cause problems. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Patchwork: http://patchwork.linux-mips.org/patch/4590 Acked-by: Florian Fainelli <florian@openwrt.org>
2012-11-21ssb: add ssb_chipco_gpio_pull{up,down}Hauke Mehrtens
Add functions to access the GPIO registers for pullup and pulldown. These are needed for handling gpio registration. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Patchwork: http://patchwork.linux-mips.org/patch/4589 Acked-by: Florian Fainelli <florian@openwrt.org>
2012-10-29ssb: handle BCM43222 in pmu code.Hauke Mehrtens
The BCM43222 with the chipid 43222 or 0xa8d6 in hex do not need any special handling in the pmu code. This prevents some error messages being shown. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-10-29ssb: add PCI ID 0x4350Hauke Mehrtens
14e4:4350 is found on a Broadcom BCM43222. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-10-19ssb: add attribute to indicate a parallel flash is availableHauke Mehrtens
2012-10-19ssb: move parallel flash config into an own structHauke Mehrtens
This is a preparing step for adding serial flash support. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-10ssb: check for flash presentenceRafał Miłecki
We can not assume parallel flash is always present, there are boards with *serial* flash and probably some without flash at all. Define some bits by the way. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Reviewed-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-11ssb: add missing PCI ID for b/g/n single band BCM4322Jonas Gorski
14e4:432c is found on some bcm63xx devices. The device is working fine with b43. Reported-by: Álvaro Fernández Rojas <noltari@gmail.com> Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06ssb: recognize ARM Cortex M3Hauke Mehrtens
I found this core on a BCM4322, a PCI card in the Linksys WRT610N V1. This core is not used by the driver, this patch just makes ssb show the correct name. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16ssb: add PCI IDs 0x4322 and 43222Hauke Mehrtens
The 0x4322 ID is found on the BCM4322 used on some SoCs like the Linksys WRT610N V1 connected to a BCM4705. The 43222 (0xa8d6) ID is found on the BCM43222 used on some other SoCs like the D-Link DSL-2760U connected to a BCM63xx. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16bcma/ssb: parse new attributes from spromHauke Mehrtens
These newly added attributes are used by brcmsmac. Now bcma should parse all attributes used by brcmsmac out of the sprom. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16ssb: fill board_rev attribute from spromHauke Mehrtens
This attribute is now used in b43 driver and should be filled for all sprom versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16ssb/bcma: fill attribute alpha2 from spromHauke Mehrtens
The attribute country_code and alpha2 are two different attributes in the sprom. country_code contains some code in an 8 bit coding and alpha2 contains two chars with the country code. The attributes where read out wrongly in the past and country_code is only available on sprom version 1. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-16ssb: remove rev from boardinfoHauke Mehrtens
Previously the rev contained the revision read from the pci config space and was used as board_rev in the wireless drivers. This is wrong the board_rev is only fetched from the sprom accordingly to the open source part of the Broadcom SDK and brcmsmac. This patch removes the rev from the boardinfo structure and uses the board_rev attribute from sprom instead. This attribute is filled by PCI, PCMCIA, SDIO and SoC code. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-09Merge 3.3-rc6 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a conflict in the drivers/base/cpu.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-05ssb: remove 5GHz antenna gain from spromHauke Mehrtens
There is no 2.4 GHz or 5GHz antenna gain stored in sprom. The sprom just stores the gain values for antenna 1 and 2 or 1 to 4 for more recent sprom versions. On old devices antenna 2 was used for 5 GHz wifi. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: net/mac80211/debugfs_sta.c net/mac80211/sta_info.h
2012-02-06ssb: add support for bcm5354Hauke Mehrtens
This patch adds support the the BCM5354 SoC. It has a PMU and a constant not configurable clock. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06ssb: log the id, rev and pkg of the chip foundHauke Mehrtens
This makes us see what type of hardware someone uses by the dmesg output. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-01ssb: fix cardbus slot in hostmodeHauke Mehrtens
ssb supports one extra device on the cardbus. This results in two devices in total, one beeing the host controller itself and the other the external device connected to the hostcontroller over cardbus. This makes the cardbus slot work on the Linksys WRT150N. Reported-by: Aaron Z <aaronz@pls-net.org> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-24Remove useless get_driver()/put_driver() callsAlan Stern
As part of the removal of get_driver()/put_driver(), this patch (as1512) gets rid of various useless and unnecessary calls in several drivers. In some cases it may be desirable to pin the driver by calling try_module_get(), but that can be done later. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: "David S. Miller" <davem@davemloft.net> CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: Michael Buesch <m@bues.ch> CC: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24ssb: SPROM: extract each core power infoRafał Miłecki
We already extract some basic info but it's incomplete, reads info about the first core only. Used data structure doesn't allow easy adding of more cores. This patch adds new struct and array for storing power info. The plan is to: switch all extractors (including the ones using NVRAM) to new struct, switch drivers, then deprecate and finally drop old SSB fields. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-14Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c
2011-12-13ssb: extract FEM info from SPROMRafał Miłecki
2011-12-08ssb: fix init regression with SoCsHauke Mehrtens
This fixes a Data bus error on some SoCs. The first fix for this problem did not solve it on all devices. commit 6ae8ec27868bfdbb815287bee8146acbefaee867 Author: Rafał Miłecki <zajec5@gmail.com> Date: Tue Jul 5 17:25:32 2011 +0200 ssb: fix init regression of hostmode PCI core In ssb_pcicore_fix_sprom_core_index() the sprom on the PCI core is accessed, but the sprom only exists when the ssb bus is connected over a PCI bus to the rest of the system and not when the SSB Bus is the main system bus. SoCs sometimes have a PCI host controller and there this code will not be executed, but there are some old SoCs with an PCI controller in client mode around and ssb_pcicore_fix_sprom_core_index() should not be called on these devices too. The PCI controller on these devices are unused, but without this fix it results in an Data bus error when it gets initialized. Cc: Michael Buesch <m@bues.ch> Cc: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31ssb: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or we will get things like this when we remove the implicit path: drivers/ssb/embedded.c:32: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/ssb/driver_chipcommon.c:432: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/ssb/driver_chipcommon_pmu.c:607: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/ssb/pcihost_wrapper.c:120: error: ‘THIS_MODULE’ undeclared (first use in this function) drivers/ssb/driver_pcicore.c:721: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’ drivers/ssb/driver_gige.c:249: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31ssb: Add module.h to the real modules in drivers/ssbPaul Gortmaker
The header cleanup means that module.h is no longer simply everywhere. So real modules need to actively include it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-24ssb: fix DMA translation for some specific boardsRafał Miłecki
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-22ssb: return correct translation bit for 64-bit DMARafał Miłecki
Remove b43's workarounds at the same time. Other users of ssb_dma_translation do not support any 64-bit DMA devices, so they are not affected. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-11Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/ath/ath5k/sysfs.c net/bluetooth/l2cap_core.c net/mac80211/wpa.c
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-07ssb: fix init regression of hostmode PCI coreRafał Miłecki
Our workarounds seem to be clientmode PCI specific. Using SPROM workaround on SoC resulted in Oops: Data bus error, epc == 8017ed58, ra == 80225838 Oops[#1]: Cpu 0 $ 0 : 00000000 10008000 b8000000 00000001 $ 4 : 80293b5c 00000caa ffffffff 00000000 $ 8 : 0000000a 00000003 00000001 696d6d20 $12 : ffffffff 00000000 00000000 ffffffff $16 : 802d0140 b8004800 802c0000 00000000 $20 : 00000000 802c0000 00000000 802d04d4 $24 : 00000018 80151a00 $28 : 81816000 81817df8 8029bda0 80225838 Hi : 00000000 Lo : 00000000 epc : 8017ed58 ssb_ssb_read16+0x48/0x60 Not tainted ra : 80225838 ssb_pcicore_init+0x54/0x3b4 Reported-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Tested-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-05ssb: use pci_dev->subsystem_{vendor,device}Sergei Shtylyov
The SSB code reads PCI subsystem IDs from the PCI configuration registers while they are already stored by the PCI subsystem in the 'subsystem_{vendor|device}' fields of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05ssb: use pci_dev->revisionSergei Shtylyov
The SSB code reads PCI revision ID from the PCI configuration register while it's already stored by the PCI subsystem in the 'revision' field of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-05ssb: PCI revision ID register is 8-bit wideSergei Shtylyov
The SSB code reads PCI revision ID register as 16-bit entity while the register is actually 8-bit only (the next 8 bits are the programming interface register). Fix the read and make the 'rev' field of 'struct ssb_boardinfo' 8-bit as well, to match the register size. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27ssb: use pci_dev->revisionSergei Shtylyov
The bus scan code reads PCI revision ID from the PCI configuration register while it's already stored by PCI subsystem in the 'revision' field of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27ssb: fix ssb clock rate according to broadcom sourceHauke Mehrtens
This fix was done according to si_clock_rate function in broadcom siutils.c Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
