Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com>
[ Aisheng: fix minor conflict due to removed VBOXSF_FS ]
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
[ Aisheng: fix minor conflict due to removed CONFIG_VBOXSF_FS ]
Signed-off-by: Zhou Peng <eagle.zhou@nxp.com>
This went into staging in rc7. It turns out that was a mistake, and
apparently it wasn't even supposed to go there at all, but be introduced
as a regular filesystem.
We don't try to sneak in whole new filesystems this late in the rc, just
delete the whole thing, and it can be re-introduced as a proper patch
with proper acks from actual filesystem people instead of some odd
late-rc staging back-door.
Cc: Hans de Goede <hdegoede@redhat.com>
VirtualBox hosts can share folders with guests, this commit adds a
VFS driver implementing the Linux-guest side of this, allowing folders
exported by the host to be mounted under Linux.
This driver depends on the guest <-> host IPC functions exported by
the vboxguest driver.
Link: https://lore.kernel.org/r/20191028111744.143863-2-hdegoede@redhat.com
Pull networking updates from David Miller:
1) Support IPV6 RA Captive Portal Identifier, from Maciej Żenczykowski.
2) Use bio_vec in the networking instead of custom skb_frag_t, from
Matthew Wilcox.
3) Make use of xmit_more in r8169 driver, from Heiner Kallweit.
4) Add devmap_hash to xdp, from Toke Høiland-Jørgensen.
5) Support all variants of 5750X bnxt_en chips, from Michael Chan.
6) More RTNL avoidance work in the core and mlx5 driver, from Vlad
Buslov.
7) Add TCP syn cookies bpf helper, from Petar Penkov.
8) Add 'nettest' to selftests and use it, from David Ahern.
9) Add extack support to drop_monitor, add packet alert mode and
support for HW drops, from Ido Schimmel.
10) Add VLAN offload to stmmac, from Jose Abreu.
11) Lots of devm_platform_ioremap_resource() conversions, from
YueHaibing.
12) Add IONIC driver, from Shannon Nelson.
13) Several kTLS cleanups, from Jakub Kicinski.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next: (1930 commits)
mlxsw: spectrum_buffers: Add the ability to query the CPU port's shared buffer
mlxsw: spectrum: Register CPU port with devlink
mlxsw: spectrum_buffers: Prevent changing CPU port's configuration
net: ena: fix incorrect update of intr_delay_resolution
net: ena: fix retrieval of nonadaptive interrupt moderation intervals
net: ena: fix update of interrupt moderation register
net: ena: remove all old adaptive rx interrupt moderation code from ena_com
net: ena: remove ena_restore_ethtool_params() and relevant fields
net: ena: remove old adaptive interrupt moderation code from ena_netdev
net: ena: remove code duplication in ena_com_update_nonadaptive_moderation_interval _*()
net: ena: enable the interrupt_moderation in driver_supported_features
net: ena: reimplement set/get_coalesce()
net: ena: switch to dim algorithm for rx adaptive interrupt moderation
net: ena: add intr_moder_rx_interval to struct ena_com_dev and use it
net: phy: adin: implement Energy Detect Powerdown mode via phy-tunable
ethtool: implement Energy Detect Powerdown support via phy-tunable
xen-netfront: do not assume sk_buff_head list is empty in error handling
s390/ctcm: Delete unnecessary checks before the macro call “dev_kfree_skb”
net: ena: don't wake up tx queue when down
drop_monitor: Better sanitize notified packets
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging and IIO driver updates from Greg KH:
"Here is the big staging/iio driver update for 5.4-rc1.
Lots of churn here, with a few driver/filesystems moving out of
staging finally:
- erofs moved out of staging
- greybus core code moved out of staging
Along with that, a new filesytem has been added:
- extfat
to provide support for those devices requiring that filesystem (i.e.
transfer devices to/from windows systems or printers)
Other than that, there a number of new IIO drivers, and lots and lots
and lots of staging driver cleanups and minor fixes as people continue
to dig into those for easy changes.
All of these have been in linux-next for a while with no reported
issues"
* tag 'staging-5.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (453 commits)
Staging: gasket: Use temporaries to reduce line length.
Staging: octeon: Avoid several usecases of strcpy
staging: vhciq_core: replace snprintf with scnprintf
staging: wilc1000: avoid twice IRQ handler execution for each single interrupt
staging: wilc1000: remove unused interrupt status handling code
staging: fbtft: make several arrays static const, makes object smaller
staging: rtl8188eu: make two arrays static const, makes object smaller
staging: rtl8723bs: core: Remove Macro "IS_MAC_ADDRESS_BROADCAST"
dt-bindings: anybus-controller: move to staging/ tree
staging: emxx_udc: remove local TRUE/FALSE definition
staging: wilc1000: look for rtc_clk clock
staging: dt-bindings: wilc1000: add optional rtc_clk property
staging: nvec: make use of devm_platform_ioremap_resource
staging: exfat: drop unused function parameter
Staging: exfat: Avoid use of strcpy
staging: exfat: use integer constants
staging: exfat: cleanup spacing for casts
staging: exfat: cleanup spacing for operators
staging: rtl8723bs: hal: remove redundant variable n
staging: pi433: Fix typo in documentation
The exfat code needs a lot of work to get it into "real" shape for
the fs/ part of the kernel, so put it into drivers/staging/ for now so
that it can be worked on by everyone in the community.
The full specification of the filesystem can be found at:
https://docs.microsoft.com/en-us/windows/win32/fileio/exfat-specification
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Link: https://lore.kernel.org/r/20190828160817.6250-1-gregkh@linuxfoundation.org
EROFS filesystem has been merged into linux-staging for a year.
EROFS is designed to be a better solution of saving extra storage
space with guaranteed end-to-end performance for read-only files
with the help of reduced metadata, fixed-sized output compression
and decompression inplace technologies.
In the past year, EROFS was greatly improved by many people as
a staging driver, self-tested, betaed by a large number of our
internal users, successfully applied to almost all in-service
HUAWEI smartphones as the part of EMUI 9.1 and proven to be stable
enough to be moved out of staging.
EROFS is a self-contained filesystem driver. Although there are
still some TODOs to be more generic, we have a dedicated team
actively keeping on working on EROFS in order to make it better
with the evolution of Linux kernel as the other in-kernel filesystems.
As Pavel suggested, it's better to do as one commit since git
can do moves and all histories will be saved in this way.
Let's promote it from staging and enhance it more actively as
a "real" part of kernel for more wider scenarios!
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Pavel Machek <pavel@denx.de>
Cc: David Sterba <dsterba@suse.cz>
Cc: Amir Goldstein <amir73il@gmail.com>
Cc: Darrick J . Wong <darrick.wong@oracle.com>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Richard Weinberger <richard@nod.at>
Cc: Chao Yu <yuchao0@huawei.com>
Cc: Miao Xie <miaoxie@huawei.com>
Cc: Li Guifu <bluce.liguifu@huawei.com>
Cc: Fang Wei <fangwei1@huawei.com>
Signed-off-by: Gao Xiang <gaoxiang25@huawei.com>
Link: https://lore.kernel.org/r/20190822213659.5501-1-hsiangkao@aol.com
The UWB and wusbcore code is long obsolete, so let us just move the code
out of the real part of the kernel and into the drivers/staging/
location with plans to remove it entirely in a few releases.
Link: https://lore.kernel.org/r/20190806101509.GA11280@kroah.com
The hardware has been declared EOL by the vendor more than 5 years ago.
What's more relevant to the Linux kernel is that the quality of this driver
is not on par with many other mainline drivers.
Cc: Manish Chopra <manishc@marvell.com>
Message-id: <20190617074858.32467-1-bpoirier@suse.com>
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
I tried to find any indication of whether the capi drivers are still in
use, and have not found anything from a long time ago.
With public ISDN networks almost completely shut down over the past 12
months, there is very little you can actually do with this hardware. The
main remaining use case would be to connect ISDN voice phones to an
in-house installation with Asterisk or LCR, but anyone trying this in
turn seems to be using either the mISDN driver stack, or out-of-tree
drivers from the hardware vendors.
I may of course have missed something, so I would suggest moving these
three drivers (avm, hysdn, gigaset) into drivers/staging/ just in case
someone still uses them.
If nobody complains, we can remove them entirely in six months, or
otherwise move the core code and any drivers that are still needed back
into drivers/isdn.
As Paul Bolle notes, he is still testing the gigaset driver as long as
he can, but the Dutch ISDN network will be shut down in September 2019,
which puts an end to that.
Marcel Holtmann still maintains the Bluetooth CMTP profile and wants to
keep that alive, so the actual CAPI subsystem code remains in place for
now, after all other drivers are gone, CMTP and CAPI can be merged into
a single driver directory.
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Paul Bolle <pebolle@tiscali.nl>
Pull drm updates from Dave Airlie:
"This has two exciting community drivers for ARM Mali accelerators.
Since ARM has never been open source friendly on the GPU side of the
house, the community has had to create open source drivers for the
Mali GPUs. Lima covers the older t4xx and panfrost the newer 6xx/7xx
series. Well done to all involved and hopefully this will help ARM
head in the right direction.
There is also now the ability if you don't have any of the legacy
drivers enabled (pre-KMS) to remove all the pre-KMS support code from
the core drm, this saves 10% or so in codesize on my machine.
i915 also enable Icelake/Elkhart Lake Gen11 GPUs by default, vboxvideo
moves out of staging.
There are also some rcar-du patches which crossover with media tree
but all should be acked by Mauro.
Summary:
uapi changes:
- Colorspace connector property
- fourcc - new YUV formts
- timeline sync objects initially merged
- expose FB_DAMAGE_CLIPS to atomic userspace
new drivers:
- vboxvideo: moved out of staging
- aspeed: ASPEED SoC BMC chip display support
- lima: ARM Mali4xx GPU acceleration driver support
- panfrost: ARM Mali6xx/7xx Midgard/Bitfrost acceleration driver support
core:
- component helper docs
- unplugging fixes
- devm device init
- MIPI/DSI rate control
- shmem backed gem objects
- connector, display_info, edid_quirks cleanups
- dma_buf fence chain support
- 64-bit dma-fence seqno comparison fixes
- move initial fb config code to core
- gem fence array helpers for Lima
- ability to remove legacy support code if no drivers requires it (removes 10% of drm.ko size)
- lease fixes
ttm:
- unified DRM_FILE_PAGE_OFFSET handling
- Account for kernel allocations in kernel zone only
panel:
- OSD070T1718-19TS panel support
- panel-tpo-td028ttec1 backlight support
- Ronbo RB070D30 MIPI/DSI
- Feiyang FY07024DI26A30-D MIPI-DSI panel
- Rocktech jh057n00900 MIPI-DSI panel
i915:
- Comet Lake (Gen9) PCI IDs
- Updated Icelake PCI IDs
- Elkhartlake (Gen11) support
- DP MST property addtions
- plane and watermark fixes
- Icelake port sync and VEBOX disable fixes
- struct_mutex usage reduction
- Icelake gamma fix
- GuC reset fixes
- make mmap more asynchronous
- sound display power well race fixes
- DDI/MIPI-DSI clocks for Icelake
- Icelake RPS frequency changing support
- Icelake workarounds
amdgpu:
- Use HMM for userptr
- vega20 experimental smu11 support
- RAS support for vega20
- BACO support for vega12 + fixes for vega20
- reworked IH interrupt handling
- amdkfd RAS support
- Freesync improvements
- initial timeline sync object support
- DC Z ordering fixes
- NV12 planes support
- colorspace properties for planes=
- eDP opts if eDP already initialized
nouveau:
- misc fixes
etnaviv:
- misc fixes
msm:
- GPU zap shader support expansion
- robustness ABI addition
exynos:
- Logging cleanups
tegra:
- Shared reset fix
- CPU cache maintenance fix
cirrus:
- driver rewritten using simple helpers
meson:
- G12A support
vmwgfx:
- Resource dirtying management improvements
- Userspace logging improvements
virtio:
- PRIME fixes
rockchip:
- rk3066 hdmi support
sun4i:
- DSI burst mode support
vc4:
- load tracker to detect underflow
v3d:
- v3d v4.2 support
malidp:
- initial Mali D71 support in komeda driver
tfp410:
- omap related improvement
omapdrm:
- drm bridge/panel support
- drop some omap specific panels
rcar-du:
- Display writeback support"
* tag 'drm-next-2019-05-09' of git://anongit.freedesktop.org/drm/drm: (1507 commits)
drm/msm/a6xx: No zap shader is not an error
drm/cma-helper: Fix drm_gem_cma_free_object()
drm: Fix timestamp docs for variable refresh properties.
drm/komeda: Mark the local functions as static
drm/komeda: Fixed warning: Function parameter or member not described
drm/komeda: Expose bus_width to Komeda-CORE
drm/komeda: Add sysfs attribute: core_id and config_id
drm: add non-desktop quirk for Valve HMDs
drm/panfrost: Show stored feature registers
drm/panfrost: Don't scream about deferred probe
drm/panfrost: Disable PM on probe failure
drm/panfrost: Set DMA masks earlier
drm/panfrost: Add sanity checks to submit IOCTL
drm/etnaviv: initialize idle mask before querying the HW db
drm: introduce a capability flag for syncobj timeline support
drm: report consistent errors when checking syncobj capibility
drm/nouveau/nouveau: forward error generated while resuming objects tree
drm/nouveau/fb/ramgk104: fix spelling mistake "sucessfully" -> "successfully"
drm/nouveau/i2c: Disable i2c bus access after ->fini()
drm/nouveau: Remove duplicate ACPI_VIDEO_NOTIFY_PROBE definition
Pull staging / IIO driver updates from Greg KH:
"Here is the big staging and iio driver update for 5.2-rc1.
Lots of tiny fixes all over the staging and IIO driver trees here,
along with some new IIO drivers.
The "counter" subsystem was added in here as well, as it is needed by
the IIO drivers and subsystem.
Also we ended up deleting two drivers, making this pull request remove
a few hundred thousand lines of code, always a nice thing to see. Both
of the drivers removed have been replaced with "real" drivers in their
various subsystem directories, and they will be coming to you from
those locations during this merge window.
There are some core vt/selection changes in here, that was due to some
cleanups needed for the speakup fixes. Those have all been acked by
the various subsystem maintainers (i.e. me), so those are ok.
We also added a few new drivers, for some odd hardware, giving new
developers plenty to work on with basic coding style cleanups to come
in the near future.
Other than that, nothing unusual here.
issues, other than an odd gcc warning for one of the new drivers that
should be fixed up soon"
[ I fixed up the warning myself - Linus ]
* tag 'staging-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (663 commits)
staging: kpc2000: kpc_spi: Fix build error for {read,write}q
Staging: rtl8192e: Remove extra space before break statement
Staging: rtl8192u: ieee80211: Fix if-else indentation warning
Staging: rtl8192u: ieee80211: Fix indentation errors by removing extra spaces
staging: most: cdev: fix chrdev_region leak in mod_exit
staging: wlan-ng: Fix improper SPDX comment style
staging: rtl8192u: ieee80211: Resolve ERROR reported by checkpatch
staging: vc04_services: bcm2835-camera: Compress two lines into one line
staging: rtl8723bs: core: Use !x in place of NULL comparison.
staging: rtl8723bs: core: Prefer using the BIT Macro.
staging: fieldbus: anybus-s: fix wait_for_completion_timeout return handling
staging: kpc2000: fix up build problems with readq()
staging: rtlwifi: move remaining phydm .h files
staging: rtlwifi: strip down phydm .h files
staging: rtlwifi: delete the staging driver
staging: fieldbus: anybus-s: rename bus id field to avoid confusion
staging: fieldbus: anybus-s: keep device bus id in bus endianness
Staging: sm750fb: Change *array into *const array
staging: rtl8192u: ieee80211: Fix spelling mistake
staging: rtl8192u: ieee80211: Replace bit shifting with BIT macro
A "real" driver for this hardware is now in the wireless-drivers-next
tree, to be merged in the next major kernel release, so this staging
driver can now be deleted as it is not needed anymore.
Note, 2 .h files remain for this driver, as they are referenced in a
separate staging driver. That mess will be cleaned up in a follow-on
patch.
Cc: Ping-Ke Shih <pkshih@realtek.com>
Cc: Tzu-En Huang <tehuang@realtek.com>
Cc: Yan-Hsuan Chuang <yhchuang@realtek.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Brian Norris <briannorris@chromium.org>
Cc: Kalle Valo <kvalo@codeaurora.org>
These drivers have been outside of the kernel tree since the 2.x days,
and it's time to bring them into the tree so they can get properly
cleaned up.
This first dump of drivers is based on a tarball Matt gave to me, minus
an odd "dma" driver that I could not get to build at all. I renamed a
few files, added the proper SPDX lines to it, added Kconfig entries and
tied it into the kernel build. I also fixed up a number of initial
obvious kernel build warnings, but left the odd bitfield warning that
gcc is spitting out, as I'm not quite sure what to do about that.
There's loads of low-hanging coding style cleanups in here for people to
start attacking, as well as the more obvious logic and api cleanups as
well.
Cc: Matt Sickler <Matt.Sickler@daktronics.com>
Fieldbus device (client) adapters allow data exchange with a PLC aka.
"Fieldbus Controller" over a fieldbus (Profinet, FLNet, etc.)
They are typically used when a Linux device wants to expose itself
as an actuator, motor, console light, switch, etc. over the fieldbus.
This framework is designed to provide a generic interface to Fieldbus
Devices from both the Linux Kernel and the userspace.
Signed-off-by: Sven Van Asbroeck <TheSven73@gmail.com>
Need rc5 for udl fix to add udl cleanups on top.
The license text in this driver is "interesting" and not really obvious
that it is supposed to be able to be distributed in the kernel source
tree. Yes, the MODULE_LICENSE() text says GPL, so it's probably ok, but
to be safe, I am deleting this driver. I will be glad to add it back if
the license is properly sorted out, but for now, this isn't worth the
potential risk, I should have never taken it in the first place.
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: NeilBrown <neil@brown.name>
Cc: George Hilliard <thirtythreeforty@gmail.com>
Cc: "Christian Lütke-Stetzkamp" <christian@lkamp.de>
Cc: Nishad Kamdar <nishadkamdar@gmail.com>
Cc: Sergej Perschin <ser.perschin@gmail.com>
Cc: John Crispin <blogic@openwrt.org>
This patch moves the MT7621 SPI driver, which is used on some Ralink /
MediaTek MT76xx MIPS SoC's, out of the staging directory. No changes to
the source code are done in this patch.
This driver version was tested successfully on an MT7688 based platform
with an SPI NOR on CS0 and an SPI NAND on CS1 without any issues (so
far).
This patch also documents the devicetree bindings for the MT7621 SPI
device driver.
Cc: Rob Herring <robh@kernel.org>
Cc: Mark Brown <broonie@kernel.org>
Cc: Sankalp Negi <sankalpnegi2310@gmail.com>
Cc: Chuanhong Guo <gch981213@gmail.com>
Cc: John Crispin <john@phrozen.org>
Cc: Armando Miraglia <arma2ff0@gmail.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for 5.2:
UAPI Changes:
- Add Colorspace connector property (Uma)
- fourcc: Several new YUV formats from ARM (Brian & Ayan)
- fourcc: Fix merge conflicts between new formats above and Swati's that
went in via topic/hdr-formats-2019-03-07 branch (Maarten)
Cross-subsystem Changes:
- Typed component support via topic/component-typed-2019-02-11 (Maxime/Daniel)
Core Changes:
- Improve component helper documentation (Daniel)
- Avoid calling drm_dev_unregister() twice on unplugged devices (Noralf)
- Add device managed (devm) drm_device init function (Noralf)
- Graduate TINYDRM_MODE to DRM_SIMPLE_MODE in core (Noralf)
- Move MIPI/DSI rate control params computation into core from i915 (David)
- Add support for shmem backed gem objects (Noralf)
Driver Changes:
- various: Use of_node_name_eq for node name comparisons (Rob Herring)
- sun4i: Add DSI burst mode support (Konstantin)
- panel: Add Ronbo RB070D30 MIPI/DSI panel support (Konstantin)
- virtio: A few prime improvements (Gerd)
- tinydrm: Remove tinydrm_device (Noralf)
- vc4: Add load tracker to driver to detect underflow in atomic check (Boris)
- vboxvideo: Move it out of staging \o/ (Hans)
- v3d: Add support for V3D v4.2 (Eric)
Cc: Konstantin Sudakov <k.sudakov@integrasources.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Uma Shankar <uma.shankar@intel.com>
Cc: Noralf Trønnes <noralf@tronnes.org>
Cc: Gerd Hoffmann <kraxel@redhat.com>
Cc: David Francis <David.Francis@amd.com>
Cc: Boris Brezillon <boris.brezillon@bootlin.com>
Cc: Eric Anholt <eric@anholt.net>
Cc: Brian Starkey <brian.starkey@arm.com>
Cc: Ayan Kumar Halder <ayan.halder@arm.com>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190321170805.GA50145@art_vandelay
driver/net/ethernet/mediatek/ now supports this hardware,
so we don't need a separate driver.
Signed-off-by: NeilBrown <neil@brown.name>
The vboxvideo driver has been converted to the atomic modesetting API
and all FIXME and TODO items have been fixed, so it is time to move it out
of staging.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20190304164724.10210-4-hdegoede@redhat.com
There has not been any real work done on cleaning this driver up and
getting it out of the staging tree in years. Also, no new fb drivers
are being added to the tree, so it should be converted into a drm driver
as well.
Due to the lack of interest in this codebase, just drop it.
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch>
These drivers can be useful on other MT76xx SoCs, which have compatible
peripherals. The drivers were selectable in Kconfig, but they were
quietly excluded from the build because the SOC_MT7621 chip was not
selected. So, make the Makefiles use the same flags as Kconfig for
these drivers.
mt7621-dma and mt7621-dts are left alone because they truly do require
that SoC.
I have personally confirmed that the mt7621-spi driver works on the
MT7688, which was what prompted this change.
Cc: devel@driverdev.osuosl.org
Cc: sergio.paracuellos@gmail.com
Signed-off-by: George Hilliard <thirtythreeforty@gmail.com>
This is in preparation to allow it and the mt7621-dma drivers to be
built separately. They are completely independent pieces of software,
and the Kconfig specifies very different requirements.
Cc: Neil Brown <neil@brown.name>
Phy part of the pci for this SoC can be handled using a generic phy
driver. This commit extracts phy part of the mt7621-pci into a new
'mt7621-pci-phy' driver.
Signed-off-by: Sergio Paracuellos <sergio.paracuellos@gmail.com>
A new SPI NAND subsystem has been added in drivers/mtd/nand/spi/ and
Micron's MT29F devices are now supported in
drivers/mtd/nand/spi/micron.c.
Remove the old driver.
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Digi does not support it, no one has hardware for it, and no one is
working on it, so let's drop it for now. If anyone wants to pick it
back up, then can revert this patch.
Reported-by: Lidza Louina <lidza.louina@gmail.com>
Reported-by: Mark Hounschell <markh@compro.net>
Pull ARM SoC driver updates from Olof Johansson:
"Some of the larger changes this merge window:
- Removal of drivers for Exynos5440, a Samsung SoC that never saw
widespread use.
- Uniphier support for USB3 and SPI reset handling
- Syste control and SRAM drivers and bindings for Allwinner platforms
- Qualcomm AOSS (Always-on subsystem) reset controller drivers
- Raspberry Pi hwmon driver for voltage
- Mediatek pwrap (pmic) support for MT6797 SoC"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (52 commits)
drivers/firmware: psci_checker: stash and use topology_core_cpumask for hotplug tests
soc: fsl: cleanup Kconfig menu
soc: fsl: dpio: Convert DPIO documentation to .rst
staging: fsl-mc: Remove remaining files
staging: fsl-mc: Move DPIO from staging to drivers/soc/fsl
staging: fsl-dpaa2: eth: move generic FD defines to DPIO
soc: fsl: qe: gpio: Add qe_gpio_set_multiple
usb: host: exynos: Remove support for Exynos5440
clk: samsung: Remove support for Exynos5440
soc: sunxi: Add the A13, A23 and H3 system control compatibles
reset: uniphier: add reset control support for SPI
cpufreq: exynos: Remove support for Exynos5440
ata: ahci-platform: Remove support for Exynos5440
soc: imx6qp: Use GENPD_FLAG_ALWAYS_ON for PU errata
soc: mediatek: pwrap: add mt6351 driver for mt6797 SoCs
soc: mediatek: pwrap: add pwrap driver for mt6797 SoCs
soc: mediatek: pwrap: fix cipher init setting error
dt-bindings: pwrap: mediatek: add pwrap support for MT6797
reset: uniphier: add USB3 core reset control
dt-bindings: reset: uniphier: add USB3 core reset support
Pull staging and IIO updates from Greg KH:
"Here are the big staging/iio patches for 4.19-rc1.
Lots of churn here, with tons of cleanups happening in staging
drivers, a removal of an old crypto driver that no one was using
(skein), and the addition of some new IIO drivers. Also added was a
"gasket" driver from Google that needs loads of work and the erofs
filesystem.
Even with adding all of the new drivers and a new filesystem, we are
only adding about 1000 lines overall to the kernel linecount, which
shows just how much cleanup happened, and how big the unused crypto
driver was.
All of these have been in the linux-next tree for a while now with no
reported issues"
* tag 'staging-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (903 commits)
staging:rtl8192u: Remove unused macro definitions - Style
staging:rtl8192u: Add spaces around '+' operator - Style
staging:rtl8192u: Remove stale comment - Style
staging: rtl8188eu: remove unused mp_custom_oid.h
staging: fbtft: Add spaces around / - Style
staging: fbtft: Erases some repetitive usage of function name - Style
staging: fbtft: Adjust some empty-line problems - Style
staging: fbtft: Removes one nesting level to help readability - Style
staging: fbtft: Changes gamma table to define.
staging: fbtft: A bit more information on dev_err.
staging: fbtft: Fixes some alignment issues - Style
staging: fbtft: Puts macro arguments in parenthesis to avoid precedence issues - Style
staging: rtl8188eu: remove unused array dB_Invert_Table
staging: rtl8188eu: remove whitespace, add missing blank line
staging: rtl8188eu: use is_multicast_ether_addr in rtw_sta_mgt.c
staging: rtl8188eu: remove whitespace - style
staging: rtl8188eu: cleanup block comment - style
staging: rtl8188eu: use is_multicast_ether_addr in rtl8188eu_xmit.c
staging: rtl8188eu: use is_multicast_ether_addr in recv_linux.c
staging: rtlwifi: refactor rtl_get_tcb_desc
This commit adds Makefile and Kconfig for erofs, and
updates Makefile and Kconfig files in the fs directory.
Signed-off-by: Miao Xie <miaoxie@huawei.com>
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Remove the staging/drivers/fsl-mc directory from the staging
area now that all the components have been moved to the main
kernel areas.
Signed-off-by: Roy Pledge <roy.pledge@nxp.com>
Reviewed-by: Horia Geantă <horia.geanta@nxp.com>
Reviewed-by: Ioana Radulescu <ruxandra.radulescu@nxp.com>
Signed-off-by: Li Yang <leoyang.li@nxp.com>
This IP core has read and write AXI-Stream FIFOs, the contents of which can
be accessed from the AXI4 memory-mapped interface. This is useful for
transferring data from a processor into the FPGA fabric. The driver creates
a character device that can be read/written to with standard
open/read/write/close.
See Xilinx PG080 document for IP details.
https://www.xilinx.com/support/documentation/ip_documentation/axi_fifo_mm_s/v4_1/pg080-axi-fifo-mm-s.pdf
The driver currently supports only store-forward mode with a 32-bit
AXI4 Lite interface. DOES NOT support:
- cut-through mode
- AXI4 (non-lite)
Signed-off-by: Jacob Feder <jacobsfeder@gmail.com>
Remove driver from staging. It has been accepted in
the linux-gpio tree.
The Gasket (Google ASIC Software, Kernel Extensions, and Tools) kernel
framework is a generic, flexible system that supports thin kernel
drivers. Gasket kernel drivers are expected to handle opening and
closing devices, mmap'ing BAR space as requested, a small selection of
ioctls, and handling page table translation (covered below). Any other
functions should be handled by userspace code.
The Gasket common module is not enough to run a device. In order to
customize the Gasket code for a given piece of hardware, a device
specific module must be created. At a minimum, this module must define a
struct gasket_driver_desc containing the device-specific data for use by
the framework; in addition, the module must declare an __init function
that calls gasket_register_device with the module's gasket_driver_desc
struct. Finally, the driver must define an exit function that calls
gasket_unregister_device with the module's gasket_driver_desc struct.
One of the core assumptions of the Gasket framework is that precisely
one process is allowed to have an open write handle to the device node
at any given time. (That process may, once it has one write handle, open
any number of additional write handles.) This is accomplished by
tracking open and close data for each driver instance.
Signed-off-by: Rob Springer <rspringer@google.com>
Signed-off-by: John Joseph <jnjoseph@google.com>
Signed-off-by: Simon Que <sque@chromium.org>
It's been four years since this was added. In the interim, skein has
not seen any mainstream adoption. Same with the threefish block cipher
upon which it's based.
In the discussion over which hash algorithm will replace SHA1 in git,
it's not one of the contenders.
There's absolutely no reason to think that there is anything wrong with
Skein or Threefish. The only reason for this removal is a lack of
adoption.
If a real user comes forward, I'd be happy to assist with integrating
this code into mainline.
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Move TCPCI(Typec port controller interface) driver and rt1711h
driver out of staging.
Signed-off-by: Li Jun <jun.li@nxp.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
The ipx code moved into the staging tree back in November 2017 and no
one has complained or even noticed it was gone. Because of that, let's
just delete it.
Note, the ipx header files are not removed here, that will come later
through the networking tree, as that takes a bit more work to unwind.
Cc: Stephen Hemminger <stephen@networkplumber.org>
The ncpfs code moved into the staging tree back in November 2017 and no
just delete it.
The Lustre filesystem has been in the kernel tree for over 5 years now.
While it has been an endless source of enjoyment for new kernel
developers learning how to do basic codingstyle cleanups, as well as an
semi-entertaining source of bewilderment from the vfs developers any
time they have looked into the codebase to try to figure out how to port
their latest api changes to this filesystem, it has not really moved
forward into the "this is in shape to get out of staging" despite many
half-completed attempts.
And getting code out of staging is the main goal of that portion of the
kernel tree. Code should not stagnate and it feels like having this
code in staging is only causing the development cycle of the filesystem
to take longer than it should. There is a whole separate out-of-tree
copy of this codebase where the developers work on it, and then random
changes are thrown over the wall at staging at some later point in time.
This dual-tree development model has never worked, and the state of this
codebase is proof of that.
So, let's just delete the whole mess. Now the lustre developers can go
off and work in their out-of-tree codebase and not have to worry about
providing valid changelog entries and breaking their patches up into
logical pieces. They can take the time they have spend doing those
types of housekeeping chores and get the codebase into a much better
shape, and it can be submitted for inclusion into the real part of the
kernel tree when ready.
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: James Simmons <jsimmons@infradead.org>
Add device tree source for mt7621 and gnubee1 to
make testing easier.
This patch adds the Makefile and Kconfig required to make the driver build.
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Michael Lee <igvtee@gmail.com>
NeilBrown:
Added range-check on pdev->id before assigning ot
host->id
of_dma_configure() sets a default ->dma_mask of
DMA_BIT_MASK(32), claiming devices can DMA from
the full 32bit address space.
The mtk-mmc driver does not support access to
highmem pages, so it is really limited to the
bottom 512M (actually 448M due to 64M of IO space).
Setting ->dma_mask to NULL causes mmc_setup_queue()
to fall-back to using BLK_BOUNCE_HIGH to tell the
block layer to use a bounce-buffer for any highmem
pages requiring IO.
NeilBrown:
The code will fail with a warning if asked to transfer
more than 32 bytes at a time. So used max_transfer_size
interface to tell users about this.
