binder_deferred_release was not unmapping the page from the buffer
before freeing it, causing memory corruption. This only happened
when page(s) had not been freed by binder_update_page_range, which
properly unmaps the pages.
This only happens on architectures with VIPT aliasing.
To reproduce, create a program which opens, mmaps, munmaps, then closes
the binder very quickly. This should leave a page allocated when the
binder is released. When binder_deferrred_release is called on the
close, the page will remain mapped to the address in the linear
proc->buffer. Later, we may map the same physical page to a different
virtual address that has different coloring, and this may cause
aliasing to occur.
PAGE_POISONING will greatly increase your chances of noticing any
problems.
Change-Id: I6941bf212881b8bf846bdfda43d3609c7ae4892e
Signed-off-by: Christopher Lais <chris+android@zenthought.org>
Some drivers flush the global workqueue when closed. This would deadlock if
the last reference to the file was released from the binder.
Change-Id: Ifdabc0b383fecb20836d1bbb9786c632402a14e1
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Change-Id: Ia0f9c8cec68054c6600a799ef864ebf1185c93ab
Change-Id: I6e9c064ba024329099cb833b2ae9ab43c2ad8c6d
This reverts commit b0a0ccfad85b3657fe999805df65f5cfe634ab8a.
These drivers are no longer being developed and the original authors
seem to have abandonded them and hence, do not want them in the mainline
kernel tree.
So sad :(
Cc: Brian Swetland <swetland@google.com>
This was done using a semantic patch (http://coccinelle.lip6.fr/) that
checks that the declaration is not inside a function definition, that the
defined variable is not exported using EXPORTED_SYMBOL, etc, and that the
defined variable does not occur in any other file. If these conditions
hold, static is added before the declaration.
Clean up 3 or so checkpatch errors from one of my prior patches.
Signed-off-by: Daniel Walker <dwalker@fifo99.com>
Cc: Arve Hjønnevåg <arve@android.com>
This file has a lot of long line problems due to the massive indent issues
that exist. This just cleans up some of the really really long ones.
An initial cleanup of all the binder_stat statements. The binder
command and return stats still need some assistance tho.
Replaced a manual hlist_head declaration with a macro based one.
Also reorganized the globals to be grouped better.
Declare the binder_deferred_state enum, and use the new enum
for one of the binder_defer_work function arguments. This
should keep the argument within the confines of the enum
instead of the whole int range.
I removed the binder_transaction_buffer_release predefine, and put
the actual function in place of it.
I moved the continual,
if (binder_debug_mask & mask)
printk()
into a single macro so it's all in one place. It could be refined further
from there.
This cleans up the majority of the checkpatch warnings in the android
binder driver. All that is left now is a bunch of too-long-line stuff.
Cc: San Mehat <san@android.com>
If a transaction that contains a file descriptor fails on a later object,
the new file descriptor needs to be closed. If this is a binder file
descriptor we would deadlock in flush. If there were no other references to
the file at this point release would also be called.
stack.
If a thread is part of a transaction stack, it is only allowed to make
another call if it was the target of the top transaction on the stack.
mmapped
This prevents breaking fget_light if a single threaded application
allows incoming file descriptors (in replies or on nodes).
Should also prevent inserting a file in the wrong files_struct if the
receving process execs in the middle of a transaction (between
task_get_unused_fd_flags and task_fd_install).
Check that datasize is not smaller than one flat_binder_object.
Check that offsets are aligned.
Check that offsets_size is aligned.
Only allow a binder file pointer to be mmapped once. The buffer management
code cannot deal with more then one area.
Also remove leftover mutex_unlock if mmap fails.
driver is opened twice in one process.
Many platforms do not support mappings without VM_EXEC.
Fix printk format warnings in android binder:
drivers/staging/android/binder.c:2652: warning: format '%lx' expects type 'long unsigned int', but argument 7 has type 'pgprotval_t'
drivers/staging/android/binder.c:2659: warning: format '%lx' expects type 'long unsigned int', but argument 7 has type 'pgprotval_t'
drivers/staging/android/binder.c:2680: warning: format '%lx' expects type 'long unsigned int', but argument 7 has type 'pgprotval_t'
Compile tested.
task_struct->signal is not protected by RCU, the code is bogus.
Change the code to take ->siglock to pin ->signal.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
This fixes the build errors and warnings in the binder driver. It can't
be a module, due to a lack of some of the symbols being exported.
Also added a MODULE_LICENSE(), as it was missing.
Cc: Robert Love <rlove@google.com>
Task credentials were moved and must be accessed through task_struct.cred
Signed-off-by: J.R. Mauro <jrm8005@gmail.com>
for size_t in printk
Use the proper format specifiers for printing size_t values.
It builds, but not as a module, and with lots of warnings.
I also had to fix up a few syntax errors to get it to build
properly, I'm doubting that anyone has built it in a while :(
Signed-off-by: Brian Swetland <swetland@google.com>
