This fixes the following warnings:
1: Changes a printk(KERN_ERR) call to a pr_err call in line 785
2: Changes a printk(KERN_ERR) call to a pr_err call in line 791
3: Changes a printk(KERN_ERR) call to a pr_err call in line 798
4: Reduces line length below 80 at line 785 (Not intended)
5: Reduces line length below 80 at line 798 (Not intended)
Signed-off-by: Cruz Julian Bishop <cruz@massive-dynamics.biz>
err() was a very old USB-specific macro that I thought had
gone away. This patch removes it from being used in the
driver and uses dev_err() instead.
CC: Jakub Schmidtke <sjakub@gmail.com>
CC: Pekka Paalanen <pq@iki.fi>
CC: Peter Huewe <peterhuewe@gmx.de>
CC: "Ken O'Brien" <kernel@kenobrien.org>
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and
is no longer parsed by new kmod tool. References to this file are
replaced in Documentation, comments and Kconfig according to the
context.
There are also some references to the old /etc/modules.conf from 2.4
kernels that are being removed.
Acked-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This patch removes a superfluous loop in asus_oled.c
The code is equivalent to do{...} while (0) and thus executes the code
exactly once -> so we can simply remove the loop.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Asus_oled triggers the following bug on module unloading:
usbcore: deregistering interface driver asus-oled
BUG: unable to handle kernel NULL pointer dereference at 0000000000000038
IP: [<ffffffff8111292b>] sysfs_delete_link+0x30/0x66
Call Trace:
[<ffffffff81225373>] device_remove_class_symlinks+0x6b/0x70
[<ffffffff812256a8>] device_del+0x9f/0x1ab
[<ffffffff812257c5>] device_unregister+0x11/0x1e
[<ffffffffa000cb82>] asus_oled_disconnect+0x4f/0x9e [asus_oled]
[<ffffffff81277430>] usb_unbind_interface+0x54/0x103
[<ffffffff812276c4>] __device_release_driver+0xa2/0xeb
[<ffffffff81227794>] driver_detach+0x87/0xad
[<ffffffff812269e9>] bus_remove_driver+0x91/0xc1
[<ffffffff81227fb4>] driver_unregister+0x66/0x6e
[<ffffffff812771ed>] usb_deregister+0xbb/0xc4
[<ffffffffa000ce87>] asus_oled_exit+0x2f/0x31 [asus_oled]
[<ffffffff81068365>] sys_delete_module+0x1b8/0x21b
[<ffffffff810ae3de>] ? do_munmap+0x2ef/0x313
[<ffffffff813699bb>] system_call_fastpath+0x16/0x1b
This is due to an incorrect destruction sequence in asus_oled_exit().
Fix the order, fixes the bug. Tested on an Asus G50V laptop only.
Cc: Jakub Schmidtke <sjakub@gmail.com>
Signed-off-by: Pekka Paalanen <pq@iki.fi>
Cc: stable <stable@vger.kernel.org>
Programming an image was broken, because odev->buf_offs was not advanced
for val == 0 in append_values(). This regression was introduced in:
commit 1ff12a4aa354bed093a0240d5e6347b1e27601bc
Author: Kevin A. Granade <kevin.granade@gmail.com>
Date: Sat Sep 5 01:03:39 2009 -0500
Staging: asus_oled: Cleaned up checkpatch issues.
Fix the image processing by special-casing val == 0.
I have tested this change on an Asus G50V laptop only.
Cc: Kevin A. Granade <kevin.granade@gmail.com>
Removed use of obsolete function "strict_strtoul". Replaced with "kstrtoul"
as suggested by checkpatch.pl
Signed-off-by: Ken O'Brien <kernel@kenobrien.org>
This was done to handle a number of conflicts in the batman-adv
and winbond drivers properly. It also now allows us to fix up the sysfs
attributes properly that were not in the .37 release due to them being
only in this tree at the time.
They should be writable by root, not readable.
Doh, stupid me with the wrong flags.
Reported-by: Jonathan Cameron <jic23@cam.ac.uk>
Cc: stable <stable@kernel.org>
They should not be writable by any user
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
This is a patch to the asus_oled.c file that fixes up brace and enum
warning found by the checkpatch.pl tool
Signed-off-by: Johan Meiring <johanmeiring@gmail.com>
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
drivers/staging/asus_oled/asus_oled.c:774: ERROR: code indent should use tabs where possible
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Convert some drivers who export a single string as class attribute
to the new class_attr_string functions. This removes redundant
code all over.
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
This makes the class attributes the same as sysdev_class attributes
and plain attributes.
This will allow further cleanups in drivers.
Full tree sweep converting all users.
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
Cc: cocci@diku.dk
This patch adds a NULL test to check wether kmalloc was successful or
not.
consistent with hid-ids.h
This almost trivial patch replaces the hardcoded values for the vendor and
device ids with defines, as they are used in drivers/hid/hid-ids.h
For me this seems to be more consistent, however as drivers/hid/hid-ids.h
is not within the default include directory I had to redefine the defines here
(maybe move the hid-ids.h to include/linux ?)
After updating to 2.6.32 kernel, I started experiencing Oopses caused by
the asus_oled module. After quick investigation, I wrapped this simple
patch which fixes an Oops in by asus_oled module on 2.6.32.2 kernel,
caused by incorrect usage of strict_strtoul function call within
set_enabled and set_disabled functions. This can be triggered by simple
running the userspace client for asus_old (e.g., 'asusoled -e' or
'asusoled -d').
Signed-off-by: Eugeni Dodonov <eugeni@mandriva.com>
Signed-off-by: Kevin A. Granade <kevin.granade@gmail.com>
Cc: Belisko Marek <marek.belisko@gmail.com>
This fixes some build warnings in the asus_oled driver.
This fixes some errors reported by checkpatch.pl
Signed-off-by: Andre Haupt <andre@bitwigglers.org>
obsolete spaces
fix the following error reported by checkpatch.pl
ERROR: trailing statements should be on next line
ERROR: do not initialise statics to 0 or NULL
pointer
asus_oled depends on the CONFIG_USB_SUPPORT, I have only build tested
the patch.
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Driver for the OLED tiny display on some Asus laptops.
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
