git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (741 commits)
staging:iio:meter:ade7753 should be 16 bit read not 8 bit for mode register.
staging:iio:kfifo_buf fix double initialization of the ring device structure.
staging:iio:accel:lis3l02dq: fix incorrect pointer passed to spi_set_drvdata.
staging:iio:imu fix missing register table index for some channels
spectra: enable device before poking it
staging: rts_pstor: Fix a miswriting
staging/lirc_bt829: Return -ENODEV when no hardware is found.
staging/lirc_parallel: remove pointless prototypes.
staging/lirc_parallel: fix panic on rmmod
staging:iio:adc:ad7476: Incorrect pointer into spi_set_drvdata.
Staging: zram: Fix kunmapping order
Revert "gma500: Fix dependencies"
gma500: Add medfield header
gma500: wire up the mrst i2c bus from chip_info
gma500: Fix DPU build
gma500: Clean up the DPU config and make it runtime
gma500: resync with Medfield progress
gma500: Use the mrst helpers and power control for mode commit
gma500@ Fix backlight range error
gma500: More Moorestown muddle meddling means MM maybe might modeset
Fix up fairly trivial conflicts all over, mostly due to header file
cleanup conflicts, but some deleted files and some just context changes:
- Documentation/feature-removal-schedule.txt
- drivers/staging/bcm/headers.h
- drivers/staging/brcm80211/brcmfmac/dhd_linux.c
- drivers/staging/brcm80211/brcmfmac/dhd_sdio.c
- drivers/staging/brcm80211/brcmfmac/wl_cfg80211.h
- drivers/staging/brcm80211/brcmfmac/wl_iw.c
- drivers/staging/et131x/et131x_netdev.c
- drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c
- drivers/staging/rtl8192e/r8192E.h
- drivers/staging/usbip/userspace/src/utils.h
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
The third parameter of module_param is supposed to represent sysfs
file permissions. A value of "1" makes no sense.
I am changing it to "0" to align with the other module parameters in
this driver.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Henry Ptasinski <henryp@broadcom.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Roland Vossen <rvossen@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
The implicit include of linux/interrupt.h is being removed from
netdevice.h.
Some macros were missing a terminating '\n' character. This commit fixes
those.
Reported-by: Dan Carpenter <error27@gmail.com>
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
Replaced two functions with strcpy().
The script checkpatch.pl flagged for some extern variables in
dhd_linux.c source. Several have been fixed in this patch. Two
remaining are in macro conditional code that needs cleanup so
they are not resolved here.
Reviewed-by: Roland Vossen <rvossen@broadcom.com>
SDIOH_API_ACCESS_RETRY_LIMIT is always defined.
And deleted unused definitions. Improves code since it makes clear that the
definitions are only used by a specific .c file.
Having both a 'generic' as a 'linux' specific variant of a file makes
no sense in a Linux environment. Merged bcmsdh_sdmmc_linux.c into
bcmsdh_sdmmc.c, and bcmsdh_linux.c into bcmsdh.c.
WLC (caps) was replaced, wlc (small caps) has not been replaced yet.
The driver sources contained a couple of checkpatch warnings of the
given class. These have been cleaned up.
Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
ASSERTs are non desirable, replaced by error handling where applicable.
The header file dhd_dbg.h contains several macros used throughout
the code starting with DHD_. These have been renamed to get rid
of this broadcom specific acronym.
CONFIG_MACH_SANDGATE2G, CONFIG_MMC_MSM7X00A,
CONFIG_HAS_EARLYSUSPEND and CONFIG_WIFI_CONTROL_FUNC were never
defined.
DHD is a Broadcom internal term and has been replaced by BRCMF.
A checkpatch error was introduced in following commit:
0f22b8a staging: brcm80211: remove MMC_SDIO_ABORT macro definition
The patch gets rid of the error.
Renamed external function getting rid of wl_ prefix. Removed unused
function from the API header file wl_cfg80211.h as it was not defined.
Reviewed-by: Franky Lin <frankyl@broadcom.com>
The data structures in fullmac driver references are made easier by
using provided macros in wl_cfg80211.h. The abbreviation 'wl' in these
macros has been replaced by cfg or the macro has been removed if used
only once.
Making an effort getting rid of the wl_ prefix from the fullmac source
files.
Signed-off-by: Roland Vossen <rvossen@broadcom.com>
Reviewed-by: Arend van Spriel <arend@broadcom.com>
Code cleanup. W_REG was defined the same for both big and little endian systems.
Replaced W_REG on two spots with its expansion.
Code cleanup. Warnings were due to pointer declarations being used for an
address that does not reside on the CPU bus.
Code cleanup. Decreases amd64 compiler warnings.
Code cleanup. Leads to more readable code and better type checking.
Code cleanup. Fullmac contains macro's that access registers on the 32 bits
backplane bus. These registers should not be declared as pointers since
pointers can be 64 bits. The following patch series gets rid of these pointers
and ultimately of all compiler warning when compiling for amd64.
Code cleanup.
Code cleanup.
The header file dhd_bus.h contains several function prototypes
starting with dhd_bus_ and using parameter with struct dhd_bus.
These function and structure have been renamed to brcmf_bus.
This commit gets rid of variables whose name is a broadcom specific
acronym and not very meaningful.
Code cleanup. Deleted unused definitions. Moved locally used definitions to
.c files. Moved definitions from bcmsdh_sdmmc.h to bcmsdbus.h.
Code cleanup. Contents merged into other files.
Code cleanup. These functions were empty.
Code cleanup. This function did not perform a reset, hence it was removed.
Code cleanup. This function always returned 0.
Gave struct brcmf_sdio the more applicable name 'brcmf_sdio_card'. Enforced
stronger type checking by replacing void *sdh by struct brcmf_sdio_card *.
Code cleanup. This was a Broadcom specific acronym.
Code cleanup. Replaced Broadcom proprietary error codes with Linux native
ones.
The static functions in wl_cfg80211.c starting with wl_ prefix have
been renamed starting with brcmf_ prefix to be consistent.
cleanup of some unused macros.
Code cleanup.
