A previous set of patches by Ravishankar Karkala Mallikarjunayya
replaced a load of printk() calls with dev_info(), dev_err(), etc.
Unfortunately, these used the 'struct device *hw_dev' member of 'struct
comedi_device') as the first parameter of these dev_...() calls, but
that pointer is usually NULL, so the kernel log messages come out a bit
wrong (they contain the phrase "(NULL device *)").
Use the 'struct device *class_dev' member of 'struct comedi_device'
instead for these dev_...() calls. It will be non-NULL and somewhat
meaningful to users. It's also consistent with those comedi drivers
that already use the class_dev member in their dev_...() calls.
Some of the messages included the format "comedi%d" with the minor
device number used for the "%d". This is now redundant as it will be
the same as the dev_name() part of the kernel log message produced by
the dev_...() calls.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
1. Change the return type from int to void
All the detach functions, except for the comedi usb drivers, simply
return success (0). Plus, the return code is never checked in the
comedi core.
The comedi usb drivers do return error codes but the conditions can
never happen.
The first check is:
if (!dev)
return -EFAULT;
This checks that the passed comedi_device pointer is valid. The detach
function itself is called using this pointer so it MUST always be valid
or there is a bug in the core:
if (dev->driver)
dev->driver->detach(dev);
And the second check:
usb = dev->private;
if (!usb)
return -EFAULT;
The dev->private pointer is setup in the attach function to point to the
probed usb device. This value could be NULL if the attach fails. But,
since the comedi core is going to unload the driver anyway and does not
check for errors there is no gain by returning one.
After removing these checks from the comedi usb drivers the detach
functions required a bit of cleanup.
2. Remove all the printk noise in the detach functions
All of the printk output is really just noise. The user did a rmmod to
unload the driver, we really don't need to tell them about it.
Also, some of the messages are output using:
dev_dbg(dev->hw_dev, ...
or
dev_info(dev->hw_dev, ...
Unfortunately the hw_dev value is only used by drivers that are doing
DMA. For most drivers this variable is going to be NULL so the output
is not going to work as expected.
3. Refactor a couple static 'free_resource' functions into the detach
functions.
The 'free_resource' function is only being called by the detach and it
makes more sense to just absorb the code.
4. Remove a couple unnecessary braces for single statements.
5. Remove unnecessary comments.
Most of the comedi drivers appear to be based on the comedi skel driver
and have the comments from that driver included. These comments make
sense in the skel driver for reference but they don't need to be in any
of the actual drivers.
6. Remove all the extra whitespace.
It's not needed to make the functions any more readable.
7. Remove the now unused 'attached_successfully' variable in the
cb_pcimdda driver.
This variable was only used to conditionally output some driver noise
during the detach. Since all the printk's have been removed this
variable is no longer necessary.
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: Mori Hess <fmhess@users.sourceforge.net>
Move the module_init/module_exit routines and the associated
struct comedi_drive and struct pci_driver to the end of the
source. This is more typical of how other drivers are written and
removes the need for the forward declarations.
Convert the driver to use the module_comedi_pci_driver() macro
which makes the code smaller and a bit simpler.
The comedi_pci_auto_config() and comedi_usb_auto_config() functions
currently take a board name parameter which is actually a driver name
parameter. Replace it with a pointer to the struct comedi_driver. This
will allow comedi_pci_auto_config() and comedi_usb_auto_config() to call
bus-type-specific auto-configuration hooks in the struct comedi_driver
if they exist (they don't yet). The idea is that these
bus-type-specific auto-configuration hooks won't have to search the bus
for the device being auto-configured like 'attach()' hook has to.
Paul Fulmek reports that PXIe-6251 works the same as the existing
PCIe-6251 and just needs the new PCI device ID adding to ni_pci_table[]
and a new entry adding to ni_boards[] based on the existing entry for
PCIe-6251.
The new entry has PCI device ID 0x72e8 and board name "pxie-6251".
Thanks Paul!
This is a patch to the ni_pcimio.c file that fixes up a printk
warning found by the checkpatch.pl tool.
Signed-off-by: Ravishankar Karkala Mallikarjunayya <ravishankar.km@greenturtles.in>
Converted printks to dev_<level> and pr_<level>.
This is a patch to the ni_pcimio.c file that fixes up a brace
As mentioned by W. Trevor King on the devel@linuxdriverproject.org list
on "Thu, 27 Jan 2011 18:52:15 -0500", "Message-ID:
<20110127235214.GA5107@thialfi.dhcp.drexel.edu>", the ni_pcimio module
is missing module metadata, including a license.
This patch adds module metadata to all the NI comedi driver modules. It
also removes a duplicate MODULE_LICENSE("GPL") line from the "mite"
module.
Cc: W. Trevor King <wking@drexel.edu>
Move the PCI devinit/devexit routines to the respective C source files
instead of calling COMEDI_PCI_INITCLEANUP
Signed-off-by: Arun Thomas <arun.thomas@gmail.com>
Don't redefine something that we already have in the core
kernel. Also move to use PCI_DEVICE() macros to make things
a bit simpler when changing the define.
Signed-off-by: Frank Mori Hess <fmhess@users.sourceforge.net>
These changes were a direct result of using a semantic patch
More information can be found at http://www.emn.fr/x-info/coccinelle/
Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu>
Lindent changes to comdi driver in staging tree.
This patch is followed by the checkpatch.pl error fixes.
Did not make them part of this patch as the patch size is already huge.
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
There are a number of comedi "wrappers" for some RT functions that are
about to go away. This patch removes all of the wrapper calls within
the comedi drivers and core in order to prepare for removing the RT
comedi code.
Cc: Frank Mori Hess <fmhess@users.sourceforge.net>
Change from the foo: bar format to the .foo = bar format.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Alessio Igor Bogani <abogani@texware.it>
This fixes compilation of ni_mio_cs.c that was broken.
Added PXI-6224 based on report by Romain Bossart of equivalence to PCI-6224.
Cc: David Schleef <ds@schleef.org>
m-series boards
Nothing is done with it yet, eventually it will be made available to
user-space via a readable file in sysfs.
From: Frank Mori Hess <fmhess@users.sourceforge.net>
Hardware driver for NI PCI-MIO E series cards
Supports PCI-MIO-16XE-10, PXI-6030E, PCI-MIO-16E-1, PCI-MIO-16E-4,
PCI-6014, PCI-6040E, PXI-6040E, PCI-6030E, PCI-6031E, PCI-6032E,
PCI-6033E, PCI-6071E, PCI-6023E, PCI-6024E, PCI-6025E, PXI-6025E,
PCI-6034E, PCI-6035E, PCI-6052E, PCI-6110, PCI-6111, PCI-6220,
PCI-6221, PCI-6224, PCI-6225, PCI-6229, PCI-6250, PCI-6251, PCIe-6251,
PCI-6254, PCI-6259, PCIe-6259, PCI-6280, PCI-6281, PXI-6281, PCI-6284,
PCI-6289, PCI-6711, PXI-6711, PCI-6713, PXI-6713, PXI-6071E,
PCI-6070E, PXI-6070E, PXI-6052E, PCI-6036E, PCI-6731, PCI-6733,
PXI-6733, PCI-6143, PXI-6143
