commit a56d3e40bda460edf3f8d6aac00ec0b322b4ab83 upstream.
USB bulk and interrupt message timeouts are specified in milliseconds
and should specifically not vary with CONFIG_HZ.
Note that the bulk-out transfer timeout was set to the endpoint
bInterval value, which should be ignored for bulk endpoints and is
typically set to zero. This meant that a failing bulk-out transfer
would never time out.
Assume that the 10 second timeout used for all other transfers is more
than enough also for the bulk-out endpoint.
Fixes: 985cafccbf9b ("Staging: Comedi: vmk80xx: Add k8061 support")
Fixes: 951348b37738 ("staging: comedi: vmk80xx: wait for URBs to complete")
Cc: stable@vger.kernel.org # 2.6.31
Signed-off-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
Link: https://lore.kernel.org/r/20211025114532.4599-6-johan@kernel.org
commit 78cdfd62bd54af615fba9e3ca1ba35de39d3871d upstream.
The driver is using endpoint-sized buffers but must not assume that the
tx and rx buffers are of equal size or a malicious device could overflow
the slab-allocated receive buffer when doing bulk transfers.
Link: https://lore.kernel.org/r/20211025114532.4599-5-johan@kernel.org
commit a23461c47482fc232ffc9b819539d1f837adf2b1 upstream.
The driver uses endpoint-sized USB transfer buffers but up until
recently had no sanity checks on the sizes.
Commit e1f13c879a7c ("staging: comedi: check validity of wMaxPacketSize
of usb endpoints found") inadvertently fixed NULL-pointer dereferences
when accessing the transfer buffers in case a malicious device has a
zero wMaxPacketSize.
Make sure to allocate buffers large enough to handle also the other
accesses that are done without a size check (e.g. byte 18 in
vmk80xx_cnt_insn_read() for the VMK8061_MODEL) to avoid writing beyond
the buffers, for example, when doing descriptor fuzzing.
The original driver was for a low-speed device with 8-byte buffers.
Support was later added for a device that uses bulk transfers and is
presumably a full-speed device with a maximum 64-byte wMaxPacketSize.
Link: https://lore.kernel.org/r/20211025114532.4599-4-johan@kernel.org
commit 907767da8f3a925b060c740e0b5c92ea7dbec440 upstream.
The driver uses endpoint-sized USB transfer buffers but had no sanity
checks on the sizes. This can lead to zero-size-pointer dereferences or
overflowed transfer buffers in ni6501_port_command() and
ni6501_counter_command() if a (malicious) device has smaller max-packet
sizes than expected (or when doing descriptor fuzz testing).
Add the missing sanity checks to probe().
Fixes: a03bb00e50ab ("staging: comedi: add NI USB-6501 support")
Cc: stable@vger.kernel.org # 3.18
Cc: Luca Ellero <luca.ellero@brickedbrain.com>
Link: https://lore.kernel.org/r/20211027093529.30896-2-johan@kernel.org
commit 536de747bc48262225889a533db6650731ab25d3 upstream.
USB transfer buffers are typically mapped for DMA and must not be
allocated on the stack or transfers will fail.
Allocate proper transfer buffers in the various command helpers and
return an error on short transfers instead of acting on random stack
data.
Note that this also fixes a stack info leak on systems where DMA is not
used as 32 bytes are always sent to the device regardless of how short
the command is.
Fixes: 63274cd7d38a ("Staging: comedi: add usb dt9812 driver")
Cc: stable@vger.kernel.org # 2.6.29
Link: https://lore.kernel.org/r/20211027093529.30896-3-johan@kernel.org
[ Upstream commit d2d106fe3badfc3bf0dd3899d1c3f210c7203eab ]
request_irq() wont accept a name which contains slash so we need to
repalce it with something else -- otherwise it will trigger a warning
and the entry in /proc/irq/ will not be created
since the .name might be used by userspace and we don't want to break
userspace, so we are changing the parameters passed to request_irq()
[ 1.565966] name 'pci-das6402/16'
[ 1.566149] WARNING: CPU: 0 PID: 184 at fs/proc/generic.c:180 __xlate_proc_name+0x93/0xb0
[ 1.568923] RIP: 0010:__xlate_proc_name+0x93/0xb0
[ 1.574200] Call Trace:
[ 1.574722] proc_mkdir+0x18/0x20
[ 1.576629] request_threaded_irq+0xfe/0x160
[ 1.576859] auto_attach+0x60a/0xc40 [cb_pcidas64]
Suggested-by: Ian Abbott <abbotti@mev.co.uk>
Signed-off-by: Tong Zhang <ztong0001@gmail.com>
Link: https://lore.kernel.org/r/20210315195814.4692-1-ztong0001@gmail.com
[ Upstream commit 2e5848a3d86f03024ae096478bdb892ab3d79131 ]
[ 1.630764] name 'pci-das1602/16'
[ 1.630950] WARNING: CPU: 0 PID: 181 at fs/proc/generic.c:180 __xlate_proc_name+0x93/0xb0
[ 1.634009] RIP: 0010:__xlate_proc_name+0x93/0xb0
[ 1.639441] Call Trace:
[ 1.639976] proc_mkdir+0x18/0x20
[ 1.641946] request_threaded_irq+0xfe/0x160
[ 1.642186] cb_pcidas_auto_attach+0xf4/0x610 [cb_pcidas]
Link: https://lore.kernel.org/r/20210315195914.4801-1-ztong0001@gmail.com
commit 148e34fd33d53740642db523724226de14ee5281 upstream.
The analog input subdevice supports Comedi asynchronous commands that
use Comedi's 16-bit sample format. However, the call to
`comedi_buf_write_samples()` is passing the address of a 32-bit integer
parameter. On bigendian machines, this will copy 2 bytes from the wrong
end of the 32-bit value. Fix it by changing the type of the parameter
holding the sample value to `unsigned short`.
[Note: the bug was introduced in commit edf4537bcbf5 ("staging: comedi:
pcl818: use comedi_buf_write_samples()") but the patch applies better to
commit d615416de615 ("staging: comedi: pcl818: introduce
pcl818_ai_write_sample()").]
Fixes: d615416de615 ("staging: comedi: pcl818: introduce pcl818_ai_write_sample()")
Cc: <stable@vger.kernel.org> # 4.0+
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Link: https://lore.kernel.org/r/20210223143055.257402-10-abbotti@mev.co.uk
commit a084303a645896e834883f2c5170d044410dfdb3 upstream.
variable. On bigendian machines, this will copy 2 bytes from the wrong
end of the 32-bit value. Fix it by changing the type of the variable
Fixes: 1f44c034de2e ("staging: comedi: pcl711: use comedi_buf_write_samples()")
Cc: <stable@vger.kernel.org> # 3.19+
Link: https://lore.kernel.org/r/20210223143055.257402-9-abbotti@mev.co.uk
commit b39dfcced399d31e7c4b7341693b18e01c8f655e upstream.
use Comedi's 16-bit sample format. However, the calls to
`comedi_buf_write_samples()` are passing the address of a 32-bit integer
Fixes: de88924f67d1 ("staging: comedi: me4000: use comedi_buf_write_samples()")
Link: https://lore.kernel.org/r/20210223143055.257402-8-abbotti@mev.co.uk
commit 54999c0d94b3c26625f896f8e3460bc029821578 upstream.
[Note: the bug was introduced in commit 1700529b24cc ("staging: comedi:
dmm32at: use comedi_buf_write_samples()") but the patch applies better
to the later (but in the same kernel release) commit 0c0eadadcbe6e
("staging: comedi: dmm32at: introduce dmm32_ai_get_sample()").]
Fixes: 0c0eadadcbe6e ("staging: comedi: dmm32at: introduce dmm32_ai_get_sample()")
Link: https://lore.kernel.org/r/20210223143055.257402-7-abbotti@mev.co.uk
commit 459b1e8c8fe97fcba0bd1b623471713dce2c5eaf upstream.
Fixes: ad9eb43c93d8 ("staging: comedi: das800: use comedi_buf_write_samples()")
Link: https://lore.kernel.org/r/20210223143055.257402-6-abbotti@mev.co.uk
commit 1c0f20b78781b9ca50dc3ecfd396d0db5b141890 upstream.
Fixes: d1d24cb65ee3 ("staging: comedi: das6402: read analog input samples in interrupt handler")
Link: https://lore.kernel.org/r/20210223143055.257402-5-abbotti@mev.co.uk
commit b2e78630f733a76508b53ba680528ca39c890e82 upstream.
end of the 32-bit value. Fix it by changing the type of the variables
holding the sample value to `unsigned short`. The type of the `val`
parameter of `pci1710_ai_read_sample()` is changed to `unsigned short *`
accordingly. The type of the `val` variable in `pci1710_ai_insn_read()`
is also changed to `unsigned short` since its address is passed to
`pci1710_ai_read_sample()`.
Fixes: a9c3a015c12f ("staging: comedi: adv_pci1710: use comedi_buf_write_samples()")
Link: https://lore.kernel.org/r/20210223143055.257402-4-abbotti@mev.co.uk
commit ac0bbf55ed3be75fde1f8907e91ecd2fd589bde3 upstream.
The digital input subdevice supports Comedi asynchronous commands that
read interrupt status information. This uses 16-bit Comedi samples (of
which only the bottom 8 bits contain status information). However, the
interrupt handler is calling `comedi_buf_write_samples()` with the
address of a 32-bit variable `unsigned int status`. On a bigendian
machine, this will copy 2 bytes from the wrong end of the variable. Fix
it by changing the type of the variable to `unsigned short`.
Fixes: a8c66b684efa ("staging: comedi: addi_apci_1500: rewrite the subdevice support functions")
Cc: <stable@vger.kernel.org> #4.0+
Link: https://lore.kernel.org/r/20210223143055.257402-3-abbotti@mev.co.uk
commit 25317f428a78fde71b2bf3f24d05850f08a73a52 upstream.
The Change-Of-State (COS) subdevice supports Comedi asynchronous
commands to read 16-bit change-of-state values. However, the interrupt
handler is calling `comedi_buf_write_samples()` with the address of a
32-bit integer `&s->state`. On bigendian architectures, it will copy 2
bytes from the wrong end of the 32-bit integer. Fix it by transferring
the value via a 16-bit integer.
Fixes: 6bb45f2b0c86 ("staging: comedi: addi_apci_1032: use comedi_buf_write_samples()")
Link: https://lore.kernel.org/r/20210223143055.257402-2-abbotti@mev.co.uk
commit 56c90457ebfe9422496aac6ef3d3f0f0ea8b2ec2 upstream.
I have had reports from two different people that attempts to read the
analog input channels of the MF624 board fail with an `ETIMEDOUT` error.
After triggering the conversion, the code calls `comedi_timeout()` with
`mf6x4_ai_eoc()` as the callback function to check if the conversion is
complete. The callback returns 0 if complete or `-EBUSY` if not yet
complete. `comedi_timeout()` returns `-ETIMEDOUT` if it has not
completed within a timeout period which is propagated as an error to the
user application.
The existing code considers the conversion to be complete when the EOLC
bit is high. However, according to the user manuals for the MF624 and
MF634 boards, this test is incorrect because EOLC is an active low
signal that goes high when the conversion is triggered, and goes low
when the conversion is complete. Fix the problem by inverting the test
of the EOLC bit state.
Fixes: 04b565021a83 ("comedi: Humusoft MF634 and MF624 DAQ cards driver")
Cc: <stable@vger.kernel.org> # v4.4+
Cc: Rostislav Lisovy <lisovy@gmail.com>
Link: https://lore.kernel.org/r/20201207145806.4046-1-abbotti@mev.co.uk
commit 647a6002cb41d358d9ac5de101a8a6dc74748a59 upstream.
The "cb_pcidas" driver supports asynchronous commands on the analog
output (AO) subdevice for those boards that have an AO FIFO. The code
(in `cb_pcidas_ao_check_chanlist()` and `cb_pcidas_ao_cmd()`) to
validate and set up the command supports output to a single channel or
to two channels simultaneously (the boards have two AO channels).
However, the code in `cb_pcidas_auto_attach()` that initializes the
subdevices neglects to initialize the AO subdevice's `len_chanlist`
member, leaving it set to 0, but the Comedi core will "correct" it to 1
if the driver neglected to set it. This limits commands to use a single
channel (either channel 0 or 1), but the limit should be two channels.
Set the AO subdevice's `len_chanlist` member to be the same value as the
`n_chan` member, which will be 2.
Link: https://lore.kernel.org/r/20201021122142.81628-1-abbotti@mev.co.uk
commit e1f13c879a7c21bd207dc6242455e8e3a1e88b40 upstream.
While finding usb endpoints in vmk80xx_find_usb_endpoints(), check if
wMaxPacketSize = 0 for the endpoints found.
Some devices have isochronous endpoints that have wMaxPacketSize = 0
(as required by the USB-2 spec).
However, since this doesn't apply here, wMaxPacketSize = 0 can be
considered to be invalid.
Reported-by: syzbot+009f546aa1370056b1c2@syzkaller.appspotmail.com
Tested-by: syzbot+009f546aa1370056b1c2@syzkaller.appspotmail.com
Signed-off-by: Anant Thazhemadam <anant.thazhemadam@gmail.com>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20201010082933.5417-1-anant.thazhemadam@gmail.com
commit 926234f1b8434c4409aa4c53637aa3362ca07cea upstream.
The `INSN_CONFIG` comedi instruction with sub-instruction code
`INSN_CONFIG_DIGITAL_TRIG` includes a base channel in `data[3]`. This is
used as a right shift amount for other bitmask values without being
checked. Shift amounts greater than or equal to 32 will result in
undefined behavior. Add code to deal with this.
Fixes: 1e15687ea472 ("staging: comedi: addi_apci_1564: add Change-of-State interrupt subdevice and required functions")
Cc: <stable@vger.kernel.org> #3.17+
Link: https://lore.kernel.org/r/20200717145257.112660-4-abbotti@mev.co.uk
commit fc846e9db67c7e808d77bf9e2ef3d49e3820ce5d upstream.
undefined behavior. Add code to deal with this, adjusting the checks
for invalid channels so that enabled channel bits that would have been
lost by shifting are also checked for validity. Only channels 0 to 15
are valid.
Fixes: a8c66b684efaf ("staging: comedi: addi_apci_1500: rewrite the subdevice support functions")
Cc: <stable@vger.kernel.org> #4.0+: ef75e14a6c93: staging: comedi: verify array index is correct before using it
Link: https://lore.kernel.org/r/20200717145257.112660-5-abbotti@mev.co.uk
commit f07804ec77d77f8a9dcf570a24154e17747bc82f upstream.
`ni6527_intr_insn_config()` processes `INSN_CONFIG` comedi instructions
for the "interrupt" subdevice. When `data[0]` is
`INSN_CONFIG_DIGITAL_TRIG` it is configuring the digital trigger. When
`data[2]` is `COMEDI_DIGITAL_TRIG_ENABLE_EDGES` it is configuring rising
and falling edge detection for the digital trigger, using a base channel
number (or shift amount) in `data[3]`, a rising edge bitmask in
`data[4]` and falling edge bitmask in `data[5]`.
If the base channel number (shift amount) is greater than or equal to
the number of channels (24) of the digital input subdevice, there are no
changes to the rising and falling edges, so the mask of channels to be
changed can be set to 0, otherwise the mask of channels to be changed,
and the rising and falling edge bitmasks are shifted by the base channel
number before calling `ni6527_set_edge_detection()` to change the
appropriate registers. Unfortunately, the code is comparing the base
channel (shift amount) to the interrupt subdevice's number of channels
(1) instead of the digital input subdevice's number of channels (24).
Fix it by comparing to 32 because all shift amounts for an `unsigned
int` must be less than that and everything from bit 24 upwards is
ignored by `ni6527_set_edge_detection()` anyway.
Fixes: 110f9e687c1a8 ("staging: comedi: ni_6527: support INSN_CONFIG_DIGITAL_TRIG")
Cc: <stable@vger.kernel.org> # 3.17+
Link: https://lore.kernel.org/r/20200717145257.112660-2-abbotti@mev.co.uk
commit 0bd0db42a030b75c20028c7ba6e327b9cb554116 upstream.
Fixes: 33cdce6293dcc ("staging: comedi: addi_apci_1032: conform to new INSN_CONFIG_DIGITAL_TRIG")
Cc: <stable@vger.kernel.org> #3.8+
Link: https://lore.kernel.org/r/20200717145257.112660-3-abbotti@mev.co.uk
[ Upstream commit ef75e14a6c935eec82abac07ab68e388514e39bc ]
This code reads from the array before verifying that "trig" is a valid
index. If the index is wildly out of bounds then reading from an
invalid address could lead to an Oops.
Link: https://lore.kernel.org/r/20200709102936.GA20875@mwanda
commit 332e0e17ad49e084b7db670ef43b5eb59abd9e34 upstream.
comedi_open() invokes comedi_dev_get_from_minor(), which returns a
reference of the COMEDI device to "dev" with increased refcount.
When comedi_open() returns, "dev" becomes invalid, so the refcount
should be decreased to keep refcount balanced.
The reference counting issue happens in one exception handling path of
comedi_open(). When "cfp" allocation is failed, the refcnt increased by
comedi_dev_get_from_minor() is not decreased, causing a refcnt leak.
Fix this issue by calling comedi_dev_put() on this error path when "cfp"
allocation is failed.
Fixes: 20f083c07565 ("staging: comedi: prepare support for per-file read and write subdevices")
Signed-off-by: Xiyu Yang <xiyuyang19@fudan.edu.cn>
Signed-off-by: Xin Tan <tanxin.ctf@gmail.com>
Link: https://lore.kernel.org/r/1587361459-83622-1-git-send-email-xiyuyang19@fudan.edu.cn
commit ed87d33ddbcd9a1c3b5ae87995da34e6f51a862c upstream.
The DT2815 analog output command is 16 bits wide, consisting of the
12-bit sample value in bits 15 to 4, the channel number in bits 3 to 1,
and a voltage or current selector in bit 0. Both bytes of the 16-bit
command need to be written in turn to a single 8-bit data register.
However, the driver currently only writes the low 8-bits. It is broken
and appears to have always been broken.
Electronic copies of the DT2815 User's Manual seem impossible to find
online, but looking at the source code, a best guess for the sequence
the driver intended to use to write the analog output command is as
follows:
1. Wait for the status register to read 0x00.
2. Write the low byte of the command to the data register.
3. Wait for the status register to read 0x80.
4. Write the high byte of the command to the data register.
Step 4 is missing from the driver. Add step 4 to (hopefully) fix the
driver.
Also add a "FIXME" comment about setting bit 0 of the low byte of the
command. Supposedly, it is used to choose between voltage output and
current output, but the current driver always sets it to 1.
Link: https://lore.kernel.org/r/20200406142015.126982-1-abbotti@mev.co.uk
commit 9fea3a40f6b07de977a2783270c8c3bc82544d45 upstream.
This patch fixes a regression on setting up asynchronous commands to use
external trigger sources when board-specific routing information is
missing.
`ni_find_device_routes()` (called via `ni_assign_device_routes()`) finds
the table of register values for the device family and the set of valid
routes for the specific board. If both are found,
`tables->route_values` is set to point to the table of register values
for the device family and `tables->valid_routes` is set to point to the
list of valid routes for the specific board. If either is not found,
both `tables->route_values` and `tables->valid_routes` are left set at
their initial null values (initialized by `ni_assign_device_routes()`)
and the function returns `-ENODATA`.
Returning an error results in some routing functionality being disabled.
Unfortunately, leaving `table->route_values` set to `NULL` also breaks
the setting up of asynchronous commands that are configured to use
external trigger sources. Calls to `ni_check_trigger_arg()` or
`ni_check_trigger_arg_roffs()` while checking the asynchronous command
set-up would result in a null pointer dereference if
`table->route_values` is `NULL`. The null pointer dereference is fixed
in another patch, but it now results in failure to set up the
asynchronous command. That is a regression from the behavior prior to
commit 347e244884c3 ("staging: comedi: tio: implement global tio/ctr
routing") and commit 56d0b826d39f ("staging: comedi: ni_mio_common:
implement new routing for TRIG_EXT").
Change `ni_find_device_routes()` to set `tables->route_values` and/or
`tables->valid_routes` to valid information even if the other one can
only be set to `NULL` due to missing information. The function will
still return an error in that case. This should result in
`tables->valid_routes` being valid for all currently supported device
families even if the board-specific routing information is missing.
That should be enough to fix the regression on setting up asynchronous
commands to use external triggers for boards with missing routing
information.
Fixes: 347e244884c3 ("staging: comedi: tio: implement global tio/ctr routing")
Fixes: 56d0b826d39f ("staging: comedi: ni_mio_common: implement new routing for TRIG_EXT").
Cc: <stable@vger.kernel.org> # 4.20+
Cc: Spencer E. Olson <olsonse@umich.edu>
Link: https://lore.kernel.org/r/20200114182532.132058-3-abbotti@mev.co.uk
commit 01e20b664f808a4f3048ca3f930911fd257209bd upstream.
In `ni_find_route_source()`, `tables->route_values` gets dereferenced.
However it is possible that `tables->route_values` is `NULL`, leading to
a null pointer dereference. `tables->route_values` will be `NULL` if
the call to `ni_assign_device_routes()` during board initialization
returned an error due to missing device family routing information or
missing board-specific routing information. For example, there is
currently no board-specific routing information provided for the
PCIe-6251 board and several other boards, so those are affected by this
bug.
The bug is triggered when `ni_find_route_source()` is called via
`ni_check_trigger_arg()` or `ni_check_trigger_arg_roffs()` when checking
the arguments for setting up asynchronous commands. Fix it by returning
`-EINVAL` if `tables->route_values` is `NULL`.
Even with this fix, setting up asynchronous commands to use external
trigger sources for boards with missing routing information will still
fail gracefully. Since `ni_find_route_source()` only depends on the
device family routing information, it would be better if that was made
available even if the board-specific routing information is missing.
That will be addressed by another patch.
Fixes: 4bb90c87abbe ("staging: comedi: add interface to ni routing table information")
Link: https://lore.kernel.org/r/20200114182532.132058-2-abbotti@mev.co.uk
commit a9d3a9cedc1330c720e0ddde1978a8e7771da5ab upstream.
The Advantech PCI-1713 has 32 analog input channels, but an incorrect
bit-mask in the definition of the `PCI171X_MUX_CHANH(x)` and
PCI171X_MUX_CHANL(x)` macros is causing channels 16 to 31 to be aliases
of channels 0 to 15. Change the bit-mask value from 0xf to 0xff to fix
it. Note that the channel numbers will have been range checked already,
so the bit-mask isn't really needed.
Fixes: 92c65e5553ed ("staging: comedi: adv_pci1710: define the mux control register bits")
Reported-by: Dmytro Fil <monkdaf@gmail.com>
Cc: <stable@vger.kernel.org> # v4.5+
Link: https://lore.kernel.org/r/20191227170054.32051-1-abbotti@mev.co.uk
commit ab42b48f32d4c766420c3499ee9c0289b7028182 upstream.
The "auto-attach" handler function `gsc_hpdi_auto_attach()` calls
`dma_alloc_coherent()` in a loop to allocate some DMA data buffers, and
also calls it to allocate a buffer for a DMA descriptor chain. However,
it does not check the return value of any of these calls. Change
`gsc_hpdi_auto_attach()` to return `-ENOMEM` if any of these
`dma_alloc_coherent()` calls fail. This will result in the comedi core
calling the "detach" handler `gsc_hpdi_detach()` as part of the
clean-up, which will call `gsc_hpdi_free_dma()` to free any allocated
DMA coherent memory buffers.
Cc: <stable@vger.kernel.org> #4.6+
Link: https://lore.kernel.org/r/20191216110823.216237-1-abbotti@mev.co.uk
commit 5618332e5b955b4bff06d0b88146b971c8dd7b32 upstream.
The userspace comedilib function 'get_cmd_generic_timed' fills
the cmd structure with an informed guess and then calls the
function 'usbduxfast_ai_cmdtest' in this driver repeatedly while
'usbduxfast_ai_cmdtest' is modifying the cmd struct until it
no longer changes. However, because of rounding errors this never
converged because 'steps = (cmd->convert_arg * 30) / 1000' and then
back to 'cmd->convert_arg = (steps * 1000) / 30' won't be the same
because of rounding errors. 'Steps' should only be converted back to
the 'convert_arg' if 'steps' has actually been modified. In addition
the case of steps being 0 wasn't checked which is also now done.
Signed-off-by: Bernd Porr <mail@berndporr.me.uk>
Cc: <stable@vger.kernel.org> # 4.4+
Link: https://lore.kernel.org/r/20191118230759.1727-1-mail@berndporr.me.uk
This patch fix a spelling typo in ni_mio_common.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Link: https://lore.kernel.org/r/20190820153356.25189-1-standby24x7@gmail.com
We need the staging fixes in here as well.
Variable fx2delay is being initialized with a value that is never read
and fx2delay is being re-assigned a little later on. The assignment is
redundant and hence can be removed.
Addresses-Coverity: ("Unused value")
Link: https://lore.kernel.org/r/20190815105314.5756-1-colin.king@canonical.com
`dt3k_ns_to_timer()` determines the prescaler and divisor to use to
produce a desired timing period. It is influenced by a rounding mode
and can round the divisor up, down, or to the nearest value. However,
the code for rounding up currently does the same as rounding down! Fix
ir by using the `DIV_ROUND_UP()` macro to calculate the divisor when
rounding up.
Also, change the types of the `divider`, `base` and `prescale` variables
from `int` to `unsigned int` to avoid mixing signed and unsigned types
in the calculations.
Also fix a typo in a nearby comment: "improvment" => "improvement".
Link: https://lore.kernel.org/r/20190812120814.21188-1-abbotti@mev.co.uk
In `dt3k_ns_to_timer()` the following lines near the end of the function
result in a signed integer overflow:
prescale = 15;
base = timer_base * (1 << prescale);
divider = 65535;
*nanosec = divider * base;
(`divider`, `base` and `prescale` are type `int`, `timer_base` and
`*nanosec` are type `unsigned int`. The value of `timer_base` will be
either 50 or 100.)
The main reason for the overflow is that the calculation for `base` is
completely wrong. It should be:
base = timer_base * (prescale + 1);
which matches an earlier instance of this calculation in the same
function.
Reported-by: David Binderman <dcb314@hotmail.com>
Link: https://lore.kernel.org/r/20190812111517.26803-1-abbotti@mev.co.uk
Remove function db2k_initialize_dac as all it does is call
db2k_dac_disarm.
Modify call site accordingly.
Issue found with Coccinelle.
Signed-off-by: Nishka Dasgupta <nishkadg.linux@gmail.com>
Link: https://lore.kernel.org/r/20190725052359.2308-1-nishkadg.linux@gmail.com
Remove function mite_request_channel_in_range as all it does is call
__mite_request_channel.
Rename __mite_request_channel to mite_request_channel_in_range and
change its type from static to non-static to maintain compatibility with
call sites.
Change only remaining call site of __mite_request_channel to call
mite_request_channel_in_range_instead.
Link: https://lore.kernel.org/r/20190701070025.3838-3-nishkadg.linux@gmail.com
Remove function gat_sce as all it does is call clk_gat_sce.
Modify call sites of the former to call the latter directly.
Link: https://lore.kernel.org/r/20190701070025.3838-2-nishkadg.linux@gmail.com
Remove function clk_sce as all it does is call clk_gat_sce.
Modify call site of clk_sce to call clk_gat_sce instead.
Link: https://lore.kernel.org/r/20190701070025.3838-1-nishkadg.linux@gmail.com
The interrupt handler `dt282x_interrupt()` causes a null pointer
dereference for those supported boards that have no analog output
support. For these boards, `dev->write_subdev` will be `NULL` and
therefore the `s_ao` subdevice pointer variable will be `NULL`. In that
case, the following call near the end of the interrupt handler results
in a null pointer dereference:
comedi_handle_events(dev, s_ao);
Fix it by only calling the above function if `s_ao` is valid.
(There are other uses of `s_ao` by the interrupt handler that may or may
not be reached depending on values of hardware registers. Trust that
they are reliable for now.)
Note:
commit 4f6f009b204f ("staging: comedi: dt282x: use comedi_handle_events()")
propagates an earlier error from
commit f21c74fa4cfe ("staging: comedi: dt282x: use cfc_handle_events()").
Fixes: 4f6f009b204f ("staging: comedi: dt282x: use comedi_handle_events()")
Cc: <stable@vger.kernel.org> # v3.19+
The interrupt handler `pci230_interrupt()` causes a null pointer
dereference for a PCI260 card. There is no analog output subdevice for
a PCI260. The `dev->write_subdev` subdevice pointer and therefore the
`s_ao` subdevice pointer variable will be `NULL` for a PCI260. The
following call near the end of the interrupt handler results in the null
pointer dereference for a PCI260:
Note that the other uses of `s_ao` in the calls
`pci230_handle_ao_nofifo(dev, s_ao);` and `pci230_handle_ao_fifo(dev,
s_ao);` will never be reached for a PCI260, so they are safe.
Fixes: 39064f23284c ("staging: comedi: amplc_pci230: use comedi_handle_events()")
Comedi's acquisition buffer allocation code can allocate the buffer from
normal kernel memory or from DMA coherent memory depending on the
`dma_async_dir` value in the comedi subdevice. (A value of `DMA_NONE`
causes the buffer to be allocated from normal kernel memory. Other
values cause the buffer to be allocated from DMA coherent memory.) The
buffer currently consists of a bunch of page-sized blocks that are
vmap'ed into a contiguous range of virtual addresses. The pages are also
mmap'able into user address space. For DMA'able buffers, these
page-sized blocks are allocated by `dma_alloc_coherent()`.
For DMA-able buffers, the DMA API is currently abused in various ways,
the most serious abuse being the calling of `virt_to_page()` on the
blocks allocated by `dma_alloc_coherent()` and passing those pages to
`vmap()` (for mapping to the kernels vmalloc address space) and via
`page_to_pfn()` to `remap_pfn_range()` (for mmap'ing to user space). it
also uses the `__GFP_COMP` flag when allocating the blocks, and marks
the allocated pages as reserved (which is unnecessary for DMA coherent
allocations).
The code can be changed to get rid of the vmap'ed address altogether if
necessary, since there are only a few places in the comedi code that use
the vmap'ed address directly and we also keep a list of the kernel
addresses for the individual pages prior to the vmap operation. This
would add some run-time overhead to buffer accesses. The real killer is
the mmap operation.
For mmap, the address range specified in the VMA needs to be mmap'ed to
the individually allocated page-sized blocks. That is not a problem
when the pages are allocated from normal kernel memory as the individual
pages can be remapped by `remap_pfn_range()`, but it is a problem when
the page-sized blocks are allocated by `dma_alloc_coherent()` because
the DMA API currently has no support for splitting a VMA across multiple
blocks of DMA coherent memory (or rather, no support for mapping part of
a VMA range to a single block of DMA coherent memory).
In order to comply with the DMA API and allow the buffer to be mmap'ed,
the buffer needs to be allocated as a single block by a single call to
`dma_alloc_coherent()`, freed by a single call to `dma_free_coherent()`,
and mmap'ed to user space by a single call to `dma_mmap_coherent()`.
This patch changes the buffer allocation, freeing, and mmap'ing code to
do that, with the unfortunate consequence that buffer allocation is more
likely to fail. It also no longer uses the `__GFP_COMP` flag when
allocating DMA coherent memory, no longer marks the
allocated pages of DMA coherent memory as reserved, and no longer vmap's
the DMA coherent memory pages (since they are contiguous anyway).
Variable fx2delay is being initialized to a value that is never read
and is being re-assigned a few statements later. The initialization
is redundant and can be removed.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging / IIO driver updates from Greg KH:
"Here is the big staging and iio driver update for 5.2-rc1.
Lots of tiny fixes all over the staging and IIO driver trees here,
along with some new IIO drivers.
The "counter" subsystem was added in here as well, as it is needed by
the IIO drivers and subsystem.
Also we ended up deleting two drivers, making this pull request remove
a few hundred thousand lines of code, always a nice thing to see. Both
of the drivers removed have been replaced with "real" drivers in their
various subsystem directories, and they will be coming to you from
those locations during this merge window.
There are some core vt/selection changes in here, that was due to some
cleanups needed for the speakup fixes. Those have all been acked by
the various subsystem maintainers (i.e. me), so those are ok.
We also added a few new drivers, for some odd hardware, giving new
developers plenty to work on with basic coding style cleanups to come
in the near future.
Other than that, nothing unusual here.
All of these have been in linux-next for a while with no reported
issues, other than an odd gcc warning for one of the new drivers that
should be fixed up soon"
[ I fixed up the warning myself - Linus ]
* tag 'staging-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (663 commits)
staging: kpc2000: kpc_spi: Fix build error for {read,write}q
Staging: rtl8192e: Remove extra space before break statement
Staging: rtl8192u: ieee80211: Fix if-else indentation warning
Staging: rtl8192u: ieee80211: Fix indentation errors by removing extra spaces
staging: most: cdev: fix chrdev_region leak in mod_exit
staging: wlan-ng: Fix improper SPDX comment style
staging: rtl8192u: ieee80211: Resolve ERROR reported by checkpatch
staging: vc04_services: bcm2835-camera: Compress two lines into one line
staging: rtl8723bs: core: Use !x in place of NULL comparison.
staging: rtl8723bs: core: Prefer using the BIT Macro.
staging: fieldbus: anybus-s: fix wait_for_completion_timeout return handling
staging: kpc2000: fix up build problems with readq()
staging: rtlwifi: move remaining phydm .h files
staging: rtlwifi: strip down phydm .h files
staging: rtlwifi: delete the staging driver
staging: fieldbus: anybus-s: rename bus id field to avoid confusion
staging: fieldbus: anybus-s: keep device bus id in bus endianness
Staging: sm750fb: Change *array into *const array
staging: rtl8192u: ieee80211: Fix spelling mistake
staging: rtl8192u: ieee80211: Replace bit shifting with BIT macro
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull mmiowb removal from Will Deacon:
"Remove Mysterious Macro Intended to Obscure Weird Behaviours (mmiowb())
Remove mmiowb() from the kernel memory barrier API and instead, for
architectures that need it, hide the barrier inside spin_unlock() when
MMIO has been performed inside the critical section.
The only relatively recent changes have been addressing review
comments on the documentation, which is in a much better shape thanks
to the efforts of Ben and Ingo.
I was initially planning to split this into two pull requests so that
you could run the coccinelle script yourself, however it's been plain
sailing in linux-next so I've just included the whole lot here to keep
things simple"
* tag 'arm64-mmiowb' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (23 commits)
docs/memory-barriers.txt: Update I/O section to be clearer about CPU vs thread
docs/memory-barriers.txt: Fix style, spacing and grammar in I/O section
arch: Remove dummy mmiowb() definitions from arch code
net/ethernet/silan/sc92031: Remove stale comment about mmiowb()
i40iw: Redefine i40iw_mmiowb() to do nothing
scsi/qla1280: Remove stale comment about mmiowb()
drivers: Remove explicit invocations of mmiowb()
drivers: Remove useless trailing comments from mmiowb() invocations
Documentation: Kill all references to mmiowb()
riscv/mmiowb: Hook up mmwiob() implementation to asm-generic code
powerpc/mmiowb: Hook up mmwiob() implementation to asm-generic code
ia64/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
mips/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
sh/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
m68k/io: Remove useless definition of mmiowb()
nds32/io: Remove useless definition of mmiowb()
x86/io: Remove useless definition of mmiowb()
arm64/io: Remove useless definition of mmiowb()
ARM/io: Remove useless definition of mmiowb()
mmiowb: Hook up mmiowb helpers to spinlocks and generic I/O accessors
The "comedi_isadma" module calls `dma_alloc_coherent()` and
`dma_free_coherent()` with a NULL device pointer which is no longer
allowed. If the `hw_dev` member of the `struct comedi_device` has been
set to a valid device, that can be used instead. Unfortunately, all the
current users of the "comedi_isadma" module leave the `hw_dev` member
set to NULL. In that case, fall back to using the comedi "class" device
pointed to by the `class_dev` member if that is non-NULL. In that case,
make it "DMA-capable" with a coherent DMA mask set to the ISA bus limit
of 16MB (24 bits).
We want the fixes in here as well as this resolves an iio driver merge
issue.
- Resolve the following warning from the Kconfig,
"WARNING: prefer 'help' over '---help---' for new help texts"
Signed-off-by: Moses Christopher <moseschristopherb@gmail.com>
`dt9812_detach()` is the Comedi "detach" handler for the dt9812 driver.
When it is called, the private data for the device is about to be freed.
The private data contains a mutex `devpriv->mut` that was initialized
when the private data was allocated. Call `mutex_destroy()` to mark it
as invalid.
Also remove the calls to `mutex_lock()` and `mutex_unlock()` from
`dt9812_detach()` as the mutex is only being used around a call to
`usb_set_intfdata()` to clear the USB interface's driver data pointer.
The mutex lock seems redundant here, especially as it is about to be
destroyed.
