Use dev_pm_ops instead of the deprecated legacy suspend/resume callbacks.
alloc failures already get standardized OOM
messages and a dump_stack.
For the affected mallocs around these OOM messages:
Converted kzallocs with multiplies to kcalloc.
Converted kmallocs with multiplies to kmalloc_array.
Converted a kmalloc/strlen/strncpy to kstrdup.
Moved a spin_lock below a removed OOM message and
removed a now unnecessary spin_unlock.
Neatened alignment and whitespace.
use the module_i2c_driver and remove the reimplementation of module_i2c_driver
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
The below checkpatch error was fixed,
drivers/staging/cptm1217/cp_tm1217.h:5: ERROR: open brace '{' following struct go on the same line
Signed-off-by: Toshiaki Yamane <yamanetoshi@gmail.com>
This commit fixes coding style issues including quoted string
across multiple lines.
Signed-off-by: Adnan Ali <adnan.ali@codethink.co.uk>
Acked-by: Dan Carpenter <dan.carpenter@oracle.com>
This code is in a loop that currently is only executed once. Because of
this property, the first block of code is currently actually correct.
Nevertheless, the comments associated with the code suggest that the loop
is planned to take more than one iteration in the future, and thus this
patch is made with that case in mind.
In the first block of code, there is currently an immediate abort from the
function. It is changed to jump to the error handling code at fail, to be
able to unregister and free the resources allocated on previous iterations.
In the second block of code, the input_dev for the current iteration has
been allocated, but has not been registered. It has also not been stored
in ts->cp_input_info[i].input. Thus on jumping to fail, it will not be
freed. In this case, we want to free, but not unregister, so the free for
this most recently allocated resource is put before the jump.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression struct input_dev * x;
expression ra,rr;
position p1,p2;
x = input_allocate_device@p1(...)
... when != x = rr
when != input_free_device(x,...)
when != if (...) { ... input_free_device(x,...) ...}
if(...) { ... when != x = ra
when forall
\(return <+...x...+>; \| return@p2...; \) }
@script:python@
p1 << r.p1;
p2 << r.p2;
cocci.print_main("input_allocate_device",p1)
cocci.print_secs("input_free_device",p2)
// </smpl>
clearpad_tm1217 driver uses many input_() interfaces, so it should
depend on INPUT.
clearpad_tm1217.c:(.text+0xf19ac): undefined reference to `input_unregister_device'
clearpad_tm1217.c:(.text+0xf1b19): undefined reference to `input_event'
clearpad_tm1217.c:(.text+0xf1b31): undefined reference to `input_event'
clearpad_tm1217.c:(.text+0xf1bb4): undefined reference to `input_event'
clearpad_tm1217.c:(.text+0xf1bf2): undefined reference to `input_event'
drivers/built-in.o:clearpad_tm1217.c:(.text+0xf1c08): more undefined references to `input_event' follow
clearpad_tm1217.c:(.text+0xf1df3): undefined reference to `input_allocate_device'
clearpad_tm1217.c:(.text+0xf1eac): undefined reference to `input_set_abs_params'
clearpad_tm1217.c:(.text+0xf1ed1): undefined reference to `input_set_abs_params'
clearpad_tm1217.c:(.text+0xf1ed8): undefined reference to `input_register_device'
clearpad_tm1217.c:(.text+0xf2040): undefined reference to `input_unregister_device'
clearpad_tm1217.c:(.text+0xf204b): undefined reference to `input_free_device'
Cc: Ramesh Agarwal <ramesh.agarwal@intel.com>
We dereference "ts" in the printk so move the kfree() down a line.
Acked-by: Alan Cox <alan@linux.intel.com>
This is submitted as a staging driver because there is a more generic driver
"on the way" for all these devices and has been for some time. The intent is
that as soon as the general drivers are in the mainstream this one will get
any leftovers integrated and then be dumped. Until this unspecified future
data at least people can actually use their hardware.
As its interface is simply input layer we can do that without pain.
Some clean up by Alan Cox
- Extract gpio support and IRQ support more sanely
- Tidying
Signed-off-by: Ramesh Agarwal <ramesh.agarwal@intel.com>
[avoid deference NULL ts if kzalloc fails]
[finger_touched may be used uninitialized]
[fix missing sync which confused twm]
Signed-off-by: Hong Liu <hong.liu@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
