In practice, it is being hard to distinguish when a patch
should go to staging tree or to the media tree. Better
to distinguish it, by putting the media drivers at a
separate staging directory. Newer staging drivers that include
anything with "dvb*.h", "v4l2*.h" or "videodev2.h" should
go to the drivers/staging/media tree.
timeval[0-9] were not used or used in a ready only code
so we can remove them safely and so the code
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
remove support for OSS. OSS is being deprecated
and it is just plain headache to support both alsa and oss.
Last I broke the compilation when OSS is enabled with the patch
cdaa898b5efcc598ab1004e8f913061dc7005091
staging/easycap: kill telltale logic
so this fixes also that issue.
Cc: Mike Thomas <rmthomas@sciolus.org>
This reason for this feature was
'some versions of the videodev module overwrite the data which has
been written by the call to usb_set_intfdata() in easycap_usb_probe(),
replacing it with a pointer to the embedded v4l2_device structure.
to detect this, the string in the easycap.telltale[] buffer is checked.'
The upstream version of v4l2_device_register sets driver data
only when it wasn't already set, therefore this is not needed
drivers/staging/easycap/
It was pointed out by 'make versioncheck' that linux/version.h was not
always being included where needed and sometimes included needlessly
in drivers/staging/easycap/.
This patch fixes up the includes.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
I'm not 100% sure, only 99.99% that PAGE_SIZE is always defined in
Linux. So there is no need to check for it.
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
Acked-by: Tomas Winkler <tomas.winkler@intel.com>
remove EASYCAP_IS_VIDEODEV_CLIENT and irrelevant code as the define
is always set in the in-kernel driver
wait_i2c is only used from easycap_low.c
so remove it from the easycap.h and mark it static
remove pointless compilation flag
EASYCAP_NEEDS_V4L2_DEVICE_H and EASYCAP_NEEDS_V4L2_FOPS are required in
in-tree driver
NOREADBACK doesn't justify Kconfig option so we use module
paramter for it.
regget and regset functions are used only from within
easycap_low.c so they can be static
Move the functions to avoid forward declarations
Move GET and SET macro definitions into the c-file
No longer needed feature for testing driver's handling of
the audio stream independently of the urb completion routine
This has simulated a fault condition of probing for audio capability
remove PREFER_NTSC ifdef as it cannot be possible put into Kconfig
easyoss_fops are only accessed from within easycap_sound_oss file
rc is used extensively in code as return code variable
so it is better not shadowing it in macros
the underscored types should be used in user space headers only
for sake of readability replace #if defined with #ifdef
and #if (!defined with #ifndef
we can kill this option for in-kernel driver
1. make also ops function static
2. move around code so to avid forward declarations
1. make oss ops function static
3. move OSS ioclts from ioctl.c to sound_oss.c
OSS is deprecated yet currently it is reported to be more stable
therefore we keep it but make it optional
Revert the conditional compilation:
add CONFIG_EASYCAP_OSS and kill EASYCAP_NEEDS_ALSA
move oss-only code from easycap_sound.c to easycap_sound_oss.c
Replace long switch statements that just print out errno
with strerror function. It reduces around 700 lines from the code.
The function should be probably dropped at all but leave for now
to not break currently expected debug output.
indent level 1 by tabs
replace
struct {
int a;
with more readable
struct {
int a;
1. remove declarations from the header file
2. rearange code in main.c to reduce number of forward declarations
1. For readability group module parameters handling on one place
2. Introduce kernel config option EASY_DEBUG
use common #ifndef __EASYCAP_H_ instead of if (!defined(EASYCAP_H))
for protecting header from double inclusion
place all globals to easycap.h, which is included
by all c-files
easycap_standard: fix declaration vs. definiton conflict
remove \ from the code where C syntex doesnt require it
easycap_main.c:34:5: warning: symbol 'easycap_debug' was not declared. Should it be static?
easycap_main.c:36:5: warning: symbol 'easycap_gain' was not declared. Should it be static?
These two variables actually were declared in several places.
The variables are used in several files.
I've fixed "easycap_debug" so it gets declared in one place only and included properly.
For "easycap_gain" made it static and I created added a
->gain member to the easycap struct. This seems cleaner than using a
global variable and later on we may make this controlable via sysfs.
Cc:Mike Thomas <rmthomas@sciolus.org>
Acked-by: Dan Carpenter <error27@gmail.com>
This is necessary because some distributions are disabling OSS entirely.
Signed-off-by: Mike Thomas <rmthomas@sciolus.org>
The parameter easycap_debug appears in macros JOT and JOM and therefore
needs to be visible from all source files. The easycap_ prefix should
be sufficient to avoid namespace clashes outside the module.
This was done to handle a number of conflicts in the batman-adv
and winbond drivers properly. It also now allows us to fix up the sysfs
attributes properly that were not in the .37 release due to them being
only in this tree at the time.
Add header file to fix build error:
drivers/staging/easycap/easycap_main.c:4251: error: implicit declaration of function 'lock_kernel'
drivers/staging/easycap/easycap_main.c:4254: error: implicit declaration of function 'unlock_kernel'
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
The easycap driver has module parameters (bars, gain, & debug)
with global scope that intrude on the kernel namespace and cause
build problems. Change the names of them to be driver-specific
and make 2 of them static.
drivers/built-in.o:(.bss+0x97c00): multiple definition of `debug'
ld: Warning: size of symbol `debug' changed from 58 in arch/x86/built-in.o to 4 in drivers/built-in.o
The changes here represent an intermediate step towards bringing the
driver within the V4L2 framework.
No locking is required for normal operation of the driver, but locking
is needed to prevent an Oops during some hot-unplugging scenarios. The
BKL is replaced here by mutex locks together with traps to detect null
pointers following asynchronous device disconnection.
A new module parameter turns on the option of displaying a testcard when
the analogue input signal is lost (more precisely: when the hardware
detects no field/frame synchronization). This feature has been requested
in the context of security cameras used at night.
Interlaced modes are requested by tvtime. Reduced framerates are
preferred by some userspace programs, e.g. astronomy applications.
Sometimes at startup the video urbs consistently and persistently deliver
bad data, each video frame (not isoc frame) containing an excess of
precisely two bytes. A brute-force cure implemented here is to
repeatedly reinitialize the registers of the SAA7113H chip and the
STK1160 USB bridge until good behaviour is obtained.
In order to allow multiple EasyCAP dongles to operate simultaneously
without mutual interference all static variables have been eliminated
except for a persistent inventory of plugged-in dongles at module level.
The so-called bridger routine has proved unnecessary following general
improvements elsewhere. The explain_() functions were a convenience
during early development, but are unnecessary and inappropriate now.
These were amongst the last users of struct file_operations:ioctl
