This patch will fix following compilation error:
drivers/staging/gma500/psb_drv.c:1635: error: unknown field ‘pci_driver’ specified in initializer
drivers/staging/gma500/psb_drv.c:1636: error: unknown field ‘name’ specified in initializer
drivers/staging/gma500/psb_drv.c:1636: warning: initialization from incompatible pointer type
drivers/staging/gma500/psb_drv.c:1637: error: unknown field ‘id_table’ specified in initializer
drivers/staging/gma500/psb_drv.c:1637: warning: excess elements in union initializer
drivers/staging/gma500/psb_drv.c:1637: warning: (near initialization for ‘driver.kdriver’)
drivers/staging/gma500/psb_drv.c:1638: error: unknown field ‘resume’ specified in initializer
drivers/staging/gma500/psb_drv.c:1638: warning: excess elements in union initializer
drivers/staging/gma500/psb_drv.c:1638: warning: (near initialization for ‘driver.kdriver’)
drivers/staging/gma500/psb_drv.c:1639: error: unknown field ‘suspend’ specified in initializer
drivers/staging/gma500/psb_drv.c:1639: warning: excess elements in union initializer
drivers/staging/gma500/psb_drv.c:1639: warning: (near initialization for ‘driver.kdriver’)
drivers/staging/gma500/psb_drv.c:1640: error: unknown field ‘probe’ specified in initializer
drivers/staging/gma500/psb_drv.c:1640: warning: excess elements in union initializer
drivers/staging/gma500/psb_drv.c:1640: warning: (near initialization for ‘driver.kdriver’)
drivers/staging/gma500/psb_drv.c:1641: error: unknown field ‘remove’ specified in initializer
drivers/staging/gma500/psb_drv.c:1641: warning: excess elements in union initializer
drivers/staging/gma500/psb_drv.c:1641: warning: (near initialization for ‘driver.kdriver’)
drivers/staging/gma500/psb_drv.c:1643: error: unknown field ‘driver’ specified in initializer
drivers/staging/gma500/psb_drv.c:1643: warning: excess elements in union initializer
drivers/staging/gma500/psb_drv.c:1643: warning: (near initialization for ‘driver.kdriver’)
drivers/staging/gma500/psb_drv.c: In function ‘psb_init’:
drivers/staging/gma500/psb_drv.c:1664: error: implicit declaration of function ‘drm_init’
drivers/staging/gma500/psb_drv.c: In function ‘psb_exit’:
drivers/staging/gma500/psb_drv.c:1669: error: implicit declaration of function ‘drm_exit’
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Remove all sorts of bits we can get rid of. We are now a very simple KMS
driver relying on the stolen memory for our framebuffer base (which is for
the moment hardcoded).
To support multiple frame buffers and some accel bits we will need some kind
of memory allocator, possibly a minimal use of GEM.
These gotos were swapped. In the original code, the first would result
in a NULL dereference and the second would result in a memory leak.
Cc: Alan Cox <alan@linux.intel.com>
This is taken from Richard Purdie's previous attempt to rip the heart out
of the PVR driver and stake it.
Accelerate copies and fills.
[Revised patch which disables the methods until we can finish debugging them]
Lots of little ones all through the driver, mostly
all in a cut-and-paste header comment.
The mod.c file should not be part of the repo.
This is an initial staging driver for the GMA500. It's been stripped out
of the PVR drivers and crunched together from various bits of code and
different kernels.
Currently it's unaccelerated but still pretty snappy even compositing with
the frame buffer X server.
Lots of work is needed to rework the ttm and bo interfaces from being
ripped out and then 2D acceleration wants putting back for framebuffer and
somehow eventually via DRM.
There is no support for the parts without open source userspace (video
accelerators, 3D) as per kernel policy.
