The IIO DAC drivers are in a reasonably good shape. They all make use of channel
spec and non of them provides non-documented sysfs attributes. Code style should
be OK as well, both checkpatch and coccicheck only report trivial issues.
So lets move the whole folder out of staging.
Acked-by: Jonathan Cameron <jic23@kernel.org>
Generalize naming to allow other frequency synthesis techniques as well.
No functional changes.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Take the core support + the kfifo buffer implentation out of
staging. Whilst we are far from done in improving this subsystem
it is now at a stage where the userspae interfaces (provided by
the core) can be considered stable.
Drivers will follow over a longer time scale.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Direct copy of version proposed for the non staging branch.
Needed here to allow testing of more advanced inkernel
interface code.
Minimal support of simple in, curr and temp attributes
so far.
Lifted from proposal for in kernel interface built on the out of staging
branch.
Two elements here:
* Map as defined in "inkern.h"
* Matching code to actually get the iio_dev and channel
that we want from the global list of IIO devices.
V4: Everything now built if iio is built (rather than being optional)
Removal race condition prevented by using info pointer as a check
of removal under a lock.
V3: Drop the option of registering / getting channels using dev pointer.
Stick to name only as suggested by Mark Brown (this has caused user
confusion in the regulator framework.)
V2: As per Greg KH suggestion, move over to registration by passing
the tables into the provider drivers (how regulator does it).
This does not prevent us using the original more flexible approach
if at a later date there is a usecase that demands it.
The core iio file has gotten quite cluttered over time. This patch moves
the event handling code into its own file. Since the event handling code is
largely independent from the core code the only code changes necessary for
this are to make the moved iio_device_register_eventset,
iio_device_unregister_eventset and iio_event_getfd functions non static.
This has also the advantage that industrialio-core.c is now closer again to
its counterpart in the outofstaging branch.
Fix Kconfig description.
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Very simple buffered reading. Did not provide a trigger as
the sysfs trigger already meets that requirement.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
The event generator is not very pretty but does the job and
allows this driver to look a lot more like a normal driver
than it otherwise would.
The documenation explaining how to go about writing a driver is lagging
horribly, so here is another approach; an actual driver with
lots of explanatory comments.
Note it is currently minimal in that there are no events and no
buffer. With care they can probably be added in additional files
without messing up the clarity of what we have here.
V2: Addressed some of Manuel Stahl's feedback.
Fixed up kernel doc.
Added more general description.
They aren't always ring buffers, so just use buffer for all naming.
Functionality is generic, so name is missleading.
Network Analyzer
The AD5933 is a high precision impedance converter system solution
that combines an on-board frequency generator with a 12-bit, 1 MSPS,
analog-to-digital converter (ADC). The frequency generator allows an
external complex impedance to be excited with a known frequency.
The response signal from the impedance is sampled by the on-board ADC
and a discrete Fourier transform (DFT) is processed by an on-chip DSP engine.
The DFT algorithm returns a real (R) and imaginary (I) data-word at each
output frequency.
Changes since V1:
Apply list review feedback:
Consistently use poll_time_jiffies.
Use be|le cpu endian helpers where applicable.
Add various comments.
Changes since V2:
Fix KernelVersion tag in Documentation.
Declare ad5933_default_pdata static.
Fix typos.
A very simple use of a kfifo as an alternative for the ring_sw
Tested-by: Michael Hennerich <michael.hennerich@analog.com>
This also kicks off the new resolver subsection.
Signed-off-by: Graf Yang <graf.yang@analog.com>
This also kicks off the new meter subsection.
Signed-off-by: Barry Song <barry.song@analog.com>
This is the initial driver in the new Direct Digital Synthesis section.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
This is used to convert digital streams into voltages.
IIO driver for temperature sensor, ADC and DAC devices over SPI and I2C.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Adding support for the Honeywell HMC5843. The interface to the device is
i2c
TODO:
Adding the documentation
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
Standardize the spacing/style across the IIO build files:
- comment block in Kconfigs
- newlines at ends of files
- trailing lines at ends of files
- indent with one tab, not spaces or mixed
Signed-off-by: Barry Song <Barry.Song@analog.com>
The original posting of this driver led to a discussion in
which it was commented that a better system was needed
for dealing with the many possible periodic interrupt
sources available on some SoCs. Unfortunately that is
a big task and as far as I know, no-one has taken it
on as yet. So in the meantime this driver is still
in here.
Please note this ring buffer implementation is very much a
work in progress (and hence RFC). In it's current form
it is stable and reasonably efficient. There are a couple
of unlikely cases that will lead to more data being lost
that is strictly necessary. The target was for the case
of requiring regular sampling even during user space reads.
All comments welcome.
The intention is to make this only one of several
implementations with run time selection. For now there
is only one, so it is hard coded into the drivers using it.
Add general registration support for IIO triggers. These
are currently only used to initialize a 'poll' of a given
device. Examples include the lis3l02dq's data ready signal
being used to initialize a read and gpio triggers being
used to allow externally synchronized sensor reading.
Each trigger can cause any number of 'consumer' devices
to be polled with each storing data into a related ring
buffer.
Two stage triggering is supported with 'fast' and 'slow'
paths. The first is used for things like pulling a data
hold line high and the second for actual read which
may take far longer.
Changes since V2:
* As with IIO triggers now use a registration approach
much closer to that of input leading to cleaner code.
This provides a unified interface for hardware and software
ring buffers.
Changes since V2:
* Moved to a more consistent structure. Now the ring buffer
has an associated struct device which is a child of the
relevant iio_dev. This in turn has two children, one
for the event interface and one for the access interface.
These two interfaces are now managed via cdev structures.
* Numerous minor cleanups
A later patch in the series will add data ready triggering
and ring buffer support.
This core patch provides an event interface and sysfs
based reading of values.
This is a pretty minimalist example of an IIO driver.
Core support for MAX1361, MAX1362, MAX1363, MAX1364,
MAX1136, MAX1137, MAX1138, MAX1139, MAX1236, MAX1237,
MAX1238, MAX1239.
Ring buffer support later in series.
