This adds an ADC driver for the STMPE device using the industrial
input/output interface. The driver supports raw reading of values.
The driver depends on the MFD stmpe driver. If the touchscreen
block is enabled too, only for of the 8 ADC channels are available.
New driver for AD7792/AD7793 3-Channel, Low Noise,
Low Power, 16-/24-Bit Sigma-Delta ADC with On-Chip In-Amp
and Reference.
The AD7792/AD7793 features a dual use data out ready DOUT/RDY output.
In order to avoid contentions on the SPI bus, it's necessary to use
spi bus locking. The DOUT/RDY output must also be wired to an
interrupt capable GPIO.
In INDIO_RING_TRIGGERED mode, this driver may block its SPI bus segment
for an extended period of time.
Changes since V1:
Use bool where applicable.
Use data buffer that lives in their own cache line.
Restructure ad7793_calibrate_all to use an array.
Use msleep.
Query REG_ID instead of doing a write/read This is a test.
Add support for unipolar mode.
Drop range attribute in favor of write scale.
Add proper locking.
Use new validate_trigger callbacks.
Use IIO_IN_DIFF for differential channels.
Change attribute naming.
Use available_scan_masks.
Some other miscellaneous cleanup (none functional changes).
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
V2: IIO_CHAN macro usage update.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Changes since v1:
IIO: ADC: AD7780: Apply review feedback
Abort probe() with error in case platform_data is not present.
Add comment explaining power down reset (PDRST) GPIO handling
and dual function DOUT/RDY interrupt usage.
This patch adds support for the
AD7298: 8-Channel, 1MSPS, 12-Bit SAR ADC with Temperature Sensor
via SPI bus.
This patch replaces the existing ad7298.c driver completely.
It was necessary since, the old driver did not comply with the
IIO ABI for such devices.
Changes since V1:
IIO: ADC: New driver for the AD7298 8-channel SPI ADC
Add documentation for new sysfs file tempX_input.
Simplify bit defines.
Remove outdated comments.
Fix indention style.
ad7298_show_temp():
Add locking.
Simplify temperature calculation.
Change temperature result from degrees into milli degrees Celsius.
Rename file according to new sysfs ABI documentation
Add timestamp attributes.
Revise timestamp handling accordingly.
Preset timestamp generation.
Reviewed-by: Shubhrajyoti <Shubhrajyoti@ti.com>
This patch adds support for the:
AD7606/AD7606-6/AD7606-4 8/6/4-Channel Data Acquisition
system (DAS) with 16-Bit, Bipolar, Simultaneous Sampling ADC.
Changes since V1:
IIO: ADC: New driver for AD7606/AD7606-6/AD7606-4: Apply review feedback
Rename sysfs node oversampling to oversampling_ratio.
Kconfig: Add GPIOLIB dependency.
Use range in mV to better match HWMON.
Rename ad7606_check_oversampling.
Fix various comments and style.
Reorder is_visible cases.
Use new gpio_request_one/array and friends.
Drop check for SPI max_speed_hz.
Changes since V2:
Documentation: specify unit
Avoid raise condition in ad7606_scan_direct()
Check return value of bus ops read_block()
Changes since V3:
IIO: ADC: New driver for AD7606/AD7606-6/AD7606-4: Add missing include file
Add linux/sched.h
Changes since V4:
IIO: ADC: New driver for AD7606/AD7606-6/AD7606-4: Fix kconfig declaration
consistently use tristate to avoid configuration mismatches
Enable support for AD7887: SPI Micropower, 2-Channel, 125 kSPS, 12-Bit ADC
staging: iio: adc: Fix according to review feedback
Review feedback by Jonathan Cameron:
Combine statements.
Document struct members.
Remove redundant variable initialization.
Simplify multichannel scan from ring logic.
Fix coding style.
[v2]
staging: iio: adc: ad7887: Fix typos
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Barry Song <barry.song@analog.com>
Randy Dunlap
Fix function function decalration
Enable CONFIG_IIO_RING_BUFFER for the ad7476 driver
Print in_scale in decimal format.
Kconfig list the names of the parts in full, to ease seraching.
Use st->spi in the call as it is only used the once.
New driver handling:
AD7475, AD7476, AD7477, AD7478, AD7466, AD7467, AD7468, AD7495
SPI micropower and high speed 12-/10-/8-Bit ADCs
staging: iio: adc: ad7476 apply list review feedback by Jonathan Cameron
Changes since last RFC post V1:
Mainly list review feedback by Jonathan Cameron
-Remove scan_attrs from chip info structure.
-Remove name from chip info structure, use new spi_device_id instead.
-Allow transfer buffers to live in their own cache lines, to avoid DMA/cache coherency issues.
-Move scan el code into the ring buffer file.
-Use helper function to alloc the pollfunc.
-Use regulator framework and get vref_mv from the regulator in case not specified by pdata.
-Devices with buit-in reference use vref from the chip info structure
-Don't error on missing platform_data
-Make vref_mv type unsigned short
-Print in_scale "Vref / 2^(bits)" if fractional.
Driver for ad7991, ad7995, ad7999, ad7992, ad7993, ad7994, ad7997 and
ad7998 multichannel ADC.
max11600-5
max1363 uses both the iio hardware ring buffer and software
ring buffer interfaces, but its Makefile and Kconfig do not
reflect that usage, so its build breaks. Add a new Kconfig
symbol to reflect that usage and change max1363.h & Makefile
to use the new Kconfig symbol.
Both the max1363 and lis3l02dq modules rely on IIO trigger support in
their ring buffer implementations, which is presently a separate config
option. In the case of IIO_RING_BUFFER=y and IIO_TRIGGER=n, we end up
with the following:
ERROR: "iio_trigger_attach_poll_func" [drivers/staging/iio/adc/max1363.ko] undefined!
ERROR: "iio_trigger_dettach_poll_func" [drivers/staging/iio/adc/max1363.ko] undefined!
ERROR: "iio_trigger_unregister" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_trigger_notify_done" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_trigger_read_name" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_trigger_poll" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_trigger_attach_poll_func" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_trigger_register" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_free_trigger" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_trigger_dettach_poll_func" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
ERROR: "iio_allocate_trigger" [drivers/staging/iio/accel/lis3l02dq.ko] undefined!
make[1]: *** [__modpost] Error 1
make: *** [modules] Error 2
This adds an IIO_TRIGGER select for these two drivers conditional on
IIO ring buffer support. Caught with an SH randconfig in -next.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Core support for MAX1361, MAX1362, MAX1363, MAX1364,
MAX1136, MAX1137, MAX1138, MAX1139, MAX1236, MAX1237,
MAX1238, MAX1239.
Ring buffer support later in series.
