This patch fixes the following checkpatch.pl warning:
WARNING: line over 80 charcaters
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch fixes following checkpatch.pl warning:
WARNING: else is not generally useful after a break or return
Acked-by: Daniel Baluta <daniel.baluta@intel.com>
This patch fixes the checkpatch warning:
WARNING: quoted string split across lines
Signed-off-by: Darshana Padmadas <darshanapadmadas@gmail.com>
Correct spelling typo in comment within staging/iio
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
devm_iio_device_register simplifies the code.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
devm_* APIs are device managed and make code simpler.
Replace deprecated strict_strtol()/strict_strtoul() with
kstrtol()/kstrtoul(). Add missing checks for conversion return codes.
Signed-off-by: Aida Mynzhasova <ai.c.c0der@gmail.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jonathan Cameron <jic23@kernel.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Since commit 1c6c69525b ("genirq: Reject bogus threaded irq requests") threaded
IRQs without a primary handler need to be requested with IRQF_ONESHOT, otherwise
the request will fail. This patch adds the IRQF_ONESHOT to IIO drivers where it
is missing.
Replace open-coded instances of getting a iio_dev struct from a device struct
with dev_to_iio_dev().
Acked-by: Jonathan Cameron <jic23@kernel.org>
Currently we use two different naming schemes in the IIO API, iio_verb_object
and iio_object_verb. E.g iio_device_register and iio_allocate_device. This
patches renames instances of the later to the former. The patch also renames allocate to
alloc as this seems to be the preferred form throughout the kernel.
In particular the following renames are performed by the patch:
iio_put_device -> iio_device_put
iio_allocate_device -> iio_device_alloc
iio_free_device -> iio_device_free
iio_get_trigger -> iio_trigger_get
iio_put_trigger -> iio_trigger_put
iio_allocate_trigger -> iio_trigger_alloc
iio_free_trigger -> iio_trigger_free
The conversion was done with the following coccinelle patch with manual fixes to
comments and documentation.
<smpl>
-iio_put_device
+iio_device_put
-iio_allocate_device
+iio_device_alloc
-iio_free_device
+iio_device_free
-iio_get_trigger
+iio_trigger_get
-iio_put_trigger
+iio_trigger_put
-iio_allocate_trigger
+iio_trigger_alloc
-iio_free_trigger
+iio_trigger_free
</smpl>
Step 1 in moving the IIO core out of staging.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits)
net/hyperv: Add support for jumbo frame up to 64KB
net/hyperv: Add NETVSP protocol version negotiation
net/hyperv: Remove unnecessary kmap_atomic in netvsc driver
staging/rtl8192e: Register against lib80211
staging/rtl8192e: Convert to lib80211_crypt_info
staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops
staging/rtl8192e: Add lib80211.h to rtllib.h
staging/mei: add watchdog device registration wrappers
drm/omap: GEM, deal with cache
staging: vt6656: int.c, int.h: Change return of function to void
staging: usbip: removed unused definitions from header
staging: usbip: removed dead code from receive function
staging:iio: Drop {mark,unmark}_in_use callbacks
staging:iio: Drop buffer mark_param_change callback
staging:iio: Drop the unused buffer enable() and is_enabled() callbacks
staging:iio: Drop buffer busy flag
staging:iio: Make sure a device is only opened once at a time
staging:iio: Disallow modifying buffer size when buffer is enabled
staging:iio: Disallow changing scan elements in all buffered modes
staging:iio: Use iio_buffer_enabled instead of open coding it
Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of
module_init due to using module_i2c_driver() helper, next to removal of
MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_register_driver() so
we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
// <smpl>
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
// </smpl>
Issue brought up by Lars-Peter Clausen. This is a varient of what
he suggested.
io/iio.h for driver stuff (has to include types.h)
Sub files for the bits drivers may or may not use
iio/sysfs.h
iio/buffer.h (contents of current buffer_generic.h)
(obviously anything offering events will need events.h as well)
iio/types.h for the enums that matter to both
iio_chan_type, iio_modifier
iio/events.h for the event code stuff
IIO_EVENT_CODE and friends. + everything in chrdev.h So this
is the stuff that userspace cares about.
Also include iio_event_type, iio_event_direction
Thus iio drivers include iio.h + as required
events.h
sysfs.h
buffer.h
in kernel users (once that interface is merged) will need inkern.h
which will pull in types.h
Userspace will need just events.h (which pulls in types.h) to get
everything they need to know about. Buffer userspace access doesn't
currently need any core defines. All information about the data
format is passed through sysfs.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Use the newly introduced module_spi_driver macro for registering SPI drivers.
This allows us to remove a few lines of boilerplate code.
Fix a dumb lack of consideration of the effect of combining
the iio_device_unregister and iio_free_device calls into
one. There is no valid place to free some of the sysfs
array elements.
We had a random missmatch of these two. Lets pick the most common
and get rid of the other.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
This set also includes quite a number of bug fixes of particularly
remove functions.
Necessary due to issue pointed out in Bart Van Assche's patch:
docs/driver-model: Document device.groups
V2: Rebase due to patch reordering.
V3: Pull various error fixes and cleanups out into their own patches.
Acked-by: Michael Hennerich <Michael.Hennerich@analog.com>
This includes calling iio_free_device as that should only be called
before the device has been registered.
Also one case of iio_free_device being called on a registered device.
This has been pulled out of the reworking attributes patch.
We don't have a use case for these. Two drivers appeared to use them
but both report all events on the first.
V2: Remove now irrelevant comment.
V3: Include fixup for adc/ad7280a.c
buffer.
Change suggested by Arnd Bergmann.
No real reason to have two chrdevs per device. This step merges them into one.
Currently this means that events will only work on devices with buffers. THat will
be remedied shortly.
V2: set name for event attribute groups. Otherwise they all sorts of fun occurs on
dynamic channel event attribute creation.
Lots of people expect module.h to just "be there" without
any #include effort. But we are crushing that. So fix those
files in staging relying on implicit module.h presence.
IIO_EV_CLASS_<TYPE> etc
The original definitions were duplicated to reduce tree churn during introduction of chan_spec
registration. Now there is no point in maintaining the two sets of definitions.
access.
Again, get rid of unwanted iio_dev pointer in state.
elements out of iio_dev.
This was suggested by Arnd Bergmann, Other elements may well
move in here in future, but it definitely makes sense for these.
This was another abuse of the buffer event codes.
I'm not sure what the event is and am very much against the dodgy
hack to give it a code. However for now, lets just stop it using
the deprecated core handling so we can move on.
Suggested by Arnd Bergmann. Note this will break ALL drivers that
are out of mainline. The fix is trivial change of
iio_allocate_device() -> iio_allocate_device(0)
Sorry if this causes issues for any one!
V2: Include new drivers in the update
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
