Remove parentheses on the right hand side of assignment as they are not
needed. Semantic patch used:
expression a, b, c, d;
a = (c == d)
a =
b
Signed-off-by: Janani Ravichandran <janani.rvchndrn@gmail.com>
Remove the macros since they are not used anywhere throughout the
kernel.
Signed-off-by: Shraddha Barke <shraddha.6596@gmail.com>
Reviewed-by: Daniel Baluta <daniel.baluta@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next
Jonathan writes:
Second set of new drivers, functionality and cleanups for IIO in the 4.4 cycle.
Core stuff
* adjust resistance documentation to allow for output devices.
New device support:
* bmc150
- split the i2c driver up into a core and i2c_regmap part including regmap
conversion.
- add spi support.
* mcp4531 digitial potentiometer driver.
* Measurement Specialties set of drivers with a core library module providing
common functionality. Note that the htu21 has a driver in hwmon, but the
view from that side was that, given the range of devices the same silicon
turns up in are not all typical hwmon material, that driver would be
deprecated in favour of this new support.
- ms8607 temperature, pressure and humidty sensor
- ms5637 temperature and pressure sensor
- htu21 temperature and humidity sensor
- tsys02d temperature sensor
- tsys01 temperature sensor
Cleanups
* tree wide.
- squish cases where irq 0 is still considered valid.
* apds9960
- sparse endian warning cleanups by making endianness explicit.
* ad5504
- leave group naming to the core.
* ad7746
- cleanup comment style.
- drop an unnecessary bit of dev_info
- add some appropriate uses of the BIT macro.
* ad799x
* hdc100x - introduced this cycle,.
- fix a wrong offset value.
* lidar
- add missing MODULE_DEVICE_TABLE for dt.
* max1363
- leave sysfs group naming to the core.
* m62332 got the Harmut treatment and as ever he found a 'few' bits the
rest of us had missed!
- Share scale and offset attributes across channels.
- Shutdown the device on driver remove
- Use ARRAY_SIZE rather than a hard coded count for channels.
- Return more directly in the write_raw callback dropping a local variable
along the way.
- a few style issues
- move to reading the regulator voltage for each use allowing for dynamic
regulators. This is a common feature across drivers so we might end
up with more fixes throughout the tree for this.
* mlx96014 - introduced this cycle.
- fixed up a spot of error handling.
* vz89x - introduced this cycle.
- work around a hardware quirk.
This patch to ad7746.c makes the comment blocks end with a */
on a separate line, and start with a /* on an empty line.
Signed-off-by: Hugo Camboulive <hugo.camboulive@gmail.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch to ad7746.c makes the comment block end with a */
on a separate line.
Replace iio_device_register with resource managed devm_iio_device_register in order
to ease the error path. Also delete de remove function since there is no need after
this change.
Signed-off-by: Ioana Ciornei <ciorneiioana@gmail.com>
Remove dev_info as the information can be obtained by other means
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Replace bit shifting on 1 with the BIT(x) macro
This patch replaces bit shifting on 1 with the BIT(x) macro
This was done with coccinelle:
@@ int g; @@
-(1 << g)
+BIT(g)
Correct spelling typo in comment within staging/iio
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Some I2C controllers might not be able to handle transfer buffers that are
stored on stack.
Fixes the following warnings from sparse:
drivers/staging/iio/cdc/ad7746.c:599:25: warning: cast to restricted __be32
Move the complexity of calculating the fixed point scale to the core.
Using devm_iio_device_alloc makes code simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
The original info_mask is going away in favour of the broken out versions.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jonathan Cameron <jic23@kernel.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r1@
statement S;
position p,p1;
S@p1;@p
@script:python r2@
p << r1.p;
p1 << r1.p1;
if p[0].line != p1[0].line_end:
cocci.include_match(False)
position r1.p;
-;@p
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Replace open-coded instances of getting a iio_dev struct from a device struct
with dev_to_iio_dev().
Acked-by: Jonathan Cameron <jic23@kernel.org>
Currently we use two different naming schemes in the IIO API, iio_verb_object
and iio_object_verb. E.g iio_device_register and iio_allocate_device. This
patches renames instances of the later to the former. The patch also renames allocate to
alloc as this seems to be the preferred form throughout the kernel.
In particular the following renames are performed by the patch:
iio_put_device -> iio_device_put
iio_allocate_device -> iio_device_alloc
iio_free_device -> iio_device_free
iio_get_trigger -> iio_trigger_get
iio_put_trigger -> iio_trigger_put
iio_allocate_trigger -> iio_trigger_alloc
iio_free_trigger -> iio_trigger_free
The conversion was done with the following coccinelle patch with manual fixes to
comments and documentation.
<smpl>
-iio_put_device
+iio_device_put
-iio_allocate_device
+iio_device_alloc
-iio_free_device
+iio_device_free
-iio_get_trigger
+iio_trigger_get
-iio_put_trigger
+iio_trigger_put
-iio_allocate_trigger
+iio_trigger_alloc
-iio_free_trigger
+iio_trigger_free
</smpl>
Step 1 in moving the IIO core out of staging.
There is no longer any need for this as we have separate
info_mask elements for raw and processed value reads.
Precursor to making value read / write attribute optional.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits)
net/hyperv: Add support for jumbo frame up to 64KB
net/hyperv: Add NETVSP protocol version negotiation
net/hyperv: Remove unnecessary kmap_atomic in netvsc driver
staging/rtl8192e: Register against lib80211
staging/rtl8192e: Convert to lib80211_crypt_info
staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops
staging/rtl8192e: Add lib80211.h to rtllib.h
staging/mei: add watchdog device registration wrappers
drm/omap: GEM, deal with cache
staging: vt6656: int.c, int.h: Change return of function to void
staging: usbip: removed unused definitions from header
staging: usbip: removed dead code from receive function
staging:iio: Drop {mark,unmark}_in_use callbacks
staging:iio: Drop buffer mark_param_change callback
staging:iio: Drop the unused buffer enable() and is_enabled() callbacks
staging:iio: Drop buffer busy flag
staging:iio: Make sure a device is only opened once at a time
staging:iio: Disallow modifying buffer size when buffer is enabled
staging:iio: Disallow changing scan elements in all buffered modes
staging:iio: Use iio_buffer_enabled instead of open coding it
Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of
module_init due to using module_i2c_driver() helper, next to removal of
MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
Internally the fact that say scale is shared across channels is
actually of remarkably little interest. Hence lets not store it.
Numerous devices have weird combinations of channels sharing
scale anyway so it is not as though this was really telling
us much. Note however that we do still use the shared sysfs
attrs thus massively reducing the number of attrs in complex
drivers.
Side effect is that certain drivers that were abusing this
(mostly my work) needed to do a few more checks on what the
channel they are being queried on actually is.
This is also helpful for in kernel interfaces where we
just want to query the scale and don't care whether it
is shared with other channels or not.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Currently the iio framework uses bitmasks for the address field of channel info
attributes. This is for historical reasons and no longer required since it will
only ever query a single info attribute at once. This patch changes the code to
use the non-shifted iio_chan_info_enum values for the info attribute address.
Use the newly introduced module_i2c_driver macro for registering I2C drivers.
This allows us to remove a few lines of boilerplate code.
No functional changes.
Fix Kconfig description.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
