Route all buffer writes through the demux.
Addition or removal of a buffer results in tear down and
setup of all the buffers for a given device.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Tested-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
This resolves the conflict with:
drivers/staging/comedi/drivers/amplc_dio200.c
and syncs up the changes that happened in the staging directory for
3.7-rc3.
Most of the channel offsets and scales in the adis16260 are incorrect:
* Temperature scale is off by a factor of 1000
* Voltage scale is off by a factor of 1000
* Temperature offset is completely wrong
This patch fixes these issues. Also use the IIO_DEGREE_TO_RAD for the angle
velocity since this makes it much easier to compare it to the value given in the
datasheet.
Some drivers define a DRIVER_NAME, but never use the define. This patch removes
defines.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r1@
statement S;
position p,p1;
S@p1;@p
@script:python r2@
p << r1.p;
p1 << r1.p1;
if p[0].line != p1[0].line_end:
cocci.include_match(False)
position r1.p;
-;@p
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
In the Linux device driver model the remove callback is not allowed to fail and
the device will be removed regardless of the return value of the remove
callback. So if we abort in the remove function and do not free all resources we
will create a resource leak. Also all kinds of undefined behaviour are expected
to happen since the IIO device is still there while its parent is already gone.
The error which the driver tries to handle in the remove function is
non-critical, so we can just ignore it and continue to free all resources and
remove the IIO device.
This pulls in the staging tree fixes in 3.6-rc6 into our branch to resolve the
merge issues.
Drop timestamp parameter from buffer store_to callback and subsequently from
iio_push_to_buffer. The timestamp parameter is unused and it seems likely that
it will stay unused in the future, so it should be safe to remove it.
Consistently use iio_push_to_buffer instead of manually calling the buffers
store_to callback.
"val" is used as a divisor later, so we should check for zero here to
avoid a division by zero.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Autogenerated using the following coccinelle semantic patch:
// <smpl>
@r1@
identifier driver;
identifier fn;
position p;
type T;
T driver = {
.remove =
fn@p
__devexit_p(fn@p)
@r2@
identifier r1.fn;
position p != r1.p;
fn@p
@r3@
identifier r1.fn;
position r1.p;
__devexit_p(fn@p)
-fn@p
+__devexit_p(fn)
@depends on !r2@
identifier r1.fn;
static
-int fn
+int __devexit fn
@r11@
identifier driver;
identifier fn;
position p;
type T;
T driver = {
.probe = fn@p
@r12@
identifier r11.fn;
position p != r11.p;
fn@p
@depends on !r12@
identifier r11.fn;
static
-int fn
+int __devinit fn
// </smpl>
The SPI drvdata is set to adis16260_state struct in probe(), but assumed to be
the iio_dev struct in remove(). Fix this by setting it to the iio_dev in
probe().
The issue has been discovered using the following coccinelle patch:
// <smpl>
@r1@
type T;
T data;
expression dev;
spi_set_drvdata(dev, (void *)data)
spi_set_drvdata(dev, data)
@r2@
type r1.T;
T data;
position p;
expression dev;
data = spi_get_drvdata@p(dev)
@depends on r1@
position p != r2.p;
expression dev;
identifier data;
*data = spi_get_drvdata@p(dev)
// </smpl>
The interrupt handler should only ever return one of the three irqreturn_t
constants and not an error code. Also make sure to always call
iio_trigger_notify_done before leaving the trigger handler.
There is no reason for userspace to do this, so lets
drop this abi.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
None of these drivers ever schedule any work, so there is no need to flush any
scheduled work when the driver is removed.
Acked-by: Jonathan Cameron <jic23@kernel.org>
Removed the following sparse warning:
In function 'adis16080_read_raw':
warning: 'ut' may be used uninitialized in this function
Signed-off-by: Leed Aguilar <leed.aguilar@ti.com>
Cc: Jonathan Cameron <jic23@kernel.org>
Replace open-coded instances of getting a iio_dev struct from a device struct
with dev_to_iio_dev().
When calling adis16260_read_ring_data we pass the device struct of embedded in
the IIO device only to look up the IIO device from the device struct again right
away. This patch changes the code to pass the IIO device directly.
Correct spelling typo in staging/iio
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Michael Hennerich<michael.hennerich@analog.com>
Currently we use two different naming schemes in the IIO API, iio_verb_object
and iio_object_verb. E.g iio_device_register and iio_allocate_device. This
patches renames instances of the later to the former. The patch also renames allocate to
alloc as this seems to be the preferred form throughout the kernel.
In particular the following renames are performed by the patch:
iio_put_device -> iio_device_put
iio_allocate_device -> iio_device_alloc
iio_free_device -> iio_device_free
iio_get_trigger -> iio_trigger_get
iio_put_trigger -> iio_trigger_put
iio_allocate_trigger -> iio_trigger_alloc
iio_free_trigger -> iio_trigger_free
The conversion was done with the following coccinelle patch with manual fixes to
comments and documentation.
<smpl>
-iio_put_device
+iio_device_put
-iio_allocate_device
+iio_device_alloc
-iio_free_device
+iio_device_free
-iio_get_trigger
+iio_trigger_get
-iio_put_trigger
+iio_trigger_put
-iio_allocate_trigger
+iio_trigger_alloc
-iio_free_trigger
+iio_trigger_free
</smpl>
Step 1 in moving the IIO core out of staging.
This will be needed when multiple buffer support is added.
Precursor to making value read / write attribute optional.
No processed values in gyroscopes.
This macro is being removed to simplify ongoing maintenance
so we need to unwind and remaining users.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
Different tree maintainers picked up independently generated
trivial compile fixes based on linux-next testing, resulting
in some cases where a file would have got more than one addition
of module.h once everything was all merged together.
Delete any duplicates so includecheck isn't complaining about
anything related to module.h/export.h changes.
Setup the buffer access functions in the buffer allocate function. There is no
need to let each driver handle this on its own.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits)
net/hyperv: Add support for jumbo frame up to 64KB
net/hyperv: Add NETVSP protocol version negotiation
net/hyperv: Remove unnecessary kmap_atomic in netvsc driver
staging/rtl8192e: Register against lib80211
staging/rtl8192e: Convert to lib80211_crypt_info
staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops
staging/rtl8192e: Add lib80211.h to rtllib.h
staging/mei: add watchdog device registration wrappers
drm/omap: GEM, deal with cache
staging: vt6656: int.c, int.h: Change return of function to void
staging: usbip: removed unused definitions from header
staging: usbip: removed dead code from receive function
staging:iio: Drop {mark,unmark}_in_use callbacks
staging:iio: Drop buffer mark_param_change callback
staging:iio: Drop the unused buffer enable() and is_enabled() callbacks
staging:iio: Drop buffer busy flag
staging:iio: Make sure a device is only opened once at a time
staging:iio: Disallow modifying buffer size when buffer is enabled
staging:iio: Disallow changing scan elements in all buffered modes
staging:iio: Use iio_buffer_enabled instead of open coding it
Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of
module_init due to using module_i2c_driver() helper, next to removal of
MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Add missing scale attributes.
Temperature data is presented as 10-bit, twos complement number.
Therefore use singed and shift accordingly.
In all existing cases, the calls are coming from a location where
the indio_dev is already available.
Legacy of having multiple chrdevs that never got cleaned up.
Obviously drivers should only use this for pushing to buffers.
They need buffer->scan_mask for pulling from them post demux.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
These callbacks should not be buffer instance specific.
Hence move them out of the buffer.
Has no remaining users.
Quite a few iio drivers provide no MODULE_DEVICE_TABLE or MODULE_ALIAS or only
provide a MODULE_ALIAS while they have support for multiple device ids. This
prevents auto module loading from working correctly.
This patch fixes it by adding the missing MODULE_DEVICE_TABLEs and
MODULE_ALIAS'.
Internally the fact that say scale is shared across channels is
actually of remarkably little interest. Hence lets not store it.
Numerous devices have weird combinations of channels sharing
scale anyway so it is not as though this was really telling
us much. Note however that we do still use the shared sysfs
attrs thus massively reducing the number of attrs in complex
drivers.
Side effect is that certain drivers that were abusing this
(mostly my work) needed to do a few more checks on what the
channel they are being queried on actually is.
This is also helpful for in kernel interfaces where we
just want to query the scale and don't care whether it
is shared with other channels or not.
Currently the iio framework uses bitmasks for the address field of channel info
attributes. This is for historical reasons and no longer required since it will
only ever query a single info attribute at once. This patch changes the code to
use the non-shifted iio_chan_info_enum values for the info attribute address.
Issue brought up by Lars-Peter Clausen. This is a varient of what
he suggested.
io/iio.h for driver stuff (has to include types.h)
Sub files for the bits drivers may or may not use
iio/sysfs.h
iio/buffer.h (contents of current buffer_generic.h)
(obviously anything offering events will need events.h as well)
iio/types.h for the enums that matter to both
iio_chan_type, iio_modifier
iio/events.h for the event code stuff
IIO_EVENT_CODE and friends. + everything in chrdev.h So this
is the stuff that userspace cares about.
Also include iio_event_type, iio_event_direction
Thus iio drivers include iio.h + as required
events.h
sysfs.h
buffer.h
in kernel users (once that interface is merged) will need inkern.h
which will pull in types.h
Userspace will need just events.h (which pulls in types.h) to get
everything they need to know about. Buffer userspace access doesn't
currently need any core defines. All information about the data
format is passed through sysfs.
Use the newly introduced module_spi_driver macro for registering SPI drivers.
This allows us to remove a few lines of boilerplate code.
This 2nd batch of implicit module.h users only appeared when we
removed the unnecessary module.h from include/linux/miscdevice.h
[The 1st batch is already present in Greg's staging tree.]
Lots of drivers have in the past expected the presence of basic things
like THIS_MODULE and EXPORT_SYMBOL. With the header cleanup, they wont
have these. Call out the include explicitly.
Fix a dumb lack of consideration of the effect of combining
the iio_device_unregister and iio_free_device calls into
one. There is no valid place to free some of the sysfs
array elements.
Numerous drivers either had pointless includes of gpio.h
or should have been dependent on GENERIC_GPIO and were not.
Conversion of ads1210 to use array registration triggered
build failures that highlighted all was not well.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Ensure naming reflects what is measured, not how it is done.
Resolvers can measure the same thing for starters.
IIO_GYRO->IIO_ANGL_VEL to ensure consistent naming.
This was originally there to avoid churn during a complex change.
Now everything is stable lets get rid of this as it is missleading
and confusing.
They aren't always ring buffers, so just use buffer for all naming.
Nothing in this file is specific to RING buffers so rename it.
