Starting with commit fd2bb310ca (Staging: iio: Move evgen interrupt
generation to irq_work) event processing is handled by calling
both the top half and the threaded part properly simulating real
hardware interrupts making use of threaded interrupts.
This way the processing is split in 2 parts:
* the IRQ handler that runs in IRQ context and only saves the event
timestamp
* the threaded handler that runs in process context, reads the events
and pushes the in the userspace.
If the IRQ handler returns IRQ_HANDLED the threaded handler is not
even being called since the interrupt is considered to be processed.
Because the iio dummy driver processes the events in the threaded
handler the IRQ handler must return IRQ_WAKE_THREAD so that the
threaded part would be awakened and called.
Signed-off-by: Ioana Ciornei <ciorneiioana@gmail.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Enhance interrupt generation in the dummy driver and expand its usage
by introducing the irq_work infrastructure to trigger an interrupt.
This way, the irq_work_queue() wrapper permits calling both of the top
half and threaded part from a hard irq context, unlike handle_nested_irq(),
which only calls the threaded part.
As an outcome, the driver succeeds in simulating real hardware
interrupts, while keeping the normal interrupt flow.
Signed-off-by: Cristina Opriceana <cristina.opriceana@gmail.com>
Acked-by: Daniel Baluta <daniel.baluta@intel.com>
Fixing indentation errors in
drivers/staging/iio/iio_simple_dummy_events.c.
Signed-off-by: Lars Svensson <lars1.svensson@sonymobile.com>
The functions iio_dummy_remove(), iio_simple_dummy_events_unregister() and
iio_dummy_evgen_release_irq() were changed to return void instead of int.
Signed-off-by: Vladimirs Ambrosovs <rodriguez.twister@gmail.com>
Shock horror, example template code that has never been used in reality is
in fact a hazard. This fixes the obvious bug, probably these kind of
"examples" should be deleted so real (working) examples are followed.
Signed-off-by: Alan Cox <alan@linux.intel.com>
By introducing IIO_EV_TYPE_CHANGE, IIO_EV_TYPE_INSTANCE becomes redundant.
The effect of IIO_EV_TYPE_INSTANCE can be obtained by using IIO_EV_TYPE_CHANGE
with IIO_EV_INFO_VALUE set to 1.
Remove all instances of IIO_EV_TYPE_INSTANCE and replace them with
IIO_EV_TYPE_CHANGE where needed.
Signed-off-by: Irina Tirdea <irina.tirdea@intel.com>
Adds support for the new channel types in the dummy driver:
* a new channel IIO_ACTIVITY
* two state transition events (running and walking)
* a new channel IIO_STEPS and support for reading and writing
pedometer step counter
* step detect event
* a new IIO_CHAN_INFO_CALIBHEIGHT mask bit for reading and writing
user's height.
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
We need a way to store events generated by iio_dummy_evgen module,
in order to correctly process IRQs in iio_simple_dummy_events.
For the moment, we add two registers:
* id_reg - ID register, stores the source of the event
* id_data - DATA register, stores the type of the event
e.g echo 4 > /sys/bus/iio/devices/iio_evgen/poke2
id_reg 0x02, id_data 0x04
This means, event of type 4 was generated by fake device 2.
We currently use a hardcoded mapping of virtual events to IIO events.
This fixes the following checkpatch.pl warning:
WARNING: Missing a blank line after declarations.
Signed-off-by: Catalina Mocanu <catalina.mocanu@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Switch the simple_dummy driver to the new IIO event config interface as the old
one is going to be removed.
Correct spelling typo in staging/iio
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Michael Hennerich<michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Step 1 in moving the IIO core out of staging.
Issue brought up by Lars-Peter Clausen. This is a varient of what
he suggested.
io/iio.h for driver stuff (has to include types.h)
Sub files for the bits drivers may or may not use
iio/sysfs.h
iio/buffer.h (contents of current buffer_generic.h)
(obviously anything offering events will need events.h as well)
iio/types.h for the enums that matter to both
iio_chan_type, iio_modifier
iio/events.h for the event code stuff
IIO_EVENT_CODE and friends. + everything in chrdev.h So this
is the stuff that userspace cares about.
Also include iio_event_type, iio_event_direction
Thus iio drivers include iio.h + as required
events.h
sysfs.h
buffer.h
in kernel users (once that interface is merged) will need inkern.h
which will pull in types.h
Userspace will need just events.h (which pulls in types.h) to get
everything they need to know about. Buffer userspace access doesn't
currently need any core defines. All information about the data
format is passed through sysfs.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
The event generator is not very pretty but does the job and
allows this driver to look a lot more like a normal driver
than it otherwise would.
