The driver leaves the device in power-down state anyway,
so there is nothing to do on suspend.
On resume, we just have to make sure the range and ADC
values are updated in the device since it may have been
powered down in suspend.
Signed-off-by: Bryan Freed <bfreed@chromium.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
The Industrial IO framework supports scaling ADC values by fractions,
but most drivers default to using whole numbers.
This change turns on fractional scaling in the isl29018 driver.
beware, does change the ABI as proximity_on_chip_ambient_infrared_supression
is changed to proximity_on_chip_ambient_infrared_suppression
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
Replace open-coded instances of getting a iio_dev struct from a device struct
with dev_to_iio_dev().
Currently we use two different naming schemes in the IIO API, iio_verb_object
and iio_object_verb. E.g iio_device_register and iio_allocate_device. This
patches renames instances of the later to the former. The patch also renames allocate to
alloc as this seems to be the preferred form throughout the kernel.
In particular the following renames are performed by the patch:
iio_put_device -> iio_device_put
iio_allocate_device -> iio_device_alloc
iio_free_device -> iio_device_free
iio_get_trigger -> iio_trigger_get
iio_put_trigger -> iio_trigger_put
iio_allocate_trigger -> iio_trigger_alloc
iio_free_trigger -> iio_trigger_free
The conversion was done with the following coccinelle patch with manual fixes to
comments and documentation.
<smpl>
-iio_put_device
+iio_device_put
-iio_allocate_device
+iio_device_alloc
-iio_free_device
+iio_device_free
-iio_get_trigger
+iio_trigger_get
-iio_put_trigger
+iio_trigger_put
-iio_allocate_trigger
+iio_trigger_alloc
-iio_free_trigger
+iio_trigger_free
</smpl>
Step 1 in moving the IIO core out of staging.
Using regmap for accessing register through i2c bus. This will
remove the code for caching registers, read-modify-write logics.
Also it will provide the debugfs feature to dump register
through regmap debugfs.
Reviewed-by: Grant Grundler <grundler@chromium.org>
ISL29018/ISL29028 is from Intersil Corporation and making the
vendor prefix for this part as "isil" for OF compatibity.
There is no longer any need for this as we have separate
info_mask elements for raw and processed value reads.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Precursor to making value read / write attribute optional.
Note that minimal change route taken here. The read_raw callbacks
in both drivers could do fewer checks to identify the channel than
they now do.
As simple as can be right now; just one ID and no custom properties to parse.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits)
net/hyperv: Add support for jumbo frame up to 64KB
net/hyperv: Add NETVSP protocol version negotiation
net/hyperv: Remove unnecessary kmap_atomic in netvsc driver
staging/rtl8192e: Register against lib80211
staging/rtl8192e: Convert to lib80211_crypt_info
staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops
staging/rtl8192e: Add lib80211.h to rtllib.h
staging/mei: add watchdog device registration wrappers
drm/omap: GEM, deal with cache
staging: vt6656: int.c, int.h: Change return of function to void
staging: usbip: removed unused definitions from header
staging: usbip: removed dead code from receive function
staging:iio: Drop {mark,unmark}_in_use callbacks
staging:iio: Drop buffer mark_param_change callback
staging:iio: Drop the unused buffer enable() and is_enabled() callbacks
staging:iio: Drop buffer busy flag
staging:iio: Make sure a device is only opened once at a time
staging:iio: Disallow modifying buffer size when buffer is enabled
staging:iio: Disallow changing scan elements in all buffered modes
staging:iio: Use iio_buffer_enabled instead of open coding it
Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of
module_init due to using module_i2c_driver() helper, next to removal of
MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
Internally the fact that say scale is shared across channels is
actually of remarkably little interest. Hence lets not store it.
Numerous devices have weird combinations of channels sharing
scale anyway so it is not as though this was really telling
us much. Note however that we do still use the shared sysfs
attrs thus massively reducing the number of attrs in complex
drivers.
Side effect is that certain drivers that were abusing this
(mostly my work) needed to do a few more checks on what the
channel they are being queried on actually is.
This is also helpful for in kernel interfaces where we
just want to query the scale and don't care whether it
is shared with other channels or not.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Currently the iio framework uses bitmasks for the address field of channel info
attributes. This is for historical reasons and no longer required since it will
only ever query a single info attribute at once. This patch changes the code to
use the non-shifted iio_chan_info_enum values for the info attribute address.
Use the newly introduced module_i2c_driver macro for registering I2C drivers.
This allows us to remove a few lines of boilerplate code.
Fix a dumb lack of consideration of the effect of combining
the iio_device_unregister and iio_free_device calls into
one. There is no valid place to free some of the sysfs
array elements.
No functional change, just a trivial tidy up so all drivers
do the same thing.
V3 is a straightforward forward port to teh current tree of V2.
Simple fix is to just not cache REG_TEST (offset 8).
Cache doesn't help REG_TEST anyway since we write all 8 bits exactly once
(at resume/init time).
Also fix an "off-by-one" allocation of reg_cache[] array size that
was in the original code before I touched it.
Reported-by: Dan Carpenter <error27@gmail.com>
Signed-off-by: Grant Grundler <grundler@chromium.org>
These are no longer needed.
Requires a few driver updates for places "sysfs.h" should have been
present but wasn't.
After a voltage brownout, sensor will now operate correctly.
Page 10 of ISL29018 data sheet and the Intersil Application Note 1534
describe the required initialization sequence:
1. Write 0x00 to register 0x08 (TEST)
2. Write 0x00 to register 0x00 (CMD1)
3. msleep(1)
4. program remaining registers as before
Reviewed-by: Bryan Freed <bfreed@chromium.org>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
iio_chan_spec framework.
Remove the driver's get_sensor_data() interfaces and replace them with
iio_chan_spec channels. This converts 4 files to the new framework.
Driver ABI change: The intensity_infrared_raw file is now intensity_ir_raw.
The I2C clientdata is set to indio_dev instead of chip as of a couple weeks ago.
Correct the calls to i2c_get_clientdata() accordingly.
Otherwise the driver fails to initialize.
sensor driver.
Defaulting to 1, this gives a way to amplify the lux value before being
reduced by the programmed adc_bit shift.
Only support whole numbers right now. When this driver is converted to the new
IIO_CHAN framework, it will be easy to support the framework's pseudo float.
Add illuminance0_calibscale documentation to sysfs-bus-iio-light.
Acked-by: Rhyland Klein <rklein@nvidia.com>
V2: Actually allocate the space for iio_priv
elements out of iio_dev.
This was suggested by Arnd Bergmann, Other elements may well
move in here in future, but it definitely makes sense for these.
Suggested by Arnd Bergmann. Note this will break ALL drivers that
are out of mainline. The fix is trivial change of
iio_allocate_device() -> iio_allocate_device(0)
Sorry if this causes issues for any one!
V2: Include new drivers in the update
adding support for the ISL 29018 ambient light and proximity sensor.
Addressed comments from reviews by Jonathan Cameron and Joe Perches
* Removed some excess dbg prints that only printed function name
* Renamed some properties to make them more descriptive
* Added a property to list available adc resolutions
* Defined arrays for resolutions/ranges as static const
* Change loops initialization to memset for extensibility.
* used sizeof() instead of ARRAY_SIZE() to be safer
* Added a property to list available adc ranges
* Fixed warnings and property names.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
