When grepping through sysfs, grep tries to read all sysfs files
which are available. Some of them lead to error due to null pointers.
Therefor check for null pointers before using them.
This adds an ADC driver for the STMPE device using the industrial
input/output interface. The driver supports raw reading of values.
The driver depends on the MFD stmpe driver. If the touchscreen
block is enabled too, only for of the 8 ADC channels are available.
set is_int_enable to true only if we register for a irq.
Bug 1211260
Change-Id: I603efe721796db70d504da7999e5d7939d45d13a
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/193047
(cherry picked from commit 8b89b2b64c67d80fcfc29cd4f6a92d4527e70df9)
Reviewed-on: http://git-master/r/195844
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Change-Id: I34748241728bb0bab1861f8abacffdfe2939740f
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/109158
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Adding driver for Ambient Light and Proximity sensor from
Lite On Technology.
This driver has sysfs interface to get the als and proximity values
and enable/disable als and proximity.
Bug 901133
Change-Id: Iafa0346d74825a67d94143181922de7a16cc7718
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/83837
Reviewed-by: Darrell Hunt <dhunt@nvidia.com>
i2c_get_clientdata() returns an object of type struct indio_dev and not
of type struct ak8975_data.
Bug 946328
Change-Id: I5803306d6a7829cdf822d22f51fdcdb769fbea1d
Reviewed-on: http://git-master/r/88329
Reviewed-by: Mursalin Akon <makon@nvidia.com>
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Fix ak8975_probe() to jump to the appropriate exit labels when an error
occurs. With the previous code, some cleanup actions were being skipped
for some error conditions.
Upstream v3.2 commit ad31d250bf60c8e4c990e8b0daeedbaa2d6884a9
Change-Id: Ib0ef38f154fbcf18604ad283f51f040b5e038c65
Acked-by: Andrew Chew <achew@nvidia.com>
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83532
Reviewed-by: Andrew Chew <achew@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
gpio_is_valid() is the defined mechanism to determine whether a GPIO is
valid. Use this instead of assuming that 0 is an invalid GPIO.
Upstream v3.2 commit 7c6c936832a46e86b0fac654923ce5015bdc80ee
Change-Id: Ica81b9fa8379db07ca7d23a6c43c6ab742ef09b6
Reviewed-on: http://git-master/r/83531
Tegra doesn't have irq_to_gpio() any more, and ak8975 is included in
tegra_defconfig. This causes a build failure. Instead, pass the GPIO name
through platform data.
[swarren: Rewrote commit description when I squashed this with my patch
to remove the irq_to_gpio() call]
Upstream v3.2 commit f6d838d7fecfd4e59a4ce7bdfb16165add36d26e
Change-Id: I6bd269aa8c0ff8165078ff67e4cbcfdde936c20d
Reviewed-on: http://git-master/r/83530
Set i2c client data before we call ak8975_setup() in the probe function
because ak8975_setup() is making a call to ak8975_write_data() which in
turn calls i2c_get_clientdata(). If this is not done then
i2c_get_clientdata() returns NULL pointer.
Bug: 918820
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: I36316fb508d196a32b26853c377921175f94dde6
Reviewed-on: http://git-master/r/71775
Rebase-Id: R5de165b205927a47ac2d3e1c8cfa916105682e0d
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
Convert als data units from count to lux before reporting
Bug 876339
Change-Id: Ie08b38bc1f4dbd22103cdf921435c5cf1fd21ded
Reviewed-on: http://git-master/r/39501
(cherry picked from commit 85f6bcb9497b52a1f1b58e6d30ac0387fbfdeaee)
Reviewed-on: http://git-master/r/52862
Tested-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Joseph Lehrer <jlehrer@nvidia.com>
Tested-by: Joseph Lehrer <jlehrer@nvidia.com>
Rebase-Id: Re0d20d362e55df910caf15b3873e7743dbee132d
Adding the complete driver for the ISL29028 to get the proximity,
ALS and IR sensing.
The reading of these data is provided through sysfs interface.
Bug 876339
Original-Change-Id: I25661d0ef54e1053ccf47a716c89607ca51a9862
Reviewed-on: http://git-master/r/23155
Change-Id: I14114e30937fb2e5d308b77a76f2c6f634bf907c
(cherry picked from commit b441479716b41ac91cc398c803692e5eb005a704)
Reviewed-on: http://git-master/r/52594
Rebase-Id: Re9322c535586f4190c8bd24c2135b0487bef8083
This code was cut and pasted in several places. It's missing some
unlocks on error.
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Build tested only.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Looks like this moved into the core at somepoint and kfifo buf got left
behind.
This mean all sorts of interesting results on driver removal.
A number of these register indexes were not set or actually wrong.
This only effects sysfs reads.
Will cause issues only on driver removal.
iio_chan_spec framework.
Remove the driver's get_sensor_data() interfaces and replace them with
iio_chan_spec channels. This converts 4 files to the new framework.
Driver ABI change: The intensity_infrared_raw file is now intensity_ir_raw.
Signed-off-by: Bryan Freed <bfreed@chromium.org>
Add "proximity" to the iio_chan_type_name_spec_shared string list to
support proximity sensors.
Now this list fully matches the declared iio_chan_type enums.
This makes comparison between the iio_chan_type_name_spec_shared strings
and the iio_chan_type enums easier.
The I2C clientdata is set to indio_dev instead of chip as of a couple weeks ago.
Correct the calls to i2c_get_clientdata() accordingly.
Otherwise the driver fails to initialize.
There are a couple places here where we should have called
mutex_unlock() before returning.
Cc: stable <stable@kernel.org> [3.0]
sensor driver.
Defaulting to 1, this gives a way to amplify the lux value before being
reduced by the programmed adc_bit shift.
Only support whole numbers right now. When this driver is converted to the new
IIO_CHAN framework, it will be easy to support the framework's pseudo float.
Add illuminance0_calibscale documentation to sysfs-bus-iio-light.
Acked-by: Rhyland Klein <rklein@nvidia.com>
There were some uninitialized variable warnings in iio. Two of
these came from the recent changes to how the private data was
allocated in 83f0422dc6a16 "staging:iio:accel:sca3000: allocate
state in iio_dev and use iio_priv to access."
drivers/staging/iio/accel/sca3000_core.c: In function 'sca3000_probe':
drivers/staging/iio/accel/sca3000_core.c:1137:9: warning: 'st' may be used uninitialized in this function
drivers/staging/iio/adc/ad7291.c: In function 'ad7291_probe':
drivers/staging/iio/adc/ad7291.c:805:15: warning: 'chip' may be used uninitialized in this function
drivers/staging/iio/dac/ad5624r_spi.c: In function 'ad5624r_probe':
drivers/staging/iio/dac/ad5624r_spi.c:228:24: warning: 'st' may be used uninitialized in this function
This handles the merge conflicts with the
drivers/staging/brcm80211/Kconfig file due to changes on the two
different branches.
This is so we can support it on x86 SMBUS adapters.
Since i2c adapters which do not provide an smbus_xfer interface fall
back to using their I2C master_xfer interface, all the i2c_master_send()
calls in this driver are changed to i2c_smbus_*() calls.
This will fail on an i2c adapter that implements a proper subset of
(SMBUS_BYTE | SMBUS_BYTE_DATA | SMBUS_WORD_DATA), but I do not see that
in any of our adapters today.
This results in a few wrapper functions that provide little additional
functionality, so remove them and call the smbus functions directly from
the general driver code.
Add the required read/write_raw functions to the tsl2563_info_no_irq data
structure. This structure is used insted of tsl2563_info when the I2C client
has no IRQ.
The absence of these functions causes a panic when reading or writing the
created sysfs files.
Add a wrapper for this driver around the IIO_CHAN() wrapper to make channel
parameters more readable. This fixes a panic caused by the info_masks being
accidentally passed in as channel2 parameters which easily surpass the size
of the iio_modifier_names_light array.
Same problem as seen and fixed in adis16204 et al.
These were fixed by Randy in:
staging: fix more iio builds when IIO_RING_BUFFER is not enabled
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
In the error handling, it dereferences "st" before it has been
initialized. I also just tidied it up a bit to remove some extra
conditions.
No point to start comments with '\'.
Signed-off-by: maximilian attems <max@stro.at>
New driver for AD5686R, AD5685R, AD5684R Quad channel digital to analog converters
Changes since V1:
drop header file
use strtobool()
Fix dev attribute macros
Reorder probe() function
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Add IIO_OUT type for DAC like devices
In case of IIO_OUT make sure the channel device attribute is writable
Ideally we add a flag to iio_chan_spec that tells the core that
the channel device attribute is writable...
New driver for AD7792/AD7793 3-Channel, Low Noise,
Low Power, 16-/24-Bit Sigma-Delta ADC with On-Chip In-Amp
and Reference.
The AD7792/AD7793 features a dual use data out ready DOUT/RDY output.
In order to avoid contentions on the SPI bus, it's necessary to use
spi bus locking. The DOUT/RDY output must also be wired to an
interrupt capable GPIO.
In INDIO_RING_TRIGGERED mode, this driver may block its SPI bus segment
for an extended period of time.
Changes since V1:
Use bool where applicable.
Use data buffer that lives in their own cache line.
Restructure ad7793_calibrate_all to use an array.
Use msleep.
Query REG_ID instead of doing a write/read This is a test.
Add support for unipolar mode.
Drop range attribute in favor of write scale.
Add proper locking.
Use new validate_trigger callbacks.
Use IIO_IN_DIFF for differential channels.
Change attribute naming.
Use available_scan_masks.
Some other miscellaneous cleanup (none functional changes).
allocated buffer.
Signed-off-by: anish kumar <anish198519851985@gmail.com>
Corrected the spelling.
adis16201_state
Basically use various new facilities to tidy up.
V2: Actually allocate the space for iio_priv
Here the ordering is a little tricky, so to keep changes minimal, a copy of the gpio
number is introduced.
Very simple driver, so not much to do.
I've currently squashed the vel + pos combined attribute. If people need them
precisely paired I doubt they will get them from the sysfs interface anyway.
If that is a requirement it should come via a buffer implementation.
Note this patch leaves the completely non standard interface alone.
That will get fixed later.
Note I haven't made any changes to the userspace interface as yet.
This is all about cleaning up what was actually there (handling
all errors etc).
Requires moving a few things around, but should be no functional changes.
