The semantic patch used to find this is:
@r@
expression x;
void* e;
type T;
identifier f;
*((T *)e)
((T *)x)[...]
((T *)x)->f
- (T *)
e
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Fixes checkpatch.pl CHECK:LINE_SPACING: Please use a blank line after
function/struct/union/enum declarations
The patch is generated using checkpatch.pl --fix-inplace:
for f in $(find drivers/staging/lustre/ -type f) ; do
./scripts/checkpatch.pl --types "LINE_SPACING" --fix-inplace -f $f
done
Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com>
Fixes checkpatch.pl CHECK:LINE_SPACING: Please don't use multiple blank
lines.
./scripts/checkpatch.pl --types "LINE_SPACING" --test-only=multiple \
--fix-inplace -f $f
done
Drop unused functions.
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
The CFS_TIME_T macro serves no real purpose as we stopped using time_t
and changed over to time64_t, so we can remove the last remaining uses
of this.
Two uses of this macro are incorrect and refer to jiffies values
rather than time_t, and one refers to an inode timespec that gets
changed separately.
ptlrpc_enc_page_pool computes time deltas using 'long' values from
get_seconds(). This is probably safe beyond y2038, but it's better
to go use monotonic times and 64-bit here for consistency.
!x is more normal for kzalloc failure in the kernel.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x;
statement S1, S2;
x = kzalloc(...);
if (
- x == NULL
+ !x
) S1 else S2
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Replace uses of OBD_ALLOC_LARGE by libcfs_kvzalloc and OBD_FREE_LARGE by
kvfree.
// <smpl>
expression ptr,size;
- OBD_ALLOC_LARGE(ptr,size)
+ ptr = libcfs_kvzalloc(size, GFP_NOFS)
- OBD_FREE_LARGE(ptr, size);
+ kvfree(ptr);
// </smpl>
Minor changes to remove excessive whitespace and improve
readability of ptlrpc functions.
Signed-off-by: Chris Hanna <hannac@iu.edu>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
// </smpl>
This patch remove unnecessary bracket.
Signed-off-by: Gauthier Voron <gauthier.voron@lip6.fr>
Signed-off-by: Hakan Metin <hakan.metin@lip6.fr>
This patch fix too large line.
The seq_printf return value, because it's frequently misused,
will eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
Convert these uses to:
seq_printf(seq, ...);
return 0;
Done via cocci script:
struct seq_file *seq;
int i;
- i = seq_printf(seq,
+ seq_printf(seq,
- return i;
+ return 0;
int i;
- i = 0;
- i += seq_printf(seq,
+ seq_printf(seq,
- return i;
+ return 0;
With some additional reformatting and typing post conversion
to remove the now unnecessary "int i;" declaration.
Join the string fragments to make it easier to grep.
Ignored all the 80+ column lines.
Added many missing spaces when coalescing formats.
This patch fixes the checkpatch.pl issue
Error: Required space after " '+' ',' '=' '(' ' if' "
Signed-off-by: Hema Prathaban <hemaklnce@gmail.com>
Fix checkpatch.pl "foo * bar" should be "foo *bar" errors
Signed-off-by: Greg Donald <gdonald@gmail.com>
Just call get_seconds() directly.
Cc: Andreas Dilger <andreas.dilger@intel.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: hpdd-discuss <hpdd-discuss@lists.01.org>
Just use unsigned long everywhere, like the rest of the kernel does.
Fix up the relative paths in the .c files to properly build with the
Makefile change.
We need to remove the ccflags from the Lustre code as it prevents
individual object files from building properly in the kernel build
system. It also hids the horrid mess that the Lustre include files are
made up of.
Start out by removing the toplevel ccflags variable pointing to
drivers/staging/lustre/include/ as a valid include path. This requires
the absolute include markings of a bunch of .h and .c files, which is
also done here.
spin_is_locked() is always false when the platform is
uniprocessor and CONFIG_DEBUG_SPINLOCK is not enabled.
This patch replaces its assertion by assert_spin_locked().
Signed-off-by: Li Xi <lixi@ddn.com>
Signed-off-by: James Simmons <uja.ornl@gmail.com>
Reviewed-on: http://review.whamcloud.com/8144
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4199
Reviewed-by: Alexey Lyashkov <alexey_lyashkov@xyratex.com>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Signed-off-by: Oleg Drokin <oleg.drokin@intel.com>
In Lustre 2.4, the flags passed to the memory allocation functions are
translated from CFS enumeration values types to the kernel GFP
values by calling cfs_alloc_flags_to_gfp(). This function adds
__GFP_WAIT to all flags except CFS_ALLOC_ATOMIC. In 2.5, when
the cfs wrappers were dropped, cfs_alloc_flags_to_gfp() was
removed and the CFS_ALLOC_xxxx was simply replaced with __GFP_xxxx.
This means that most memory allocation calls are missing the
__GFP_WAIT flag. The result is that Lustre experiences more ENOMEM
errors, many of which the higher levels of Lustre do not handle
robustly.
Notes GFP_NOFS = __GFP_WAIT | __GFP_IO. So the patch replaces
__GFP_IO with GFP_NOFS.
Patch does not add __GFP_WAIT to GFP_IOFS. GFP_IOFS was not used in
Lustre 2.4 so it has never been used with __GFP_WAIT.
Signed-off-by: Ann Koehler <amk@cray.com>
Signed-off-by: Emoly Liu <emoly.liu@intel.com>
Reviewed-on: http://review.whamcloud.com/9223
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-4357
Reviewed-by: Liang Zhen <liang.zhen@intel.com>
Reviewed-by: James Simmons <uja.ornl@gmail.com>
Signed-off-by: Peng Tao <bergwolf@gmail.com>
This patch fixed spelling typo in lustre/ptlrpc.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
This resolves the merge problem with two iio drivers that Stephen
Rothwell pointed out.
drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c:217:2-3: Unneeded semicolon
Removes unneeded semicolon.
Generated by: coccinelle/misc/semicolon.cocci
CC: Peng Tao <bergwolf@gmail.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
It duplicates the definition in arch/alpha/include/asm/pgtable.h and emits
warnings.
Cc: Peng Tao <tao.peng@emc.com>
Convert sptlrpc encode pool shrinker to use scan/count API.
Signed-off-by: Peng Tao <tao.peng@emc.com>
Signed-off-by: Andreas Dilger <andreas.dilger@intel.com>
Cc: Dave Chinner <dchinner@redhat.com>
The global variable num_physpages is going away. Replace it
with totalram_pages.
Cc: Jiang Liu <jiang.liu@huawei.com>
In 3.10 merge window, proc_dir_entry is now private to proc. However,
Lustre lprocfs depends heavily on it and its now-gone read_proc_t and
write_proc_t members.
The patch largely changed the fact, and made lprocfs depend on none of
proc_dir_entry private members. All lprocfs callers are converted to
use the new seq_file scheme.
Also lprocfs_srch is removed so that we can drop lprocfs_lock. All callers
are changed to save created pde in proper place.
See https://jira.hpdd.intel.com/browse/LU-3319 for more details.
Lustre is the most deployed distributed file system
in the HPC (High Performance Computing) world. The patch
adds its client side support.
The code is not very clean and needs to live in drivers/staging
for some time for continuing cleanup work. See
drivers/staging/lustre/TODO for details.
The code is based on Lustre master commit faefbfc04
commit faefbfc0460bc00f2ee4c1c1c86aa1e39b9eea49
Author: Alex Zhuravlev <alexey.zhuravlev@intel.com>
Date: Tue Apr 30 23:05:21 2013 +0400
LU-3244 utils: tunefs.lustre should preserve virgin label
Plus a few under-review patches on Whamcloud gerrit:
3.8 kernel support:
http://review.whamcloud.com/#change,5973
http://review.whamcloud.com/#change,5974
http://review.whamcloud.com/#change,5768
http://review.whamcloud.com/#change,5781
http://review.whamcloud.com/#change,5763
http://review.whamcloud.com/#change,5613
http://review.whamcloud.com/#change,5655
3.9 kernel support:
http://review.whamcloud.com/#change,5898
http://review.whamcloud.com/#change,5899
Kconfig/Kbuild:
http://review.whamcloud.com/#change,4646
http://review.whamcloud.com/#change,4644
libcfs cleanup:
http://review.whamcloud.com/#change,2831
http://review.whamcloud.com/#change,4775
http://review.whamcloud.com/#change,4776
http://review.whamcloud.com/#change,4777
http://review.whamcloud.com/#change,4778
http://review.whamcloud.com/#change,4779
http://review.whamcloud.com/#change,4780
All starting/trailing whitespaces are removed, to match kernel
coding style. Also ran scripts/cleanfile on all lustre source files.
[maked the Kconfig depend on BROKEN as the recent procfs changes causes
this to fail - gregkh]
