path: root/drivers/staging/mei/iorw.c
2011-06-28staging: mei: io_list functions revampTomas Winkler
1. remove list used for loop. There were only 2 loops used in non time critical places so we can safely unroll them 2. normalize functions names operating on io_list to mei_io_list_<op> 3. rename mei_fe_same_id to mei_cl_cmp_id used for comparing list elements containing struct mei_cl 4. group together io_list functions in the header file Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Oren Weil <oren.jer.weil@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-28staging: mei: rename num_mei_me_clients to me_clients_numTomas Winkler
2011-06-28staging: mei: mei_dev - use type bool instead of intTomas Winkler
use type bool for boolean variables in struct mei_dev this should save some space providing boolean is 8 bits Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Oren Weil <oren.jer.weil@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-28staging: mei: fix mei driver namespaceTomas Winkler
All global functions must start with mei_ to reduce the risk of name colisions Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Oren Weil <oren.jer.weil@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-18staging/mei: PCI device and char driver support.Oren Weil
contains module entries and PCI driver and char device definitions (using file_operations, pci_driver struts). The HW interface is exposed on PCI interface. PCI: The MEI HW resources are memory map 32 bit registers (Host and ME Status Registers and Data Registers) and interrupt (shared, with Intel GFX on some chipsets and USB2 controller on others). The device is part of the chipsets and cannot be hotplugged. The MEI device present is determined by BIOS configuration. Probe: The driver starts the init MEI flow, that is explained in the patch "MEI driver init flow" [06/10], then schedules a timer that handles timeouts and watchdog heartbeats. Remove: The driver closes all connections and stops the watchdog. The driver expose char device that supports: open, release, write, read, ioctl, poll. Open: Upon open the driver allocates HOST data structure on behalf of application which will resides in the file's private data and assign a host ID number which will identify messages between driver client instance and MEI client. The driver also checks readiness of the device. The number of simultaneously opened instances is limited to 253. (255 - (amthi + watchdog)) Release: In release the driver sends a Disconnect Command to ME feature and clean all the data structs. IOCTL: MEI adds new IOCTL: (IOCTL_MEI_CONNECT_CLIENT) The IOCTL links the current file descriptor to ME feature. This is done by sending MEI Bus command: 'hbm_client_connect_request' to the ME and waiting for an answer :'hbm_client_connect_response'. Upon answer reception the driver updates its and HOST data structures in file structure to indicate that the file descriptor is associated to ME feature. Each ME feature is represented by UUID which is given as an input parameter to the IOCTL, upon success connect command the IOCTL will return the ME feature properties. ME can reject CONNECT commands due to several reasons, most common are: Invalid UUID ME or feature does not exists in ME. No More Connection allowed to this is feature, usually only one connection is allowed. Write: Upon write, the driver splits the user data into several MEI messages up to 512 bytes each and sends it to the HW. If the user wants to write data to AMTHI ME feature then the drivers routes the messages through AMTHI queues. Read: In read the driver checks is a connection exists to current file descriptor and then wait until a data is available. Message might be received (by interrupt from ME) in multiple chunks. Only complete message is released to the application. Poll: Nothing special here. Waiting for see if we have data available for reading. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Itzhak Tzeel-Krupp <itzhak.tzeel-krupp@intel.com> Signed-off-by: Oren Weil <oren.jer.weil@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
