Replace a BSD-style license in Code Aurora Forum authored files with
an explicit GPLv2.
Signed-off-by: David Brown <davidb@codeaurora.org>
This was done to resolve conflicts in the following files due
to patches in Linus's tree and in the staging-next tree:
drivers/staging/brcm80211/brcmsmac/wl_mac80211.c
drivers/staging/ste_rmi4/synaptics_i2c_rmi4.c
This code elsewhere returns a negative constant to an indicate an error,
while IS_ERR returns the result of a >= operation.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x;
if (...) { ...
- return IS_ERR(x);
+ return PTR_ERR(x);
// </smpl>
Acked-by: David Brown <davidb@codeaurora.org>
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
Cc: Greg KH <gregkh@suse.de>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
Driver init() function should return error code.
Also fix tvenc_clk leak.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
backlight_device_register has been expecting a const "ops" argument, and using
it as such, since 9905a43b2d563e6f89e4c63c4278ada03f2ebb14. Let's make the
remaining backlight_ops instances const.
Inspired by hunks of the grsecurity patch, updated for newer kernels.
Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr>
Changed <module>-objs to <module>-y in Makefile.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
Fixup the last remaining users of DECLARE_MUTEX and init_MUTEX.
Scripted conversion, resulting code is binary equivalent.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
LKML-Reference: <20100907125057.278833764@linutronix.de>
init_MUTEX(_LOCKED) and DECLARE_MUTEX are going away. Bulk convert
staging users.
Start cleaning up the msm framebuffer in preparation
for integration with mainline. Remove unused drivers.
Signed-off-by: Neil Leeder <nleeder@codeaurora.org>
Use %p instead of %08x in printk().
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Acked-by: Daniel Walker <dwalker@codeaurora.org>
These could not be detected by the semantic patch.
Remove duplicated #include('s) in
drivers/staging/msm/mddihost.h
drivers/staging/msm/msm_fb_def.h
drivers/staging/msm/staging-devices.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Qualcomm development of the MSM SOC framebuffer driver has
diverged significantly from the driver used by Android. This
is a snapshot of our current driver, in all it's agony. We are
putting this in staging to help with the process of converging
the two drivers.
At this point, the driver has been tested only in dumb
framebuffer mode.
Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org>
[dwalker@codeaurora.org: added a small compile fix and TODO.]
Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
