Reformat a comment to fit it into 80 columns line lenght.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reformat the original license text to fit in 80-column terminal. No
change in wording.
Delete CVS keyword marker and a comment that the file is autogenerated.
Use helper macros to avoid copy-paste and too long lines.
Delete unused macros.
Adjust struct member comments to be closer to kernel-doc format.
Fix struct indentation.
Fix placement of braces in structs and unions.
Delete unused union members.
Delete unused data types.
change in wording.
Format all comments (except license text) to fit to 80 column terminals.
Delete some unused macros.
Remove duplicated include.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
platform_device_register_simple fails
device_register is called before platform_device_register_simple gets called.
unregister and reset the octeon_usb_registered variable
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: David Daney <ddaney.cavm@gmail.com>
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
the return value is a pointer having an error set. we have to check for
IS_ERR and return PTR_ERR when appropriate
place the opening brace right after the if, else, else if, switch
statements.
place the opening brace right after the if,else, else if,switch
statements.
this places the opening braces just after the if, else, elseif, switch
statements
this fixes coding style problem, placing of the braces just right after the
struct name, not below the struct name.
this reduces the errors reported by checkpatch script from
total: 1496 errors, 2133 warnings, 3344 lines checked
to
total: 1488 errors, 2132 warnings, 3336 lines checked
Add support for Octeon USB HCD. Tested on EdgeRouter Lite with USB
mass storage.
The driver has been extracted from GPL sources of EdgeRouter Lite firmware
(based on Linux 2.6.32.13). Some minor fixes and cleanups have been done
to make it work with 3.10-rc3.
$ uname -a
Linux (none) 3.10.0-rc3-edge-00005-g86cb5bc #41 SMP PREEMPT Sat Jun 1 20:41:46 EEST 2013 mips64 GNU/Linux
$ modprobe octeon-usb
[ 37.971683] octeon_usb: module is from the staging directory, the quality is unknown, you have been warned.
[ 37.983649] OcteonUSB: Detected 1 ports
[ 37.999360] OcteonUSB OcteonUSB.0: Octeon Host Controller
[ 38.004847] OcteonUSB OcteonUSB.0: new USB bus registered, assigned bus number 1
[ 38.012332] OcteonUSB OcteonUSB.0: irq 122, io mem 0x00000000
[ 38.019970] hub 1-0:1.0: USB hub found
[ 38.023851] hub 1-0:1.0: 1 port detected
[ 38.028101] OcteonUSB: Registered HCD for port 0 on irq 122
[ 38.391443] usb 1-1: new high-speed USB device number 2 using OcteonUSB
[ 38.586922] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 38.597375] scsi0 : usb-storage 1-1:1.0
[ 39.604111] scsi 0:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4
[ 39.619113] sd 0:0:0:0: [sda] 7579008 512-byte logical blocks: (3.88 GB/3.61 GiB)
[ 39.630696] sd 0:0:0:0: [sda] Write Protect is off
[ 39.635945] sd 0:0:0:0: [sda] No Caching mode page present
[ 39.641464] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 39.651341] sd 0:0:0:0: [sda] No Caching mode page present
[ 39.656917] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 39.664296] sda: sda1 sda2
[ 39.675574] sd 0:0:0:0: [sda] No Caching mode page present
[ 39.681093] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 39.687223] sd 0:0:0:0: [sda] Attached SCSI removable disk
