checked against 0
commit f764cd68d9036498f08fe8834deb6a367b5c2542 upstream.
Zero-initializing ether_type masked that the ether type would never be
obtained for 8021x packets and the comparison against eapol_type
would always fail.
Reported-by: Jes Sorensen <Jes.Sorensen@redhat.com>
commit 3a21f00a5002b14e4aab52aef59d33ed28468a13 upstream.
The latest version of NetworkManager does not recognize the device as wireless
without this change.
Same result no matter what path is taken.
Signed-off-by: Niklas Söderlund <niso@kth.se>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
There is no implementation of these functions anywhere in the code.
Signed-off-by: Przemo Firszt <przemo@firszt.eu>
Remove duplicate code.The definitions are already in
include/linux/rndis.h
I've changed the ugly casting here and used min_t() instead. I
also changed the u16 to a u32 because ->network.Ssid.SsidLength
is 32 bits. It doesn't make a difference, but truncating the
upper bits away is sloppy.
Replace printk with netdev_printk helpers, dev_printk helpers or
pr_err/warn/info if there is no device info available.
Those definitions are not used anywhere in the kernel. If you know any
reason why they should stay in the code please speak up!
Clean some trivial formating problems in rtl8712 from staging tree. This patch
also changes the way preprocessor macros are defined to keep checkpatch.pl
quiet.
These calls are followed by calls to memcpy() on the same memory area, so they
can be safely removed.
Signed-off-by: Cyril Roelandt <tipecaml@gmail.com>
This is to get the comedi fixes, and resolve the issue in comdi_test.c
and comedi_fops.c that were caused by changes in both branches.
It also allows the fwserial driver changes to be applied, as they
required the fixes that are in staging-linus.
In r8711_wx_get_wap(), make sure we do not call memcpy() on a memory area that
has just been zeroed by a call to memset().
Acked-by: Dan Carpenter <dan.carpenter@oracle.com>
The ISY IWL 1000 USB WLAN stick with USB ID 050d:11f1 is a clone of
the Belkin F7D1101 V1 device.
Reported-by: Thomas Hartmann <hartmann@ict.tuwien.ac.at>
Cc: Thomas Hartmann <hartmann@ict.tuwien.ac.at>
Cc: Stable <stable@vger.kernel.org>
In routine r8712_report_sec_ie(), the code could set the length
of the buffer to 256; however, that value is one larger than the
corresponding memory allocation.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This seems like a cut and paste bug. Smatch complains that we don't
allocate enough memory for a set_stakey_rsp struct. In fact this is
used as a set_assocsta_rsp struct throughout and that also matches the
name of the function.
The dereference should be moved below the NULL test.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Some post-3.4 kernels have a problem when a cloned skb is used in the
RX path. This patch handles one such case for r8712u.
The patch was suggested by Eric Dumazet.
Cc: Stable <stable@vger.kernel.org> [v3.4+]
fixes the following errors:
drivers/staging/rtl8712/rtl871x_security.c:61: ERROR: "foo * bar" should
be "foo *bar"
drivers/staging/rtl8712/rtl871x_security.c:291: ERROR: "foo * bar"
should be "foo *bar"
drivers/staging/rtl8712/rtl871x_security.c:323: ERROR: "foo * bar"
drivers/staging/rtl8712/rtl871x_security.c:1371: ERROR: "(foo*)" should
be "(foo *)"
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
fixes the following error:
drivers/staging/rtl8712/rtl8712_xmit.c:379: ERROR: "foo * bar" should
be "foo *bar"
fixes the following checkpatch warning:
drivers/staging/rtl8712/os_intfs.c:99: ERROR: do not initialise statics
to 0 or NULL
as statics are always initialised to 0.
This pulls in the staging tree fixes in 3.6-rc6 into our branch to resolve the
merge issues.
64bit arches have a buggy r8712u driver, let's fix it.
skb->tail must be set properly or network stack behavior is undefined.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=847525
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=45071
Cc: Dave Jones <davej@redhat.com>
Cc: stable <stable@vger.kernel.org> [2.6.37+]
Using is_zero_ether_addr() instead of directly use
memcmp(addr, "\x00\x00\x00\x00\x00\x00", ETH_ALEN)
to determine if the ethernet address is all zeros.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
This driver has a number of defines, etc. that are not used.
The driver has a dev_alloc_skb() and an skb_clone() call that are not
checked for failure.
memcmp() to determine if the ethernet address is
all zeros.
Using is_broadcast_ether_addr() to simplify the code.
The current value for the maximum receive buffer size is 30720, which is
too large. For long-running systems, memory fragmentation may make it
difficult to obtain the buffers of O(2) needed for aggregation. Buffers
of O(3) are even worse, particularly when not needed. The new size is set
to 9100, which will allow aggregation.
This picks up the staging changes made in 3.5-rc4 so that everyone can sync up
properly.
This driver contains version information that is outdated, has no real
value in terms of the Linux update process, and tends to confuse users.
There are two new devices for this driver.
Correct spelling typo "padater" to "padapter" in rtl871x_io.h
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
In commit ee6aeff, a swatch warning was fixed by moving some code inside
an if block that is executed only when the pointer padapter is not NULL.
In fact, padapter can never be NULL and the corect fix should have been
the removal of the test of padapter.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
This driver had headers like big_endian.h, little_endian.h, swab.h
and yet we can throw them all in the trash can and the thing
still builds on x86-64 and ppc, just by deleting the references
to the deleted files.
Cc: Larry Finger <Larry.Finger@lwfinger.net>
This driver should not be carrying around ancient copies of
headers like <linux/ip.h> for its own use. Mapping it onto
the mainline one uncovers no build issues.
headers like <linux/if_ether.h> for its own use. Mapping it
onto the mainline one uncovers no build issues.
The output of "make versioncheck" told us that:
drivers/staging/rtl8712/osdep_service.h: 32 linux/version.h not needed.
drivers/staging/rtl8712/rtl871x_ioctl_linux.c: 46 linux/version.h not needed.
If we take a look at these files, we will agree to remove it.
Cc: Florian Schilhabel <florian.c.schilhabel@googlemail.com>
Cc: <devel@driverdev.osuosl.org>
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
ACKed-by: Larry Finger <Larry.Finger@lwfinger.net>
spatch http://coccinelle.lip6.fr/rules/array.cocci did these.
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
The patch 2080913e017a: "staging: r8712u: Fix regression caused by
commit 8c213fa" from Feb 25, 2012, leads to the following Smatch
complaint:
drivers/staging/rtl8712/usb_intf.c:629 r871xu_dev_remove()
warn: variable dereferenced before check 'padapter' (see line 625)
The fix is to move the new statements inside the block where padapter
is not NULL.
It seems the USB device ID 0bda:8192 is wrongly assigned to the
RTL8192SU chip and not to the RTL8191SU chip in the USB database.
So this patch moves this device ID from the rtl8192u staging
driver to the rtl8712 staging driver.
This patch was tested with a Radicom WIFIHU embedded wireless
module with a RTL8191SU chip and the USB device ID 0bda:8192.
Without the patch the rtl8192u driver claims this device, but
it does not work. With the patch the rtl8712 driver services
this device and it works.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
Remove copies of the double USB device IDs:
- 0bda:8172
- 0bda:8174
In commit c6dc001 "staging: r8712u: Merging Realtek's latest (v2.6.6).
Various fixes", the returned qual.qual member of the iw_statistics
struct was changed. For strong signals, this change made no difference;
however for medium and weak signals it results in a low signal that
shows considerable fluctuation, When using wicd for a medium-strength
AP, the value reported in the status line is reduced from 100% to 60% by
this bug.
This problem is reported in https://bugzilla.kernel.org/show_bug.cgi?id=42826.
Reported-and-tested-by: Robert Crawford <wrc1944@gmail.com>
In commit 8c213fa "staging: r8712u: Use asynchronous firmware loading",
the command to release the firmware was placed in the wrong routine.
In combination with the bug introduced in commit a5ee652 "staging: r8712u:
Interface-state not fully tracked", the driver attempts to upload firmware
that had already been released. This bug is the source of one of the
problems in https://bugs.archlinux.org/task/27996#comment89833.
Tested-by: Alberto Lago Ballesteros <saniukeokusainaya@gmail.com>
Tested-by: Adrian <agib@gmx.de>
In commit a5ee652 "staging: r8712u: Interface-state not fully tracked",
the private boolean "bup" was set false when the interface was brought down,
as that seemed appropriate. This change has not caused any problems when
using NetworkManager or manual control of the device; however, when wicd
control is used, there is a locking problem in wpa_supplicant, as shown in
https://bugzilla.kernel.org/show_bug.cgi?id=42818.
This fix reverts the only code change in commit a5ee652. My
analysis is that "bup" is badly named. In its present form, it
seems to indicate the up/down state of the device, but its usage
is more consistent with an initialized/uninitialized state. That
problem will be addressed in a later patch.
Note: Commit 8c213fa, which introdued asynchronous firmware loading
for this driver, exposed this bug to a greater extent. That bug
is addressed in the next patch in this series.
This bug is also responsible for the bug in
https://bugzilla.kernel.org/show_bug.cgi?id=42815. and this bug is
also part of the problems discussed at https://bugs.archlinux.org/task/27996#comment89950.
Cc: Stable <stable@vger.kernel.org> [3.2+]
This was done to resolve some merge issues with the following files that
had changed in both branches:
drivers/staging/rtl8712/rtl871x_sta_mgt.c
drivers/staging/tidspbridge/rmgr/drv_interface.c
drivers/staging/zcache/zcache-main.c
