commit 3d5f1eedbfd22ceea94b39989d6021b1958181f4 upstream.
Add 024c:0525 to the list of SDIO device-ids, based on a patch found
in the Android X86 kernels. According to that patch this device id is
used on the Alcatel Plus 10 device.
Reported-and-tested-by: youling257 <youling257@gmail.com>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20191111113846.24940-1-hdegoede@redhat.com
commit 2d9d2491530a156b9a5614adf9dc79285e35d55e upstream.
The driver only binds by SDIO device-ids, all the ACPI device-id does
is causing the driver to load unnecessarily on devices where the DSDT
contains a bogus OBDA8723 device.
Link: https://lore.kernel.org/r/20191111113846.24940-2-hdegoede@redhat.com
casting to void pointer from any pointer type and vice-versa is done
implicitly and therefore casting is not needed in such a case.
Signed-off-by: Himanshu Jha <himanshujha199640@gmail.com>
ERROR: do not use assignment in if condition
Detected by scripts/checkpatch.pl -f
Signed-off-by: Bingyu Zhou <rain.by.zhou@gmail.com>
The rtl8723bs is found on quite a few systems used by Linux users,
such as on Atom systems (Intel Computestick and various other
Atom based devices) and on many (budget) ARM boards such as
the CHIP.
The plan moving forward with this is for the new clean,
written from scratch, rtl8xxxu driver to eventually gain
support for sdio devices. But there is no clear timeline
for that, so lets add this driver included in staging for now.
Cc: Bastien Nocera <hadess@hadess.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Jes Sorensen <jes.sorensen@gmail.com>
