path: root/drivers/staging/sm750fb
2017-07-27staging: sm750fb: avoid conflicting vesafbTeddy Wang
commit 740c433ec35187b45abe08bb6c45a321a791be8e upstream. If vesafb is enabled in the config then /dev/fb0 is created by vesa and this sm750 driver gets fb1, fb2. But we need to be fb0 and fb1 to effectively work with xorg. So if it has been alloted fb1, then try to remove the other fb0. In the previous send, why #ifdef is used was asked. https://lkml.org/lkml/2017/6/25/57 Answered at: https://lkml.org/lkml/2017/6/25/69 Also pasting here for reference. 'Did a quick research into "why". The patch d8801e4df91e ("x86/PCI: Set IORESOURCE_ROM_SHADOW only for the default VGA device") has started setting IORESOURCE_ROM_SHADOW in flags for a default VGA device and that is being done only for x86. And so, we will need that #ifdef to check IORESOURCE_ROM_SHADOW as that needs to be checked only for a x86 and not for other arch.' Signed-off-by: Teddy Wang <teddy.wang@siliconmotion.com> Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-07staging: sm750fb: Fix bugs introduced by early commitsHuacai Chen
Early commit 30ca5cb63c56965 ("staging: sm750fb: change definition of PANEL_PLANE_TL fields") and 27b047bbe1ee9c0 ("staging: sm750fb: change definition of PANEL_PLANE_BR fields") modify the register bit fields definitions. But the modifications are wrong, because the bit mask of "bit field 10:0" is not 0xeff, but 0x7ff. The wrong definition bugs makes display very strange. Signed-off-by: Huacai Chen <chenhc@lemote.com> Cc: stable <stable@vger.kernel.org> # 4.6+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-02staging: sm750fb: replace roundedDiv with DIV_ROUND_CLOSESTMoshe Green
Replace local implementation of rounded division (roundedDiv macro) with the in-kernel implementation (DIV_ROUND_CLOSEST macro) in ddk750_chip.c Signed-off-by: Moshe Green <mgmoshes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-02staging: sm750fb: conform to block comment styleElizabeth Ferdman
Fix 2 checkpatch errors: -Block comments use * on subsequent lines, -Block comments use a trailing */ on a separate line to conform to block commenting style. Signed-off-by: Elizabeth Ferdman <gnudevliz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-27staging: sm750fb: rename getChipType to sm750_get_chip_typeMoshe Green
Rename CamelCased function getChipType to sm750_get_chip_type (prefex with sm750 in order to make the context of the function clear). This issue was found by checkpatch.pl Signed-off-by: Moshe Green <mgmoshes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-22staging: sm750fb: Remove unnecessary parenthesesRehas Sachdeva
Remove unnecessary parentheses from right side of an assignment. Issue detected by the following Coccinelle semantic patch: @r@ identifier x; expression e1, e2; @@ - x = (e1 << e2); + x = e1 << e2; Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-22staging: sm750fb: Use BIT(x) macroRehas Sachdeva
Replaces left shift operation (1 << d) by BIT(x) macro. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-20staging: sm750fb: Add spaces around '|'Rehas Sachdeva
Adds spaces on either side of a '|'. Issue found by checkpatch. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-16staging: sm750fb: Change 'uint32_t' to 'u32'Rehas Sachdeva
It is preferred to use 'u32' instead of 'uint32_t' for unsigned int. Issue detected by checkpatch. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-16staging: sm750fb: Change 'x != NULL' to 'x'Rehas Sachdeva
Changes the explicit comparison to NULL from 'x != NULL' to 'x'. Issue detected by checkpatch. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-16staging: sm750fb: fix block comment style and spelling issues in ddk750_chip.cMoshe Green
Fix the following warning types: - line length - block comment line * prefix - trailing */ on a separate line found by the checkpatch.pl tool in multiple block comments. Fix a single spelling error in a comment. Signed-off-by: Moshe Green <mgmoshes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-16staging: sm750fb: fix line length coding style issues in ddk750_chip.cMoshe Green
Fix multiple line length warnings found by the checkpatch.pl tool in ddk750_chip.c. Signed-off-by: Moshe Green <mgmoshes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-16Staging: sm750fb: Remove unnecessary blank lineSandhya Bankar
Remove unnecessary blank line. This patch is detected by checkpatch.pl script . CHECK: Blank lines aren't necessary before a close brace '}' Signed-off-by: Sandhya Bankar <bankarsandhya512@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-12staging: sm750fb: Correctly set CLOCK_PHASE bit of display controller.Phil Turnbull
Commit 6fba39cf32a3 ("staging: sm750fb: use BIT macro for PANEL_DISPLAY_CTRL single-bit fields") accidentally changed the CLOCK_PHASE logic from '|=' to '=' which clears all the previously set bits. Fixes: 6fba39cf32a3 ("staging: sm750fb: use BIT macro for PANEL_DISPLAY_CTRL single-bit fields") Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21staging: sm750fb: Fix block comment styleEdward Lipinsky
This patch fixes the checkpatch.pl warning: WARNING: Block comments use * on subsequent lines Signed-off-by: Edward Lipinsky <ellipinsky@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21sm750fb/sm750_hw.c: split assignment & long linesStefan Wolz
Split lines over 80 characters and separated assignments. Signed-off-by: Stefan Wolz <wolzstefan@web.de> Signed-off-by: Christian Halder <christian.halder@fau.de> Signed-off-by: Sebastian Handwerker <sebastian.handwerker@posteo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21sm750fb/sm750_hw.c: fixed commentsStefan Wolz
Fixed multiline comments to meet style standards, fixed typos and split comment lines over 80 characters. Signed-off-by: Stefan Wolz <wolzstefan@web.de> Signed-off-by: Christian Halder <christian.halder@fau.de> Signed-off-by: Sebastian Handwerker <sebastian.handwerker@posteo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21sm750fb/sm750_hw.c: fixed whitespacingStefan Wolz
Deleted unnecessary newlines and added whitespaces around operators. Signed-off-by: Stefan Wolz <wolzstefan@web.de> Signed-off-by: Christian Halder <christian.halder@fau.de> Signed-off-by: Sebastian Handwerker <sebastian.handwerker@posteo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21sm750fb/sm750_hw.c: corrected alignmentStefan Wolz
Fixed alignment in multiline declarations. Signed-off-by: Stefan Wolz <wolzstefan@web.de> Signed-off-by: Christian Halder <christian.halder@fau.de> Signed-off-by: Sebastian Handwerker <sebastian.handwerker@posteo.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21staging: sm750fb: fix block comments errors in ddk750_display.cyeongjun Kim
WARNING: Block comments use * on subsequent lines WARNING: Block comments use a trailing */ on a separate line WARNING: Block comments use * on subsequent lines WARNING: Block comments use a trailing */ on a separate line Signed-off-by: yeongjun Kim <iam.yeongjunkim@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21Staging: sm750fb: fix block comment coding style issue in ddk750_chip.cMoshe Green
This is a patch to the ddk750_chip.c file that fixes up two block comment coding style warnings found by the checkpatch.pl tool Signed-off-by: Moshe Green <mgmoshes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21Staging: sm750fb: fix line length coding style issue in ddk750_chip.cMoshe Green
This is a patch to the ddk750_chip.c file that fixes up a line length warning found by the checkpatch.pl tool Signed-off-by: Moshe Green <mgmoshes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-21Staging: sm750fb: fix a line length coding style warning in ddk750_chip.cMoshe Green
This is a patch to the ddk750_chip.c file that fixes up a line length warning found by the checkpatch.pl tool. Signed-off-by: Moshe Green <paledirac@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-29staging: sm750fb: initialize max_d to maximum D value of 6Colin Ian King
max_d is not initialized and should be set to the largest D value of 6. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11Staging: sm750fb: Remove unused functionsBhumika Goyal
The functions dviGetDeviceID and dviGetVendorID are not used anywhere in the kernel so remove them. Also, remove their function prototypes. Grepped to find occurences. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11Staging: sm750fb: Remove leading and trailing whitespace.Sandhya Bankar
Remove leading and trailing whitespace. Signed-off-by: Sandhya Bankar <bankarsandhya512@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11staging: sm750fb: convert pr_err() to dev_err()Eva Rachel Retuya
Replace pr_err() calls with respective dev_err() counterpart. Change is safe since pdev is not NULL, this was identified by hand. Semantic patch used to detect and apply the transformation: @r exists@ identifier f,s,i; position p; @@ f(...,struct s *i,...) { <+... pr_err@p(...) ...+> } @s@ identifier r.s, dev; @@ struct s { ... struct device dev; ... }; @t@ identifier r.i, s.dev; expression fmt; position r.p; @@ - pr_err@p( + dev_err(&i->dev, fmt, ...); Signed-off-by: Eva Rachel Retuya <eraretuya@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11staging: sm750fb: Remove Unused macroBhaktipriya Shridhar
The macro PEEK32 is used nowhere in the file. Hence,removed. Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11staging: sm750fb: Use pcim_enable_device()Amitoj Kaur Chawla
Devm_ functions allocate memory that is released when a driver detaches. Replace pci_enable_device with the managed pcim_enable_device and remove corresponding pci_disable_device from probe and suspend functions of a pci_dev. Also, an unnecessary label has been removed by replacing it with a direct return statement. Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11staging: sm750fb: Replace kzalloc with devm_kzallocAmitoj Kaur Chawla
Devm_ functions allocate memory that is released when a driver detaches. Replace kzalloc with devm_kzalloc and remove corresponding kfrees from probe and remove functions of a pci_dev. Also, an unnecessary label has been removed by replacing it with a direct return statement. Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11staging: sm750fb: Remove unnecessary pci_set_drvdata()Amitoj Kaur Chawla
Unnecessary pci_set_drvdata() has been removed since the driver core clears the driver data to NULL after device release or on probe failure. There is no need to manually clear the device driver data to NULL. The Coccinelle semantic patch used to make this change is as follows: //<smpl> @@ struct pci_dev *pci; @@ - pci_set_drvdata(pci, NULL); //</smpl> Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-11staging: sm750fb: Remove parentheses from return argumentsAmitoj Kaur Chawla
Remove unnecessary parentheses from return arguments. The Coccinelle semantic patch that makes this change is as follows: // <smpl> @@ identifier i; constant c; @@ return - ( \(i\|-i\|i(...)\|c\) - ) ; // </smpl> Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-22staging: sm750fb: Remove header filesAmitoj Kaur Chawla
Remove duplicate include files. Found using includecheck. Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-20staging: sm750fb: remove sm750_help.hMike Rapoport
This header only contains unused FIELD_*() macros and friends and may be removed Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-20staging: sm750fb: move MHz() and roundedDiv() close to their usageMike Rapoport
The MHz() and roundedDiv macros are used only by ddk750_chip.c, so move their definition there. Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-20staging: sm750fb: replace absDiff with kernel standard abs macroMike Rapoport
<linux/kernel.h> already has 'abs', use it instead of custom absDiff Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-20staging: sm750: change definition of multi-bit register fieldsMike Rapoport
Use stratigh-forward of multi-bit register fields Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-20staging: sm750fb: use BIT() macro for single-bit fields definitionMike Rapoport
Replace complex definition of single-bit fields with BIT() macro for the registers that are not currently referenced by the driver. Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of CRT_FB_ADDRESS fieldsMike Rapoport
Use stratight-forward definition of CRT_FB_ADDRESS register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of CRT_FB_WIDTH fieldsMike Rapoport
Use stratight-forward definition of CRT_FB_WIDTH register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_WINDOW_WIDTH fieldsMike Rapoport
Use stratight-forward definition of DE_WINDOW_WIDTH register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_STRETCH_FORMAT fieldsMike Rapoport
Use stratight-forward definition of DE_STRETCH_FORMAT register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_PITCH fieldsMike Rapoport
Use stratight-forward definition of DE_PITCH register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_CONTROL fieldsMike Rapoport
Use stratight-forward definition of DE_CONTROL register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_DIMENSION fieldsMike Rapoport
Use stratight-forward definition of DE_DIMENSION register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_DESTINATION fieldsMike Rapoport
Use stratight-forward definition of DE_DESTINATION register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of DE_SOURCE fieldsMike Rapoport
Use stratight-forward definition of DE_SOURCE register fields and use open-coded implementation for register manipulation Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of HWC_COLOR_{12, 3} fieldsMike Rapoport
Use straight-forward definition of HWC_COLOR_{12,3} register fields instead of magic numbers Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of HWC_LOCATION fieldsMike Rapoport
Use BIT() macro for single-bit fields of HWC_LOCATION register and define HWC_LOCATION_{X,Y}_MASK for masking the address bits. Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-15staging: sm750fb: change definition of HWC_ADDRESS fieldsMike Rapoport
Use BIT() macro for single-bit fields of HWC_ADDRESS register and define HWC_ADDRESS_ADDRESS_MASK for masking the address bits. Signed-off-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
