disable the pci device when the module exits.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
before starting to access any address inside the PCI region we should
reserve the resource and release the resource when the module exits.
add MODULE_DEVICE_TABLE to support hot-plugging.
change return type of sm7xx_vga_setup() to void as we are not using
the return type anywhere. if this function fails we fall back to the
default configuration.
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
as we start to use kernel boot parameters and fb_get_options()
we donot need to use __setup() any more.
use module_init() and module_exit() instead of module_pci_driver
and at the same time make way for use of kernel boot parameters.
the variable vgamode is used only in this file and hence can be
safely made as static.
since mixed case names are not encouraged in coding, so those has
been changed to their corresponding lowercase version.
This symbol is never used anywhere else besides sm7xxfb.c
Signed-off-by: Max Perepelitsyn <mperepelitsyn@gmail.com>
Tested-by: Sudip Mukherjee <sudip@vectorindia.org>
checkpatch cleanup: alignment should match open parenthesis
checkpatch cleanup: blank lines are not necessary before closing brace
and after opening brace.
checkpatch cleanup: space is not necessary after cast
checkpatch cleanup to add missing blank line after declaration
update the email addresses in the TODO file, also update the final
destination of this driver.
This reverts commit "dc93c85235efa5201e9a3c116bc3fbd1afc1a182"
It hasn't been worked on in a very long time, and the original author
has moved on to a different product as this one is no longer being made.
So remove the driver. If someone wants to resurect it, and clean it up
and get it merged to the "proper" part of the kernel, this commit can be
reverted.
Cc: Teddy Wang <teddy.wang@siliconmotion.com.cn>
This patch fixes the following checkpatch.pl issues in sm7xxfb.c:
WARNING: Quoted string split across lines
Signed-off-by: Monam Agarwal <monamagarwal123@gmail.com>
Mark function smtcfb_setmode() as static in sm7xxfb.c because it is not
used outside this file.
This eliminates the following warning in sm7xxfb.c:
drivers/staging/sm7xxfb/sm7xxfb.c:588:6: warning: no previous prototype for ‘smtcfb_setmode’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Javier M. Mellid <jmunhoz@igalia.com>
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro
is not preferred.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Fix checkpatch.pl issues with line over 80 characters
in sm7xxfb.c
Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com>
Fixed coding style issues.
Signed-off-by: Martin Berglund <martin@rogsta.net>
Driver core sets driver data to NULL upon failure or remove.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Instead of assigning the pm_ops fields individually we can simply use
SIMPLE_DEV_PM_OPS.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Javier Muñoz <jmunhoz@igalia.com>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
This patch erases smtc_VRAMBaseAddress variable.
Signed-off-by: Javier M. Mellid <jmunhoz@igalia.com>
This patch renames pFramebufferPhysical name to mmio_base.
This patch improves naming style and comments on smtcfb_info fields.
This patch annotates iomem pointers.
This patch improves code legibility after last changes.
Setting up smtcfb_fix's id happens through smtc_alloc_fb_info. It adds
complexity and unnecesary code.
Part of fb_fix_screeninfo and fb_var_screeninfo initialization happens
in smtc_alloc_fb_info. It duplicates code while hiding the real
functionality of smtc_alloc_fb_info. This patch groups initialization
together.
the name is not initialised and passed to the function smtc_alloc_fb_info
and copies the name into a member of fb structure.
copy the name before calling alloc_fb_info.
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
the sm7xxfb is a pci device, and should depend on the PCI.
And also if we wont' depend on the PCI sub-system, the following warns
will be triggered,
drivers/staging/sm7xxfb/sm7xxfb.c:1061:1: warning: data definition has no type or storage class [enabled by default]
drivers/staging/sm7xxfb/sm7xxfb.c:1061:1: warning: type defaults to 'int' in declaration of 'module_pci_driver' [-Wimplicit-int]
drivers/staging/sm7xxfb/sm7xxfb.c:1061:1: warning: parameter names (without types) in function declaration [enabled by default]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This patch improves coding style on smtc_alloc_fb_info.
Tested with SM712.
This patch moves pseudo palette into smtcfb_info struct.
Tested with SM712.
This patch keeps smtc_set_timing and sm7xx_set_timing functions closed
to smtcfb_setmode. This change eases reviewing and maintaining this
logic path.
Tested with SM712.
sm712_set_timing handles timing for 0x710, 0x712 and 0x720 chips. This
patch renames the name of the function of sm712_set_timing to
sm7xx_set_timing.
Tested with SM712.
This patch keeps code related to sm7xx_vga_setup closed. It is useful to
understand/maintain the logic behind sm7xx_vga_setup with a simple look.
Tested with SM712.
This patch renames sm712vga_setup to sm7xx_vga_setup. sm7xx_vga_setup
process command line options in order to get the vga parameter. This
parameter will be the lookup index to match the right vesa mode. It is
chip independent.
This change of name improves readability on sm712_vga_setup and
smtcfb_pci_probe. It is coherent with the name of vars being used on
code while avoiding the use of extra long lines in functions.
Tested with SM712.
This patchs renames index var on sm712vga_setup.
Tested with SM712.
This patch renames structs related to vesa modes in order to get more
readable code on sm712vga_setup.
Tested with SM712.
as smtc_alloc_fb_info can fail, but we are returning the 0,
how? because the pci_enable_device succeeded, which makes the probe
return 0, and may cause panics or some strange problems at remove
when driver unloaded by modprobe -r.
so return err properly as smtc_alloc_fb_info is doing kzallocs its
good to do -ENOMEM
as the manual of module_pci_driver says that
it can be used when the init and exit functions of
the module does nothing but the pci_register_driver
and pci_unregister_driver.
use it for the sm7xxfb driver, as the driver does nothing in
its _init and _exit functions but the register and unregister.
This patch erases hardcode cast between smtcfb_info and fb_info in order
to get a more robust and less rigid smtcfb_info structure. fb_info
doesn't need to be the first field in smtcfb_info after this patch.
Tested with SM712.
This patch fixes CamelCase var names in smtcfb_info holding device and
revision identifiers.
Tested with SM712.
