path: root/drivers/staging/staging.c
2008-10-13Staging: workaround build system bugGreg Kroah-Hartman
This is needed as CONFIG_STAGING is set to y, yet there is no code in drivers/staging/ to build, so the build-in.o doesn't get created properly. Create a "dummy" module in drivers/staging called staging.c to work around this bug. Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
