[ Upstream commit 7566f39dfdc11f8a97d5810c6e6295a88f97ef91 ]
Abort the probing of the camera driver in case there isn't a camera
actually connected to the Raspberry Pi. This solution also avoids a
NULL ptr dereference of mmal instance on driver unload.
Fixes: 7b3ad5abf027 ("staging: Import the BCM2835 MMAL-based V4L2 camera driver.")
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de>
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit ca4e4efbefbbdde0a7bb3023ea08d491f4daf9b9 ]
These are accidentally returning positive EINVAL instead of negative
-EINVAL. Some of the callers treat positive values as success.
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
commit ca641bae6da977d638458e78cd1487b6160a2718 upstream.
The create_pagelist() "count" parameter comes from the user in
vchiq_ioctl() and it could overflow. If you look at how create_page()
is called in vchiq_prepare_bulk_data(), then the "size" variable is an
int so it doesn't make sense to allow negatives or larger than INT_MAX.
I don't know this code terribly well, but I believe that typical values
of "count" are typically quite low and I don't think this check will
affect normal valid uses at all.
The "pagelist_size" calculation can also overflow on 32 bit systems, but
not on 64 bit systems. I have added an integer overflow check for that
as well.
The Raspberry PI doesn't offer the same level of memory protection that
x86 does so these sorts of bugs are probably not super critical to fix.
Fixes: 71bad7f08641 ("staging: add bcm2708 vchiq driver")
Cc: stable <stable@vger.kernel.org>
commit 5a96b2d38dc054c0bbcbcd585b116566cbd877fe upstream.
The compatibility ioctl wrapper for VCHIQ_IOC_AWAIT_COMPLETION assumes that
the native ioctl always uses a message buffer and decrements msgbufcount.
Certain message types do not use a message buffer and in this case
msgbufcount is not decremented, and completion->header for the message is
NULL. Because the wrapper unconditionally decrements msgbufcount, the
calling process may assume that a message buffer has been used even when
it has not.
This results in a memory leak in the userspace code that interfaces with
this driver. When msgbufcount is decremented, the userspace code assumes
that the buffer can be freed though the reference in completion->header,
which cannot happen when the reference is NULL.
This patch causes the wrapper to only decrement msgbufcount when the
native ioctl decrements it. Note that we cannot simply copy the native
ioctl's value of msgbufcount, because the wrapper only retrieves messages
from the native ioctl one at a time, while userspace may request multiple
messages.
See https://github.com/raspberrypi/linux/pull/2703 for more discussion of
this patch.
Fixes: 5569a1260933 ("staging: vchiq_arm: Add compatibility wrappers for ioctls")
Signed-off-by: Ben Wolsieffer <benwolsieffer@gmail.com>
[ Upstream commit 678c5b119307c40f9a17152512f9c949d0ec7292 ]
Currently, if bcm2835_audio_open() fails partway, the allocated
workqueue is leaked. Avoid that.
While at it, propagate the return value of
bcm2835_audio_open_connection() on failure instead of returning -1.
[ Upstream commit 5b70084f6cbcd53f615433f9d216e01bd71de0bb ]
wait_for_completion_timeout returns unsigned long not int so a variable of
proper type is introduced. Further the check for <= 0 is ambiguous and
should be == 0 here indicating timeout.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
[ Upstream commit b7afce51d95726a619743aaad8870db66dfa1479 ]
proper type is introduced. Further the check for <= 0 is ambiguous and should
be == 0 here indicating timeout which is the only error case so no additional
check needed here.
[ Upstream commit 8113b89fc615cfb531df0334fb3a091cf6a45ce0 ]
The bail out branch in case of a invalid tx_pos missed a semaphore
release. Dan Carpenter found this with a static checker.
Fixes: d1eab9dec610 ("staging: vchiq_core: Bail out in case of invalid tx_pos")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 626118b472d2eb45f83a0276a18d3e6a01c69f6a ]
In the current implementation, `rmmod snd_bcm2835` does not release
resources properly. It causes an oops when trying to list sound devices.
This commit fixes it.
The details WRT allocation / free are described below.
Device structure WRT allocation:
pdev
\childdev[]
\card
\chip
\pcm
\ctl
Allocation / register sequence:
* childdev: devm_kzalloc - freed during driver detach
* childdev: device_initialize - freed during device_unregister
* pdev: devres_alloc - freed during driver detach
* childdev: device_add - removed during device_unregister
* pdev, childdev: devres_add - freed during driver detach
* card: snd_card_new - freed during snd_card_free
* chip: kzalloc - freed during kfree
* card, chip: snd_device_new - freed during snd_device_free
* chip: new_pcm - TODO: free pcm
* chip: new_ctl - TODO: free ctl
* card: snd_card_register - unregistered during snd_card_free
Free / unregister sequence:
* card: snd_card_free
* card, chip: snd_device_free
* childdev: device_unregister
* chip: kfree
Steps to reproduce the issue before this commit:
$ rmmod snd_bcm2835
$ aplay -L
[ 138.648130] Unable to handle kernel paging request at virtual address 7f1343c0
[ 138.660415] pgd = ad8f0000
[ 138.665567] [7f1343c0] *pgd=3864c811, *pte=00000000, *ppte=00000000
[ 138.674887] Internal error: Oops: 7 [#1] SMP ARM
[ 138.683571] Modules linked in: sha256_generic cfg80211 rfkill snd_pcm snd_timer
snd fixed uio_pdrv_genirq uio ip_tables x_tables ipv6 [last unloaded: snd_bcm2835
[ 138.706594] CPU: 3 PID: 463 Comm: aplay Tainted: G WC 4.15.0-rc1-v
7+ #6
[ 138.719833] Hardware name: BCM2835
[ 138.726016] task: b877ac00 task.stack: aebec000
[ 138.733408] PC is at try_module_get+0x38/0x24c
[ 138.740813] LR is at snd_ctl_open+0x58/0x194 [snd]
[ 138.748485] pc : [<801c4d5c>] lr : [<7f0e6b2c>] psr: 20000013
[ 138.757709] sp : aebedd60 ip : aebedd88 fp : aebedd84
[ 138.765884] r10: 00000000 r9 : 00000004 r8 : 7f0ed440
[ 138.774040] r7 : b7e469b0 r6 : 7f0e6b2c r5 : afd91900 r4 : 7f1343c0
[ 138.783571] r3 : aebec000 r2 : 00000001 r1 : b877ac00 r0 : 7f1343c0
[ 138.793084] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 138.803300] Control: 10c5387d Table: 2d8f006a DAC: 00000055
[ 138.812064] Process aplay (pid: 463, stack limit = 0xaebec210)
[ 138.820868] Stack: (0xaebedd60 to 0xaebee000)
[ 138.828207] dd60: 00000000 b848d000 afd91900 00000000 b7e469b0 7f0ed440 aebedda4 aebedd88
[ 138.842371] dd80: 7f0e6b2c 801c4d30 afd91900 7f0ea4dc 00000000 b7e469b0 aebeddcc aebedda8
[ 138.856611] dda0: 7f0e250c 7f0e6ae0 7f0e2464 b8478ec0 b7e469b0 afd91900 7f0ea388 00000000
[ 138.870864] ddc0: aebeddf4 aebeddd0 802ce590 7f0e2470 8090ab64 afd91900 afd91900 b7e469b0
[ 138.885301] dde0: afd91908 802ce4e4 aebede1c aebeddf8 802c57b4 802ce4f0 afd91900 aebedea8
[ 138.900110] de00: b7fa4c00 00000000 00000000 00000004 aebede3c aebede20 802c6ba8 802c56b4
[ 138.915260] de20: aebedea8 00000000 aebedf5c 00000000 aebedea4 aebede40 802d9a68 802c6b58
[ 138.930661] de40: b874ddd0 00000000 00000000 00000001 00000041 00000000 afd91900 aebede70
[ 138.946402] de60: 00000000 00000000 00000002 b7e469b0 b8a87610 b8d6ab80 801852f8 00080000
[ 138.962314] de80: aebedf5c aebedea8 00000001 80108464 aebec000 00000000 aebedf4c aebedea8
[ 138.978414] dea0: 802dacd4 802d970c b8a87610 b8d6ab80 a7982bc6 00000009 af363019 b9231480
[ 138.994617] dec0: 00000000 b8c038a0 b7e469b0 00000101 00000002 00000238 00000000 00000000
[ 139.010823] dee0: 00000000 aebedee8 00080000 0000000f aebedf3c aebedf00 802ed7e4 80843f94
[ 139.027025] df00: 00000003 00080000 b9231490 b9231480 00000000 00080000 af363000 00000000
[ 139.043229] df20: 00000005 00000002 ffffff9c 00000000 00080000 ffffff9c af363000 00000003
[ 139.059430] df40: aebedf94 aebedf50 802c6f70 802dac70 aebec000 00000000 00000001 00000000
[ 139.075629] df60: 00020000 00000004 00000100 00000001 7ebe577c 0002e038 00000000 00000005
[ 139.091828] df80: 80108464 aebec000 aebedfa4 aebedf98 802c7060 802c6e6c 00000000 aebedfa8
[ 139.108025] dfa0: 801082c0 802c7040 7ebe577c 0002e038 7ebe577c 00080000 00000b98 e81c8400
[ 139.124222] dfc0: 7ebe577c 0002e038 00000000 00000005 7ebe57e4 00a20af8 7ebe57f0 76f87394
[ 139.140419] dfe0: 00000000 7ebe55c4 76ec88e8 76df1d9c 60000010 7ebe577c 00000000 00000000
[ 139.156715] [<801c4d5c>] (try_module_get) from [<7f0e6b2c>] (snd_ctl_open+0x58/0x194 [snd])
[ 139.173222] [<7f0e6b2c>] (snd_ctl_open [snd]) from [<7f0e250c>] (snd_open+0xa8/0x14c [snd])
[ 139.189683] [<7f0e250c>] (snd_open [snd]) from [<802ce590>] (chrdev_open+0xac/0x188)
[ 139.205465] [<802ce590>] (chrdev_open) from [<802c57b4>] (do_dentry_open+0x10c/0x314)
[ 139.221347] [<802c57b4>] (do_dentry_open) from [<802c6ba8>] (vfs_open+0x5c/0x88)
[ 139.236788] [<802c6ba8>] (vfs_open) from [<802d9a68>] (path_openat+0x368/0x944)
[ 139.248270] [<802d9a68>] (path_openat) from [<802dacd4>] (do_filp_open+0x70/0xc4)
[ 139.263731] [<802dacd4>] (do_filp_open) from [<802c6f70>] (do_sys_open+0x110/0x1d4)
[ 139.279378] [<802c6f70>] (do_sys_open) from [<802c7060>] (SyS_open+0x2c/0x30)
[ 139.290647] [<802c7060>] (SyS_open) from [<801082c0>] (ret_fast_syscall+0x0/0x28)
[ 139.306021] Code: e3c3303f e5932004 e2822001 e5832004 (e5943000)
[ 139.316265] ---[ end trace 7f3f7f6193b663ed ]---
[ 139.324956] note: aplay[463] exited with preempt_count 1
Signed-off-by: Kirill Marinushkin <k.marinushkin@gmail.com>
Cc: Eric Anholt <eric@anholt.net>
Cc: Stefan Wahren <stefan.wahren@i2se.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: bcm-kernel-feedback-list@broadcom.com
Cc: Michael Zoran <mzoran@crowfest.net>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: linux-rpi-kernel@lists.infradead.org
Cc: devel@driverdev.osuosl.org
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The previous commit (0adbfd46) fixed a memory leak but also freed a
block in the success case, causing a stale pointer to be used with
potentially fatal results. Only free the vchi_instance block in the
case that vchi_connect fails; once connected, the instance is
retained for subsequent connections.
Simplifying the code by removing a bunch of gotos and returning errors
directly.
Signed-off-by: Phil Elwell <phil@raspberrypi.org>
Fixes: 0adbfd4694c2 ("staging: bcm2835-audio: fix memory leak in bcm2835_audio_open_connection()")
Cc: stable <stable@vger.kernel.org> # 4.12+
Tested-by: Stefan Wahren <stefan.wahren@i2se.com>
This fixes a NULL pointer dereference on RPi 2 with multi_v7_defconfig.
The function page_address() could return NULL with enabled CONFIG_HIGHMEM.
So fix this by using kmap() instead.
Make this const as it is only used in a copy operation.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
These vb2_ops structures are only stored in the ops field of a
vb2_queue structure, which is declared as const. Thus the vb2_ops
structures themselves can be const.
Done with the help of Coccinelle.
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct vb2_ops i@p = { ... };
@ok@
identifier r.i;
struct vb2_queue e;
position p;
e.ops = &i@p;
@bad@
position p != {r.p,ok.p};
identifier r.i;
struct vb2_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct vb2_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Make these const as they are only used during a copy operation.
Done using Coccinelle.
Check for snd_pcm_ops structures that are only stored in the ops field of
a snd_soc_platform_driver structure or passed as the third argument to
snd_pcm_set_ops. The corresponding field or parameter is declared const,
so snd_pcm_ops structures that have this property can be declared as
const also.
This issue was detected using Coccinelle and the following semantic patch:
identifier i;
position p;
static struct snd_pcm_ops i@p = { ... };
@ok1@
identifier r.i;
struct snd_soc_platform_driver e;
position p;
e.ops = &i@p;
@ok2@
identifier r.i;
expression e1, e2; position p;
snd_pcm_set_ops(e1, e2, &i@p)
@bad@
position p != {r.p,ok1.p,ok2.p};
identifier r.i;
struct snd_pcm_ops e;
e@i@p
identifier r.i;
static
+const
struct snd_pcm_ops i = { ... };
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
This resolves a merge issue and gets the vmbox drm driver into this
branch to be able to start taking fixes for it...
kzalloc call was changed to kcalloc by checkpatch.pl recommendation
Signed-off-by: Andrey Severin <lkd1024@mail.ru>
If vchiq_debugfs_init() fails, then we accidentally return a valid
pointer casted to int on error. This code is simpler if we get rid of
the "ptr_err" variable and just use "err" throughout.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This development cycle resulted in a fair amount of changes in both
core and driver sides. The most significant change in ALSA core is
about PCM. Also the support of of-graph card and the new DAPM widget
for DSP are noteworthy changes in ASoC core. And there're lots of
small changes splat over the tree, as you can see in diffstat.
Below are a few highlights:
ALSA core:
- Removal of set_fs() hackery from PCM core stuff, and the code
reorganization / optimization thereafter
- Improved support of PCM ack ops, and a new ABI for improved
control/status mmap handling
- Lots of constifications in various codes
ASoC core:
- The support of of-graph card, which may work as a better generic
device for a replacement of simple-card
- New widget types intended mainly for use with DSPs
ASoC drivers:
- New drivers for Allwinner V3s SoCs
- Ensonic ES8316 codec support
- More Intel SKL and KBL works
- More device support for Intel SST Atom (mostly for cheap tablets
and 2-in-1 devices)
- Support for Rockchip PDM controllers
- Support for STM32 I2S and S/PDIF controllers
- Support for ZTE AUD96P22 codecs
HD-audio:
- Support of new Realtek codecs (ALC215/ALC285/ALC289), more quirks
for HP and Dell machines
- A few more fixes for i915 component binding"
* tag 'sound-4.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (418 commits)
ALSA: hda - Fix unbalance of i915 module refcount
ASoC: Intel: Skylake: Remove driver debugfs exit
ASoC: Intel: Skylake: explicitly add the headers sst-dsp.h
ALSA: hda/realtek - Remove GPIO_MASK
ALSA: hda/realtek - Fix typo of pincfg for Dell quirk
ALSA: pcm: add a documentation for tracepoints
ALSA: atmel: ac97c: fix error return code in atmel_ac97c_probe()
ALSA: x86: fix error return code in hdmi_lpe_audio_probe()
ASoC: Intel: Skylake: Add support to read firmware registers
ASoC: Intel: Skylake: Add sram address to sst_addr structure
ASoC: Intel: Skylake: Debugfs facility to dump module config
ASoC: Intel: Skylake: Add debugfs support
ASoC: fix semicolon.cocci warnings
ASoC: rt5645: Add quirk override by module option
ASoC: rsnd: make arrays path and cmd_case static const
ASoC: audio-graph-card: add widgets and routing for external amplifier support
ASoC: audio-graph-card: update bindings for amplifier support
ASoC: rt5665: calibration should be done before jack detection
ASoC: rsnd: constify dev_pm_ops structures.
ASoC: nau8825: change crosstalk-bypass property to bool type
For applying more ALSA timer cleanups.
This replaces all remaining BUG_ON with WARN_ON. So in case of
a VCHIQ bug the system is still usable.
Properly handle the error case in case of an invalid tx_pos.
Bail out properly if the process index doesn't match the remote insert.
We also drop the BUG in case the process index is at local insert,
so we can trigger the WARN_ON again some steps later.
If the ref counter of service has an unexpected value then we better
bail out.
In the unlikely case that service is NULL we should bail out instead
of calling BUG_ON(). The other BUG_ON calls will be fixed in separate
patches.
VCHIQ suspend and resume isn't implemented, but even it was
there is no need to call BUG().
In case VCHIQ state is already initialized we need to bailout
in order to aovid a memory leak.
Since the ARM side of VCHIQ support only 1 state, we could simplify
the init code. This makes it possible to avoid BUG_ON and a theoretical
overflow of id.
Use the PAGE_MASK instead of open code it.
In case vmalloc_to_page returns NULL create_pagelist must abort
imediatly.
Assuming the intension of the function is to clean up, so fix the function
name accordingly.
Reduce the indentation within vchiq_dump_service_use_state in order
to avoid a multiline derefernce.
This comment was apparently forgotten in the correction of CamelCase.
The variable slot_mem_size is assigned a value which is never used.
This issue has been found by CppCheck.
We can reduce the scope of the counting variable i. This has
Instead of saving the return value of mutex_lock_killable in a
local variable we could use the value directly.
Now that the indirect-PCM transfer helper gives back an error, we
should return the error from ack callbacks.
Acked-by: Eric Anholt <eric@anholt.net>
vchiq_arm supports transfers less than one page and at arbitrary
alignment, using the dma-mapping API to perform its cache maintenance
(even though the VPU drives the DMA hardware). Read (DMA_FROM_DEVICE)
operations use cache invalidation for speed, falling back to
clean+invalidate on partial cache lines, with writes (DMA_TO_DEVICE)
using flushes.
If a read transfer has ends which aren't page-aligned, performing cache
maintenance as if they were whole pages can lead to memory corruption
since the partial cache lines at the ends (and any cache lines before or
after the transfer area) will be invalidated. This bug was masked until
the disabling of the cache flush in flush_dcache_page().
Honouring the requested transfer start- and end-points prevents the
corruption.
Fixes: cf9caf192988 ("staging: vc04_services: Replace dmac_map_area with dmac_map_sg")
Cc: stable <stable@vger.kernel.org> # 4.10
Reported-by: Stefan Wahren <stefan.wahren@i2se.com>
Gstreamer's v4l2src reacted poorly to certain outputs from the bcm2835
video driver's ioctl ops function vidioc_enum_framesizes, so a
workaround was created that could be activated by user input. This
workaround would replace the driver's ioctl ops struct with another,
similar struct--only with no function pointed to by
vidioc_enum_framesizes. With no response, gstreamer would attempt to
continue with some default settings that happened to work better.
However, this bug has been fixed in gstreamer since 2014, so we
shouldn't include this workaround in the stable version of the driver.
Signed-off-by: Kevin Wern <kevin.m.wern@gmail.com>
vchi_cfg.h: fix checkpatch ERROR: Macros with complex values should be enclosed in parenthesis
Signed-off-by: Haim Daniel <haimdaniel@gmail.com>
Remove unnecessary log messages in the driver which are just tracking
function entry and exits.
Signed-off-by: Aishwarya Pant <aishpant@gmail.com>
trivial fix to spelling mistake in various comments and pr_debug messages
We need the IIO fixes in here as well to handle merge issues.
Regarding to the header the driver is licensed under BSD and GPL.
The firmware for the Raspberry PI already supports simultanous output
of audio through both the HDMI and the Headphone jack. The current
implementation of ALSA doesn't expose this well to user mode since
the firmware audio is represented as a single card.
A newer approach is taken here and a virtual card is created for each
output(HDMI, Headphones, and Traditional ALSA). The firmware has
the concept of channels or streams for which the number to use is
passed in the device tree. These streams are allocated to each of the
virtual cards.
As a side effect of this change, since each output is represented
independenly it's now very easy to use PulseAudio to control the
priorities of the outputs.
Testing:
Audacity and VLC were both loaded at the same time. Each application
was assigned to a different card. With this change I was able to play
different music files at the same time through the HDMI and Headphones
jacks and control the audio independently.
Signed-off-by: Michael Zoran <mzoran@crowfest.net>
https://github.com/raspberrypi/linux/issues/1447
port_parameter_get() failed to account for the header
(u32 id and u32 size) in the size before memcpying
the response into the response buffer, so overrunning
the provided buffer by 8 bytes.
Account for those bytes, and also a belt-and-braces
check to ensure we never copy more than *value_size
bytes into value.
Signed-off-by: Dave Stevenson <dave.stevenson@raspberrypi.org>
Tested-by: Michael Zoran <mzoran@crowfest.net>
Adding the 'bool' symbol brought back a randconfig build bug that
I had fixed before:
drivers/staging/built-in.o: In function `vchiq_probe':
(.text+0x1da30): undefined reference to `rpi_firmware_get'
drivers/staging/built-in.o: In function `vchiq_platform_init':
(.text+0x27494): undefined reference to `rpi_firmware_property'
The problem is that when RASPBERRYPI_FIRMWARE is a loadable module,
but BCM2835_VCHIQ can again be built-in. Making BCM_VIDEOCORE
itself tristate will make Kconfig honor the dependency correctly.
Fixes: 6bbfe4a76158 ("staging: vc04_services: Create new BCM_VIDEOCORE setting for VideoCore services.")
Currently, if pservice is null then service is set to NULL and immediately
afterwards service is dereferenced causing a null pointer dereference. Fix
this by bailing out early of the function with a null return.
Detected by CoverityScan, CID#1419681 ("Explicit null dereferenced")
Using typedef for a structure type and upper case struct names is not
suggested in Linux kernel coding style guidelines. Hence, occurences
of typedefs have been removed and struct names converted to lowercase
in the file. Grep was also used to ensure that all occurence of the
typedefs have been removed. The module compiles without any warnings
or errors.
Script 1:
@r1@
type T;
typedef struct { ... } T;
@script:python c1@
T2;
T << r1.T;
if T[-2:] =="_T":
coccinelle.T2 = T[:-2].lower();
print T
else:
coccinelle.T2=T.lower();
@r2@
type r1.T;
identifier c1.T2;
-typedef
struct
+ T2
-T
@r3@
type r1.T;
identifier c1.T2;
- T
+ struct T2
Script 2:
typedef VCHIQ_ELEMENT_T;
- VCHIQ_ELEMENT_T
+ struct vchiq_element
Signed-off-by: Gargi Sharma <gs051095@gmail.com>
