path: root/drivers/staging/vt6655
2011-05-06staging: vt6655: Fix warnings if CONFIG_PM is not definedLarry Finger
If staging:vt6655 is built without CONFIG_DM being defined, there are large numbers of warnings of the following form due to use of #if instead of #ifdef: In file included from drivers/staging/vt6655/upc.h:32, from drivers/staging/vt6655/mac.h:39, from drivers/staging/vt6655/wroute.c:34: drivers/staging/vt6655/device.h:399:5: warning: "CONFIG_PM" is not defined Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25staging: Remove unnecessary semicolons when switch (foo) {...};Joe Perches
Done via perl script: $ cat remove_semi_switch.pl my $match_balanced_parentheses = qr/(\((?:[^\(\)]++|(?-1))*\))/; my $match_balanced_braces = qr/(\{(?:[^\{\}]++|(?-1))*\})/; foreach my $file (@ARGV) { my $f; my $text; my $oldtext; next if ((-d $file)); open($f, '<', $file) or die "$P: Can't open $file for read\n"; $oldtext = do { local($/) ; <$f> }; close($f); next if ($oldtext eq ""); $text = $oldtext; my $count = 0; do { $count = 0; $count += $text =~ s@\b(switch\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx; } while ($count > 0); if ($text ne $oldtext) { my $newfile = $file; open($f, '>', $newfile) or die "$P: Can't open $newfile for write\n"; print $f $text; close($f); } } $ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25staging: Remove unnecessary semicolons when for (foo) {...};Joe Perches
Done via perl script: $ cat remove_semi_for.pl my $match_balanced_parentheses = qr/(\((?:[^\(\)]++|(?-1))*\))/; my $match_balanced_braces = qr/(\{(?:[^\{\}]++|(?-1))*\})/; foreach my $file (@ARGV) { my $f; my $text; my $oldtext; next if ((-d $file)); open($f, '<', $file) or die "$P: Can't open $file for read\n"; $oldtext = do { local($/) ; <$f> }; close($f); next if ($oldtext eq ""); $text = $oldtext; my $count = 0; do { $count = 0; $count += $text =~ s@\b(for\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx; } while ($count > 0); if ($text ne $oldtext) { my $newfile = $file; open($f, '>', $newfile) or die "$P: Can't open $newfile for write\n"; print $f $text; close($f); } } $ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25staging: Remove unnecessary semicolons when if (foo) {...};Joe Perches
Done via perl script: $ cat remove_semi_if.pl my $match_balanced_parentheses = qr/(\((?:[^\(\)]++|(?-1))*\))/; my $match_balanced_braces = qr/(\{(?:[^\{\}]++|(?-1))*\})/; foreach my $file (@ARGV) { my $f; my $text; my $oldtext; next if ((-d $file)); open($f, '<', $file) or die "$P: Can't open $file for read\n"; $oldtext = do { local($/) ; <$f> }; close($f); next if ($oldtext eq ""); $text = $oldtext; my $count = 0; do { $count = 0; $count += $text =~ s@\b(if\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx; } while ($count > 0); if ($text ne $oldtext) { my $newfile = $file; open($f, '>', $newfile) or die "$P: Can't open $newfile for write\n"; print $f $text; close($f); } } $ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-07Merge branch 'staging-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (28 commits) staging: usbip: bugfix for isochronous packets and optimization staging: usbip: bugfix add number of packets for isochronous frames staging: usbip: bugfixes related to kthread conversion staging: usbip: fix shutdown problems. staging: hv: Fix GARP not sent after Quick Migration staging: IIO: IMU: ADIS16400: Avoid using printk facility directly staging: IIO: IMU: ADIS16400: Fix product ID check, skip embedded revision number staging: IIO: IMU: ADIS16400: Make sure only enabled scan_elements are pushed into the ring staging: IIO: IMU: ADIS16400: Fix addresses of GYRO and ACCEL calibration offset staging: IIO: IMU: ADIS16400: Add delay after self test staging: IIO: IMU: ADIS16400: Fix up SPI messages cs_change behavior staging/rtl81*: build as loadable modules only staging: brcm80211: removed 'is_amsdu causing toss' log spam staging: brcm80211: fix for 'Short CCK' log spam staging: brcm80211: fix for 'AC_BE txop..' logs spammed problem staging: memrar: remove driver from tree staging: sep: remove last memrar remnants staging: fix hv_mouse build, needs delay.h staging: fix olpc_dcon build errors staging: sm7xx: fixed defines ... Fix up trivial conflict in drivers/staging/memrar/memrar_handler.c (deleted vs trivial spelling fixes)
2011-04-04Staging: vt665?: prevent modules from being built into the kernel.Greg Kroah-Hartman
It causes lots of linking errors when both of these modules are built into the kernel directly due to their global symbol mess. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14staging: vt6655: Remove NULL check before kfreeIlia Mirkin
This patch was generated by the following semantic patch: // <smpl> @@ expression E; @@ - if (E != NULL) { kfree(E); } + kfree(E); @@ expression E; @@ - if (E != NULL) { kfree(E); E = NULL; } + kfree(E); + E = NULL; // </smpl> Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-28staging: vt6655: device_main.c remove one to many l's in the word.Justin P. Mattock
The patch below removes an extra "l" in the word. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-21staging/vt6655: fix sparse warning "obsolete struct initializer"Peter Huewe
This patch fixes the sparse warnings "obsolete struct initializer, use C99 syntax" in vt6655/device_main.c by converting the struct to C99 syntax KernelVersion: linux-next-20110110 Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-16drivers/staging: Remove unnecessary semicolonsJoe Perches
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-05Staging: vt6655: Makefile: cleaned up Makefile cflag linesTracey Dent
Changed to use the proper ccflags-y option Signed-off-by: Tracey Dent <tdent48227@gmail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20Staging: vt6655: remove unused update_BssList definitionCharles Clément
Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20Staging: vt6655: fix buffer overflowDan Carpenter
"param->u.wpa_associate.wpa_ie_len" comes from the user. We should check it so that the copy_from_user() doesn't overflow the buffer. Also further down in the function, we assume that if "param->u.wpa_associate.wpa_ie_len" is set then "abyWPAIE[0]" is initialized. To make that work, I changed the test here to say that if "wpa_ie_len" is set then "wpa_ie" has to be a valid pointer or we return -EINVAL. Oddly, we only use the first element of the abyWPAIE[] array. So I suspect there may be some other issues in this function. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20staging: vt6655: '&pointer[0]' to 'pointer' fixAndy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-16Staging: vt665x: remove unused DEF definitionCharles Clément
2010-09-16staging: vt6655: use '%pM' format to print MAC addressAndy Shevchenko
2010-08-31staging: Use available error codesJulia Lawall
An error code is stored in a variable, but 0 is returned instead. Use the variable instead of 0. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ local idexpression x; constant C; @@ if (...) { ... x = -C ... when != x ( return <+...x...+>; | return NULL; | return; | * return ...; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-31staging: vt6655: do not use PCI resources before pci_enable_device()Kulikov Vasiliy
IRQ and resource[] may not have correct values until after PCI hotplug setup occurs at pci_enable_device() time. The semantic match that finds this problem is as follows: // <smpl> @@ identifier x; identifier request ~= "pci_request.*|pci_resource.*"; @@ ( * x->irq | * x->resource | * request(x, ...) ) ... *pci_enable_device(x) // </smpl> Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02Staging: vt6655: replace BOOL with in kernel boolCharles Clément
2010-08-02Staging: vt6655: replace FALSE with in kernel falseCharles Clément
2010-08-02Staging: vt6655: replace TRUE with in kernel trueCharles Clément
2010-07-08Staging: vt6655: use for_each_pci_dev()Kulikov Vasiliy
Use for_each_pci_dev() to simplify the code. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-08Staging: vt6655: simplify broadcast and multicast ethernet address testCharles Clément
A broadcast address is also a multicast address so simplify test cases where possible. As suggested by Joe Perches. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-25Staging: vt6655: Add TODO entries on x86-64 pointers and .data sizeCharles Clément
As suggested by Jiri Slaby. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-25Staging: vt6655: remove PUINT typedefCharles Clément
2010-06-24Staging: vt6655: remove BYTE typedefCharles Clément
Replace all occurrences with unsigned char type. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-24Staging: vt6655: remove WORD typedefCharles Clément
Replace all occurrences with unsigned short type. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-24Staging: vt6655: remove DWORD typedefCharles Clément
Replace all occurrences with unsigned long type, except for pointer fields that should be u32 in packed structures and 8-byte-aligned 8 byte long structure QWORD. Thanks to Jiri Slaby for pointing out that simply replacing by unsigned long is wrong on x86-64 arch. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-22Staging: vt6655: remove DWORD_PTR pointer typedefCharles Clément
Use unsigned long instead. Signed-off-by: Charles Clément <caratorn@gmail.com>
2010-06-22Staging: vt6655: remove ULONG_PTR typedefCharles Clément
2010-06-22Staging: vt6655: move channel mapping code from card.c to channel.cCharles Clément
Move functions managing the channel mapping to a new channel.c file, as done in the staging VT6656 driver. The function names contained in card.c were prefixed with CARD followed by the first letter of the return code, remove this and use more coherent function names. The following functions moved and were renamed: ChannelValid -> is_channel_valid CARDbSetChannel -> set_channel CARDvInitChannelTable -> init_channel_table CARDbyGetChannelMapping -> get_channel_mapping CARDvSetCountryInfo -> set_country_info CARDbySetSupportChannels -> set_support_channels CARDbChannelGetList -> channel_get_list CARDvSetCountryIE -> set_country_IE CARDbGetChannelMapInfo -> get_channel_map_info CARDvSetChannelMapInfo -> set_channel_map_info CARDvClearChannelMapInfo -> clear_channel_map_info CARDbyAutoChannelSelect -> auto_channel_select CARDbyGetChannelNumber -> get_channel_number Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt6655: struct pci_driver cleanupCharles Clément
Rename driver struct and callbacks to vt6655_* instead of device_* and add __devinit/__devexit directives. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt665*: fix typos concerning "management"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt6655: fix up U32 conversionGreg Kroah-Hartman
Commit 902d2411298a6e0b8a473a0163aa4bf6d5c8a073 converted U32 to u32 which you would think would be just fine. Unfortunatly, it seems that VIA only builds their code on a 32bit processor (which makes sense if you think about it), but this doesn't work on x86-64. So fix up the few places where this really wanted to be an unsigned long width. Cc: Charles Clément <caratorn@gmail.com> Cc: Forest Bond <forest@alittletooquiet.net>, Cc: Andres More <more.andres@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt6655: include linux/ headers instead of asm/Charles Clément
2010-06-18Staging: vt6655: remove PDWORD typedefCharles Clément
Use unsigned long * instead. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt6655: remove PWORD typedefCharles Clément
Use unsigned short * instead. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt6655: remove PBYTE typedefCharles Clément
Use unsigned char * instead. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-18Staging: vt6655: remove custom ULONGLONG typedefCharles Clément
2010-06-18Staging: vt6655: remove custom ULONG typedefCharles Clément
2010-06-18Staging: vt6655: remove custom UINT typedefCharles Clément
2010-06-18Staging: vt6655: remove custom USHORT typedefCharles Clément
2010-06-18Staging: vt6655: remove custom UCHAR typedefCharles Clément
2010-06-18Staging: vt6655: remove custom LONG typedefCharles Clément
2010-06-18Staging: vt6655: remove custom INT typedefCharles Clément
2010-06-18Staging: vt6655: removed custom SHORT typedefCharles Clément
2010-06-18Staging: vt6655: removed custom CHAR typedefCharles Clément
2010-06-18Staging: vt6655: remove U32 custom macroCharles Clément
Remove custom macro for unsigned 32-bit integers, replace by u32. Signed-off-by: Charles Clément <caratorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
