Since in each case nothing has been done with the recently allocated urb,
it is not necessary to kill it before freeing it.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression urb;
statement S;
position p1,p2;
urb = usb_alloc_urb@p1(...);
... when != urb
if (urb == NULL) S
... when != urb
usb_kill_urb@p2(urb);
@other exists@
position r.p1,r.p2;
... when != usb_alloc_urb@p1(...)
usb_kill_urb@p2(...);
@depends on !other exists@
expression urb;
position r.p1,r.p2;
-usb_kill_urb@p2(urb);
+usb_free_urb(urb);
... when != urb
// </smpl>
Done via perl script:
$ cat remove_semi_switch.pl
my $match_balanced_parentheses = qr/(\((?:[^\(\)]++|(?-1))*\))/;
my $match_balanced_braces = qr/(\{(?:[^\{\}]++|(?-1))*\})/;
foreach my $file (@ARGV) {
my $f;
my $text;
my $oldtext;
next if ((-d $file));
open($f, '<', $file)
or die "$P: Can't open $file for read\n";
$oldtext = do { local($/) ; <$f> };
close($f);
next if ($oldtext eq "");
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(switch\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
} while ($count > 0);
if ($text ne $oldtext) {
my $newfile = $file;
open($f, '>', $newfile)
or die "$P: Can't open $newfile for write\n";
print $f $text;
close($f);
$ cat remove_semi_for.pl
my $f;
my $text;
my $oldtext;
close($f);
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(for\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
print $f $text;
close($f);
$ cat remove_semi_if.pl
my $f;
my $text;
my $oldtext;
close($f);
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(if\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
print $f $text;
close($f);
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (28 commits)
staging: usbip: bugfix for isochronous packets and optimization
staging: usbip: bugfix add number of packets for isochronous frames
staging: usbip: bugfixes related to kthread conversion
staging: usbip: fix shutdown problems.
staging: hv: Fix GARP not sent after Quick Migration
staging: IIO: IMU: ADIS16400: Avoid using printk facility directly
staging: IIO: IMU: ADIS16400: Fix product ID check, skip embedded revision number
staging: IIO: IMU: ADIS16400: Make sure only enabled scan_elements are pushed into the ring
staging: IIO: IMU: ADIS16400: Fix addresses of GYRO and ACCEL calibration offset
staging: IIO: IMU: ADIS16400: Add delay after self test
staging: IIO: IMU: ADIS16400: Fix up SPI messages cs_change behavior
staging/rtl81*: build as loadable modules only
staging: brcm80211: removed 'is_amsdu causing toss' log spam
staging: brcm80211: fix for 'Short CCK' log spam
staging: brcm80211: fix for 'AC_BE txop..' logs spammed problem
staging: memrar: remove driver from tree
staging: sep: remove last memrar remnants
staging: fix hv_mouse build, needs delay.h
staging: fix olpc_dcon build errors
staging: sm7xx: fixed defines
Fix up trivial conflict in drivers/staging/memrar/memrar_handler.c
(deleted vs trivial spelling fixes)
It causes lots of linking errors when both of these modules are built into the
kernel directly due to their global symbol mess.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
This patch was generated by the following semantic patch:
// <smpl>
@@ expression E; @@
- if (E != NULL) { kfree(E); }
+ kfree(E);
@@ expression E; @@
- if (E != NULL) { kfree(E); E = NULL; }
+ kfree(E);
+ E = NULL;
// </smpl>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
When switching to power saving mode we only need to notify
the receiver when in infrastructure mode.
Signed-off-by: Philip Worrall <philip.worrall@googlemail.com>
Reviewed-by: Dan Carpenter <error27@gmail.com>
Simplify setting of power state in power.c when sending power
state notifications to the access point.
Signed-off-by: Philip Worrall <philip.worrall at googlemail.com>
Clean up a number of places where unneeded spaces are used around
expressions.
Clean up power.c so that unnecessary final return statements
are not used when sending power state notifications to
the access point.
Clean up some unnecessary braces for conditional statements
where a single statement will do.
Reformat the comments in power.c to use the C89 commenting
style instead of the C99 commenting style.
Cleanup power.c to use proper tabbing as per coding standards.
The patch below removes an extra "l" in the word.
The file added to linux-firmware is a copy of the current array which
does not have a recognisable header, so no validation is done.
Change the firmware version check to accept newer versions.
This was necessary in order to resolve some conflicts that happened
between -rc1 and -rc2 with the following files:
drivers/staging/bcm/Bcmchar.c
drivers/staging/intel_sst/intel_sst_app_interface.c
All should be resolved now.
removed spaces at the start of a lines.
Signed-off-by: Felipe Andres Besoain Pino <fbesoain@gnome.cl>
removes before parenthesis
Signed-off-by: Ariel Savini <arielsavini@gmail.com>
removed a C99 '//' comment and added a space around '='
Signed-off-by: Mariano Reingart <reingart@gmail.com>
removed parentesis and spaces at the start of a line of a return
Signed-off-by: Matias De la Puente <mfpuente.ar@gmail.com>
Identation says that copy_to_user() should be called only iff
wrq->u.essid.pointer is not zero. Also it is useless to call copy_to_user(0, ...).
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Changed to use the proper ccflags-y option
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Charles Clément <caratorn@gmail.com>
Fixed the last 5 lines, indented with spaces, replacing spaces with tabs.
Signed-off-by: Clelia V. Korol <cvkorol@gmail.com>
As reported by checkpatch.
Signed-off-by: Ema Cuevas <emacupk@gmail.com>
I remove parenthesis for a return variable, and also delete a space and tab the code line
Signed-off-by: matias <munozmatiasn@gmail.com>
Added an space after the definition of the variable MSG_LEVEL_INFO on line 43
Signed-off-by: Emanuel Mariano Ravera <ravera.emanuel@gmail.com>
Removed not required parentheses in return statements.
Signed-off-by: Diego H. Iglesias <diegohi@gmail.com>
Replace (sizeof(ChannelRuleTab) / sizeof(ChannelRuleTab[0])) with
ARRAY_SIZE(ChannelRuleTab) in drivers/staging/vt6656/channel.c
Signed-off-by: Nikitas Angelinas <nikitasangelinas@gmail.com>
An error code is stored in a variable, but 0 is returned instead. Use the
variable instead of 0.
The semantic match that finds this problem is as follows:
// <smpl>
@r@
local idexpression x;
constant C;
if (...) { ...
x = -C
... when != x
return <+...x...+>;
return NULL;
return;
* return ...;
// </smpl>
The first kfree(pDevice) is pointless because pDevice is NULL. The
second kfree(pDevice) is a double free because pDevice is the driver's
private data and that is already freed by free_netdev(netdev). Also the
free_netdev() error path doesn't call usb_put_dev().
Added spaces in for loop arguments.
Signed-off-by: Luis Bosch <luis.bosch@gmail.com>
Removed spaces between functions name and parenthesis.
Signed-off-by: Victor Rosales <victorhrosales@gmail.com>
resolved checkpatch finding
Signed-off-by: Alejandro Emanuel Paredes <aleparedes@gmail.com>
Removed custom macro used to test bits.
Signed-off-by: Andres More <more.andres@gmail.com>
Removed int redefinition for function results.
Removed some unused definitions of Ethernet packet types, also replaced
two of them with in-kernel counterparts from include/linux/if_ether.h
Removed comments about who changed/added lines, they do not seem useful.
Cleared checkpatch ERROR: spaces required around that '||'
Replaced NTSTATUS with int, as defined in a couple of places.
By definition the broadcast address is also a multicast address.
Lindented the modified section as required by checkpatch.pl.
Remove PUINT from ttype.h
Signed-off-by: Roel Van Nyen <roel.vannyen@gmail.com>
Lindented, cleared checkpatch findings and simplified error handling.
Replaced custom macro with one from include/linux/if_ether.h.
Also removed MAX_LOOKAHEAD_SIZE as it is not used elsewhere.
Removed custom macro with one from include/linux/if_ether.h.
Also removed MIN_DATA_LEN as it is not used elsewhere.
FCS is an Ethernet field that holds the CRC value.
