Correct spelling "scaning" to "scanning" in
drivers/staging/vt6656/bssdb.c
drivers/staging/vt6655/bssdb.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
If we hit the default case in the switch statement in wpa_ioctl()
we'll leak the memory allocated to 'param' when the variable goes out
of scope without having been assigned to anything.
This patch fixes the leak by kfree()'ing the memory before we return
from the function.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
This patch cleans up the coding style in
drivers/staging/vt6656/wpactl.c to closer match the generally accepted
kernel CodingStyle. It is by no means a "make it perfect" patch, but
it does get the file a fair bit closer to matching the accepted style
(whomever was involved in the evolution of this file seriously need to
configure their editors to maintain a consistent style - it was a
mess).
Besides pure style cleanups I also took the liberty of removing some
pointless parens, some unneeded casts and removing some commented out code
(it was obviously not used and git has it if it's ever needed in the
future).
This function has the following issues:
Parameter info and extra are not used
Wrong error handling(the function not return -EINVAL when it
happens)
This patch simplifies this funtion, remove the not used parameters and
fix the error handilng.
Signed-off-by: Marcos Paulo de Souza <marcos.mage@gmail.com>
This function will always return 0, and this data is not used by who
calls this function.
The function iwctl_giwrange will always return 0, and this data is not
used by who calls this function.
The funciton iwctl_commit does nothing, and can be removed.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits)
net/hyperv: Add support for jumbo frame up to 64KB
net/hyperv: Add NETVSP protocol version negotiation
net/hyperv: Remove unnecessary kmap_atomic in netvsc driver
staging/rtl8192e: Register against lib80211
staging/rtl8192e: Convert to lib80211_crypt_info
staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops
staging/rtl8192e: Add lib80211.h to rtllib.h
staging/mei: add watchdog device registration wrappers
drm/omap: GEM, deal with cache
staging: vt6656: int.c, int.h: Change return of function to void
staging: usbip: removed unused definitions from header
staging: usbip: removed dead code from receive function
staging:iio: Drop {mark,unmark}_in_use callbacks
staging:iio: Drop buffer mark_param_change callback
staging:iio: Drop the unused buffer enable() and is_enabled() callbacks
staging:iio: Drop buffer busy flag
staging:iio: Make sure a device is only opened once at a time
staging:iio: Disallow modifying buffer size when buffer is enabled
staging:iio: Disallow changing scan elements in all buffered modes
staging:iio: Use iio_buffer_enabled instead of open coding it
Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of
module_init due to using module_i2c_driver() helper, next to removal of
MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
This patch removes the int return of function INTnsProcessData, because
nobody uses this return.
This patch removes the return of the function CARDbSetMediaChannel, that
always return TRUE value.
This function always return TRUE, and it is not used by the funtions
who calls it.
There are two potential integer overflows in private_ioctl() if
userspace passes in a large sList.uItem / sNodeList.uItem. The
subsequent call to kmalloc() would allocate a small buffer, leading
to a memory corruption.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
In all locations that call this function ignore your returna, so remove
it.
Cc: Forest Bond <forest@alittletooquiet.net>
This patch removes a lot of commented code, and some return calls of
void functions.
Remved some commented code, and fixed some style issues. was removed too
a redundant if statement.
Removed return call of void functions. Removed some code style issues.
Removed the function iwctl_giwnwid, that just return a error code.
Changes v1 to v2:
Removed same functions of vt6655 and vt6656.
This converts the drivers in drivers/staging/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: "David Täht" <d@teklibre.com>
Cc: Marek Belisko <marek.belisko@gmail.com>
Cc: Al Cho <acho@novell.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Huajun Li <huajun.li.lee@gmail.com>
Cc: Zac Storer <zac.3.14159@gmail.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: edwin_rong <edwin_rong@realsil.com.cn>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Julia Lawall <julia@diku.dk>
Cc: Ilia Mirkin <imirkin@alum.mit.edu>
Cc: Joe Perches <joe@perches.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1519 commits)
staging: et131x: Remove redundant check and return statement
staging: et131x: Mainly whitespace changes to appease checkpatch
staging: et131x: Remove last of the forward declarations
staging: et131x: Remove even more forward declarations
staging: et131x: Remove yet more forward declarations
staging: et131x: Remove more forward declarations
staging: et131x: Remove forward declaration of et131x_adapter_setup
staging: et131x: Remove some forward declarations
staging: et131x: Remove unused rx_ring.recv_packet_pool
staging: et131x: Remove call to find pci pm capability
staging: et131x: Remove redundant et131x_reset_recv() call
staging: et131x: Remove unused rx_ring.recv_buffer_pool
Staging: bcm: Fix three initialization errors in InterfaceDld.c
Staging: bcm: Fix coding style issues in InterfaceDld.c
staging:iio:dac: Add AD5360 driver
staging:iio:trigger:bfin-timer: Fix compile error
Staging: vt6655: add some range checks before memcpy()
Staging: vt6655: whitespace fixes to iotcl.c
Staging: vt6656: add some range checks before memcpy()
Staging: vt6656: whitespace cleanups in ioctl.c
Fix up conflicts in:
- drivers/{Kconfig,Makefile}, drivers/staging/{Kconfig,Makefile}:
vg driver movement
- drivers/staging/brcm80211/brcmfmac/{dhd_linux.c,mac80211_if.c}:
driver removal vs now stale changes
- drivers/staging/rtl8192e/r8192E_core.c:
- drivers/staging/et131x/et131*:
driver consolidation into one file, tried to do fixups
We need to verify that we're not writing past the end of the array.
The indents on this file didn't line up so it was hard to work with.
I changed other white space issues as I came across them. I also
deleted or changed some couple comments and the comment style.
param->u.wpa_key.key_len comes from the user. If it's too large we
would write past the end of the array.
Smatch has a new check for Rosenberg type information leaks where
structs are copied to the user with uninitialized stack data in them.
In this path, the .uLinkRate member doesn't get initialized so I've
set it to zero.
replace it by ndo_set_rx_mode
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Since in each case nothing has been done with the recently allocated urb,
it is not necessary to kill it before freeing it.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression urb;
statement S;
position p1,p2;
urb = usb_alloc_urb@p1(...);
... when != urb
if (urb == NULL) S
... when != urb
usb_kill_urb@p2(urb);
@other exists@
position r.p1,r.p2;
... when != usb_alloc_urb@p1(...)
usb_kill_urb@p2(...);
@depends on !other exists@
expression urb;
position r.p1,r.p2;
-usb_kill_urb@p2(urb);
+usb_free_urb(urb);
... when != urb
// </smpl>
Done via perl script:
$ cat remove_semi_switch.pl
my $match_balanced_parentheses = qr/(\((?:[^\(\)]++|(?-1))*\))/;
my $match_balanced_braces = qr/(\{(?:[^\{\}]++|(?-1))*\})/;
foreach my $file (@ARGV) {
my $f;
my $text;
my $oldtext;
next if ((-d $file));
open($f, '<', $file)
or die "$P: Can't open $file for read\n";
$oldtext = do { local($/) ; <$f> };
close($f);
next if ($oldtext eq "");
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(switch\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
} while ($count > 0);
if ($text ne $oldtext) {
my $newfile = $file;
open($f, '>', $newfile)
or die "$P: Can't open $newfile for write\n";
print $f $text;
close($f);
$ cat remove_semi_for.pl
my $f;
my $text;
my $oldtext;
close($f);
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(for\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
print $f $text;
close($f);
$ cat remove_semi_if.pl
my $f;
my $text;
my $oldtext;
close($f);
$text = $oldtext;
my $count = 0;
do {
$count = 0;
$count += $text =~ s@\b(if\s*${match_balanced_parentheses}\s*)${match_balanced_braces}\s*;@"$1$3"@egx;
print $f $text;
close($f);
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (28 commits)
staging: usbip: bugfix for isochronous packets and optimization
staging: usbip: bugfix add number of packets for isochronous frames
staging: usbip: bugfixes related to kthread conversion
staging: usbip: fix shutdown problems.
staging: hv: Fix GARP not sent after Quick Migration
staging: IIO: IMU: ADIS16400: Avoid using printk facility directly
staging: IIO: IMU: ADIS16400: Fix product ID check, skip embedded revision number
staging: IIO: IMU: ADIS16400: Make sure only enabled scan_elements are pushed into the ring
staging: IIO: IMU: ADIS16400: Fix addresses of GYRO and ACCEL calibration offset
staging: IIO: IMU: ADIS16400: Add delay after self test
staging: IIO: IMU: ADIS16400: Fix up SPI messages cs_change behavior
staging/rtl81*: build as loadable modules only
staging: brcm80211: removed 'is_amsdu causing toss' log spam
staging: brcm80211: fix for 'Short CCK' log spam
staging: brcm80211: fix for 'AC_BE txop..' logs spammed problem
staging: memrar: remove driver from tree
staging: sep: remove last memrar remnants
staging: fix hv_mouse build, needs delay.h
staging: fix olpc_dcon build errors
staging: sm7xx: fixed defines
Fix up trivial conflict in drivers/staging/memrar/memrar_handler.c
(deleted vs trivial spelling fixes)
It causes lots of linking errors when both of these modules are built into the
kernel directly due to their global symbol mess.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
This patch was generated by the following semantic patch:
// <smpl>
@@ expression E; @@
- if (E != NULL) { kfree(E); }
+ kfree(E);
@@ expression E; @@
- if (E != NULL) { kfree(E); E = NULL; }
+ kfree(E);
+ E = NULL;
// </smpl>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
When switching to power saving mode we only need to notify
the receiver when in infrastructure mode.
Signed-off-by: Philip Worrall <philip.worrall@googlemail.com>
Reviewed-by: Dan Carpenter <error27@gmail.com>
Simplify setting of power state in power.c when sending power
state notifications to the access point.
Signed-off-by: Philip Worrall <philip.worrall at googlemail.com>
Clean up a number of places where unneeded spaces are used around
expressions.
Clean up power.c so that unnecessary final return statements
are not used when sending power state notifications to
the access point.
Clean up some unnecessary braces for conditional statements
where a single statement will do.
Reformat the comments in power.c to use the C89 commenting
style instead of the C99 commenting style.
Cleanup power.c to use proper tabbing as per coding standards.
The patch below removes an extra "l" in the word.
The file added to linux-firmware is a copy of the current array which
does not have a recognisable header, so no validation is done.
Change the firmware version check to accept newer versions.
This was necessary in order to resolve some conflicts that happened
between -rc1 and -rc2 with the following files:
drivers/staging/bcm/Bcmchar.c
drivers/staging/intel_sst/intel_sst_app_interface.c
All should be resolved now.
removed spaces at the start of a lines.
Signed-off-by: Felipe Andres Besoain Pino <fbesoain@gnome.cl>
removes before parenthesis
Signed-off-by: Ariel Savini <arielsavini@gmail.com>
