path: root/drivers/staging
2015-05-16Merge tag 'staging-4.1-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging / IIO driver fixes from Greg KH: "Here's some staging and iio driver fixes to resolve a number of reported issues. All of these have been in linux-next for a while" * tag 'staging-4.1-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (31 commits) iio: light: hid-sensor-prox: Fix memory leak in probe() iio: adc: cc10001: Add delay before setting START bit iio: adc: cc10001: Fix regulator_get_voltage() return value check iio: adc: cc10001: Fix incorrect use of power-up/power-down register staging: gdm724x: Correction of variable usage after applying ALIGN() iio: adc: cc10001: Fix the channel number mapping staging: vt6655: lock MACvWriteBSSIDAddress. staging: vt6655: CARDbUpdateTSF bss timestamp correct tsf counter value. staging: vt6655: vnt_tx_packet Correct TX order of OWNED_BY_NIC staging: vt6655: Fix 80211 control and management status reporting. staging: vt6655: implement IEEE80211_TX_STAT_NOACK_TRANSMITTED staging: vt6655: device_free_tx_buf use only ieee80211_tx_status_irqsafe staging: vt6656: use ieee80211_tx_info to select packet type. staging: rtl8712: freeing an ERR_PTR staging: sm750: remove incorrect __exit annotation iio: kfifo: Set update_needed to false only if a buffer was allocated iio: mcp320x: Fix occasional incorrect readings iio: accel: mma9553: check input value for activity period iio: accel: mma9553: add enable channel for activity iio: accel: mma9551_core: prevent buffer overrun ...
2015-05-10staging: gdm724x: Correction of variable usage after applying ALIGN()Sławomir Demeszko
Fix regression introduced by commit <29ef8a53542a>. After it writing AT commands to /dev/GCT-ATM0 is unsuccessful (no echo, no response) and dmesg show "gdmtty: invalid payload : 1 16 f011". Before that commit value of dummy_cnt was only a padding size. After using ALIGN() this value is increased by its first argument. So the following usage of this variable needs correction. Signed-off-by: Sławomir Demeszko <s.demeszko@wireless-instruments.com> Cc: stable <stable@vger.kernel.org> # 3.14+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6655: lock MACvWriteBSSIDAddress.Malcolm Priestley
This function selects page 1 and cause intermittent problems on interrupt handler. lock call with spin_lock_irqsave. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: <stable@vger.kernel.org> # v3.19+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6655: CARDbUpdateTSF bss timestamp correct tsf counter value.Malcolm Priestley
The TSF counter is not set correctly. Use sync_tsf for last beacon value and get tsf local value. Remove qwLocalTSF variable and call CARDbGetCurrentTSF. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6655: vnt_tx_packet Correct TX order of OWNED_BY_NICMalcolm Priestley
The state of m_td0TD0.f1Owner should change after the buff_addr has been filled otherwise the device grabs the buffer too early. m_td0TD0.f1Owner is protected by memory barriers on both sides of change. iTDUsed is best incremented after MACvTransmit. It appears that f1Owner actually polls to do the memory transfer. A back port patch will be needed for v3.19 Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: <stable@vger.kernel.org> # v4.0+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6655: Fix 80211 control and management status reporting.Malcolm Priestley
Currently only TD_FLAGS_NETIF_SKB are reported back to mac80211. Move vnt_int_report_rate to report all frame types. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: <stable@vger.kernel.org> # v3.19+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6655: implement IEEE80211_TX_STAT_NOACK_TRANSMITTEDMalcolm Priestley
Make use of this macro for non ack frames. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: <stable@vger.kernel.org> # v4.0 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6655: device_free_tx_buf use only ieee80211_tx_status_irqsafeMalcolm Priestley
TD_FLAGS_NETIF_SKB is only for data. Fixes issue of ack frames not being reported. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: <stable@vger.kernel.org> # v3.19+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: vt6656: use ieee80211_tx_info to select packet type.Malcolm Priestley
Information for packet type is in ieee80211_tx_info band IEEE80211_BAND_5GHZ for PK_TYPE_11A. IEEE80211_TX_RC_USE_CTS_PROTECT via tx_rate flags selects PK_TYPE_11GB This ensures that the packet is always the right type. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: <stable@vger.kernel.org> # v3.17+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: rtl8712: freeing an ERR_PTRDan Carpenter
If memdup_user() fails then "pparmbuf" is an error pointer and we can't pass it to kfree(). I changed the "goto _r871x_mp_ioctl_hdl_exit" to a direct return. I changed the earlier goto to a direct return as well for consistency and removed the "pparmbuf = NULL" initializer since it's no longer needed. Fixes: 45de432775d6 ('Staging: rtl8712: Use memdup_user() instead of copy_from_user()') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-08staging: sm750: remove incorrect __exit annotationArnd Bergmann
The lynxfb_pci_remove function is used as the 'remove' callback of the driver, and must not be discarded: lynxfb_pci_remove' referenced in section `.data' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o This removes the extraneous annotation. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-05Merge tag 'media/v4.1-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "Three driver fixes: - fix for omap4, fixing a regression due to a subsystem API that got removed for 4.1 (commit efde234674d9); - fix for one of the formats supported by Marvel ccic driver; - fix rcar_vin driver that, when stopping abnormally, the driver can't return from wait_for_completion" * tag 'media/v4.1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] v4l: omap4iss: Replace outdated OMAP4 control pad API with syscon [media] media: soc_camera: rcar_vin: Fix wait_for_completion [media] marvell-ccic: fix Y'CbCr ordering
2015-04-28[media] v4l: omap4iss: Replace outdated OMAP4 control pad API with sysconLaurent Pinchart
The omap4_ctrl_pad_readl and omap4_ctrl_pad_writel functions have been removed by commit efde234674d9 but are still used by the OMAP4 ISS driver, resulting in a compilation breakage: drivers/staging/media/omap4iss/iss_csiphy.c: In function 'omap4iss_csiphy_config': drivers/staging/media/omap4iss/iss_csiphy.c:167:2: error: implicit declaration of function 'omap4_ctrl_pad_writel' [-Werror=implicit-function-declaration] omap4_ctrl_pad_writel(cam_rx_ctrl, Fix the problem by using the syscon API to reaplace the control pad API. Lookup the syscon instance by compatible name for now as the OMAP4 ISS driver doesn't support DT yet. Fixes: efde234674d9 ("ARM: OMAP4+: control: remove support for legacy pad read/write") Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Alius <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-24Merge tag 'dma-buf-for-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf Pull dma-buf updates from Sumit Semwal: "Minor cleanup only; this could've gone in for the 4.0 merge window, but for a copy-paste stupidity from me. It has been in the for-next since then, and no issues reported. - cleanup of dma_buf_export() - correction of copy-paste stupidity while doing the cleanup" * tag 'dma-buf-for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/sumits/dma-buf: staging: android: ion: fix wrong init of dma_buf_export_info dma-buf: cleanup dma_buf_export() to make it easily extensible
2015-04-21Merge branch 'drm-next-merged' of ↵Mauro Carvalho Chehab
git://people.freedesktop.org/~airlied/linux into v4l_for_linus * 'drm-next-merged' of git://people.freedesktop.org/~airlied/linux: (9717 commits) media-bus: Fixup RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus format hexdump: avoid warning in test function fs: take i_mutex during prepare_binprm for set[ug]id executables smp: Fix error case handling in smp_call_function_*() iommu-common: Fix PARISC compile-time warnings sparc: Make LDC use common iommu poll management functions sparc: Make sparc64 use scalable lib/iommu-common.c functions Break up monolithic iommu table/lock into finer graularity pools and lock sparc: Revert generic IOMMU allocator. tools/power turbostat: correct dumped pkg-cstate-limit value tools/power turbostat: calculate TSC frequency from CPUID(0x15) on SKL tools/power turbostat: correct DRAM RAPL units on recent Xeon processors tools/power turbostat: Initial Skylake support tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for O= option in Makefile tools/power turbostat: modprobe msr, if needed tools/power turbostat: dump MSR_TURBO_RATIO_LIMIT2 tools/power turbostat: use new MSR_TURBO_RATIO_LIMIT names Bluetooth: hidp: Fix regression with older userspace and flags validation config: Enable NEED_DMA_MAP_STATE by default when SWIOTLB is selected perf/x86/intel/pt: Fix and clean up error handling in pt_event_add() ... That solves several merge conflicts: Documentation/DocBook/media/v4l/subdev-formats.xml Documentation/devicetree/bindings/vendor-prefixes.txt drivers/staging/media/mn88473/mn88473.c include/linux/kconfig.h include/uapi/linux/media-bus-format.h The ones at subdev-formats.xml and media-bus-format.h are not trivial. That's why we opted to merge from DRM.
2015-04-21staging: android: ion: fix wrong init of dma_buf_export_infoSumit Semwal
Fixes: 817bd7253291 ("dma-buf: cleanup dma_buf_export() to make it easily extensible") Stupid copy-paste from me in the above patch leads to the following static checker warning: drivers/staging/android/ion/ion.c:1112 ion_share_dma_buf() error: potentially dereferencing uninitialized 'buffer'. drivers/staging/android/ion/ion.c 1103 struct dma_buf *ion_share_dma_buf(struct ion_client *client, 1104 struct ion_handle *handle) 1105 { 1106 struct ion_buffer *buffer; ^^^^^^ 1107 struct dma_buf *dmabuf; 1108 bool valid_handle; 1109 DEFINE_DMA_BUF_EXPORT_INFO(exp_info); 1110 1111 exp_info.ops = &dma_buf_ops; 1112 exp_info.size = buffer->size; ^^^^^^ 1113 exp_info.flags = O_RDWR; 1114 exp_info.priv = buffer; ^^^^^^ And here also. 1115 This patch corrects this stupidity. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
2015-04-21dma-buf: cleanup dma_buf_export() to make it easily extensibleSumit Semwal
At present, dma_buf_export() takes a series of parameters, which makes it difficult to add any new parameters for exporters, if required. Make it simpler by moving all these parameters into a struct, and pass the struct * as parameter to dma_buf_export(). While at it, unite dma_buf_export_named() with dma_buf_export(), and change all callers accordingly. Reviewed-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
2015-04-17Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS for Linux 4.1. Most noteworthy: - Add more Octeon-optimized crypto functions - Octeon crypto preemption and locking fixes - Little endian support for Octeon - Use correct CSR to soft reset Octeons - Support LEDs on the Octeon-based DSR-1000N - Fix PCI interrupt mapping for the Octeon-based DSR-1000N - Mark prom_free_prom_memory() as __init for a number of systems - Support for Imagination's Pistachio SOC. This includes arch and CLK bits. I'd like to merge pinctrl bits later - Improve parallelism of csum_partial for certain pipelines - Organize DTB files in subdirs like other architectures - Implement read_sched_clock for all MIPS platforms other than Octeon - Massive series of 38 fixes and cleanups for the FPU emulator / kernel - Further FPU remulator work to support new features. This sits on a separate branch which also has been pulled into the 4.1 KVM branch - Clean up and fixes for the SEAD3 eval board; remove unused file - Various updates for Netlogic platforms - A number of small updates for Loongson 3 platforms - Increase the memory limit for ATH79 platforms to 256MB - A fair number of fixes and updates for BCM47xx platforms - Finish the implementation of XPA support - MIPS FDC support. No, not floppy controller but Fast Debug Channel :) - Detect the R16000 used in SGI legacy platforms - Fix Kconfig dependencies for the SSB bus support" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (265 commits) MIPS: Makefile: Fix MIPS ASE detection code MIPS: asm: elf: Set O32 default FPU flags MIPS: BCM47XX: Fix detecting Microsoft MN-700 & Asus WL500G MIPS: Kconfig: Disable SMP/CPS for 64-bit MIPS: Hibernate: flush TLB entries earlier MIPS: smp-cps: cpu_set FPU mask if FPU present MIPS: lose_fpu(): Disable FPU when MSA enabled MIPS: ralink: add missing symbol for RALINK_ILL_ACC MIPS: ralink: Fix bad config symbol in PCI makefile. SSB: fix Kconfig dependencies MIPS: Malta: Detect and fix bad memsize values Revert "MIPS: Avoid pipeline stalls on some MIPS32R2 cores." MIPS: Octeon: Delete override of cpu_has_mips_r2_exec_hazard. MIPS: Fix cpu_has_mips_r2_exec_hazard. MIPS: kernel: entry.S: Set correct ISA level for mips_ihb MIPS: asm: spinlock: Fix addiu instruction for R10000_LLSC_WAR case MIPS: r4kcache: Use correct base register for MIPS R6 cache flushes MIPS: Kconfig: Fix typo for the r2-to-r6 emulator kernel parameter MIPS: unaligned: Fix regular load/store instruction emulation for EVA MIPS: unaligned: Surround load/store macros in do {} while statements ...
2015-04-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third hunk of vfs changes from Al Viro: "This contains the ->direct_IO() changes from Omar + saner generic_write_checks() + dealing with fcntl()/{read,write}() races (mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of repeatedly looking at ->f_flags, which can be changed by fcntl(2), check ->ki_flags - which cannot) + infrastructure bits for dhowells' d_inode annotations + Christophs switch of /dev/loop to vfs_iter_write()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits) block: loop: switch to VFS ITER_BVEC configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode VFS: Make pathwalk use d_is_reg() rather than S_ISREG() VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR() VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk NFS: Don't use d_inode as a variable name VFS: Impose ordering on accesses of d_inode and d_flags VFS: Add owner-filesystem positive/negative dentry checks nfs: generic_write_checks() shouldn't be done on swapout... ocfs2: use __generic_file_write_iter() mirror O_APPEND and O_DIRECT into iocb->ki_flags switch generic_write_checks() to iocb and iter ocfs2: move generic_write_checks() before the alignment checks ocfs2_file_write_iter: stop messing with ppos udf_file_write_iter: reorder and simplify fuse: ->direct_IO() doesn't need generic_write_checks() ext4_file_write_iter: move generic_write_checks() up xfs_file_aio_write_checks: switch to iocb/iov_iter generic_write_checks(): drop isblk argument blkdev_write_iter: expand generic_file_checks() call in there ...
2015-04-15Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - the rest of MM - various misc bits - add ability to run /sbin/reboot at reboot time - printk/vsprintf changes - fiddle with seq_printf() return value * akpm: (114 commits) parisc: remove use of seq_printf return value lru_cache: remove use of seq_printf return value tracing: remove use of seq_printf return value cgroup: remove use of seq_printf return value proc: remove use of seq_printf return value s390: remove use of seq_printf return value cris fasttimer: remove use of seq_printf return value cris: remove use of seq_printf return value openrisc: remove use of seq_printf return value ARM: plat-pxa: remove use of seq_printf return value nios2: cpuinfo: remove use of seq_printf return value microblaze: mb: remove use of seq_printf return value ipc: remove use of seq_printf return value rtc: remove use of seq_printf return value power: wakeup: remove use of seq_printf return value x86: mtrr: if: remove use of seq_printf return value linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK MAINTAINERS: CREDITS: remove Stefano Brivio from B43 .mailmap: add Ricardo Ribalda CREDITS: add Ricardo Ribalda Delgado ...
2015-04-15kernel: conditionally support non-root users, groups and capabilitiesIulia Manda
There are a lot of embedded systems that run most or all of their functionality in init, running as root:root. For these systems, supporting multiple users is not necessary. This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for non-root users, non-root groups, and capabilities optional. It is enabled under CONFIG_EXPERT menu. When this symbol is not defined, UID and GID are zero in any possible case and processes always have all capabilities. The following syscalls are compiled out: setuid, setregid, setgid, setreuid, setresuid, getresuid, setresgid, getresgid, setgroups, getgroups, setfsuid, setfsgid, capget, capset. Also, groups.c is compiled out completely. In kernel/capability.c, capable function was moved in order to avoid adding two ifdef blocks. This change saves about 25 KB on a defconfig build. The most minimal kernels have total text sizes in the high hundreds of kB rather than low MB. (The 25k goes down a bit with allnoconfig, but not that much. The kernel was booted in Qemu. All the common functionalities work. Adding users/groups is not possible, failing with -ENOSYS. Bloat-o-meter output: add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Iulia Manda <iulia.manda21@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs update from Al Viro: "Now that net-next went in... Here's the next big chunk - killing ->aio_read() and ->aio_write(). There'll be one more pile today (direct_IO changes and generic_write_checks() cleanups/fixes), but I'd prefer to keep that one separate" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits) ->aio_read and ->aio_write removed pcm: another weird API abuse infinibad: weird APIs switched to ->write_iter() kill do_sync_read/do_sync_write fuse: use iov_iter_get_pages() for non-splice path fuse: switch to ->read_iter/->write_iter switch drivers/char/mem.c to ->read_iter/->write_iter make new_sync_{read,write}() static coredump: accept any write method switch /dev/loop to vfs_iter_write() serial2002: switch to __vfs_read/__vfs_write ashmem: use __vfs_read() export __vfs_read() autofs: switch to __vfs_write() new helper: __vfs_write() switch hugetlbfs to ->read_iter() coda: switch to ->read_iter/->write_iter ncpfs: switch to ->read_iter/->write_iter net/9p: remove (now-)unused helpers p9_client_attach(): set fid->uid correctly ...
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add BQL support to via-rhine, from Tino Reichardt. 2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers can support hw switch offloading. From Floria Fainelli. 3) Allow 'ip address' commands to initiate multicast group join/leave, from Madhu Challa. 4) Many ipv4 FIB lookup optimizations from Alexander Duyck. 5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel Borkmann. 6) Remove the ugly compat support in ARP for ugly layers like ax25, rose, etc. And use this to clean up the neigh layer, then use it to implement MPLS support. All from Eric Biederman. 7) Support L3 forwarding offloading in switches, from Scott Feldman. 8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed up route lookups even further. From Alexander Duyck. 9) Many improvements and bug fixes to the rhashtable implementation, from Herbert Xu and Thomas Graf. In particular, in the case where an rhashtable user bulk adds a large number of items into an empty table, we expand the table much more sanely. 10) Don't make the tcp_metrics hash table per-namespace, from Eric Biederman. 11) Extend EBPF to access SKB fields, from Alexei Starovoitov. 12) Split out new connection request sockets so that they can be established in the main hash table. Much less false sharing since hash lookups go direct to the request sockets instead of having to go first to the listener then to the request socks hashed underneath. From Eric Dumazet. 13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk. 14) Support stable privacy address generation for RFC7217 in IPV6. From Hannes Frederic Sowa. 15) Hash network namespace into IP frag IDs, also from Hannes Frederic Sowa. 16) Convert PTP get/set methods to use 64-bit time, from Richard Cochran. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits) fm10k: Bump driver version to 0.15.2 fm10k: corrected VF multicast update fm10k: mbx_update_max_size does not drop all oversized messages fm10k: reset head instead of calling update_max_size fm10k: renamed mbx_tx_dropped to mbx_tx_oversized fm10k: update xcast mode before synchronizing multicast addresses fm10k: start service timer on probe fm10k: fix function header comment fm10k: comment next_vf_mbx flow fm10k: don't handle mailbox events in iov_event path and always process mailbox fm10k: use separate workqueue for fm10k driver fm10k: Set PF queues to unlimited bandwidth during virtualization fm10k: expose tx_timeout_count as an ethtool stat fm10k: only increment tx_timeout_count in Tx hang path fm10k: remove extraneous "Reset interface" message fm10k: separate PF only stats so that VF does not display them fm10k: use hw->mac.max_queues for stats fm10k: only show actual queues, not the maximum in hardware fm10k: allow creation of VLAN on default vid fm10k: fix unused warnings ...
2015-04-14Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge first patchbomb from Andrew Morton: - arch/sh updates - ocfs2 updates - kernel/watchdog feature - about half of mm/ * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (122 commits) Documentation: update arch list in the 'memtest' entry Kconfig: memtest: update number of test patterns up to 17 arm: add support for memtest arm64: add support for memtest memtest: use phys_addr_t for physical addresses mm: move memtest under mm mm, hugetlb: abort __get_user_pages if current has been oom killed mm, mempool: do not allow atomic resizing memcg: print cgroup information when system panics due to panic_on_oom mm: numa: remove migrate_ratelimited mm: fold arch_randomize_brk into ARCH_HAS_ELF_RANDOMIZE mm: split ET_DYN ASLR from mmap ASLR s390: redefine randomize_et_dyn for ELF_ET_DYN_BASE mm: expose arch_mmap_rnd when available s390: standardize mmap_rnd() usage powerpc: standardize mmap_rnd() usage mips: extract logic for mmap_rnd() arm64: standardize mmap_rnd() usage x86: standardize mmap_rnd() usage arm: factor out mmap ASLR into mmap_rnd ...
2015-04-14page_writeback: clean up mess around cancel_dirty_page()Konstantin Khlebnikov
This patch replaces cancel_dirty_page() with a helper function account_page_cleaned() which only updates counters. It's called from truncate_complete_page() and from try_to_free_buffers() (hack for ext3). Page is locked in both cases, page-lock protects against concurrent dirtiers: see commit 2d6d7f982846 ("mm: protect set_page_dirty() from ongoing truncation"). Delete_from_page_cache() shouldn't be called for dirty pages, they must be handled by caller (either written or truncated). This patch treats final dirty accounting fixup at the end of __delete_from_page_cache() as a debug check and adds WARN_ON_ONCE() around it. If something removes dirty pages without proper handling that might be a bug and unwritten data might be lost. Hugetlbfs has no dirty pages accounting, ClearPageDirty() is enough here. cancel_dirty_page() in nfs_wb_page_cancel() is redundant. This is helper for nfs_invalidate_page() and it's called only in case complete invalidation. The mess was started in v2.6.20 after commits 46d2277c796f ("Clean up and make try_to_free_buffers() not race with dirty pages") and 3e67c0987d75 ("truncate: clear page dirtiness before running try_to_free_buffers()") first was reverted right in v2.6.20 in commit ecdfc9787fe5 ("Resurrect 'try_to_free_buffers()' VM hackery"), second in v2.6.25 commit a2b345642f53 ("Fix dirty page accounting leak with ext3 data=journal"). Custom fixes were introduced between these points. NFS in v2.6.23, commit 1b3b4a1a2deb ("NFS: Fix a write request leak in nfs_invalidate_page()"). Kludge in __delete_from_page_cache() in v2.6.24, commit 3a6927906f1b ("Do dirty page accounting when removing a page from the page cache"). Since v2.6.25 all of them are redundant. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Tejun Heo <tj@kernel.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: "Part one: - struct filename-related cleanups - saner iov_iter_init() replacements (and switching the syscalls to use of those) - ntfs switch to ->write_iter() (Anton) - aio cleanups and splitting iocb into common and async parts (Christoph) - assorted fixes (me, bfields, Andrew Elble) There's a lot more, including the completion of switchover to ->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags race fixes, etc, but that goes after #for-davem merge. David has pulled it, and once it's in I'll send the next vfs pull request" * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits) sg_start_req(): use import_iovec() sg_start_req(): make sure that there's not too many elements in iovec blk_rq_map_user(): use import_single_range() sg_io(): use import_iovec() process_vm_access: switch to {compat_,}import_iovec() switch keyctl_instantiate_key_common() to iov_iter switch {compat_,}do_readv_writev() to {compat_,}import_iovec() aio_setup_vectored_rw(): switch to {compat_,}import_iovec() vmsplice_to_user(): switch to import_iovec() kill aio_setup_single_vector() aio: simplify arguments of aio_setup_..._rw() aio: lift iov_iter_init() into aio_setup_..._rw() lift iov_iter into {compat_,}do_readv_writev() NFS: fix BUG() crash in notify_change() with patch to chown_common() dcache: return -ESTALE not -EBUSY on distributed fs race NTFS: Version 2.1.32 - Update file write from aio_write to write_iter. VFS: Add iov_iter_fault_in_multipages_readable() drop bogus check in file_open_root() switch security_inode_getattr() to struct path * constify tomoyo_realpath_from_path() ...
2015-04-13Merge tag 'staging-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver updates from Greg KH: "Here's the big staging driver patchset for 4.1-rc1. There's a lot of patches here, the Outreachy application period happened during this development cycle, so that means that there was a lot of cleanup patches accepted. Other than the normal coding style and sparse fixes here, there are some driver updates and work toward making some of the drivers into "mergable" shape (like the Unisys drivers.) All of these have been in linux-next for a while" * tag 'staging-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1214 commits) staging: lustre: orthography & coding style staging: lustre: lnet: lnet: fix error return code staging: lustre: fix sparse warning Revert "Staging: sm750fb: Fix C99 Comments" Staging: rtl8192u: use correct array for debug output staging: rtl8192e: Remove dead code staging: rtl8192e: Comment cleanup (style/format) staging: rtl8192e: Fix indentation in rtllib_rx_auth_resp() staging: rtl8192e: Decrease nesting of rtllib_rx_auth_resp() staging: rtl8192e: Divide rtllib_rx_auth() staging: rtl8192e: Fix PRINTK_WITHOUT_KERN_LEVEL warnings staging: rtl8192e: Fix DO_WHILE_MACRO_WITH_TRAILING_SEMICOLON warning staging: rtl8192e: Fix BRACES warning staging: rtl8192e: Fix LINE_CONTINUATIONS warning staging: rtl8192e: Fix UNNECESSARY_PARENTHESES warnings staging: rtl8192e: remove unused EXPORT_SYMBOL_RSL macro staging: rtl8192e: Fix RETURN_VOID warnings staging: rtl8192e: Fix UNNECESSARY_ELSE warning staging: rtl8723au: Remove unneeded comments staging: rtl8723au: Use __func__ in trace logs ...
2015-04-13Merge tag 'for-v4.1' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply and reset changes from Sebastian Reichel: - new API for safe access of power supply function attrs - devres support for power supply (un)registration - new drivers / chips: - generic syscon based poweroff driver - iio & charger driver for da9150 - fuel gauge driver for axp288 - bq27x00: add support for bq27510 - bq2415x: add support for bq24157s - twl4030-madc-battery: convert to iio consumer - misc fixes * tag 'for-v4.1' of git://git.infradead.org/battery-2.6: (66 commits) power: twl4030_madc_battery: Add missing MODULE_ALIAS power: twl4030-madc-battery: Convert to iio consumer. dt: power: Add docs for generic SYSCON poweroff driver. power: reset: Add generic SYSCON register mapped poweroff. power: max17042_battery: add missed blank power: max17042_battery: Use reg type instead of chip type power/reset: at91: big endian fixes for atsama5d3x power_supply: charger-manager: Fix dereferencing of ERR_PTR HID: input: Fix NULL pointer dereference when power_supply_register fails power: constify of_device_id array power/reset/rmobile-reset.c: Fix !HAS_IOMEM build power_supply: 88pm860x_charger: Fix possible NULL pointer dereference and use of initialized variable arm: mach-pxa: Decrement the power supply's device reference counter mfd: ab8500: Decrement the power supply's device reference counter power_supply: bq2415x_charger: Decrement the power supply's device reference counter power_supply: 88pm860x_charger: Decrement the power supply's device reference counter x86/olpc/xo15/sci: Use newly added power_supply_put API x86/olpc/xo1/sci: Use newly added power_supply_put API power_supply: charger-manager: Decrement the power supply's device reference counter power_supply: Increment power supply use counter when obtaining references ...
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11serial2002: switch to __vfs_read/__vfs_writeAl Viro
2015-04-11ashmem: use __vfs_read()Al Viro
2015-04-11lustre: kill unused members of struct vvp_thread_infoAl Viro
2015-04-11Merge branch 'iocb' into for-nextAl Viro
2015-04-09Merge branch 'iocb' into for-davemAl Viro
trivial conflict in net/socket.c and non-trivial one in crypto - that one had evaded aio_complete() removal. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-08[media] mn88472: add ts mode and ts clock to driverBenjamin Larsson
Signed-off-by: Benjamin Larsson <benjamin@southpole.se> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-07Merge 4.0-rc7 into staging-nextGreg Kroah-Hartman
We want those fixes (iio primarily) into the -next branch to help with merge and testing issues. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/mellanox/mlx4/cmd.c net/core/fib_rules.c net/ipv4/fib_frontend.c The fib_rules.c and fib_frontend.c conflicts were locking adjustments in 'net' overlapping addition and removal of code in 'net-next'. The mlx4 conflict was a bug fix in 'net' happening in the same place a constant was being replaced with a more suitable macro. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-05staging: lustre: orthography & coding styleAmaury.Bouchra.Pilet@ENS.fr
Orthography and coding style corrections. Signed-off-by: Amaury Bouchra Pilet <Amaury.Bouchra.Pilet@ENS.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-05staging: lustre: lnet: lnet: fix error return codeJulia Lawall
Return a negative error code on failure. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier ret; expression e1,e2; @@ ( if (\(ret < 0\|ret != 0\)) { ... return ret; } | ret = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-05staging: lustre: fix sparse warningTal Shorer
Sparse reports: drivers/staging/lustre/lustre/obdclass/obd_mount.c:1284:6: warning: symbol 'lustre_kill_super' was not declared. Should it be static? Fix this warning by making lustre_kill_super static. It is not used outside this file. Signed-off-by: Tal Shorer <tal.shorer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-04Revert "Staging: sm750fb: Fix C99 Comments"Greg Kroah-Hartman
This reverts commit 6ad6b5ed3e2472b399b567a2f036006bf25df467. It added a file that should not be in the kernel source tree. Cc: Amitoj Kaur Chawla <amitoj1606@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03Staging: rtl8192u: use correct array for debug outputDan Carpenter
This is supposed to be ->rates_ex[] instead of ->rates[]. I found this because static checkers complain than ->rates is too small so we're reading beyond the end of the array. It has 12 elements instead of 15. This bug was apparently copy and pasted from ipw2x00. I fixed it before in that driver 428e3cf5f98c ('ipw2x00: printing the wrong array in debug code') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03staging: rtl8192e: Remove dead codeMateusz Kulikowski
Remove commented-out code Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03staging: rtl8192e: Comment cleanup (style/format)Mateusz Kulikowski
- Multiline comments use "network subsystem comment style" - Merge short multiline comments - Remove empty comments - Remove function name comment at the end of small (<1 screen) functions - Reformat 802.11 data frame format to use spaces and network format Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03staging: rtl8192e: Fix indentation in rtllib_rx_auth_resp()Mateusz Kulikowski
2015-04-03staging: rtl8192e: Decrease nesting of rtllib_rx_auth_resp()Mateusz Kulikowski
Return from rtllib_rx_auth_resp() if auth_parse() fails. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
