ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits)
[media] gspca - sunplus: Fix some warnings and simplify code
[media] gspca: Fix some warnings tied to 'no debug'
[media] gspca: Unset debug by default
[media] gspca - cpia1: Remove a bad conditional compilation instruction
[media] gspca - main: Remove USB traces
[media] gspca - main: Version change to 2.13
[media] gspca - stk014 / t613: Accept the index 0 in querymenu
[media] gspca - kinect: Remove __devinitdata
[media] gspca - cpia1: Fix some warnings
[media] video/Kconfig: Fix mis-classified devices
[media] support for medion dvb stick 1660:1921
[media] tm6000: fix uninitialized field, change prink to dprintk
[media] cx231xx: Add support for Iconbit U100
[media] saa7134 add new TV cards
[media] Use a more consistent value for RC repeat period
[media] cx18: Move spinlock and vb_type initialisation into stream_init
[media] tm6000: remove tm6010 sif audio start and stop
[media] tm6000: remove unused exports
[media] tm6000: add pts logging
[media] tm6000: change from ioctl to unlocked_ioctl
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (970 commits)
staging: usbip: replace usbip_u{dbg,err,info} and printk with dev_ and pr_
staging:iio: Trivial kconfig reorganization and uniformity improvements.
staging:iio:documenation partial update.
staging:iio: use pollfunc allocation helpers in remaining drivers.
staging:iio:max1363 misc cleanups and use of for_each_bit_set to simplify event code spitting out.
staging:iio: implement an iio_info structure to take some of the constant elements out of iio_dev.
staging:iio:meter:ade7758: Use private data space from iio_allocate_device
staging:iio:accel:lis3l02dq make write_reg_8 take value not a pointer to value.
staging:iio: ring core cleanups + check if read_last available in lis3l02dq
staging:iio:core cleanup: squash tiny wrappers and use dev_set_name to handle creation of event interface name.
staging:iio: poll func allocation clean up.
staging:iio:ad7780 trivial unused header cleanup.
staging:iio:adc: AD7780: Use private data space from iio_allocate_device + trivial fixes
staging:iio:adc:AD7780: Convert to new channel registration method
staging:iio:adc: AD7606: Drop dev_data in favour of iio_priv()
staging:iio:adc: AD7606: Consitently use indio_dev
staging:iio: Rip out helper for software rings.
staging:iio:adc:AD7298: Use private data space from iio_allocate_device
staging:iio: rationalization of different buffer implementation hooks.
staging:iio:imu:adis16400 avoid allocating rx, tx, and state separately from iio_dev.
Fix up trivial conflicts in
- drivers/staging/intel_sst/intelmid.c: patches applied in both branches
- drivers/staging/rt2860/common/cmm_data_{pci,usb}.c: removed vs spelling
- drivers/staging/usbip/vhci_sysfs.c: trivial header file inclusion
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits)
ASoC: core: Don't set "(null)" as a driver name
ALSA: hda - Use LPIB for ATI/AMD chipsets as default
Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets"
ASoC: Tegra: Fix compile when debugfs not enabled
ASoC: spdif-dit: Add missing MODULE_*
SOUND: OSS: Remove Au1550 driver.
ALSA: hda - add Intel Panther Point HDMI codec id
ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live!
ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek
ALSA: hda - Fix input-src parse in patch_analog.c
ASoC: davinci-mcasp: enable ping-pong SRAM buffers
ASoC: add iPAQ hx4700 machine driver
ASoC: Asahi Kasei AK4641 codec driver
ALSA: hda - Enable Realtek ALC269 codec input layer beep
ALSA: intel8x0m: enable AMD8111 modem
ALSA: HDA: Add jack detection for HDMI
ALSA: sound, core, pcm_lib: fix xrun_log
ASoC: Max98095: Move existing NULL check before pointer dereference.
ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt
ALSA: usb-audio - Add support for USB X-Fi S51 Pro
Signed-off-by: Stefan Ringel <stefan.ringel@arcor.de>
move from tm6000_set_reg to tm6000_set_reg_mask
change input control
vitual input enums
change to virtual inputs
add tm6010 audio mode setup
add radio capabilities
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
On some situations, it is desired to use eeprom data to detect
the board type. This patch adds a logic for it and fixes 2 detection
issues:
1) 10Moons UT-821 uses a generic Trident ID. Other boards
also share the same ID. So, better to use an alternative way for
it;
2) Sometimes, HVR-900H is loaded with the default Trident
ID. This seems to be some hardware bug or race condition.
The new logic will only be enabled if the device is detected as
having a generic ID.
add CARDLIST
In commit 8aff8ba95155df, most of the manipulations to vbuf inside
copy_streams were gated on if !dev->radio, but one place that touches
vbuf lays outside those gates -- a memcpy of vbuf isn't NULL. If we
initialize vbuf to NULL, that memcpy will never happen in the case where
we do have dev->radio, and otherwise, in the !dev->radio case, the code
behaves exactly like it did prior to 8aff8ba95155df.
While we're at it, also fix an incorrectly indented closing brace for
one of the sections touching vbuf that is conditional on !dev->radio.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
This switches all of the usbip_u{dbg,err,info} and printk statements to
dev_<level>, if possible, or pr_<level> macros. And removes a few
unnecessary debug statements.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
More to be added, but this brings the docs in line with
the current code. Now they are hopefully just uninformative
rather than actually incorrect.
Some didn't get converted the first time around.
This was suggested by Arnd Bergmann, Other elements may well
move in here in future, but it definitely makes sense for these.
Use private data space from iio_allocate_device.
Drop dev_data in favor of iio_priv().
Fix indention issues from previous patches.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Silliness that has been there a long time.
Add a function to neatly deal with allocation of poll functions.
Ultimately this allows us to more easily change the implementation.
trivial fixes
Fix typo in gpio name
Fix error return path, free gpio
Make scale_uv type unsigned long
Some other small cleanups including excess header removals.
It seemed like a good idea at the time, it wasn't.
The code with this in place is larger and more complex for
no real gain. Basically we've cleaned up the core around
it so much that this no longer makes sense.
Only really effects the lis3l02dq driver.
Signed-off-by: Jonathan Cameron <jic23@cam.acuk>
1) move a generic helper function out of ring_sw. It applies to other buffers as well.
2) Get rid of a lot of left over function definitions.
3) Move all the access functions into static structures.
4) Introduce and use a static structure for the setup functions, preenable etc.
Some driver conversions thanks to Michael Hennerich (pulled out of patches
that would otherwise sit after this).
