path: root/drivers/staging
2009-08-07Staging: rspiusb: Fix buffer overflowRoel Kluin
usb_buffer_map_sg() may return -1. This will result in a read from pdx->PixelUrb[frameInfo][-1] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07staging: add dependencies on PCI for drivers that require itJeff Mahoney
This patch adds PCI dependencies to staging drivers that require it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07Staging: rtl8192su: fix build errorGreg Kroah-Hartman
This fixes a build error when selecting the rtl8192su driver as a module. This has been reported by me, and the opensuse kernel developer team, and I finally tracked it down. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07Staging: rt2870: Revert d44ca7 Removal of kernel_thread() APIMike Galbraith
Staging: rt2870: Revert d44ca7 Removal of kernel_thread() API The sanity check this patch introduced triggers on shutdown, apparently due to threads having already exited by the time BUG_ON() is reached. Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Peter Teoh <htmldeveloper@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07Staging: rt2870: Add USB ID for Linksys, Planex Communications, BelkinJakob Gruber
Linksys WUSB100, Belkin F5D8053 N, Planex Communications unknown model. Signed-off-by: Jakob Gruber <jakob.gruber@kabelnet.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28staging: udlfb: Add vmalloc.h includeAmit Kucheria
Required for vmalloc_32 and vfree declarations on non-x86 platforms. Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28staging: remove aten2011 driverGreg Kroah-Hartman
This driver is not needed, as the existing mos7840 driver works properly for this device. Thanks to Russell Lang for doing the work to figure this out. Cc: Russell Lang <gsview@ghostgum.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28Staging: android: lowmemorykiller.c: fix it for "oom: move oom_adj value ↵David Rientjes
from task_struct to mm_struct" I'm about to merge "oom: move oom_adj value from task_struct to mm_struct", and this fixup is needed to repair linux-next's drivers/staging/android/lowmemorykiller.c. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28Staging: serqt_usb2: fix memory leak in error caseOliver Neukum
a standard memory leak, as later allocations may fail even if prior allocations did not. Then the prior allocations must be undone. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28Staging: serqt_usb2: add missing calls to tty_kref_put()Bill Pemberton
tty_port_tty_get() was called without a corresponding tty_kref_put() in qt_read_bulk_callback() and qt_close(). Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: Staging: stlc45xx: convert config_interface to bss_info_changed, fixing a build error Staging: comedi: s626: use subvendor:subdevice ids for SAA7146 board Staging: prevent rtl8192su from crashing dev_ioctl in SIOCGIWNAME Staging: prevent rtl8187se from crashing dev_ioctl() in SIOCGIWNAME Staging: rtl8192su: convert to net_device_ops Staging: serqt_usb2: declare qt_open static in serqt_usb2 Staging: serqt_usb2: fix qt_close parameters in serqt_usb2 Staging: comedi: jr3_pci.c: add required includes Staging: meilhaus: add email address to TODO Staging: rspiusb: use NULL virtual address instead of a bogus one Staging: vt6655: compile fix Staging: rt2870: Add USB ID for Sitecom WL-608
2009-07-13Fix staging drivers after smp_lock.h reduxJean Delvare
Commit 405f55712dfe464b3240d7816cc4fe4174831be2 ("headers: smp_lock.h redux") broke the build of two staging drivers. Fix them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12Staging: stlc45xx: convert config_interface to bss_info_changed, fixing a ↵Alexander Beregalov
build error See commit 2d0ddec5b2b (mac80211: unify config_interface and bss_info_changed) This fixes a build error. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: comedi: s626: use subvendor:subdevice ids for SAA7146 boardHerton Ronaldo Krzesinski
The current s626 comedi driver in staging conflicts with philips SAA7146 media/dvb based cards, because it claims the same vendor:device pci id for all subdevice/subvendor ids. What happens is that for people that have a philips SAA7146 media/dvb based card, s626 if available gets loaded by udev and makes system freeze (https://qa.mandriva.com/show_bug.cgi?id=51445). The s626 driver shouldn't claim all 1131:7146 devices. Fix this by specifying specific known subvendor:subdevice ids in its pci id table list. Also s626_attach is modified to use now pci_get_subsys instead of pci_get_device as reported by Ian Abbott, and now we loop over pci id table entries in case more ids are added in the future. Reference: http://lkml.org/lkml/2009/6/16/552 Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: prevent rtl8192su from crashing dev_ioctl in SIOCGIWNAMEDan Aloni
(adapted from the rtl8187se patch) ieee80211_wx_get_name() ignores sizeof(wrqu->name) which is IFNAMSIZ (16), and on certain conditions, the concatenated string will be larger than IFNAMSIZ including the terminating zero. length ("802.11" ++ "b" ++ "/g" ++ " linked" ++ "\x00") == 17 This fix uses strl{cpy,cat} in addition to the reduction of the total possible length of the output string by a char. It can be applied to 2.6.30-stable as well. Signed-off-by: Dan Aloni <dan@aloni.org> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: prevent rtl8187se from crashing dev_ioctl() in SIOCGIWNAMEDan Aloni
I repeatedly get __stack_chk_fail panic()s with this driver before applying the attached fix. ieee80211_wx_get_name() ignores sizeof(wrqu->name) which is IFNAMSIZ (16), and on certain conditions, the concatenated string will be larger than IFNAMSIZ including the terminating zero. length ("802.11" ++ "b" ++ "/g" ++ " linked" ++ "\x00") == 17 This fix uses strl{cpy,cat} in addition to the reduction of the total possible length of the output string by a char. It can be applied to 2.6.30-stable as well. Signed-off-by: Dan Aloni <dan@aloni.org> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: rtl8192su: convert to net_device_opsBartlomiej Zolnierkiewicz
commit e3804cbebb67887879102925961d41b503f7fbe3 removed COMPAT_NET_DEV_OPS so this change is needed to make rtl8192su buildable again. Loosely based on Alexander's patch for rtl8187se, untested. Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: serqt_usb2: declare qt_open static in serqt_usb2Bill Pemberton
2009-07-12Staging: serqt_usb2: fix qt_close parameters in serqt_usb2Bill Pemberton
The parameter list for qt_close() was from the old non usb-serial driver. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: comedi: jr3_pci.c: add required includesAlexander Beregalov
Fix this build errors: jr3_pci.c:739: error: 'jiffies' undeclared jr3_pci.c:748: error: implicit declaration of function 'msecs_to_jiffies' jr3_pci.c:763: error: implicit declaration of function 'add_timer' jr3_pci.c:790: error: implicit declaration of function 'init_timer' jr3_pci.c:951: error: implicit declaration of function 'del_timer_sync' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: meilhaus: add email address to TODOGreg Kroah-Hartman
Meilhaus Support also wants to be notified of changes to these drivers. Cc: David Kiliani <mail@davidkiliani.de> Cc: Meilhaus Support <support@meilhaus.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: rspiusb: use NULL virtual address instead of a bogus onePete Zaitcev
The main problem here is that I just cannot see how this could ever be correct: usb_fill_bulk_urb(pdx->PixelUrb[frameInfo][i], pdx->udev, epAddr, (dma_addr_t *) sg_dma_address(&pdx->sgl[frameInfo][i]), sg_dma_len(&pdx->sgl[frameInfo][i]), You cannot take a DMA address, cast it to a _pointer to_ a DMA address, and then regard it as a virtual address of the transfer buffer. However, finding the right virtual address was too hard for me, so I just stubbed it with NULL. At least usbmon won't oops then (it will not show any data but it's better than crashing). Also, too big a buffer was allocated elsewhere. And since we're at it, drop clearly unnecessary usb_buffer_alloc too, leaving it where it may be useful. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: vt6655: compile fixAlan Cox
At least make it compile Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Staging: rt2870: Add USB ID for Sitecom WL-608Jorrit Schippers
Add the USB id 0x0DF6,0x003F to the rt2870.h file such that the Sitecom WL-608 device will be recognized by this driver. Signed-off-by: Jorrit Schippers <jorrit@ncode.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-24Staging: octeon-ethernet: Fix race freeing transmit buffers.David Daney
The existing code had the following race: Thread-1 Thread-2 inc/read in_use inc/read in_use inc tx_free_list[qos].len inc tx_free_list[qos].len The actual in_use value was incremented twice, but thread-1 is going to free memory based on its stale value, and will free one too many times. The result is that memory is freed back to the kernel while its packet is still in the transmit buffer. If the memory is overwritten before it is transmitted, the hardware will put a valid checksum on it and send it out (just like it does with good packets). If by chance the TCP flags are clobbered but not the addresses or ports, the result can be a broken TCP stream. The fix is to track the number of freed packets in a single location (a Fetch-and-Add Unit register). That way it can never get out of sync with itself. We try to free up to MAX_SKB_TO_FREE (currently 10) buffers at a time. If fewer are available we adjust the free count with the difference. The action of claiming buffers to free is atomic so two threads cannot claim the same buffers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24Staging: octeon-ethernet: Convert to use net_device_ops.David Daney
Convert the driver to use net_device_ops as it is now mandatory. Also compensate for the removal of struct sk_buff's dst field. The changes are mostly mechanical, the content of ethernet-common.c was moved to ethernet.c and ethernet-common.{c,h} are removed. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-22tty: fix some bogns in the serqt_usb2 driverAlan Cox
Remove the replicated urban legends from the comments and fix a couple of other silly calls Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19Staging: comedi: fix build errorsGreg Kroah-Hartman
Some of the comedi drivers need timer.h to build properly, so put it in the comedidev.h file to fix these errors. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: udlfb: update to version 0.2.3Roberto De Ioris
This updates the udlfb to the 0.2.3 version. From: Roberto De Ioris <roberto@unbit.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: udlfb: fix some sparse warnings.Greg Kroah-Hartman
There are others remaining due to the __iomem namespace of the framebuffer data pointer. Cc: Roberto De Ioris <roberto@unbit.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: udlfb: clean up checkpatch warnings in udlfb.cGreg Kroah-Hartman
This cleans up a bunch of checkpatch.pl warnings in the udlfb.c file. Cc: Roberto De Ioris <roberto@unbit.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: udlfb: clean up checkpatch warnings in udlfb.hGreg Kroah-Hartman
This cleans up a bunch of checkpatch.pl warnings in the udlfb.h file. Cc: Roberto De Ioris <roberto@unbit.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: udlfb: add udlfb driver to buildGreg Kroah-Hartman
This adds the udlfb driver to the build system Cc: Roberto De Ioris <roberto@unbit.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: add udlfb driverRoberto De Ioris
This adds the udlfb driver, a framebuffer driver for DisplayLink devices. From: Roberto De Ioris <roberto@unbit.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: remove pointless commentsGreg Kroah-Hartman
These comments contribute nothing to the code, and most were just cut and pasted from another driver. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: remove DRIVER macrosGreg Kroah-Hartman
They are not needed, and the version one was pointless now that the code is merged into the tree. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: remove dbgprintf macroGreg Kroah-Hartman
Use dev_dbg() instead. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: remove broken flagGreg Kroah-Hartman
The "in_module_init" flag was wrong, so just remove it, it's not needed. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: fix build warningsGreg Kroah-Hartman
struct ata_port_info shouldn't be const, so remove that which fixes up the compiler warnings. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: use PCI_DEVICEGreg Kroah-Hartman
Use the PCI_DEVICE macro, that's what it is there for... Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: remove function prototypesGreg Kroah-Hartman
Move code around so we do not need the function prototypes anymore. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: coding style fixesGreg Kroah-Hartman
This fixes a number of coding style issues in the pata_rdc.h file Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: convert code to work in 2.6.29Greg Kroah-Hartman
This fixes build problems in the pata_rdc driver due to api changes in the libata layer. Cc: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: pata_rdc: add driver to the build systemGreg Kroah-Hartman
2009-06-19Staging: add pata_rdc driverKevin Huang
This is our IDE Source code. This is base on kernel 2.6.28. pata_rdc.h and pata_rdc.c From: Kevin Huang <Kevin.Huang@rdc.com.tw> Cc: Tomy Wang <Tomy.Wang@rdc.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: remove obsolete serqt_usb driverGreg Kroah-Hartman
Now that Bill rewrote the driver "properly", this old thing can be removed. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: serqt_usb2 add the driver to the buildBill Pemberton
2009-06-19Staging: Add serqt_usb2, a rewrite of serqt_usb for the usb-serial layerBill Pemberton
This is the serqt_usb driver rewritten to use usb-serial. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: asus_oled: fix build warningsGreg Kroah-Hartman
This fixes some build warnings in the asus_oled driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: slicoss: fix build warningsGreg Kroah-Hartman
This fixes some build warnings in the slicoss driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
