commit 34ffb33e09132401872fe79e95c30824ce194d23 upstream.
The 'ni_at_a2150' module links to `cfc_write_to_buffer` in the
'comedi_fc' module, so selecting 'COMEDI_NI_AT_A2150' in the kernel config
needs to also select 'COMEDI_FC'.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit c43435d7722134ed1fda58ce1025f41029bd58ad upstream.
comedi_auto_config() associates a Comedi minor device number with an
auto-configured hardware device and comedi_auto_unconfig() disassociates
it. Currently, these use the hardware device's private data pointer to
point to some allocated storage holding the minor device number. This
is a bit of a waste of the hardware device's private data pointer,
preventing it from being used for something more useful by the low-level
comedi device drivers. For example, it would make more sense if
comedi_usb_auto_config() was passed a pointer to the struct
usb_interface instead of the struct usb_device, but this cannot be done
currently because the low-level comedi drivers already use the private
data pointer in the struct usb_interface for something more useful.
This patch stops the comedi core hijacking the hardware device's private
data pointer. Instead, comedi_auto_config() stores a pointer to the
hardware device's struct device in the struct comedi_device_file_info
associated with the minor device number, and comedi_auto_unconfig()
calls new function comedi_find_board_minor() to recover the minor device
number associated with the hardware device.
commit 6102c48bd421074a33e102f2ebda3724e8d275f9 upstream.
Check that array index is in-bounds before accessing the synths[] array.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Nickolai Zeldovich <nickolai@csail.mit.edu>
commit ae428655b826f2755a8101b27beda42a275ef8ad upstream.
Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu>
Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>
commit da849a92d3bafaf24d770e971c2c9e5c3f60b5d1 upstream.
The ISY IWL 1000 USB WLAN stick with USB ID 050d:11f1 is a clone of
the Belkin F7D1101 V1 device.
Reported-by: Thomas Hartmann <hartmann@ict.tuwien.ac.at>
Cc: Thomas Hartmann <hartmann@ict.tuwien.ac.at>
commit c0729eeefdcd76db338f635162bf0739fd2c5f6f upstream.
Éric Piel reported a kernel oops in the "comedi_test" module. It was a
NULL pointer dereference within `waveform_ai_interrupt()` (actually a
timer function) that sometimes occurred when a running asynchronous
command is cancelled (either by the `COMEDI_CANCEL` ioctl or by closing
the device file).
This seems to be a race between the caller of `waveform_ai_cancel()`
which on return from that function goes and tears down the running
command, and the timer function which uses the command. In particular,
`async->cmd.chanlist` gets freed (and the pointer set to NULL) by
`do_become_nonbusy()` in "comedi_fops.c" but a previously scheduled
`waveform_ai_interrupt()` timer function will dereference that pointer
regardless, leading to the oops.
Fix it by replacing the `del_timer()` call in `waveform_ai_cancel()`
with `del_timer_sync()`.
Reported-by: Éric Piel <piel@delmic.com>
commit 34b55d8c48f4f76044d8f4d6ec3dc786cf210312 upstream.
The minimum period was set to 357 ns, while the divider for these boards is 50
ns. This prevented to output at maximum speed as ni_ao_cmdtest() would return
357 but would not accept it.
Not sure why it was set to 357 ns (this was done before the git history,
which starts 5 years ago). My guess is that it comes from reading the
specification stating a 2.8 MHz rate (~ 357 ns). The latest
specification states a 2.86 MHz rate (~ 350 ns), which makes a lot
more sense.
Tested on a pci-6251.
Signed-off-by: Éric Piel <piel@delmic.com>
Acked-By: Ian Abbott <abbotti@mev.co.uk>
commit 7d3135af399e92cf4c9bbc5f86b6c140aab3b88c upstream.
When a low-level comedi driver auto-configures a device, a `struct
comedi_dev_file_info` is allocated (as well as a `struct
comedi_device`) by `comedi_alloc_board_minor()`. A pointer to the
hardware `struct device` is stored as a cookie in the `struct
comedi_dev_file_info`. When the low-level comedi driver
auto-unconfigures the device, `comedi_auto_unconfig()` uses the cookie
to find the `struct comedi_dev_file_info` so it can detach the comedi
device from the driver, clean it up and free it.
A problem arises if the user manually unconfigures and reconfigures the
comedi device using the `COMEDI_DEVCONFIG` ioctl so that is no longer
associated with the original hardware device. The problem is that the
cookie is not cleared, so that a call to `comedi_auto_unconfig()` from
the low-level driver will still find it, detach it, clean it up and free
it.
Stop this problem occurring by always clearing the `hardware_device`
cookie in the `struct comedi_dev_file_info` whenever the
`COMEDI_DEVCONFIG` ioctl call is successful.
commit 70e227790d4ee4590023d8041a3485f8053593fc upstream.
The timer appears to run too fast/race on 64 bit systems.
Using msecs_to_jiffies seems to cause a deadlock on 64 bit.
A calculation of (MSecond * HZ) / 1000 appears to run satisfactory.
Change BSSIDInfoCount to u32.
After this patch the driver can be successfully connect on little endian 64/32 bit systems.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit c0d05b305b00c698b0a8c1b3d46c9380bce9db45 upstream.
Fixes long issues.
commit b4dc03af5513774277c9c36b12a25cd3f25f4404 upstream.
Fixes long warning messages from patch
[PATCH 08/14] staging: vt6656: 64 bit fixes : correct all type sizes
commit 7730492855a2f9c828599bcd8d62760f96d319e4 upstream.
After this patch all BYTE/WORD/DWORD types can be replaced with the appropriate u sizes.
commit a552397d5e4ef0cc0bd3e9595d6acc9a3b381171 upstream.
Size of long issues replace with u32.
commit ab1dd9963137a1e122004d5378a581bf16ae9bc8 upstream.
Calling RFbSetPower with uCH zero value will cause out of bound array reference.
This causes 64 bit kernels to oops on boot.
Note: Driver does not function on 64 bit kernels and should be
blacklisted on them.
[Not needed in 3.8 or newer as this driver is removed there. - gregkh]
We get this from user space and nothing has been done to ensure that
these strings are NUL terminated.
Reported-by: Chen Gang <gang.chen@asianux.com>
commit d38e0e3fed4f58bcddef4dc93a591dfe2f651cb0 upstream.
Commit 6bd4a5d96c08dc2380f8053b1bd4f879f55cd3c9 changed the
ANDROID_ALARM_GET_TIME ioctls from IOW to IOR. While technically
correct, the _IOC_DIR bits are ignored by alarm_ioctl, so the
commit breaks a userspace ABI used by all existing Android devices
for a purely cosmetic reason. Revert it.
Cc: Dae S. Kim <dae@velatum.com>
Signed-off-by: Colin Cross <ccross@android.com>
commit aaeb61a97b7159ebe30b18a422d04eeabfa8790b upstream.
`pc236_detach()` is called by the comedi core if it attempted to attach
a device and failed. `pc236_detach()` calls `pc236_intr_disable()` if
the comedi device private data pointer (`devpriv`) is non-null. This
test is insufficient as `pc236_intr_disable()` accesses hardware
registers and the attach routine may have failed before it has saved
their I/O base addresses.
Fix it by checking `dev->iobase` is non-zero before calling
`pc236_intr_disable()` as that means the I/O base addresses have been
saved and the hardware registers can be accessed. It also implies the
comedi device private data pointer is valid, so there is no need to
check it.
commit 585650dcec88e704a19bb226a34b6a7166111623 upstream.
The default kernel mapping for the pages allocated for the binder
buffers is never used. Set the __GFP_HIGHMEM flag when allocating
these pages so we don't needlessly use low memory pages that may
be required elsewhere.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
commit 675d66b0ed5fd170d6a44cf8dbb3fa56a5347bdb upstream.
If a thread or process exited while a reply, one-way transaction or
death notification was pending, the struct holding the pending work
was leaked.
commit c8cad4c89ee3b15935c532210ae6ebb5c0a2734d upstream.
When `do_cmd_ioctl()` allocates memory for the kernel copy of a channel
list, it frees any previously allocated channel list in
`async->cmd.chanlist` and replaces it with the new one. However, if the
device is ever removed (or "detached") the cleanup code in
`cleanup_device()` in "drivers.c" does not free this memory so it is
lost.
A sensible place to free the kernel copy of the channel list is in
`do_become_nonbusy()` as at that point the comedi asynchronous command
associated with the channel list is no longer valid. Free the channel
list in `do_become_nonbusy()` instead of `do_cmd_ioctl()` and clear the
pointer to prevent it being freed more than once.
Note that `cleanup_device()` could be called at an inappropriate time
while the comedi device is open, but that's a separate bug not related
to this this patch.
commit 5d06e3df280bd230e2eadc16372e62818c63e894 upstream.
`parse_insn()` is dereferencing the user-space pointer `insn->data`
directly when handling the `INSN_INTTRIG` comedi instruction. It
shouldn't be using `insn->data` at all; it should be using the separate
`data` pointer passed to the function. Fix it.
commit e1878957b4676a17cf398f7f5723b365e9a2ca48 upstream.
Correct a direct dereference of I/O memory to use an appropriate I/O
memory access function. Note that the pointer being dereferenced is not
currently tagged with `__iomem` but I plan to correct that for 3.7.
commit b655c2c4782ed3e2e71d2608154e295a3e860311 upstream.
`s626_enc_insn_config()` is incorrectly dereferencing `insn->data` which
is a pointer to user memory. It should be dereferencing the separate
`data` parameter that points to a copy of the data in kernel memory.
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
commit fa16e5ea25d7dd83f663f333e70713aa2fa5dffe upstream.
Some post-3.4 kernels have a problem when a cloned skb is used in the
RX path. This patch handles one such case for r8712u.
The patch was suggested by Eric Dumazet.
commit 40fe4f89671fb3c7ded94190fb267402a38b0261 upstream.
softsynth_read() reads a character at a time from the init string;
when it finds the null terminator it sets the initialized flag but
then repeats the last character.
Additionally, if the read() buffer is not big enough for the init
string, the next read() will start reading from the beginning again.
So the caller may never progress to reading anything else.
Replace the simple initialized flag with the current position in
the init string, carried over between calls. Switch to reading
real data once this reaches the null terminator.
(This assumes that the length of the init string can't change, which
seems to be the case. Really, the string and position belong together
in a per-file private struct.)
Tested-by: Samuel Thibault <sthibault@debian.org>
commit 4b71ca6bce8fab3d08c61bf330e781f957934ae1 upstream.
For one, the driver device pointer needs to be filled in, or the lirc core
will refuse to load the driver. And we really need to wire up all the
platform_device bits. This has been tested via the lirc sourceforge tree
and verified to work, been sitting there for months, finally getting
around to sending it. :\
Signed-off-by: Jarod Wilson <jarod@redhat.com>
CC: Josh Boyer <jwboyer@redhat.com>
commit 61ed59ed09e6ad2b8395178ea5ad5f653bba08e3 upstream.
Don't zero out bits 15..12 of the data value in `das08jr_ao_winsn()` as
that knobbles the upper three-quarters of the output range for the
'das08jr-16-ao' board.
commit abf02cfc179bb4bd30d05f582d61b3b8f429b813 upstream.
64bit arches have a buggy r8712u driver, let's fix it.
skb->tail must be set properly or network stack behavior is undefined.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=847525
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=45071
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit aa209eef3ce8419ff2926c2fa944dfbfb5afbacb upstream.
This patch fixes a bug with driver failing to negotiate a connection.
The bug was traced to commit
203e4615ee9d9fa8d3506b9d0ef30095e4d5bc90
staging: vt6656: removed custom definitions of Ethernet packet types
In that patch, definitions in include/linux/if_ether.h replaced ones
in tether.h which had both big and little endian definitions.
include/linux/if_ether.h only refers to big endian values, cpu_to_be16
should be used for the correct endian architectures.
commit 6d7d9798ad5c97ee4e911dd070dc12dc5ae55bd0 upstream.
This patch fixes a race condition that results in memory
corruption when using cleancache.
The race exists between the zcache shrinker handler,
shrink_zcache_memory() and cleancache_get_page().
In most cases, the shrinker will both evict a zbpg
from its buddy list and flush it from tmem before a
cleancache_get_page() occurs on that page. A subsequent
cleancache_get_page() will fail in the tmem layer.
In the rare case that two occur together and the
cleancache_get_page() path gets through the tmem
layer before the shrinker path can flush tmem,
zbud_decompress() does a check to see if the zbpg is a
"zombie", i.e. not on a buddy list, which means the shrinker
is in the process of reclaiming it. If the zbpg is a zombie,
zbud_decompress() returns -EINVAL.
However, this return code is being ignored by the caller,
zcache_pampd_get_data_and_free(), which results in the
caller of cleancache_get_page() thinking that the page has
been properly retrieved when it has not.
This patch modifies zcache_pampd_get_data_and_free() to
convey the failure up the stack so that the caller of
cleancache_get_page() knows the page retrieval failed.
This needs to be applied to stable trees as well.
zcache-main.c was named zcache.c before v3.1, so
I'm not sure how you want to handle trees earlier
than that.
Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Minchan Kim <minchan@kernel.org>
commit 4ea418b8b2fa8a70d0fcc8231b65e67b3a72984b upstream.
A local static variable was declared as a pointer to a string
constant. We're assigning to the underlying memory, so it
needs to be an array instead.
Signed-off-by: Christopher Brannon <chris@the-brannons.com>
commit 6bd4a5d96c08dc2380f8053b1bd4f879f55cd3c9 upstream.
Fixed a bug. Data was being written to user space using an IOCTL
command encoded with _IOC_WRITE access mode.
Signed-off-by: Dae S. Kim <dae@velatum.com>
commit 43a34695d9cd79c6659f09da6d3b0624f3dd169f upstream.
This structure needs to always stick around, even if CONFIG_HOTPLUG
is disabled, otherwise we can oops when trying to probe a device that
was added after the structure is thrown away.
Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Bjørn Mork <bjorn@mork.no>
CC: Pavel Machek <pavel@ucw.cz>
CC: Paul Gortmaker <paul.gortmaker@windriver.com>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Eliad Peller <eliad@wizery.com>
CC: Devendra Naga <devendra.aaru@gmail.com>
commit 4d088876f24887cd15a29db923f5f37db6a99f21 upstream.
CC: Forest Bond <forest@alittletooquiet.net>
CC: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jesper Juhl <jj@chaosbits.net>
CC: Jiri Pirko <jpirko@redhat.com>
commit 069f101fa463351f528773d73b74e9b606b3f66a upstream.
ZSMALLOC is tristate, but the code has no MODULE_LICENSE and since it
depends on GPL-only symbols it cannot be loaded as a module. This in
turn breaks zram which now depends on it. I assume it's meant to be
Dual BSD/GPL like the other z-stuff.
There is also no module_exit, which will make it impossible to unload.
Add the appropriate module_init and module_exit declarations suggested
by comments.
Reported-by: Christian Ohm <chr.ohm@gmx.net>
References: http://bugs.debian.org/677273
Reviewed-by: Jonathan Nieder <jrnieder@gmail.com>
commit 279bf2e57c30c9a4482b2b6ede11b31c41e35e78 upstream.
Commit 50ac23be ("staging:iio:adc:ad7606 add local define for chan_spec
structures.") accidentally removed the scale info_mask flag. This patch
adds it back again.
Acked-by: Jonathan Cameron <jic23@kernel.org>
[herton: Backported to 3.4: info_mask was not used yet with another flag]
Signed-off-by: Herton R. Krzesinski <herton@canonical.com>
commit 3026b0e942c65c65c8fc80d391d004228b52b916 upstream.
There are two new devices for this driver.
commit 484dd30e016eb425b0de871357fff2c9bb93be45 upstream.
This is a longstanding bug, almost unnoticeable when calling
persistent_ram_write() for small buffers.
But when called for large data buffers, the write routine behaves
incorrectly, as the size may never update: instead of clamping
the size to the maximum buffer size, buffer_size_add_clamp() returns
an error (which is never checked by the write routine, btw).
To fix this, we now use buffer_size_add() that actually clamps the
size to the max value.
Also remove buffer_size_add_clamp(), it is no longer needed.
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Acked-by: Colin Cross <ccross@android.com>
commit abae41e6438b798e046d721b6ccdd55b4a398170 upstream.
aux_free is freed on all other exits from the function. By removing the
return, we can benefit from the vfree already at the end of the function.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Rupesh Gujare <rgujare@ozmodevices.com>
Signed-off-by: Chris Kelly <ckelly@ozmodevices.com>
This patch fixes the following build failures:
drivers/staging/octeon/ethernet.c: In function 'cvm_oct_cleanup_module':
drivers/staging/octeon/ethernet.c:799:2: error: implicit declaration of function 'free_irq'
drivers/staging/octeon/ethernet-rx.c: In function 'cvm_oct_no_more_work':
drivers/staging/octeon/ethernet-rx.c:119:3: error: implicit declaration of function 'enable_irq'
drivers/staging/octeon/ethernet-rx.c: In function 'cvm_oct_do_interrupt':
drivers/staging/octeon/ethernet-rx.c:136:2: error: implicit declaration of function 'disable_irq_nosync'
drivers/staging/octeon/ethernet-rx.c: In function 'cvm_oct_rx_initialize':
drivers/staging/octeon/ethernet-rx.c:532:2: error: implicit declaration of function 'request_irq'
drivers/staging/octeon/ethernet-tx.c: In function 'cvm_oct_tx_initialize':
drivers/staging/octeon/ethernet-tx.c:712:2: error: implicit declaration of function 'request_irq'
drivers/staging/octeon/ethernet-tx.c: In function 'cvm_oct_tx_shutdown':
drivers/staging/octeon/ethernet-tx.c:723:2: error: implicit declaration of function 'free_irq'
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Acked-by: David Daney <david.daney@cavium.com>
ZCACHE is a boolean in the Kconfig. When selected, it
should require that CRYPTO be builtin (=y).
Currently, ZCACHE=y and CRYPTO=m is a valid configuration
when it should not be.
This patch changes the zcache Kconfig to enforce this
dependency.
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Instead now use ioremap. This is needed for 3.4 since this change
emerged in mainline during one of the previous rc cycles.
These solves the following compilation breaks:
drivers/staging/tidspbridge/core/tiomap3430.c:
In function ‘bridge_brd_start’:
drivers/staging/tidspbridge/core/tiomap3430.c:425:4:
error: implicit declaration of function ‘OMAP2_L4_IO_ADDRESS’
drivers/staging/tidspbridge/core/wdt.c: In function ‘dsp_wdt_init’:
drivers/staging/tidspbridge/core/wdt.c:56:2:
For control registers a new function needs to be defined so we
can get rid of a layer violation, but that approach must be queued
for the next merge window.
As seen in:
http://www.arm.linux.org.uk/developer/build/
platform: omap4430-sdp build: uImage
config: randconfig version: 3.4.0-rc3
start time: Apr 20 2012 01:07
Reported-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree fixes from Greg KH:
"Here are a number of bugfixes for the drivers/staging/ portion of the
kernel that have been reported recently.
Nothing major here, with maybe the exception of the ramster code can
now be built so it is enabled in the build again, and lots of memory
leaks that people like to have fixed on their systems.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'staging-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: android: fix mem leaks in __persistent_ram_init()
staging: vt6656: Don't leak memory in drivers/staging/vt6656/ioctl.c::private_ioctl()
staging: iio: hmc5843: Fix crash in probe function.
staging/xgifb: fix display on XGI Volari Z11m cards
Staging: android: timed_gpio: Fix resource leak in timed_gpio_probe error paths
android: make persistent_ram based drivers depend on HAVE_MEMBLOCK
staging: iio: ak8975: Remove i2c client data corruption
staging: drm/omap: move where DMM driver is registered
staging: zsmalloc: fix memory leak
Staging: rts_pstor: off by one in for loop
staging: ozwpan: Added new maintainer for ozwpan
staging:rts_pstor:Avoid "Bad target number" message when probing driver
staging:rts_pstor:Fix possible panic by NULL pointer dereference
Staging: vt6655-6: check keysize before memcpy()
staging/media/as102: Don't call release_firmware() on uninitialized variable
staging:iio:core add missing increment of loop index in iio_map_array_unregister()
staging: ramster: unbreak my heart
staging/vme: Fix module parameters
staging: sep: Fix sign of error
If, in __persistent_ram_init(), the call to
persistent_ram_buffer_init() fails or the call to
persistent_ram_init_ecc() fails then we fail to free the memory we
allocated to 'prz' with kzalloc() - thus leaking it.
To prevent the leaks I consolidated all error exits from the function
at a 'err:' label at the end and made all error cases jump to that
label where we can then make sure we always free 'prz'. This is safe
since all the situations where the code bails out happen before 'prz'
has been stored anywhere and although we'll do a redundant kfree(NULL)
call in the case of kzalloc() itself failing that's OK since kfree()
deals gracefully with NULL pointers and I felt it was more important
to keep all error exits at a single location than to avoid that one
harmless/redundant kfree() on a error path.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Cc: stable <stable@vger.kernel.org>
If copy_to_user() fails in the WLAN_CMD_GET_NODE_LIST case of the
switch in drivers/staging/vt6656/ioctl.c::private_ioctl() we'll leak
the memory allocated to 'pNodeList'. Fix that by kfree'ing the memory
in the failure case.
Also remove a pointless cast (to type 'PSNodeList') of a kmalloc()
return value - kmalloc() returns a void pointer that is implicitly
converted, so there is no need for an explicit cast.
Fix crash after issuing:
echo hmc5843 0x1e > /sys/class/i2c-dev/i2c-2/device/new_device
[ 37.180999] device: '2-001e': device_add
[ 37.188293] bus: 'i2c': add device 2-001e
[ 37.194549] PM: Adding info for i2c:2-001e
[ 37.200958] bus: 'i2c': driver_probe_device: matched device 2-001e with driver hmc5843
[ 37.210815] bus: 'i2c': really_probe: probing driver hmc5843 with device 2-001e
[ 37.224884] HMC5843 initialized
[ 37.228759] ------------[ cut here ]------------
[ 37.233612] kernel BUG at mm/slab.c:505!
[ 37.237701] Internal error: Oops - BUG: 0 [#1] PREEMPT
[ 37.243103] Modules linked in:
[ 37.246337] CPU: 0 Not tainted (3.3.1-gta04+ #28)
[ 37.251647] PC is at kfree+0x84/0x144
[ 37.255493] LR is at kfree+0x20/0x144
[ 37.259338] pc : [<c00b408c>] lr : [<c00b4028>] psr: 40000093
[ 37.259368] sp : de249cd8 ip : 0000000c fp : 00000090
[ 37.271362] r10: 0000000a r9 : de229eac r8 : c0236274
[ 37.276855] r7 : c09d6490 r6 : a0000013 r5 : de229c00 r4 : de229c10
[ 37.283691] r3 : c0f00218 r2 : 00000400 r1 : c0eea000 r0 : c00b4028
[ 37.290527] Flags: nZcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 37.298095] Control: 10c5387d Table: 9e1d0019 DAC: 00000015
[ 37.304107] Process sh (pid: 91, stack limit = 0xde2482f0)
[ 37.309844] Stack: (0xde249cd8 to 0xde24a000)
[ 37.314422] 9cc0: de229c10 de229c00
[ 37.322998] 9ce0: de229c10 ffffffea 00000005 c0236274 de140a80 c00b4798 dec00080 de140a80
[ 37.331573] 9d00: c032f37c dec00080 000080d0 00000001 de229c00 de229c10 c048d578 00000005
[ 37.340148] 9d20: de229eac 0000000a 00000090 c032fa40 00000001 00000000 00000001 de229c10
[ 37.348724] 9d40: de229eac 00000029 c075b558 00000001 00000003 00000004 de229c10 c048d594
[ 37.357299] 9d60: 00000000 60000013 00000018 205b0007 37332020 3432322e 5d343838 c0060020
[ 37.365905] 9d80: de251600 00000001 00000000 de251600 00000001 c0065a84 de229c00 de229c48
[ 37.374481] 9da0: 00000006 0048d62c de229c38 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.383056] 9dc0: 00000000 c048d62c 00000000 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.391632] 9de0: 00000000 c048d62c 00000000 c0330164 00000000 de1f6c20 c048d62c de1f6c00
[ 37.400207] 9e00: c0330078 de1f6c04 c078d714 de189b58 00000000 c02ccfd8 de1f6c20 c0795f40
[ 37.408782] 9e20: c0238330 00000000 00000000 c02381a8 de1b9fc0 de1f6c20 de1f6c20 de249e48
[ 37.417358] 9e40: c0238330 c0236bb0 decdbed8 de7d0f14 de1f6c20 de1f6c20 de1f6c54 de1f6c20
[ 37.425933] 9e60: 00000000 c0238030 de1f6c20 c078d7bc de1f6c20 c02377ec de1f6c20 de1f6c28
[ 37.434509] 9e80: dee64cb0 c0236138 c047c554 de189b58 00000000 c004b45c de1f6c20 de1f6cd8
[ 37.443084] 9ea0: c0edfa6c de1f6c00 dee64c68 de1f6c04 de1f6c20 dee64cb8 c047c554 de189b58
[ 37.451690] 9ec0: 00000000 c02cd634 dee64c68 de249ef4 de23b008 dee64cb0 0000000d de23b000
[ 37.460266] 9ee0: de23b007 c02cd78c 00000002 00000000 00000000 35636d68 00333438 00000000
[ 37.468841] 9f00: 00000000 00000000 001e0000 00000000 00000000 00000000 00000000 0a10cec0
[ 37.477416] 9f20: 00000002 de249f80 0000000d dee62990 de189b40 c0234d88 0000000d c010c354
[ 37.485992] 9f40: 0000000d de210f28 000acc88 de249f80 0000000d de248000 00000000 c00b7bf8
[ 37.494567] 9f60: de210f28 000acc88 de210f28 000acc88 00000000 00000000 0000000d c00b7ed8
[ 37.503143] 9f80: 00000000 00000000 0000000d 00000000 0007fa28 0000000d 000acc88 00000004
[ 37.511718] 9fa0: c000e544 c000e380 0007fa28 0000000d 00000001 000acc88 0000000d 00000000
[ 37.520294] 9fc0: 0007fa28 0000000d 000acc88 00000004 00000001 00000020 00000002 00000000
[ 37.528869] 9fe0: 00000000 beab8624 0000ea05 b6eaebac 600d0010 00000001 00000000 00000000
[ 37.537475] [<c00b408c>] (kfree+0x84/0x144) from [<c0236274>] (device_add+0x530/0x57c)
[ 37.545806] [<c0236274>] (device_add+0x530/0x57c) from [<c032fa40>] (iio_device_register+0x8c8/0x990)
[ 37.555480] [<c032fa40>] (iio_device_register+0x8c8/0x990) from [<c0330164>] (hmc5843_probe+0xec/0x114)
[ 37.565338] [<c0330164>] (hmc5843_probe+0xec/0x114) from [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8)
[ 37.574737] [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8) from [<c02381a8>] (driver_probe_device+0x118/0x218)
[ 37.584777] [<c02381a8>] (driver_probe_device+0x118/0x218) from [<c0236bb0>] (bus_for_each_drv+0x4c/0x84)
[ 37.594818] [<c0236bb0>] (bus_for_each_drv+0x4c/0x84) from [<c0238030>] (device_attach+0x78/0xa4)
[ 37.604125] [<c0238030>] (device_attach+0x78/0xa4) from [<c02377ec>] (bus_probe_device+0x28/0x9c)
[ 37.613433] [<c02377ec>] (bus_probe_device+0x28/0x9c) from [<c0236138>] (device_add+0x3f4/0x57c)
[ 37.622650] [<c0236138>] (device_add+0x3f4/0x57c) from [<c02cd634>] (i2c_new_device+0xf8/0x19c)
[ 37.631805] [<c02cd634>] (i2c_new_device+0xf8/0x19c) from [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130)
[ 37.641754] [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130) from [<c0234d88>] (dev_attr_store+0x18/0x24)
[ 37.651611] [<c0234d88>] (dev_attr_store+0x18/0x24) from [<c010c354>] (sysfs_write_file+0x10c/0x140)
[ 37.661193] [<c010c354>] (sysfs_write_file+0x10c/0x140) from [<c00b7bf8>] (vfs_write+0xb0/0x178)
[ 37.670410] [<c00b7bf8>] (vfs_write+0xb0/0x178) from [<c00b7ed8>] (sys_write+0x3c/0x68)
[ 37.678833] [<c00b7ed8>] (sys_write+0x3c/0x68) from [<c000e380>] (ret_fast_syscall+0x0/0x3c)
[ 37.687683] Code: 1593301c e5932000 e3120080 1a000000 (e7f001f2)
[ 37.700775] ---[ end trace aaf805debdb69390 ]---
Client data was assigned to iio_dev structure in probe but in
hmc5843_init_client function casted to private driver data structure which
is wrong. Possibly calling mutex_init(&data->lock); corrupt data
which the lead to above crash.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Image on Z11m cards was totally garbled due to wrong memory being
selected. Add a special handling for Z11m cards. Tested on PCIe Z11 and
Z11m cards.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
If gpio_request fails, we need to free all allocated resources.
Current code uses wrong array index to access gpio_data array.
So current code actually frees gpio_data[i].gpio by j times.
This patch moves the error handling code to err_out and thus improves
readability.
m68k doesn't have memblock_reserve, which causes a build failure
with allmodconfig. Make PERSISTENT_RAM and RAM_CONSOLE depend on
HAVE_MEMBLOCK.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
