In order to support multiple ST platform devices, a new symbol
'st_get_plat_device' earlier needed to be exported by the arch/XX/brd-XX.c
file which intends to add the ST platform device.
On removing this dependency, now inside ST driver maintain the array of
ST platform devices that would be registered.
As of now let id=0, as and when we end up having such platforms
where mutliple ST devices can exist, id would come from
protocol drivers (BT, FM and GPS) as to on which platform device
they want to register to.
Signed-off-by: Pavan Savoy <pavan_savoy@ti.com>
Cc: Anca Emanuel <anca.emanuel@gmail.com>
"param->u.wpa_associate.wpa_ie_len" comes from the user. We should
check it so that the copy_from_user() doesn't overflow the buffer.
Also further down in the function, we assume that if
"param->u.wpa_associate.wpa_ie_len" is set then "abyWPAIE[0]" is
initialized. To make that work, I changed the test here to say that if
"wpa_ie_len" is set then "wpa_ie" has to be a valid pointer or we return
-EINVAL.
Oddly, we only use the first element of the abyWPAIE[] array. So I
suspect there may be some other issues in this function.
Cc: stable <stable@kernel.org>
This reverts commit 96d592ed599434d2d5f339a1d282871bc6377d2c.
The netfilter hook seems to be misused and may leak skbs in situations
when NF_HOOK returns NF_STOLEN. It may not filter everything as
expected. Also the ethernet bridge tables are not yet capable to
understand batman-adv packet correctly.
It was only added for testing purposes and can be removed again.
Reported-by: Vasiliy Kulikov <segooon@gmail.com>
Signed-off-by: Sven Eckelmann <sven.eckelmann@gmx.de>
The cfg80211 api has introduced a few new fields. Rather than assume
what cfg80211 api does by default, set these explicitly.
Signed-off-by: Karl Relton <karllinuxtest.relton@ntlworld.com>
OCTEON_ETHERNET should depend on NETDEVICES.
Fixes this kconfig warning:
warning: (NET_DSA && NET && EXPERIMENTAL && NETDEVICES && !S390 || ...
|| OCTEON_ETHERNET && STAGING && !STAGING_EXCLUDE_BUILD && CPU_CAVIUM_OCTEON) selects PHYLIB which has unmet direct dependencies (!S390 && NETDEVICES)
Reported-by: Arnaud Lacombe <lacombar@gmail.com>
Cc: support@caviumnetworks.com
lld_nand fails to build on arches without virt_to_bus. Since this driver
is specifically for hardware enablment on Moorestown, this patch adds
Moorestown MID support as a dependency.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Signed-off-by: Shahar Havivi <shaharh@redhat.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Taken from DPO_RT3070_LinuxSTA_V2.3.0.4_20100604.tar.bz2 and
2010_0709_RT2870_Linux_STA_v2.4.0.1.tar.bz2, with duplicates removed.
Commit 90abdc3b9 converted all PCMCIA users away from io_req_t. In
das08_cs.c the converted IO lines mask setting was added but the old
line using the now inexistent p_dev->io was not removed.
Signed-off-by: Andreas Bombe <aeb@debian.org>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
On one of my m68k test builds I get:
drivers/staging/spectra/ffsport.c: In function ‘ioctl_read_page_data’:
drivers/staging/spectra/ffsport.c:196: error: implicit declaration of function ‘kmalloc’
drivers/staging/spectra/ffsport.c:196: warning: assignment makes pointer from integer without a cast
drivers/staging/spectra/ffsport.c:212: error: implicit declaration of function ‘kfree’
drivers/staging/spectra/ffsport.c: In function ‘ioctl_write_page_data’:
drivers/staging/spectra/ffsport.c:229: warning: assignment makes pointer from integer without a cast
drivers/staging/spectra/ffsport.c: In function ‘SBD_setup_device’:
drivers/staging/spectra/ffsport.c:637: warning: assignment makes pointer from integer without a cast
Acked-by: Pekka Enberg <penberg@kernel.org>
Fixed lockup problem with bounce_buffer scatter list which caused
crashes in heavy loads. And minor code indentation cleanup in effected
area.
Removed whitespace and noted minor indentation changes in description as
pointed out by Joe Perches. (Thanks for reviewing Joe)
Signed-off-by: Hank Janssen <hjanssen@microsoft.com>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Increased storvsc ringbuffer and max_io_requests. This now more
closely mimics the numbers on Hyper-V. And will allow more IO requests
to take place for the SCSI driver.
Max_IO is set to double from what it was before, Hyper-V allows it and
we have had appliance builder requests to see if it was a problem to
increase the number.
Ringbuffer size for storvsc is now increased because I have seen A few buffer
problems on extremely busy systems. They were Set pretty low before.
And since max_io_requests is increased I Really needed to increase the buffer
as well.
Signed-off-by:Hank Janssen <hjanssen@microsoft.com>
Signed-off-by:Haiyang Zhang <haiyangz@microsoft.com>
Fixed the value of the 64bit-hole inside ring buffer, this
caused a problem on Hyper-V when running checked Windows builds.
Checked builds of Windows are used internally and given to external
system integrators at times. They are builds that for example that all
elements in a structure follow the definition of that Structure. The bug
this fixed was for a field that we did not fill in at all (Because we do
Not use it on the Linux side), and the checked build of windows gives
errors on it internally to the Windows logs.
This fixes that error.
Fixed bounce offset kmap problem by using correct index.
The symptom of the problem is that in some NAS appliances this problem
represents Itself by a unresponsive VM under a load with many clients writing
small files.
Fix missing functions for net_device_ops.
It's a bug when porting the drivers from 2.6.27 to 2.6.32. In 2.6.27,
the default functions for Ethernet, like eth_change_mtu(), were assigned
by ether_setup(). But in 2.6.32, these function pointers moved to
net_device_ops structure and no longer be assigned in ether_setup(). So
we need to set these functions in our driver code. It will ensure the
MTU won't be set beyond 1500. Otherwise, this can cause an error on the
server side, because the HyperV linux driver doesn't support jumbo frame
yet.
It's currently stalled and the original submitter recommended that it
just be dropped at this point in time due.
Cc: Alan Cox <alan@linux.intel.com>
Each net_device in a system will automatically managed as a possible
batman_if and holds different informations like a buffer with a prepared
originator messages. To reduce the memory usage, the packet_buff will
only be allocated when the interface is really added/enabled for
batman-adv.
The function to update the hw address information inside the packet_buff
just assumes that the packet_buff is always initialised and thus the
kernel will just oops when we try to change the hw address of a not
already fully enabled interface.
We must always check if the packet_buff is allocated before we try to
change information inside of it.
Reported-by: Tim Glaremin <Tim.Glaremin@web.de>
Reported-by: Kazuki Shimada <zukky@bb.banban.jp>
dev_put allows a device to be freed when all its references are dropped.
After that we are not allowed to access that information anymore. Access
to the data structure of a net_device must be surrounded a dev_hold
and ended using dev_put.
batman-adv adds a device to its own management structure in
hardif_add_interface and will release it in hardif_remove_interface.
Thus it must hold a reference all the time between those functions to
prevent any access to the already released net_device structure.
We try to get all events for all net_devices to be able to add special
sysfs folders for the batman-adv configuration. This also includes such
events like NETDEV_POST_INIT which has no valid kobject according to
v2.6.32-rc3-13-g7ffbe3f. This would create an oops in that situation.
It is enough to create the batman_if only on NETDEV_REGISTER events
because we will also receive those events for devices which already
existed when we registered the notifier call.
Earlier batman-adv versions would only create a batman_if struct after
a corresponding interface had been activated by a user. Now each
existing system interface has a batman_if struct and has to be checked
by verifying the IF_ACTIVE flag.
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
When receiving an batman icmp echo request or in case of a time-to-live
exceeded batman would reply with the mac address of the outgoing
interface which might be a secondary interface. Because secondary
interfaces are not globally known this might lead to confusion.
Now, replies are sent with the mac address of the primary interface.
If a batman icmp packet had to be routed over a secondary interface
at the first hop, the mac address of that secondary interface would
be written in the 'orig' field of the icmp packet. A node which is
more than one hop away is not aware of the mac address because
secondary interfaces are not flooded through the whole mesh and
therefore can't send a reply.
This patch always sends the mac address of the primary interface
The orig_hash_lock spinlock always has to be locked with IRQs being
disabled to avoid deadlocks between code that is being executed in
IRQ context and code that is being executed in non-IRQ context.
Reported-by: Sven Eckelmann <sven.eckelmann@gmx.de>
Greg Kroah-Hartman merged Linus 2.6.36 tree in
e9563355ac1175dd3440dc2ea5c28b27ed51a283 with his staging tree.
Different parts of the merge conflicts were resolved incorrectly and may
result in an abnormal behavior.
Fix compilation warning removing unused functions.
Signed-off-by: Javier Martinez Canillas <martinez.javier@gmail.com>
Fix a compile warning by initializaing lblk. Since FTL_Get_Block_Index()
returns BAD_BLOCK if it doesn't find the logical block number, lblk
number is initizalized to BAD_BLOCK.
Fix a compile warning by removing an unused variable int i.
This is the first patch of a patchset that removes all compilations
warnings in staging/spectra.
These patches are a delta from a previous patchset and it assumes that
these three patches all already applied:
Last patch has a style problem. Sending the correct one. Sorry for the noise
Since BKL was removed from block ioctl handling code, locked_ioctl doesn't
exist anymore.
Using ioctl instead and doing the locking manually.
REQ_TYPE_LINUX_BLOCK and REQ_LB_OP_FLUSH doesn't exist anymore. Using
the new REQ_FLUSH flag instead
This patch is the first one of a patchset that allows
stagin/spectra driver to compile in linux-next.
blk_queue_ordered doesn't receive a prepare flush function anymore
fs: fs_struct rwlock to spinlock
struct fs_struct.lock is an rwlock with the read-side used to protect root and
pwd members while taking references to them. Taking a reference to a path
typically requires just 2 atomic ops, so the critical section is very small.
Parallel read-side operations would have cacheline contention on the lock, the
dentry, and the vfsmount cachelines, so the rwlock is unlikely to ever give a
real parallelism increase.
Replace it with a spinlock to avoid one or two atomic operations in typical
path lookup fastpath.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
sysfs-writable charp arguments need to be locked against modification
(since the old ones may be kfreed underneath us). String arguments
are much simpler, so use them for small strings (eg. IFNAMSIZ).
lkdtm only uses the parameters at module initialization time, so there's
not much point making them writable.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: M. Mohan Kumar <mohan@in.ibm.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Julia Lawall <julia@diku.dk>
Cc: devel@driverdev.osuosl.org
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (94 commits)
V4L/DVB: tvp7002: fix write to H-PLL Feedback Divider LSB register
V4L/DVB: dvb: siano: free spinlock before schedule()
V4L/DVB: media: video: pvrusb2: remove custom hex_to_bin()
V4L/DVB: drivers: usbvideo: remove custom implementation of hex_to_bin()
V4L/DVB: Report supported QAM modes on bt8xx
V4L/DVB: media: ir-keytable: null dereference in debug code
V4L/DVB: ivtv: convert to the new control framework
V4L/DVB: ivtv: convert gpio subdev to new control framework
V4L/DVB: wm8739: convert to the new control framework
V4L/DVB: cs53l32a: convert to new control framework
V4L/DVB: wm8775: convert to the new control framework
V4L/DVB: cx2341x: convert to the control framework
V4L/DVB: cx25840: convert to the new control framework
V4L/DVB: cx25840/ivtv: replace ugly priv control with s_config
V4L/DVB: saa717x: convert to the new control framework
V4L/DVB: msp3400: convert to the new control framework
V4L/DVB: saa7115: convert to the new control framework
V4L/DVB: v4l2: hook up the new control framework into the core framework
V4L/DVB: Documentation: add v4l2-controls.txt documenting the new controls API
V4L/DVB: v4l2-ctrls: Whitespace cleanups
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (148 commits)
USB: serial: fix stalled writes
USB: remove fake "address-of" expressions
USB: fix thread-unsafe anchor utiliy routines
USB: usbtest: support test device with only one iso-in or iso-out endpoint
USB: usbtest: avoid to free coherent buffer in atomic context
USB: xhci: Set DMA mask for host.
USB: xhci: Don't flush doorbell writes.
USB: xhci: Reduce reads and writes of interrupter registers.
USB: xhci: Make xhci_set_hc_event_deq() static.
USB: xhci: Minimize HW event ring dequeue pointer writes.
USB: xhci: Make xhci_handle_event() static.
USB: xhci: Remove unnecessary reads of IRQ_PENDING register.
USB: xhci: Performance - move xhci_work() into xhci_irq()
USB: xhci: Performance - move interrupt handlers into xhci-ring.c
USB: xhci: Performance - move functions that find ep ring.
USB:: fix linux/usb.h kernel-doc warnings
USB: add USB serial ssu100 driver
USB: usb-storage: implement autosuspend
USB: ehci: fix remove of ehci debugfs dir
USB: Add USB 2.0 to ssb ohci driver
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
staging: Pushdown bkl to easycap ioctl handlers
autofs/autofs4: Move compat_ioctl handling into fs
v4l: Convert v4l2-dev to unlocked_ioctl
ia64/perfmon: Convert to unlocked_ioctl
sunrpc: Remove duplicated #include
ncpfs: Remove duplicated #include
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
... and let iput_final() do the actual eviction or retention
Replace inode_setattr with opencoded variants of it in all callers. This
moves the remaining call to vmtruncate into the filesystem methods where it
can be replaced with the proper truncate sequence.
In a few cases it was obvious that we would never end up calling vmtruncate
so it was left out in the opencoded variant:
spufs: explicitly checks for ATTR_SIZE earlier
btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier
ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above
In addition to that ncpfs called inode_setattr with handcrafted iattrs,
which allowed to trim down the opencoded variant.
Add latest unported version of this driver to media/IR.
Next patch will port it to ir core.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Moves drivers/staging/lirc/lirc_streamzap.c to
drivers/media/IR/streamzap.c, along with making the requisite Kconfig
and Makefile changes.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
This ports lirc_streamzap.c over to ir-core in-place, to be followed by
a patch moving the driver over to drivers/media/IR/streamzap.c and
enabling the proper Kconfig bits.
Presently, the in-kernel keymap doesn't work, as the stock Streamzap
remote uses an RC-5-like, but not-quite-RC-5 protocol, which the
in-kernel RC-5 decoder doesn't cope with. The remote can be used right
now with the lirc bridge driver though, and other remotes (at least an
RC-6(A) MCE remote) work perfectly with the driver.
I'll take a look at making the existing RC-5 decoder cope with this odd
duck, possibly implement another standalone decoder engine, or just
throw up my hands and say "meh, use lirc"... But the driver itself
should be perfectly sound.
Remaining items on the streamzap TODO list:
- add LIRC_SET_REC_TIMEOUT-alike support
- add LIRC_GET_M{AX,IN}_TIMEOUT-alike support
- add LIRC_GET_REC_RESOLUTION-alike support
All of the above should be trivial to add. There are patches pending to
add this support to ir-core from Maxim Levitsky, and I'll take care of
these once his patches get integrated. None of them are currently
essential though.
Fix when CONFIG_MODULES is not enabled:
drivers/staging/lirc/lirc_parallel.c:243: error: implicit declaration of function 'module_refcount'
drivers/staging/lirc/lirc_it87.c:150: error: implicit declaration of function 'module_refcount'
drivers/built-in.o: In function `it87_probe':
lirc_it87.c:(.text+0x4079b0): undefined reference to `init_chrdev'
lirc_it87.c:(.text+0x4079cc): undefined reference to `drop_chrdev'
drivers/built-in.o: In function `lirc_it87_exit':
lirc_it87.c:(.exit.text+0x38a5): undefined reference to `drop_chrdev'
Its a quick hack and untested beyond building, since I don't have the
hardware, but it should do the trick.
Signed-off-by: Janne Grunau <j@jannau.net>
These were amongst the last users of struct file_operations:ioctl
The open and release block_device_operations are currently
called with the BKL held. In order to change that, we must
first make sure that all drivers that currently rely
on this have no regressions.
This blindly pushes the BKL into all .open and .release
operations for all block drivers to prepare for the
next step. The drivers can subsequently replace the BKL
with their own locks or remove it completely when it can
be shown that it is not needed.
The functions blkdev_get and blkdev_put are the only
remaining users of the big kernel lock in the block
layer, besides a few uses in the ioctl code, none
of which need to serialize with blkdev_{get,put}.
Most of these two functions is also under the protection
of bdev->bd_mutex, including the actual calls to
->open and ->release, and the common code does not
access any global data structures that need the BKL.
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in
struct requests. This allows much easier grepping for different request
types instead of unwinding through macros.
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
