commit 0bf22be0da8ea74bc7ccc5b07d7855830be16eca upstream.
The lustre virtual block device cannot handle 64K pages and fails at compile
time. To avoid running into this error, let's disable the Kconfig option
for this driver in cases it doesn't support.
Reported-by: Dann Frazier <dann.frazier@canonical.com>
commit 0495081179212b758775df752e657ea71dcae020 upstream.
This can result in wrong reference count for trigger device, call
iio_trigger_get to increment reference.
Refer to http://www.spinics.net/lists/linux-iio/msg13669.html for discussion
with Jonathan.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 3a44a2058747d71385eb69691c7f977cb58cc293 upstream.
When unbinding imx-drm, the following oops was observed:
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = e995c000
[00000004] *pgd=4fea5831
Internal error: Oops: 817 [#1] SMP ARM
Modules linked in: bnep rfcomm bluetooth nfsd exportfs hid_cypress brcmfmac brcmutil snd_soc_fsl_ssi snd_soc_fsl_spdif imx_pcm_fiq imx_pcm_dma snd_soc_sgtl5000 imx_sdma imx2_wdt imx_ldb(C) imx_thermal snd_soc_imx_sgtl5000 snd_soc_imx_spdif snd_soc_imx_audmux
CPU: 1 PID: 779 Comm: bash Tainted: G C 3.16.0-rc2+ #1230
task: ea9eb180 ti: ea378000 task.ti: ea378000
PC is at ipu_dp_put+0x10/0x18
LR is at ipu_plane_dpms+0x60/0x8c
pc : [<c0350d20>] lr : [<c04bd9e8>] psr: 200f0013
sp : ea379d80 ip : ea379d90 fp : ea379d8c
r10: 00100100 r9 : 00000000 r8 : 00200200
r7 : e9ba0264 r6 : e9ba01f8 r5 : 00000000 r4 : ea34b800
r3 : 00000000 r2 : 00000000 r1 : 0000009b r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 3995c04a DAC: 00000015
Process bash (pid: 779, stack limit = 0xea378240)
Stack: (0xea379d80 to 0xea37a000)
Backtrace:
[<c0350d10>] (ipu_dp_put) from [<c04bd9e8>] (ipu_plane_dpms+0x60/0x8c)
[<c04bd988>] (ipu_plane_dpms) from [<c04bda40>] (ipu_disable_plane+0x2c/0x60)
[<c04bda14>] (ipu_disable_plane) from [<c04bda9c>] (ipu_plane_destroy+0x28/0x60)
[<c04bda74>] (ipu_plane_destroy) from [<c033ff84>] (drm_mode_config_cleanup+0x1b8/0x250)
[<c033fdcc>] (drm_mode_config_cleanup) from [<c04bc234>] (imx_drm_driver_unload+0x44/0x4c)
[<c04bc1f0>] (imx_drm_driver_unload) from [<c03394a4>] (drm_dev_unregister+0x2c/0xa0)
[<c0339478>] (drm_dev_unregister) from [<c0339f8c>] (drm_put_dev+0x30/0x6c)
[<c0339f5c>] (drm_put_dev) from [<c04bc1cc>] (imx_drm_unbind+0x14/0x18)
[<c04bc1b8>] (imx_drm_unbind) from [<c03530b4>] (component_master_del+0xbc/0xd8)
Code: e1a0c00d e92dd800 e24cb004 e3a03000 (e5c03004)
This is caused by a missing check in ipu_plane_dpms for a NULL pointer.
Fixes: b8d181e408af ("staging: drm/imx: add drm plane support")
commit a2fa6721c7237b5a666f16f732628c0c09c0b954 upstream.
The Elecom WDC-150SU2M uses this chip.
Reported-by: Hiroki Kondo <kompiro@gmail.com>
commit 8626d524ef08f10fccc0c41e5f75aef8235edf47 upstream.
The stick is not recognized.
This dongle uses r8188eu but usb-id is missing.
3.16.0
Signed-off-by: Holger Paradies <retabell@gmx.de>
initialisation
commit ec0a38bf8b28b036202070cf3ef271e343d9eafc upstream.
Fix two reported bugs, caused by et131x_adapter->phydev->addr being accessed
before it is initialised, by:
- letting et131x_mii_write() take a phydev address, instead of using the one
stored in adapter by default. This is so et131x_mdio_write() can use it's own
addr value.
- removing implementation of et131x_mdio_reset(), as it's not needed.
- moving a call to et131x_disable_phy_coma() in et131x_pci_setup(), which uses
phydev->addr, until after the mdiobus has been registered.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=80751
Link: https://bugzilla.kernel.org/show_bug.cgi?id=77121
Signed-off-by: Mark Einon <mark.einon@gmail.com>
commit 6cff1f6ad4c615319c1a146b2aa0af1043c5e9f5 upstream.
WARNING: CPU: 0 PID: 929 at /home/apw/COD/linux/kernel/irq/handle.c:147 handle_irq_event_percpu+0x1d1/0x1e0()
irq 17 handler device_intr+0x0/0xa80 [vt6655_stage] enabled interrupts
Using spin_lock_irqsave appears to fix this.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 4aa0abed3a2a11b7d71ad560c1a3e7631c5a31cd upstream.
byReAssocCount is incremented every second resulting in
disassociated message being send every 10 seconds whether
connection or not.
byReAssocCount should only advance while eCommandState
is in WLAN_ASSOCIATE_WAIT
Change existing scope to if condition.
commit 4856fbd12d69965d3ab680c686222db93872728d upstream.
The OMAP4 camera support depends on I2C and VIDEO_V4L2, both
of which can be loadable modules. This causes build failures
if we want the camera driver to be built-in.
This can be solved by turning the option into "tristate",
which unfortunately causes another problem, because the
driver incorrectly calls a platform-internal interface
for omap4_ctrl_pad_readl/omap4_ctrl_pad_writel.
Instead, this patch just forbids the invalid configurations
and ensures that the driver can only be built if all its
dependencies are built-in.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit b70e19c222a64018d308ebc80333575aff9f4e51 upstream.
We should be returning a negative error code instead of success here.
This would have been detected by GCC, except that the "ret" variable was
initialized with a bogus value to disable GCC's uninitialized variable
warnings. I've cleaned that up, as well.
commit 5d60122b7e30f275593df93b39a76d3c2663cfc2 upstream.
This patch fixes an off by one check in bcm2048_set_region().
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit ffd07de65ef5315053ea16356cd533b7f47c17e9 upstream.
Failure to terminate this match table can lead to boot failures
depending on where the compiler places the match table.
Cc: Kamlakant Patel <kamlakant.patel@broadcom.com>
Cc: Mona Anonuevo <manonuevo@micron.com>
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 9dbd79aeb9842144d9a114a979a12c0949ee11eb upstream.
The ->SupportedRates[] array has NDIS_802_11_LENGTH_RATES_EX (16)
elements. Since "ie_len" comes from then network and can go up to 255
then it means we should add a range check to prevent memory corruption.
Fixes: d6846af679e0 ('staging: r8188eu: Add files for new driver - part 7')
commit d3921a03a89acb1b9ca599590c0131c89f8737d8 upstream.
Commit d0f47ff17f29 ("ASoC: OMAP: Build config cleanup for McBSP")
removed the Kconfig symbol OMAP_MCBSP. It left two checks for
CONFIG_OMAP_MCBSP untouched.
Convert these to checks for CONFIG_SND_OMAP_SOC_MCBSP. That must be
correct, since that re-enables calls to functions that are all found in
sound/soc/omap/mcbsp.c. And that file is built only if
CONFIG_SND_OMAP_SOC_MCBSP is defined.
Fixes: d0f47ff17f29 ("ASoC: OMAP: Build config cleanup for McBSP")
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit 19bc4981a213d0c5b0e1e8b08815c0b26f01ec54 upstream.
All channels' single measurement are happening on CH 0. So enabling / disabling
the divider once is not enough, because it has impact on all channels.
Set only a flag, then check this on each measurement, and enable / disable the
divider as required.
Signed-off-by: Robert Hodaszi <robert.hodaszi@digi.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit c404618cd06dad771495fe1cf9d5a63b5664f65f upstream.
Consider high byte of proximity min and max treshold in function
'tsl2x7x_chip_on'. So far, the high byte was not set.
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
commit 9326c5ca0982f548cc08c0cffb14dcbd020f3d43 upstream.
A sparse error fixup removed a htons() which is required for the driver
to function. This patch puts the htons() back and fixes the sparse
warning correctly by changing the left side cast.
Signed-off-by: Sean MacLennan <seanm@seanm.ca>
commit 28a821c306889b9f2c3fff49abedc9b2c743eb73 upstream.
This function is largely a duplicate of paste_selection() in
drivers/tty/vt/selection.c, but with its own selection state. The
speakup selection mechanism should really be merged with vt.
For now, apply the changes from 'TTY: vt, fix paste_selection ldisc
handling', 'tty: Make ldisc input flow control concurrency-friendly',
and 'tty: Fix unsafe vt paste_selection()'.
References: https://bugs.debian.org/735202
References: https://bugs.debian.org/744015
Reported-by: Paul Gevers <elbrus@debian.org>
Reported-and-tested-by: Jarek Czekalski <jarekczek@poczta.onet.pl>
commit ffed54dced86723f352323f15789d9ad6bee25e1 upstream.
I got a patch from the original author, Fred Brooks, to add a small
settling delay after setting the AI channel multiplexor. The lack of
delay resulted in unstable or scrambled data on faster processors.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Reported-by: Fred Brooks <nsaspook@nsaspook.com>
commit d7500135802ca55b3f4e01a16544e8b34082f8c3 upstream.
Input is handled in softirq context, but when pasting we may
need to sleep. speakup_paste_selection() currently tries to
bodge this by busy-waiting if in_atomic(), but that doesn't
help because the ldisc may also sleep.
For bonus breakage, speakup_paste_selection() changes the
state of current, even though it's not running in process
context.
Move it into a work item and make sure to cancel it on exit.
NULL
commit 9452bf560273e4de2395ffdd79024debfb0c1290 upstream.
This makes the follow-on check for psta != NULL pointless and makes
the whole exercise rather pointless. This is another case of why
blindly zero-initializing variables when they are declared is bad.
Reported-by: Jes Sorensen <Jes.Sorensen@redhat.com>
commit 2704f807f9498054b8153002bafa3e818079e9a5 upstream.
In usbdux_ao_cmd(), the channels for the command are transfered from the
cmd->chanlist and stored in the private data 'ao_chanlist'. The channel
numbers are bit-shifted when stored so that they become the "command"
that is transfered to the device. The channel to command conversion
results in the 'ao_chanlist' having these values for the channels:
channel 0 -> ao_chanlist = 0x00
channel 1 -> ao_chanlist = 0x40
channel 2 -> ao_chanlist = 0x80
channel 3 -> ao_chanlist = 0xc0
The problem is, the usbduxsub_ao_isoc_irq() function uses the 'chan' value
from 'ao_chanlist' to access the 'ao_readback' array in the private data.
So instead of accessing the array as 0, 1, 2, 3, it accesses it as 0x00,
0x40, 0x80, 0xc0.
Fix this by storing the raw channel number in 'ao_chanlist' and doing the
bit-shift when creating the command.
Fixes: a998a3db530bff80 "staging: comedi: usbdux: cleanup the private data 'outBuffer'"
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
Acked-by: Bernd Porr <mail@berndporr.me.uk>
checked against 0
commit f764cd68d9036498f08fe8834deb6a367b5c2542 upstream.
Zero-initializing ether_type masked that the ether type would never be
obtained for 8021x packets and the comparison against eapol_type
would always fail.
commit abe5d64d1a74195a44cd14624f8178b9f48b7cc7 upstream.
This patch fixes the following sparse warning :
drivers/staging/serqt_usb2/serqt_usb2.c:727:40: warning: restricted __le16 degrades to integer
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
commit b34aa86f12e8848ba453215602c8c50fa63c4cb3 upstream.
Mmapping a comedi data buffer with lockdep checking enabled produced the
following kernel debug messages:
[ INFO: possible circular locking dependency detected ]
3.5.0-rc3-ija1+ #9 Tainted: G C
comedi_test/4160 is trying to acquire lock:
(&dev->mutex#2){+.+.+.}, at: [<ffffffffa00313f4>] comedi_mmap+0x57/0x1d9 [comedi]
but task is already holding lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff810c96fe>] vm_mmap_pgoff+0x41/0x76
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&mm->mmap_sem){++++++}:
[<ffffffff8106d0e8>] lock_acquire+0x97/0x105
[<ffffffff810ce3bc>] might_fault+0x6d/0x90
[<ffffffffa0031ffb>] do_devinfo_ioctl.isra.7+0x11e/0x14c [comedi]
[<ffffffffa003227f>] comedi_unlocked_ioctl+0x256/0xe48 [comedi]
[<ffffffff810f7fcd>] vfs_ioctl+0x18/0x34
[<ffffffff810f87fd>] do_vfs_ioctl+0x382/0x43c
[<ffffffff810f88f9>] sys_ioctl+0x42/0x65
[<ffffffff81415c62>] system_call_fastpath+0x16/0x1b
-> #0 (&dev->mutex#2){+.+.+.}:
[<ffffffff8106c528>] __lock_acquire+0x101d/0x1591
[<ffffffff8140c894>] mutex_lock_nested+0x46/0x2a4
[<ffffffff810d5816>] mmap_region+0x281/0x492
[<ffffffff810d5c92>] do_mmap_pgoff+0x26b/0x2a7
[<ffffffff810c971a>] vm_mmap_pgoff+0x5d/0x76
[<ffffffff810d493f>] sys_mmap_pgoff+0xc7/0x10d
[<ffffffff81004d36>] sys_mmap+0x16/0x20
Possible unsafe locking scenario:
CPU0 CPU1
lock(&mm->mmap_sem);
lock(&dev->mutex#2);
*** DEADLOCK ***
To avoid the circular dependency, just try to get the lock in
`comedi_mmap()` instead of blocking. Since the comedi device's main mutex
is heavily used, do a down-read of its `attach_lock` rwsemaphore
instead. Trying to down-read `attach_lock` should only fail if
some task has down-write locked it, and that is only done while the
comedi device is being attached to or detached from a low-level hardware
device.
Unfortunately, acquiring the `attach_lock` doesn't prevent another
task replacing the comedi data buffer we are trying to mmap. The
details of the buffer are held in a `struct comedi_buf_map` and pointed
to by `s->async->buf_map` where `s` is the comedi subdevice whose buffer
we are trying to map. The `struct comedi_buf_map` is already reference
counted with a `struct kref`, so we can stop it being freed prematurely.
Modify `comedi_mmap()` to call new function
`comedi_buf_map_from_subdev_get()` to read the subdevice's current
buffer map pointer and increment its reference instead of accessing
`async->buf_map` directly. Call `comedi_buf_map_put()` to decrement the
reference once the buffer map structure has been dealt with. (Note that
`comedi_buf_map_put()` does nothing if passed a NULL pointer.)
`comedi_buf_map_from_subdev_get()` checks the subdevice's buffer map
pointer has been set and the buffer map has been initialized enough for
`comedi_mmap()` to deal with it (specifically, check the `n_pages`
member has been set to a non-zero value). If all is well, the buffer
map's reference is incremented and a pointer to it is returned. The
comedi subdevice's spin-lock is used to protect the checks. Also use
the spin-lock in `__comedi_buf_alloc()` and `__comedi_buf_free()` to
protect changes to the subdevice's buffer map structure pointer and the
buffer map structure's `n_pages` member. (This checking of `n_pages` is
a bit clunky and I [Ian Abbott] plan to deal with it in the future.)
commit 268d1e799663b795cba15c64f5d29407786a9dd4 upstream.
According to National Instruments' PCI-DIO-96/PXI-6508/PCI-6503 User
Manual, the physical address in PCI BAR1 needs to be OR'ed with 0x80 and
written to register offset 0xC0 in the "MITE" registers (BAR0). Do so
during initialization of the National Instruments boards handled by the
"8255_pci" driver. The boards were previously handled by the
"ni_pcidio" driver, where the initialization was done by `mite_setup()`
in the "mite" module. The "mite" module comes with too much extra
baggage for the "8255_pci" driver to deal with so use a local, simpler
initialization function.
The function c4_ioctl() writes data from user in ifr->ifr_data
to the kernel struct data arg, without any iolen bounds checking.
This can lead to a arbitrary write outside of the struct data arg.
Corrected by adding bounds-checking of iolen before the copy_from_user().
Signed-off-by: Salva Peiró <speiro@ai2.upv.es>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
Fourth set of IIO fixes for the 3.14 kernel.
A single line patch fixing a regression that was introduced in 3.13 in the
reworking of the mxs touch screen and ADC drivers to be interrupt rather
than polling driven. It resulted in a stray double reporting of the release
coordinate in the touch screen driver. The bug lay in the adc side
of the driver which left the statemachine in the wrong state.
The D-Link DWA-123 REV D1 with USB ID 2001:3310 uses this driver.
Signed-off-by: Manu Gupta <manugupt1@gmail.com>
Cc: stable <stable@vger.kernel.org>
Releasing the touchscreen lets the internal statemachine left in a wrong state.
Due to this the release coordinate will be reported again by accident when the next
touchscreen event happens. This change sets up the correct state when waiting
for the next touchscreen event.
This has led to reported issues with calibrating the touchscreen.
Bug was introduced somewhere in the series that began with
18da755de59b406ce2371a55fb15ed676eb08ed2
Staging/iio/adc/touchscreen/MXS: add proper clock handling
in which the way this driver worked was substantially changed
to be interrupt driven rather than relying on a busy loop.
This was a regression in the 3.13 kernel.
Signed-off-by: Juergen Beisert <jbe@pengutronix.de>
Tested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree fix from Greg KH:
"Here is a single android driver fix for 3.14-rc4 that fixes a reported
problem in the binder driver"
* tag 'staging-3.14-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: binder: Fix death notifications
The change (008fa749e0fe5b2fffd20b7fe4891bb80d072c6a) that moved the
node release code to a separate function broke death notifications in
some cases. When it encountered a reference without a death
notification request, it would skip looking at the remaining
references, and therefore fail to send death notifications for them.
Cc: Colin Cross <ccross@android.com>
Cc: Android Kernel Team <kernel-team@android.com>
Cc: stable <stable@vger.kernel.org> # 3.10
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Jeremy Compostella <jeremy.compostella@intel.com>
Pull networking fixes from David Miller:
1) kvaser CAN driver has fixed limits of some of it's table, validate
that we won't exceed those limits at probe time. Fix from Olivier
Sobrie.
2) Fix rtl8192ce disabling interrupts for too long, from Olivier
Langlois.
3) Fix botched shift in ath5k driver, from Dan Carpenter.
4) Fix corruption of deferred packets in TIPC, from Erik Hugne.
5) Fix newlink error path in macvlan driver, from Cong Wang.
6) Fix netpoll deadlock in bonding, from Ding Tianhong.
7) Handle GSO packets properly in forwarding path when fragmentation is
necessary on egress, from Florian Westphal.
8) Fix axienet build errors, from Michal Simek.
9) Fix refcounting of ubufs on tx in vhost net driver, from Michael S
Tsirkin.
10) Carrier status isn't set properly in hyperv driver, from Haiyang
Zhang.
11) Missing pci_disable_device() in tulip_remove_one), from Ingo Molnar.
12) AF_PACKET qdisc bypass mode doesn't adhere to driver provided TX
queue selection method. Add a fallback method mechanism to fix this
bug, from Daniel Borkmann.
13) Fix regression in link local route handling on GRE tunnels, from
Nicolas Dichtel.
14) Bonding can assign dup aggregator IDs in some sequences of
configuration, fix by making the allocation counter per-bond instead
of global. From Jiri Bohac.
15) sctp_connectx() needs compat translations, from Daniel Borkmann.
16) Fix of_mdio PHY interrupt parsing, from Ben Dooks
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits)
MAINTAINERS: add entry for the PHY library
of_mdio: fix phy interrupt passing
net: ethernet: update dependency and help text of mvneta
NET: fec: only enable napi if we are successful
af_packet: remove a stray tab in packet_set_ring()
net: sctp: fix sctp_connectx abi for ia32 emulation/compat mode
ipv4: fix counter in_slow_tot
irtty-sir.c: Do not set_termios() on irtty_close()
bonding: 802.3ad: make aggregator_identifier bond-private
usbnet: remove generic hard_header_len check
gre: add link local route when local addr is any
batman-adv: fix potential kernel paging error for unicast transmissions
batman-adv: avoid double free when orig_node initialization fails
batman-adv: free skb on TVLV parsing success
batman-adv: fix TT CRC computation by ensuring byte order
batman-adv: fix potential orig_node reference leak
batman-adv: avoid potential race condition when adding a new neighbour
batman-adv: properly check pskb_may_pull return value
batman-adv: release vlan object after checking the CRC
batman-adv: fix TT-TVLV parsing on OGM reception
Add a new argument for ndo_select_queue() callback that passes a
fallback handler. This gets invoked through netdev_pick_tx();
fallback handler is currently __netdev_pick_tx() as most drivers
invoke this function within their customized implementation in
case for skbs that don't need any special handling. This fallback
handler can then be replaced on other call-sites with different
queue selection methods (e.g. in packet sockets, pktgen etc).
This also has the nice side-effect that __netdev_pick_tx() is
then only invoked from netdev_pick_tx() and export of that
function to modules can be undone.
Suggested-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Pull staging driver fixes from Greg KH:
"Here are a number (lots, I know) of fixes for staging drivers to
resolve a bunch of reported issues.
The largest patches here is one revert of a patch that is in 3.14-rc1
to fix reported problems, and a sync of a usb host driver that
required some ARM patches to go in before it could be accepted (which
is why it missed -rc1)
All of these have been in linux-next for a while with no reported
issues"
* tag 'staging-3.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (56 commits)
staging/rtl8821ae: fix build, depends on MAC80211
iio: max1363: Use devm_regulator_get_optional for optional regulator
iio:accel:bma180: Use modifier instead of index in channel specification
iio: adis16400: Set timestamp as the last element in chan_spec
iio: ak8975: Fix calculation formula for convert micro tesla to gauss unit
staging:iio:ad799x fix typo in ad799x_events[]
iio: mxs-lradc: remove useless scale_available files
iio: mxs-lradc: fix buffer overflow
iio:magnetometer:mag3110: Fix output of decimal digits in show_int_plus_micros()
iio:magnetometer:mag3110: Report busy in _read_raw() / write_raw() when buffer is enabled
wlags49_h2: Fix overflow in wireless_set_essid()
xlr_net: Fix missing trivial allocation check
staging: r8188eu: overflow in rtw_p2p_get_go_device_address()
staging: r8188eu: array overflow in rtw_mp_ioctl_hdl()
staging: r8188eu: Fix typo in USB_DEVICE list
usbip/userspace/libsrc/names.c: memory leak
gpu: ion: dereferencing an ERR_PTR
staging: comedi: usbduxsigma: fix unaligned dereferences
staging: comedi: fix too early cleanup in comedi_auto_config()
staging: android: ion: dummy: fix an error code
rtl8821ae uses ieee80211 interfaces so it should depend on
MAC80211. Fixes these build errors:
ERROR: "ieee80211_rx_irqsafe" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_beacon_get_tim" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_unregister_hw" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "rate_control_send_low" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_stop_queue" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_rate_control_register" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "wiphy_to_ieee80211_hw" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_stop_tx_ba_cb_irqsafe" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_tx_status_irqsafe" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_find_sta" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_wake_queue" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_rate_control_unregister" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_register_hw" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_start_tx_ba_session" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_alloc_hw" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_free_hw" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_connection_loss" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
ERROR: "ieee80211_start_tx_ba_cb_irqsafe" [drivers/staging/rtl8821ae/rtl8821ae.ko] undefined!
This patch fixes a typo in ad799x_events[], which caused the error "Failed to register event set".
Signed-off-by: Hartmut Knaack <knaack.h@gmx.de>
in_voltage8_scale_available and in_voltage9_scale_available are exposed to
userspace but useless as in_voltage8_raw and in_voltage9_raw are not available.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fixes:
drivers/staging/iio/adc/mxs-lradc.c:1556 mxs_lradc_probe() error: buffer
overflow 'iio->channels' 15 <= 15
The reported available scales for in_voltage15 were also wrong.
The realbits lookup is not necessary as all the channels of the LRADC have the
same resolution, use LRADC_RESOLUTION instead.
This patch prevents the wireless_set_essid() function from overwriting
the last byte of the NetworkName buffer which must be NULL.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
The go_devadd_str[] array is two characters too small to hold the
address so we corrupt memory.
I've changed the user space API slightly and I don't have a way to test
if this breaks anything. In the original code we truncated away the
last digit of the address and the NUL terminator so it was already a bit
broken.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
MAX_MP_IOCTL_SUBCODE (35) and mp_ioctl_hdl (32 elements) are no longer
in sync. It leads to a bogus pointer dereference.
There is a typo in the device list that interchanges the vendor and
product codes for one of the entries. This exchange was determined
by noticing that the vendor code is 0x07b8 for Abocom at
http://www.linux-usb.org/usb.ids.
revised patch
p is freed if NULL.
p is leaked if second calloc fails.
We dereference "heap->task" before checking if it's an ERR_PTR.
Fixes: ea313b5f88ed ('gpu: ion: Also shrink memory cached in the deferred free list')
There are a couple of dereferences such as `*(uint32_t
*)(devpriv->insn_buf + 1)` that are unaligned as `devpriv->insn_buf` is
of type `uint8_t *`. This works on x86 architecture but may not be
supported on other architectures. Call `get_unalign()` to perform the
unaligned dereferences.
Cc: Bernd Porr <mail@berndporr.me.uk>
`comedi_auto_config()` is usually called from the probe routine of a
low-level comedi driver to allocate and auto-configure a comedi device.
Part of this involves calling the low-level driver's `auto_attach()`
handler, and if that is successful, `comedi_device_postconfig()` tries
to complete the configuration of the comedi device. If either of those
fail, `comedi_device_detach()` is called to clean up, and
`comedi_release_hardware_device()` is called to remove the dynamically
allocated comedi device.
Unfortunately, `comedi_device_detach()` clears the `hw_dev` member of
the `struct comedi_device` (indirectly via `comedi_clear_hw_dev()`), and
that stops `comedi_release_hardware_device()` finding the comedi device
associated with the hardware device, so the comedi device won't be
removed properly.
Since `comedi_release_hardware_device()` also calls
`comedi_device_detach()` (assuming it finds the comedi device associated
with the hardware device), the fix is to remove the direct call to
`comedi_device_detach()` from `comedi_auto_config()` and let the call to
`comedi_release_hardware_device()` take care of it.
We should be returning -ENOMEM here instead of zero.
The changes introduced in commit 4b1a25f06b30b203 ("fix build when
CONFIG_UIDGID_STRICT_TYPE_CHECKS is on") got the UID check the wrong way
around, leading to "Permission denied" when a regular user attempts to
retrieve his quota (lfs quota -u ...) but allowing him to retrieve other
users quota.
Full details at: https://jira.hpdd.intel.com/browse/LU-4530
Cc: Peng Tao <tao.peng@emc.com>
Cc: <stable@vger.kernel.org> # 3.12.x
Cc: <stable@vger.kernel.org> # 3.13.x
Signed-off-by: Cédric Dufour <cedric.dufour@idiap.ch>
