This patch converts target-core to use se_cmd->t_transport_sent instead of
a duplicated se_cmd->transport_sent member in a handful of locations.
It also updates iscsi_target to properly use ->t_transport_sent instead of
it's own iscsi_cmd_t->transport_sent value that was not being assigned.
Reported-by: Christoph Hellwig <hch@lst.de>
iscsit_task_reassign_complete is always called from the TX thread, so
handle the CDB directly instead of offloading it.
The Linux-iSCSI.org target module is a full featured in-kernel
software implementation of iSCSI target mode (RFC-3720) for the
current WIP mainline target v4.1 infrastructure code for the v3.1
kernel. More information can be found here:
http://linux-iscsi.org/wiki/ISCSI
This includes support for:
* RFC-3720 defined request / response state machines and support for
all defined iSCSI operation codes from Section 10.2.1.2 using libiscsi
include/scsi/iscsi_proto.h PDU definitions
* Target v4.1 compatible control plane using the generic layout in
target_core_fabric_configfs.c and fabric dependent attributes
within /sys/kernel/config/target/iscsi/ subdirectories.
* Target v4.1 compatible iSCSI statistics based on RFC-4544 (iSCSI MIBS)
* Support for IPv6 and IPv4 network portals in M:N mapping to TPGs
* iSCSI Error Recovery Hierarchy support
* Per iSCSI connection RX/TX thread pair scheduling affinity
* crc32c + crc32c_intel SSEv4 instruction offload support using libcrypto
* CHAP Authentication support using libcrypto
* Conversion to use internal SGl allocation with iscsit_alloc_buffs() ->
transport_generic_map_mem_to_cmd()
(nab: Fix iscsi_proto.h struct scsi_lun usage from linux-next in commit:
iscsi: Use struct scsi_lun in iscsi structs instead of u8[8])
(nab: Fix 32-bit compile warnings)
Reviewed-by: Andy Grover <agrover@redhat.com>
Acked-by: Roland Dreier <roland@kernel.org>
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
