path: root/drivers/target/target_core_cdb.c
2011-03-14[SCSI] target: Fix volume size misreporting for volumes > 2TBNicholas Bellinger
the target infrastructure fails to send the correct conventional size to READ_CAPACITY that force a retry with READ_CAPACITY_16, which reads the capacity for devices > 2TB. Fix by adding the correct return to trigger RC(16). Reported-by: Ben Jarvis <bjarvismn@gmail.com> Signed-off-by: Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: stable@kernel.org Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
