path: root/drivers/target/target_core_rd.h
2014-01-19target/rd: Add support for protection SGL setup + releaseNicholas Bellinger
This patch adds rd_build_prot_space() + rd_release_prot_space() logic to setup + release protection information scatterlists. It also adds rd_init_prot() + rd_free_prot() se_subsystem_api callbacks used by target core code for setup + release of protection information. v2 changes: - Drop unused sg_table from rd_release_prot_space (Wei) - Drop rd_release_prot_space call from rd_free_device Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.de> Cc: Sagi Grimberg <sagig@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-11target/rd: Add ramdisk bit for NULLIO operationNicholas Bellinger
This patch adds a rd_nullio parameter that allows RAMDISK_MCP backends to function in NULLIO mode, where all se_cmd I/O is immediately completed in rd_execute_rw() without actually performing the SGL memory copy. This is useful for performance testing when the ramdisk SGL memory copy begins to eat lots of cycles during heavy small block workloads, so allow this bit to be enabled when necessary on a per rd_dev basis. Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: kill struct se_subsystem_devChristoph Hellwig
Simplify the code a lot by killing the superflous struct se_subsystem_dev. Instead se_device is allocated early on by the backend driver, which allocates it as part of its own per-device structure, borrowing the scheme that is for example used for inode allocation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-04-14target: don't limit transfer sizes for the ramdisk backendChristoph Hellwig
The ramdisk backend has not inherent limitations for handling requests, so don't artificially limits the transfer size. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-04-14target: misc ramdisk backend cleanupsChristoph Hellwig
Remove various leftovers of the old direct/indirect split, as well as the unused rd_request structure and a couple unused defines and fields. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-10-24target: make the ->get_cdb method optionalChristoph Hellwig
The most commonly used file, iblock and rd backends have no use for a per-task CDB and thus don't need a method to copy it into their otherwise unused CDB fields. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-22target: Follow up core updates from AGrover and HCH (round 4)Andy Grover
This patch contains the squashed version of forth round series cleanups from Andy and Christoph following the post heavy lifting in the preceeding: 'Eliminate usage of struct se_mem' and 'Make all control CDBs scatter-gather' changes. This also includes a conversion of target core and the v3.0 mainline fabric modules (loopback and tcm_fc) to use pr_debug and the CONFIG_DYNAMIC_DEBUG infrastructure! These have been squashed into this third and final round for v3.1. target: Remove ifdeffed code in t_g_process_write target: Remove direct ramdisk code target: Rename task_sg_num to task_sg_nents target: Remove custom debug macros for pr_debug. Use pr_err(). target: Remove custom debug macros in mainline fabrics target: Set WSNZ=1 in block limits VPD. Abort if WRITE_SAME sectors = 0 target: Remove transport do_se_mem_map callback target: Further simplify transport_free_pages target: Redo task allocation return value handling target: Remove extra parentheses target: change alloc_task call to take *cdb, not *cmd (nab: Fix bogus struct file assignments in fd_do_readv and fd_do_writev) Signed-off-by: Andy Grover <agrover@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-22target: Core cleanups from AGrover (round 1)Andy Grover
This patch contains the squashed version of a number of cleanups and minor fixes from Andy's initial series (round 1) for target core this past spring. The condensed log looks like: target: use errno values instead of returning -1 for everything target: Rename transport_calc_sg_num to transport_init_task_sg target: Fix leak in error path in transport_init_task_sg target/pscsi: Remove pscsi_get_sh() usage target: Make two runtime checks into WARN_ONs target: Remove hba queue depth and convert to spin_lock_irq usage target: dev->dev_status_queue_obj is unused target: Make struct se_queue_req.cmd type struct se_cmd * target: Remove __transport_get_qr_from_queue() target: Rename se_dev->g_se_dev_list to se_dev_node target: Remove struct se_global target: Simplify scsi mib index table code target: Make dev_queue_obj a member of se_device instead of a pointer target: remove extraneous returns at end of void functions target: Ensure transport_dump_vpd_ident_type returns null-terminated str target: Function pointers don't need to use '&' to be assigned target: Fix comment in __transport_execute_tasks() target: Misc style cleanups target: rename struct pr_reservation_template to pr_reservation target: Remove #defines that just perform indirection target: Inline transport_get_task_from_execute_queue() target: Minor header comment fixes Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-03-23[SCSI] target: Minor sparse warning fixes and annotationsDan Carpenter
This patch addresses the majority of sparse warnings and adds proper locking annotations. It also fixes the dubious one-bit signed bitfield, for which the signed one-bit types can be 0 or -1 which can cause a problem if someone ever checks if (foo->lu_gp_assoc == 1). The current code is fine because everyone just checks zero vs non-zero. But Sparse complains about it so lets change it. The warnings look like this: include/target/target_core_base.h:228:26: error: dubious one-bit signed bitfield Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
