[ Upstream commit ed1227e080990ffec5bf39006ec8a57358e6689a ]
This patch fixes the following bugs:
1. If there are multiple ordered cmds queued and multiple simple cmds
completing, target_restart_delayed_cmds() could be called on different
CPUs and each instance could start a ordered cmd. They could then run in
different orders than they were queued.
2. target_restart_delayed_cmds() and target_handle_task_attr() can race
where:
1. target_handle_task_attr() has passed the simple_cmds == 0 check.
2. transport_complete_task_attr() then decrements simple_cmds to 0.
3. transport_complete_task_attr() runs target_restart_delayed_cmds() and
it does not see any cmds on the delayed_cmd_list.
4. target_handle_task_attr() adds the cmd to the delayed_cmd_list.
The cmd will then end up timing out.
3. If we are sent > 1 ordered cmds and simple_cmds == 0, we can execute
them out of order, because target_handle_task_attr() will hit that
simple_cmds check first and return false for all ordered cmds sent.
4. We run target_restart_delayed_cmds() after every cmd completion, so if
there is more than 1 simple cmd running, we start executing ordered cmds
after that first cmd instead of waiting for all of them to complete.
5. Ordered cmds are not supposed to start until HEAD OF QUEUE and all older
cmds have completed, and not just simple.
6. It's not a bug but it doesn't make sense to take the delayed_cmd_lock
for every cmd completion when ordered cmds are almost never used. Just
replacing that lock with an atomic increases IOPs by up to 10% when
completions are spread over multiple CPUs and there are multiple
sessions/ mqs/thread accessing the same device.
This patch moves the queued delayed handling to a per device work to
serialze the cmd executions for each device and adds a new counter to track
HEAD_OF_QUEUE and SIMPLE cmds. We can then check the new counter to
determine when to run the work on the completion path.
Link: https://lore.kernel.org/r/20210930020422.92578-3-michael.christie@oracle.com
Signed-off-by: Mike Christie <michael.christie@oracle.com>
[ Upstream commit 515da6f4295c2c42b8c54572cce3d2dd1167c41e ]
On realtime kernels, spin_lock_irq*(spinlock_t) do not disable the
interrupts, a call to irqs_disabled() will return false thus firing a
warning in __transport_wait_for_tasks().
Remove the warning and also replace assert_spin_locked() with
lockdep_assert_held()
Link: https://lore.kernel.org/r/20210531121326.3649-1-mlombard@redhat.com
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
[ Upstream commit 1c73e0c5e54d5f7d77f422a10b03ebe61eaed5ad ]
TCM doesn't properly handle underflow case for service actions. One way to
prevent it is to always complete command with
target_complete_cmd_with_length(), however it requires access to data_sg,
which is not always available.
This change introduces target_set_cmd_data_length() function which allows
to set command data length before completing it.
Link: https://lore.kernel.org/r/20210209072202.41154-2-a.miloserdov@yadro.com
Reviewed-by: Roman Bolshakov <r.bolshakov@yadro.com>
Reviewed-by: Bodo Stroesser <bostroesser@gmail.com>
Signed-off-by: Aleksandr Miloserdov <a.miloserdov@yadro.com>
[ Upstream commit 3c006c7d23aac928279f7cbe83bbac4361255d53 ]
transport_init_session can allocate memory via percpu_ref_init, and
target_xcopy_release_pt never frees it. This adds a
transport_uninit_session function to handle cleanup of resources allocated
in the init function.
Link: https://lore.kernel.org/r/1593654203-12442-3-git-send-email-michael.christie@oracle.com
commit f2e6b75f6ee82308ef7b00f29e71e5f1c6b3d52a upstream.
Testing with Loopback I found that, after a Loopback LUN has executed a
TMR, I can no longer unlink the LUN. The rm command hangs in
transport_clear_lun_ref() at wait_for_completion(&lun->lun_shutdown_comp)
The reason is, that transport_lun_remove_cmd() is not called at the end of
target_tmr_work().
It seems, that in other fabrics this call happens implicitly when the
fabric drivers call transport_generic_free_cmd() during their
->queue_tm_rsp().
Unfortunately Loopback seems to not comply to the common way
of calling transport_generic_free_cmd() from ->queue_*().
Instead it calls transport_generic_free_cmd() from its
->check_stop_free() only.
But the ->check_stop_free() is called by
transport_cmd_check_stop_to_fabric() after it has reset the se_cmd->se_lun
pointer. Therefore the following transport_generic_free_cmd() skips the
transport_lun_remove_cmd().
So this patch re-adds the transport_lun_remove_cmd() at the end of
target_tmr_work(), which was removed during commit 2c9fa49e100f ("scsi:
target/core: Make ABORT and LUN RESET handling synchronous").
For fabrics using transport_generic_free_cmd() in the usual way the double
call to transport_lun_remove_cmd() doesn't harm, as
transport_lun_remove_cmd() checks for this situation and does not release
lun_ref twice.
Link: https://lore.kernel.org/r/20200513153443.3554-1-bstroesser@ts.fujitsu.com
Fixes: 2c9fa49e100f ("scsi: target/core: Make ABORT and LUN RESET handling synchronous")
Cc: stable@vger.kernel.org
Tested-by: Bryant G. Ly <bryangly@gmail.com>
Reviewed-by: Bart van Assche <bvanassche@acm.org>
Signed-off-by: Bodo Stroesser <bstroesser@ts.fujitsu.com>
commit c14335ebb92a98646ddbf447e6cacc66de5269ad upstream.
Commit 83f85b8ec305 postponed the percpu_ref_put(&se_cmd->se_lun->lun_ref)
call from command completion to the time when the final command reference
is dropped. That approach is not compatible with the iSCSI target driver
because the iSCSI target driver keeps the command with the highest stat_sn
after it has completed until the next command is received (see also
iscsit_ack_from_expstatsn()). Fix this regression by reverting commit
83f85b8ec305.
Fixes: 83f85b8ec305 ("scsi: target/core: Inline transport_lun_remove_cmd()")
Cc: Pavel Zakharov <pavel.zakharov@delphix.com>
Cc: Mike Christie <mchristi@redhat.com>
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200210051202.12934-1-bvanassche@acm.org
Reported-by: Pavel Zakharov <pavel.zakharov@delphix.com>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit 80647a89eaf3f2549741648f3230cd6ff68c23b4 ]
The SCSI specs require releasing SPC-2 reservations when a session is
closed. Make sure that the target core does this.
Running the libiscsi tests triggers the KASAN complaint shown below. This
patch fixes that use-after-free.
BUG: KASAN: use-after-free in target_check_reservation+0x171/0x980 [target_core_mod]
Read of size 8 at addr ffff88802ecd1878 by task iscsi_trx/17200
CPU: 0 PID: 17200 Comm: iscsi_trx Not tainted 5.4.0-rc1-dbg+ #1
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x8a/0xd6
print_address_description.constprop.0+0x40/0x60
__kasan_report.cold+0x1b/0x34
kasan_report+0x16/0x20
__asan_load8+0x58/0x90
__target_execute_cmd+0xb1/0xf0 [target_core_mod]
target_execute_cmd+0x22d/0x4d0 [target_core_mod]
transport_generic_new_cmd+0x31f/0x5b0 [target_core_mod]
transport_handle_cdb_direct+0x6f/0x90 [target_core_mod]
iscsit_execute_cmd+0x381/0x3f0 [iscsi_target_mod]
iscsit_sequence_cmd+0x13b/0x1f0 [iscsi_target_mod]
iscsit_process_scsi_cmd+0x4c/0x130 [iscsi_target_mod]
iscsit_get_rx_pdu+0x8e8/0x15f0 [iscsi_target_mod]
iscsi_target_rx_thread+0x105/0x1b0 [iscsi_target_mod]
kthread+0x1bc/0x210
ret_from_fork+0x24/0x30
Allocated by task 1079:
save_stack+0x23/0x90
__kasan_kmalloc.constprop.0+0xcf/0xe0
kasan_slab_alloc+0x12/0x20
kmem_cache_alloc+0xfe/0x3a0
transport_alloc_session+0x29/0x80 [target_core_mod]
iscsi_target_login_thread+0xceb/0x1920 [iscsi_target_mod]
kthread+0x1bc/0x210
Freed by task 17193:
__kasan_slab_free+0x13a/0x190
kasan_slab_free+0x12/0x20
kmem_cache_free+0xc8/0x3e0
transport_free_session+0x179/0x2f0 [target_core_mod]
transport_deregister_session+0x121/0x170 [target_core_mod]
iscsit_close_session+0x12c/0x350 [iscsi_target_mod]
iscsit_logout_post_handler+0x136/0x380 [iscsi_target_mod]
iscsit_response_queue+0x8fa/0xc00 [iscsi_target_mod]
iscsi_target_tx_thread+0x28e/0x390 [iscsi_target_mod]
kthread+0x1bc/0x210
The buggy address belongs to the object at ffff88802ecd1860
which belongs to the cache se_sess_cache of size 352
The buggy address is located 24 bytes inside of
352-byte region [ffff88802ecd1860, ffff88802ecd19c0)
The buggy address belongs to the page:
page:ffffea0000bb3400 refcount:1 mapcount:0 mapping:ffff8880bef2ed00 index:0x0 compound_mapcount: 0
flags: 0x1000000000010200(slab|head)
raw: 1000000000010200 dead000000000100 dead000000000122 ffff8880bef2ed00
raw: 0000000000000000 0000000080270027 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff88802ecd1700: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88802ecd1780: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff88802ecd1800: fb fb fb fb fc fc fc fc fc fc fc fc fb fb fb fb
ffff88802ecd1880: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff88802ecd1900: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Link: https://lore.kernel.org/r/20191113220508.198257-2-bvanassche@acm.org
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
Introduce a function that sends the SCSI status "BUSY" back to the
initiator. The next patch will add a call to this function in the srpt
target driver.
Reviewed-by: Hannes Reinecke <hare@suse.com>
Cc: Nicholas Bellinger <nab@linux-iscsi.org>
Remove the code that clears .se_lun from transport_cmd_check_stop_to_fabric()
such that the transport_lun_remove_cmd() call can be moved into
target_release_cmd_kref(). Because this guarantees that
transport_lun_remove_cmd() will be called exactly once, it is safe to change
the cmpxchg() call into a test of se_cmd.lun_ref_active. Inline
transport_lun_remove_cmd() because it is not worth to keep it as a separate
function.
Whether or not a session is being torn down does not affect whether or not
SCSI commands are in the task set. Hence remove the "tearing down" checks
from the TMF code. The TRANSPORT_ISTATE_PROCESSING check is left out
because it is now safe to wait for a command that is in that state. The
CMD_T_PRE_EXECUTE is left out because abort processing is postponed until
after commands have left the pre-execute state since the patch that makes
TMF processing synchronous.
See also commit 1c21a48055a6 ("target: Avoid early CMD_T_PRE_EXECUTE
failures during ABORT_TASK").
Cc: Hannes Reinecke <hare@suse.de>
Pull SCSI updates from James Bottomley:
"This is mostly update of the usual drivers: smarpqi, lpfc, qedi,
megaraid_sas, libsas, zfcp, mpt3sas, hisi_sas.
Additionally, we have a pile of annotation, unused variable and minor
updates.
The big API change is the updates for Christoph's DMA rework which
include removing the DISABLE_CLUSTERING flag.
And finally there are a couple of target tree updates"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (259 commits)
scsi: isci: request: mark expected switch fall-through
scsi: isci: remote_node_context: mark expected switch fall-throughs
scsi: isci: remote_device: Mark expected switch fall-throughs
scsi: isci: phy: Mark expected switch fall-through
scsi: iscsi: Capture iscsi debug messages using tracepoints
scsi: myrb: Mark expected switch fall-throughs
scsi: megaraid: fix out-of-bound array accesses
scsi: mpt3sas: mpt3sas_scsih: Mark expected switch fall-through
scsi: fcoe: remove set but not used variable 'port'
scsi: smartpqi: call pqi_free_interrupts() in pqi_shutdown()
scsi: smartpqi: fix build warnings
scsi: smartpqi: update driver version
scsi: smartpqi: add ofa support
scsi: smartpqi: increase fw status register read timeout
scsi: smartpqi: bump driver version
scsi: smartpqi: add smp_utils support
scsi: smartpqi: correct lun reset issues
scsi: smartpqi: correct volume status
scsi: smartpqi: do not offline disks for transient did no connect conditions
scsi: smartpqi: allow for larger raid maps
memory allocated by kmem_cache_alloc() should be freed using
kmem_cache_free(), not kfree().
Fixes: ad669505c4e9 ("scsi: target/core: Make sure that target_wait_for_sess_cmds() waits long enough")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Due to the "make ABORT and LUN RESET handling synchronous" patch, cmd->work
is only modified from the regular command execution path and no longer
asynchronously by the code that executes task management functions. Since
the regular command execution code is sequential per command, no locking is
required to manipulate cmd->work. Hence stop protecting cmd->work
manipulations with locking.
Cc: David Disseldorp <ddiss@suse.de>
Instead of invoking target driver callback functions from the context that
handles an abort or LUN RESET task management function, only set the abort
flag from that context and perform the actual abort handling from the
context of the regular command processing flow. This approach has the
advantage that the task management code becomes much easier to read and to
verify since the number of potential race conditions against the command
processing flow is strongly reduced.
This patch has been tested by running the following two shell commands
concurrently for about ten minutes for both the iSCSI and the SRP target
drivers ($dev is an initiator device node connected with storage provided
by the target driver under test):
* fio with data verification enabled on a filesystem mounted on top of
$dev.
* while true; do sg_reset -d $dev; echo -n .; sleep .1; done
The TASK ABORTED STATUS (TAS) bit is defined as follows in SAM:
"TASK_ABORTED: this status shall be returned if a command is aborted by a
command or task management function on another I_T nexus and the control
mode page TAS bit is set to one". TAS handling is spread over the target
core and the iSCSI target driver. If a LUN RESET is received, the target
core will send the TASK_ABORTED response for all commands for which such a
response has to be sent. If an ABORT TASK is received, only the iSCSI
target driver will send the TASK_ABORTED response for the commands for
which that response has to be sent. That is a bug since all target drivers
have to honor the TAS bit. Fix this by moving the code that handles TAS
from the iSCSI target driver into the target core. Additionally, if a
command has been aborted, instead of sending the TASK_ABORTED status from
the context that processes the SCSI command send it from the context of the
ABORT TMF. The core_tmr_abort_task() change in this patch causes the
CMD_T_TAS flag to be set if a TASK_ABORTED status has to be sent back to
the initiator that submitted the command. If that flag has been set
transport_cmd_finish_abort() will send the TASK_ABORTED response.
Instead of allowing the code that aborts a SCSI command to finish before
all iSCSI data frames have been received, make that code wait until all
iSCSI data frames have been received. Introduce a new member variable in
the target driver template to communicate that information from the iSCSI
target driver to the target core. This change allows to leave out the check
whether or not it is already safe to send the TASK_ABORTED reply from
transport_send_task_abort().
command completion
This patch does not change any functionality but makes the patch that makes
TMF handling synchronous easier to read.
A quote from SAM-5: "The order in which task management requests are
processed is not specified by the SCSI architecture model. The SCSI
architecture model does not require in-order delivery of such task
management requests or processing by the task manager in the order
received. To guarantee the processing order of task management requests
referencing sent to a specific logical unit, an application client should
not have more than one such task management request pending to that logical
unit." This means that it is safe to use the system workqueues instead of
tmr_wq for processing TMFs. An intended side effect of this patch is that
it enables concurrent processing of TMFs.
A session must only be released after all code that accesses the session
structure has finished. Make sure that this is the case by introducing a
new command counter per session that is only decremented after the
.release_cmd() callback has finished. This patch fixes the following crash:
BUG: KASAN: use-after-free in do_raw_spin_lock+0x1c/0x130
Read of size 4 at addr ffff8801534b16e4 by task rmdir/14805
CPU: 16 PID: 14805 Comm: rmdir Not tainted 4.18.0-rc2-dbg+ #5
Call Trace:
dump_stack+0xa4/0xf5
print_address_description+0x6f/0x270
kasan_report+0x241/0x360
__asan_load4+0x78/0x80
_raw_spin_lock_irqsave+0x52/0x60
srpt_set_ch_state+0x27/0x70 [ib_srpt]
srpt_disconnect_ch+0x1b/0xc0 [ib_srpt]
srpt_close_session+0xa8/0x260 [ib_srpt]
target_shutdown_sessions+0x170/0x180 [target_core_mod]
core_tpg_del_initiator_node_acl+0xf3/0x200 [target_core_mod]
target_fabric_nacl_base_release+0x25/0x30 [target_core_mod]
config_item_release+0x9c/0x110 [configfs]
config_item_put+0x26/0x30 [configfs]
configfs_rmdir+0x3b8/0x510 [configfs]
vfs_rmdir+0xb3/0x1e0
do_rmdir+0x262/0x2c0
do_syscall_64+0x77/0x230
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Since transport_clear_lun_ref() already waits until the percpu-refcount
.release() method is called, it is not necessary to wait first until
percpu_ref_kill_and_confirm() has finished transitioning the refcount into
atomic mode. Remove the code that waits for percpu_ref_kill_and_confirm()
to complete and also the completion object that is used by that code. This
patch does not change the behavior of the SCSI target code.
This patch does not change any functionality. Note: the code that frees
sess_cmd_map already uses kvfree() so that code does not need to be
modified.
Reviewed-by: David Disseldorp <ddiss@suse.de>
All fabrics return a const string. In all cases *except* iSCSI the
get_fabric_name() string matches fabric_ops.name.
Both fabric_ops.get_fabric_name() and fabric_ops.name are user-facing, with
the former being used for PR/ALUA state and the latter for ConfigFS
(config/target/$name), so we unfortunately need to keep both strings around
for now. Replace the useless .get_fabric_name() accessor function with a
const string fabric_name member variable.
Signed-off-by: David Disseldorp <ddiss@suse.de>
WRITE fails
Fixes: aa73237dcb2d ("scsi: target/core: Always call transport_complete_callback() upon failure")
If, for example, I don't enable CONFIG_TCM_PSCSI, then every time I load
the target subsystem, I get an annoying
Unable to load target_core_pscsi
kernel log message. Instead let's only request_module() on things if
that code is enabled.
Signed-off-by: Roland Dreier <roland@purestorage.com>
COMPARE AND WRITE command execution starts with a call of
sbc_compare_and_write(). That function locks the caw_sem member in the
backend device data structure and submits a read request to the backend
driver. Upon successful completion of the read compare_and_write_callback()
gets called. That last function compares the data that has been read. If it
matches transport_complete_callback is set to compare_and_write_post and a
write request is submitted. compare_and_write_post() submits a write request
to the backend driver.
XDWRITEREAD command execution starts with sbc_execute_rw() submitting a
read to the backend device. Upon successful completion of the read the
xdreadwrite_callback() gets called. That function xors the data that has
been read with the data in the data-out buffer and stores the result in
the data-in buffer.
Call transport_complete_callback() not only if COMPARE AND WRITE fails but
also if XDWRITEREAD fails. This makes the code more systematic. Make sure
that the callback functions handle (cmd, false, NULL) argument triples fine.
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
Change one occurrence of "aleady" into "already" and one occurrence of
"is" into "if".
With the addition of commit 00d909a10710 ("scsi: target: Make the session
shutdown code also wait for commands that are being aborted") in v4.19-rc, it
incorrectly assumes no signals will be pending for task_struct executing the
normal session shutdown and I/O quiesce code-path.
For example, iscsi-target and iser-target issue SIGINT to all kthreads as part
of session shutdown. This has been the behaviour since day one.
As-is when signals are pending with se_cmds active in se_sess->sess_cmd_list,
wait_event_interruptible_lock_irq_timeout() returns a negative number and
immediately kills the machine because of the do while (ret <= 0) loop that was
added in commit 00d909a107 to spin while backend I/O is taking any amount of
extended time (say 30 seconds) to complete.
Here's what it looks like in action with debug plus delayed backend I/O
completion:
[ 4951.909951] se_sess: 000000003e7e08fa before target_wait_for_sess_cmds
[ 4951.914600] target_wait_for_sess_cmds: signal_pending: 1
[ 4951.918015] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 0
[ 4951.921639] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 1
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 2
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 3
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 4
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 5
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 6
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 7
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 8
[ 4951.921944] wait_event_interruptible_lock_irq_timeout ret: -512 signal_pending: 1 loop count: 9
... followed by the usual RCU CPU stalls and deadlock.
There was never a case pre commit 00d909a107 where
wait_for_complete(&se_cmd->cmd_wait_comp) was able to be interrupted, so to
address this for v4.19+ moving forward go ahead and use
wait_event_lock_irq_timeout() instead so new code works with all fabric
drivers.
Also for commit 00d909a107, fix a minor regression in
target_release_cmd_kref() to only wake_up the new se_sess->cmd_list_wq only
when shutdown has actually been triggered via se_sess->sess_tearing_down.
Fixes: 00d909a10710 ("scsi: target: Make the session shutdown code also wait for commands that are being aborted")
Cc: <stable@vger.kernel.org> # v4.19+
Cc: Bart Van Assche <bvanassche@acm.org>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Tested-by: Nicholas Bellinger <nab@linux-iscsi.org>
Reviewed-by: Bryant G. Ly <bly@catalogicsoftware.com>
This adds a function to remove a session which should be used by drivers
that use target_setup_session. The next patches will convert the target
drivers to use this new function.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Chris Boot <bootc@bootc.net>
Cc: Michael Cyr <mikecyr@linux.vnet.ibm.com>
Cc: <qla2xxx-upstream@qlogic.com>
Cc: Johannes Thumshirn <jth@kernel.org>
Cc: Felipe Balbi <balbi@kernel.org>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Rename target_alloc_session to target_setup_session to avoid confusion with
the other transport session allocation function that only allocates the
session and because the target_alloc_session does so much more. It
allocates the session, sets up the nacl and registers the session.
The next patch will then add a remove function to match the setup in this
one, so it should make sense for all drivers, except iscsi, to just call
those 2 functions to setup and remove a session.
iscsi will continue to be the odd driver.
transport_init_session_tags is only called from target_core_transport.c so
make it static.
When __transport_register_session is called from transport_register_session
irqs will already have been disabled, so we do not want the unlock irq call
to enable them until the higher level has done the final
spin_unlock_irqrestore/ spin_unlock_irq.
This has __transport_register_session use the save/restore call.
Send a valid ASC / ASCQ combination back to the initiator if a SCSI command
is received after a LUN has been removed. This patch fixes the following
call trace:
WARNING: CPU: 0 PID: 4 at drivers/target/target_core_transport.c:3131 translate_sense_reason+0x164/0x190 [target_core_mod]
Workqueue: ib-comp-wq ib_cq_poll_work [ib_core]
RIP: 0010:translate_sense_reason+0x164/0x190 [target_core_mod]
Call Trace:
transport_send_check_condition_and_sense+0x95/0x1c0 [target_core_mod]
transport_generic_request_failure+0x102/0x270 [target_core_mod]
transport_generic_new_cmd+0x138/0x340 [target_core_mod]
transport_handle_cdb_direct+0x2f/0x80 [target_core_mod]
target_submit_cmd_map_sgls+0x212/0x2a0 [target_core_mod]
srpt_handle_new_iu+0x244/0x680 [ib_srpt]
__ib_process_cq+0x6d/0xc0 [ib_core]
ib_cq_poll_work+0x18/0x50 [ib_core]
process_one_work+0x20b/0x6a0
worker_thread+0x35/0x380
kthread+0x117/0x130
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Mike Christie <mchristi@redhat.com>
small
Instead of embedding the completion that is used for waiting for command
completion in struct se_cmd, let the context that waits for command
completion allocate it. This makes it possible to have a single code path
for non-aborted and aborted commands in target_release_cmd_kref() and
avoids that transport_generic_free_cmd() has to call
cmd->se_tfo->release_cmd() directly. This patch does not change any
functionality. Note: transport_generic_free_cmd() only waits until the
se_cmd reference count has reached zero after it has set both
CMD_T_FABRIC_STOP and CMD_T_ABORTED.
Since target_wait_free_cmd() skips TMFs with no associated LUN, it is safe
to call that function for such commands. Use this to simplify
transport_generic_free_cmd(). The only functional change in this patch is
that CMD_T_FABRIC_STOP gets set for TMFs with no associated LUN by
Move identical code outside an if/else statement. This patch does not
For the two calls to transport_cmd_finish_abort() outside
core_tmr_handle_tas_abort() it is guaranteed that CMD_T_TAS is not set. Use
this property to fold core_tmr_handle_tas_abort() into
transport_cmd_finish_abort(). This patch does not change any functionality.
Document those aspects of transport_cmd_check_stop_to_fabric() and
transport_generic_free_cmd() of which it is nontrivial to derive these from
their implementation.
being aborted
Target drivers must call target_sess_cmd_list_set_waiting() and
target_wait_for_sess_cmds() before freeing a session. Since freeing a
session is only safe after all commands that are associated with a session
have finished, make target_wait_for_sess_cmds() also wait for commands that
are being aborted. Instead of setting a flag in each pending command from
target_sess_cmd_list_set_waiting() and waiting in
target_wait_for_sess_cmds() on a per-command completion, only set a
per-session flag in the former function and wait on a per-session
completion in the latter function. This change is safe because once a SCSI
initiator system has submitted a command a target system is always allowed
to execute it to completion. See also commit 0f4a943168f3 ("target: Fix
remote-port TMR ABORT + se_cmd fabric stop").
This patch is based on the following two patches:
* Bart Van Assche, target: Simplify session shutdown code, February 19, 2015
(https://github.com/bvanassche/linux/commit/8df5463d7d7619f2f1b70cfe5172eaef0aa52815).
* Christoph Hellwig, target: Rework session shutdown code, December 7, 2015
(http://thread.gmane.org/gmane.linux.scsi.target.devel/10695).
Cc: Sagi Grimberg <sagig@mellanox.com>
Other than initializing xcopy_pt_sess.sess_wait_list, this patch does not
This patch does not change any functionality but makes the next patch
easier to read.
The sbitmap and the percpu_ida perform essentially the same task,
allocating tags for commands. The sbitmap outperforms the percpu_ida as
documented here: https://lkml.org/lkml/2014/4/22/553
The sbitmap interface is a little harder to use, but being able to remove
the percpu_ida code and getting better performance justifies the additional
complexity.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> # f_tcm
Reviewed-by: Jens Axboe <axboe@kernel.dk>
The vzalloc() function has no 2-factor argument form, so multiplication
factors need to be wrapped in array_size(). This patch replaces cases of:
vzalloc(a * b)
with:
vzalloc(array_size(a, b))
as well as handling cases of:
vzalloc(a * b * c)
with:
vzalloc(array3_size(a, b, c))
This does, however, attempt to ignore constant size factors like:
vzalloc(4 * 1024)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
vzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
vzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
vzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(u8) * COUNT
+ COUNT
vzalloc(
- sizeof(__u8) * COUNT
+ COUNT
vzalloc(
- sizeof(char) * COUNT
+ COUNT
vzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
vzalloc(
- sizeof(TYPE) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_ID
vzalloc(
- sizeof(TYPE) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_CONST
vzalloc(
- sizeof(THING) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_ID
vzalloc(
- sizeof(THING) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
vzalloc(
- SIZE * COUNT
+ array_size(COUNT, SIZE)
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
vzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
vzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
vzalloc(
- sizeof(TYPE) * COUNT * STRIDE
vzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
vzalloc(
- sizeof(THING) * (COUNT) * STRIDE
vzalloc(
- sizeof(THING) * COUNT * (STRIDE)
vzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
vzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
vzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
vzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
vzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
vzalloc(
- COUNT * (STRIDE) * SIZE
vzalloc(
- COUNT * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * SIZE
vzalloc(
- COUNT * (STRIDE) * (SIZE)
vzalloc(
- (COUNT) * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * (SIZE)
vzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
vzalloc(C1 * C2 * C3, ...)
vzalloc(
- E1 * E2 * E3
+ array3_size(E1, E2, E3)
// And then all remaining 2 factors products when they're not all constants.
expression E1, E2;
constant C1, C2;
vzalloc(C1 * C2, ...)
vzalloc(
- E1 * E2
+ array_size(E1, E2)
The kzalloc() function has a 2-factor argument form, kcalloc(). This
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
kzalloc(4 * 1024, gfp)
type TYPE;
kzalloc(
+ sizeof(TYPE) * E
kzalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
type TYPE;
expression THING;
- kzalloc
+ kcalloc
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
// Any remaining multi-factor products, first at least 3-factor products,
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
Trivial fix to spelling mistake in pr_err message text.
When a tape drive is exported via LIO using the pscsi module, a read
that requests more bytes per block than the tape can supply returns an
empty buffer. This is because the pscsi pass-through target module sees
the "ILI" illegal length bit set and thinks there is no reason to return
the data.
This is a long-standing transport issue, since it assumes that no data
need be returned under a check condition, which isn't always the case
for tape.
Add in a check for tape reads with the ILI, EOM, or FM bits set, with a
sense code of NO_SENSE, treating such cases as if the read
succeeded. The layered tape driver then "does the right thing" when it
gets such a response.
Signed-off-by: Lee Duncan <lduncan@suse.com>
For exported functions that already have near-kernel-doc notation,
fix them to begin with "/**" and make a few corrections so that they
don't have any kernel-doc warnings.
To: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: linux-scsi@vger.kernel.org
Cc: target-devel@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Jonathan Corbet <corbet@lwn.net>
