The libfc stack assigns exchange IDs based on the CPU the request
was received on, so we need to send the responses via the same CPU.
Otherwise the send logic gets confuses and responses will be delayed,
causing exchange timeouts on the initiator side.
Signed-off-by: Hannes Reinecke <hare@suse.com>
Cc: stable@vger.kernel.org # 4.5+
Update the debug statements to match those from libfc.
Not every failure is due to out-of-memory; the ACLs might not be
set, too. So return a detailed error code in ft_sess_create()
instead of just a NULL pointer.
When allocating a new command we should add the pointer to the
debug statements; that allows us to match this with other debug
statements for handling data.
When registering and unregistering as an target port we should
be setting the FC-4 service params correctly.
Turns out the template and thus many drivers got the return value wrong:
0 means the fabrics driver needs to put a session reference, which no
driver except for the iSCSI target drivers did. Fortunately none of these
drivers supports explicit Node ACLs, so the bug was harmless.
Even without that only qla2xxx and iscsi every did real work in
shutdown_session, so get rid of the boilerplate code in all other
drivers.
This patch converts tcm_fc to modern TARGET_SCF_ACK_KREF
usage for ft_queue_status(), and fixes ft_check_stop_free()
to return transport_generic_free_cmd() for ->cmd_kref.
It also converts TM request -> ft_send_tm() to use ACK_KREF,
and update ft_queue_tm_resp() to drop the outstanding kref
after queueing TM response into fabric code.
Cc: Vasu Dev <vasu.dev@linux.intel.com>
Cc: Mark Rustad <mark.d.rustad@intel.com>
Cc: Robert Love <robert.w.love@intel.com>
This patch converts tcm_fc target mode addition of tf_sess->hash to
port_id hlist_head using the new alloc_session callback().
This patch does a simple conversion of tcm_fc code to use
proper modern core_tpg_get_initiator_node_acl() lookup using
se_node_acl->acl_kref, and drops the legacy list walk from
ft_acl_get().
Note the original lookup also took node_name into account,
but since ft_init_nodeacl() only ever sets port_name for
se_node_acl->acl_group within configfs, this is purely
a mechanical change.
As per HCH, go ahead and fold ft_acl_get() into original
caller.
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
This patch avoids that the following kernel crash can occur with
later patches in this patch series:
general protection fault: 0000 [#1] SMP
CPU: 0 PID: 6 Comm: kworker/u8:0 Not tainted 4.3.0-rc1-debug+ #1
Workqueue: tmr-fileio target_tmr_work [target_core_mod]
Call Trace:
[<ffffffff810a6915>] lock_acquire+0x65/0x90
[<ffffffff815e740b>] _raw_spin_lock_irqsave+0x4b/0x60
[<ffffffffa03bc7ca>] target_release_cmd_kref+0x2a/0xa0 [target_core_mod]
[<ffffffffa03bd418>] target_put_sess_cmd+0x28/0x50 [target_core_mod]
[<ffffffffa03bad50>] core_tmr_lun_reset+0x390/0x640 [target_core_mod]
[<ffffffffa03bce50>] target_tmr_work+0x80/0xd0 [target_core_mod]
[<ffffffff81070e6d>] process_one_work+0x19d/0x430
[<ffffffff8107120f>] worker_thread+0x10f/0x460
[<ffffffff810772ba>] kthread+0xea/0x100
[<ffffffff815e7a2f>] ret_from_fork+0x3f/0x70
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Add the 'tag' attribute to FC node ACLs. This is not used by kernel code,
but gives userspace a place to store a tag string. This is used to provide
support for initiator groups in targetcli.
Just copy iscsi's implementation for tcm_fc. A few other fabrics that
support acls also need this, to be submitted separately after the holidays.
Signed-off-by: Andy Grover <agrover@redhat.com>
Use offset_in_page macro instead of (addr & ~PAGE_MASK).
Signed-off-by: Geliang Tang <geliangtang@163.com>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
This also allows to remove the target-specific old configfs macros, and
gets rid of the target_core_fabric_configfs.h header which only had one
function declaration left that could be moved to a better place.
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
Acked-by: Nicholas Bellinger <nab@linux-iscsi.org>
IS_ERR(_OR_NULL) already contain an 'unlikely' compiler flag and there
is no need to do that again from its callers. Drop it.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"It's been a busy development cycle for target-core in a number of
different areas.
The fabric API usage for se_node_acl allocation is now within
target-core code, dropping the external API callers for all fabric
drivers tree-wide.
There is a new conversion to RCU hlists for se_node_acl and
se_portal_group LUN mappings, that turns fast-past LUN lookup into a
completely lockless code-path. It also removes the original
hard-coded limitation of 256 LUNs per fabric endpoint.
The configfs attributes for backends can now be shared between core
and driver code, allowing existing drivers to use common code while
still allowing flexibility for new backend provided attributes.
The highlights include:
- Merge sbc_verify_dif_* into common code (sagi)
- Remove iscsi-target support for obsolete IFMarker/OFMarker
(Christophe Vu-Brugier)
- Add bidi support in target/user backend (ilias + vangelis + agover)
- Move se_node_acl allocation into target-core code (hch)
- Add crc_t10dif_update common helper (akinobu + mkp)
- Handle target-core odd SGL mapping for data transfer memory
(akinobu)
- Move transport ID handling into target-core (hch)
- Move task tag into struct se_cmd + support 64-bit tags (bart)
- Convert se_node_acl->device_list[] to RCU hlist (nab + hch +
paulmck)
- Convert se_portal_group->tpg_lun_list[] to RCU hlist (nab + hch +
paulmck)
- Simplify target backend driver registration (hch)
- Consolidate + simplify target backend attribute implementations
(hch + nab)
- Subsume se_port + t10_alua_tg_pt_gp_member into se_lun (hch)
- Drop lun_sep_lock for se_lun->lun_se_dev RCU usage (hch + nab)
- Drop unnecessary core_tpg_register TFO parameter (nab)
- Use 64-bit LUNs tree-wide (hannes)
- Drop left-over TARGET_MAX_LUNS_PER_TRANSPORT limit (hannes)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (76 commits)
target: Bump core version to v5.0
target: remove target_core_configfs.h
target: remove unused TARGET_CORE_CONFIG_ROOT define
target: consolidate version defines
target: implement WRITE_SAME with UNMAP bit using ->execute_unmap
target: simplify UNMAP handling
target: replace se_cmd->execute_rw with a protocol_data field
target/user: Fix inconsistent kmap_atomic/kunmap_atomic
target: Send UA when changing LUN inventory
target: Send UA upon LUN RESET tmr completion
target: Send UA on ALUA target port group change
target: Convert se_lun->lun_deve_lock to normal spinlock
target: use 'se_dev_entry' when allocating UAs
target: Remove 'ua_nacl' pointer from se_ua structure
target_core_alua: Correct UA handling when switching states
xen-scsiback: Fix compile warning for 64-bit LUN
target: Remove TARGET_MAX_LUNS_PER_TRANSPORT
target: use 64-bit LUNs
target: Drop duplicate + unused se_dev_check_wce
target: Drop unnecessary core_tpg_register TFO parameter
This patch drops unnecessary target_core_fabric_ops parameter usage
for core_tpg_register() during fabric driver TFO->fabric_make_tpg()
se_portal_group creation callback execution.
Instead, use the existing se_wwn->wwn_tf->tf_ops pointer to ensure
fabric driver is really using the same TFO provided at module_init
time.
Also go ahead and drop the forward TFO declarations tree-wide, and
handling the special case for iscsi-target discovery TPG.
Reviewed-by: Hannes Reinecke <hare@suse.de>
Only include SCSI initiator header files in target code that needs
these header files, namely the SCSI pass-through code and the tcm_loop
driver. Change SCSI_SENSE_BUFFERSIZE into TRANSPORT_SENSE_BUFFER in
target code because the former is intended for initiator code and the
latter for target code. With this patch the only initiator include
directives in target code that remain are as follows:
$ git grep -nHE 'include .scsi/(scsi.h|scsi_host.h|scsi_device.h|scsi_cmnd.h)' drivers/target drivers/infiniband/ulp/{isert,srpt} drivers/usb/gadget/legacy/tcm_*.[ch] drivers/{vhost,xen} include/{target,trace/events/target.h}
drivers/target/loopback/tcm_loop.c:29:#include <scsi/scsi.h>
drivers/target/loopback/tcm_loop.c:31:#include <scsi/scsi_host.h>
drivers/target/loopback/tcm_loop.c:32:#include <scsi/scsi_device.h>
drivers/target/loopback/tcm_loop.c:33:#include <scsi/scsi_cmnd.h>
drivers/target/target_core_pscsi.c:39:#include <scsi/scsi_device.h>
drivers/target/target_core_pscsi.c:40:#include <scsi/scsi_host.h>
drivers/xen/xen-scsiback.c:52:#include <scsi/scsi_host.h> /* SG_ALL */
Signed-off-by: James Bottomley <JBottomley@Odin.com>
This patch converts se_tpg->acl_node_lock to struct mutex, so that
->acl_node_acl walkers in core_clear_lun_from_tpg() can block when
calling core_disable_device_list_for_node().
It also updates core_dev_add_lun() to hold ->acl_node_mutex when
calling core_tpg_add_node_to_devs() to build ->lun_entry_hlist
for dynamically generated se_node_acl.
Simplify target core and target drivers by storing the task tag
a.k.a. command identifier inside struct se_cmd.
For several transports (e.g. SRP) tags are 64 bits wide.
Hence add support for 64-bit tags.
(Fix core_tmr_abort_task conversion spec warnings - nab)
(Fix up usb-gadget to use 16-bit tags - HCH + bart)
Cc: <qla2xxx-upstream@qlogic.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Now that struct se_portal_group contains a protocol identifier field we can
take all the code to format an parse protocol identifiers in CDBs into common
code instead of leaving this to low-level drivers.
Now that we store the protocol identifier in the tpg structure we don't
need this method.
Remove the unneeded fabric_ptr argument, and change the type argument
to pass in a SPC protocol identifier.
By always allocating and adding, respectively removing and freeing
the se_node_acl structure in core code we can remove tons of repeated
code in the init_nodeacl and drop_nodeacl routines. Additionally
this now respects the get_default_queue_depth method in this code
path as well.
All fabric drivers except for iSCSI always return 1, so implement
that as default behavior.
"Lots of activity in target land the last months.
- Convert fabric drivers tree-wide to target_register_template() (hch
+ bart)
- iser-target hardening fixes + v1.0 improvements (sagi)
- Convert iscsi_thread_set usage to kthread.h + kill
iscsi_target_tq.c (sagi + nab)
- Add support for T10-PI WRITE_STRIP + READ_INSERT operation (mkp +
sagi + nab)
- DIF fixes for CONFIG_DEBUG_SG=y + UNMAP file emulation (akinobu +
sagi + mkp)
- Extended TCMU ABI v2 for future BIDI + DIF support (andy + ilias)
- Fix COMPARE_AND_WRITE handling for NO_ALLLOC drivers (hch + nab)
Thanks to everyone who contributed this round with new features,
bug-reports, fixes, cleanups and improvements.
Looking forward, it's currently shaping up to be a busy v4.2 as well"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (69 commits)
target: Put TCMU under a new config option
target: Version 2 of TCMU ABI
target: fix tcm_mod_builder.py
target/file: Fix UNMAP with DIF protection support
target/file: Fix SG table for prot_buf initialization
target/file: Fix BUG() when CONFIG_DEBUG_SG=y and DIF protection enabled
target: Make core_tmr_abort_task() skip TMFs
target/sbc: Update sbc_dif_generate pr_debug output
target/sbc: Make internal DIF emulation honor ->prot_checks
target/sbc: Return INVALID_CDB_FIELD if DIF + sess_prot_type disabled
target: Ensure sess_prot_type is saved across session restart
target/rd: Don't pass incomplete scatterlist entries to sbc_dif_verify_*
target: Remove the unused flag SCF_ACK_KREF
target: Fix two sparse warnings
target: Fix COMPARE_AND_WRITE with SG_TO_MEM_NOALLOC handling
target: simplify the target template registration API
target: simplify target_xcopy_init_pt_lun
target: remove the unused SCF_CMD_XCOPY_PASSTHROUGH flag
target/rd: reduce code duplication in rd_execute_rw()
tcm_loop: fixup tpgt string to integer conversion
Instead of calling target_fabric_configfs_init() +
target_fabric_configfs_register() / target_fabric_configfs_deregister()
target_fabric_configfs_free() from every target driver, rewrite the API
so that we have simple register/unregister functions that operate on
a const operations vector.
This patch also fixes a memory leak in several target drivers. Several
target drivers namely called target_fabric_configfs_deregister()
without calling target_fabric_configfs_free().
A large part of this patch is based on earlier changes from
Bart Van Assche <bart.vanassche@sandisk.com>.
(v2: Add a new TF_CIT_SETUP_DRV macro so that the core configfs code
can declare attributes as either core only or for drivers)
This patch adds a missing set of conditional check braces in
ft_invl_hw_context() originally introduced by commit dcd998ccd
when handling DDP failures in ft_recv_write_data() code.
commit dcd998ccdbf74a7d8fe0f0a44e85da1ed5975946
Author: Kiran Patil <kiran.patil@intel.com>
Date: Wed Aug 3 09:20:01 2011 +0000
tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data
Cc: Kiran Patil <kiran.patil@intel.com>
Cc: <stable@vger.kernel.org> # 3.1+
For SPI drivers use the message definitions from scsi.h, and for target
drivers introduce a new TCM_*_TAG namespace.
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com
The use of "rcu_assign_pointer()" is NULLing out the pointer.
According to RCU_INIT_POINTER()'s block comment:
"1. This use of RCU_INIT_POINTER() is NULLing out the pointer"
it is better to use it instead of rcu_assign_pointer() because it has a
smaller overhead.
The following Coccinelle semantic patch was used:
- rcu_assign_pointer
+ RCU_INIT_POINTER
(..., NULL)
Signed-off-by: Andreea-Cristina Bernat <bernat.ada@gmail.com>
This patch changes ft_queue_status() to set SAM_STAT_TASK_SET_FULL
status upon lport->tt.seq_send( failure, and return -EAGAIN to notify
target-core to attempt to requeue the response.
It also does the same for a fc_frame_alloc() failures, in order to
signal the initiator that it should try to reduce it's current
queue_depth, to lower the number of outstanding I/Os on the wire.
Reported-by: Vasu Dev <vasu.dev@linux.intel.com>
Reviewed-by: Vasu Dev <vasu.dev@linux.intel.com>
Cc: Jun Wu <jwu@stormojo.com>
This patch changes ft_queue_data_in() to set SAM_STAT_TASK_SET_FULL
status upon a lport->tt.seq_send() failure, where it will now stop
sending subsequent DataIN, and immediately attempt to send the
response with exception status.
Sending a response with SAM_STAT_TASK_SET_FULL status is useful in
order to signal the initiator that it should try to reduce it's
current queue_depth, to lower the number of outstanding I/Os on
the wire.
Also, add a check to skip sending DataIN if TASK_SET_FULL status
has already been set due to a response lport->tt.seq_send()
failure, that has asked target-core to requeue a response.
This patch fixes a free-after-use regression in ft_free_cmd(), where
ft_sess_put() is called with cmd->sess after percpu_ida_free() has
already released the tag.
Fix this bug by saving the ft_sess pointer ahead of percpu_ida_free(),
and pass it directly to ft_sess_put().
The regression was originally introduced in v3.13-rc1 commit:
commit 5f544cfac956971099e906f94568bc3fd1a7108a
Author: Nicholas Bellinger <nab@daterainc.com>
Date: Mon Sep 23 12:12:42 2013 -0700
tcm_fc: Convert to per-cpu command map pre-allocation of ft_cmd
Reported-by: Jun Wu <jwu@stormojo.com>
Cc: <stable@vger.kernel.org> #3.13+
Because it doesn't always create, if there's an existing one it just
returns it.
These functions are not adding or deleting an lport. They are adding a
wwn that may match with an lport that is present on the system.
Renaming ft_del_lport also means we won't have functions named
both ft_del_lport and ft_lport_del any more.
Rename struct ft_lport_acl to ft_lport_wwn. "acl" is associated with
something different in LIO terms. Really, ft_lport_wwn is the
fabric-specific wrapper for the struct se_wwn.
Rename "lacl" local variables to "ft_wwn" as well.
Rename list_heads used as list members to make it clear they're nodes, not
heads.
Rename lport_node to ft_wwn_node.
Rename ft_lport_list to ft_wwn_list
tcm_fc doesn't support multiple TPGs per wwn. For proof, see
ft_lport_find_tpg. Enforce this in the code.
Replace ft_lport_wwn.tpg_list with a single pointer. We can't fold ft_tpg
into ft_lport_wwn because they can have different lifetimes.
Nobody outside tfc_conf.c uses it.
ft_del_tpg checks tpg->tport is set before unlinking the tpg from the
tport when the tpg is being removed. Set this pointer in ft_tport_create,
or the unlinking won't happen in ft_del_tpg and tport->tpg will reference
a deleted object.
This patch sets tpg->tport in ft_tport_create, because that's what
ft_del_tpg checks, and is the only way to get back to the tport to
clear tport->tpg.
The bug was occuring when:
- lport created, tport (our per-lport, per-provider context) is
allocated.
tport->tpg = NULL
- tpg created
- a PRLI is received. ft_tport_create is called, tpg is found and
tport->tpg is set
- tpg removed. ft_tpg is freed in ft_del_tpg. Since tpg->tport was not
set, tport->tpg is not cleared and points at freed memory
- Future calls to ft_tport_create return tport via first conditional,
instead of searching for new tpg by calling ft_lport_find_tpg.
tport->tpg is still invalid, and will access freed memory.
see https://bugzilla.redhat.com/show_bug.cgi?id=1071340
Cc: stable@vger.kernel.org # 3.0+
In order to support local WRITE_INSERT + READ_STRIP operations for
non PI enabled fabrics, the fabric driver needs to be able signal
what protection offload operations are supported.
This is done at session initialization time so the modes can be
signaled by individual se_wwn + se_portal_group endpoints, as well
as optionally across different transports on the same endpoint.
For iser-target, set TARGET_PROT_ALL if the underlying ib_device
has already signaled PI offload support, and allow this to be
exposed via a new iscsit_transport->iscsit_get_sup_prot_ops()
callback.
For loopback, set TARGET_PROT_ALL to signal SCSI initiator mode
operation.
For all other drivers, set TARGET_PROT_NORMAL to disable fabric
level PI.
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Now that TASK_ABORTED status is not generated for all cases by
TMR ABORT_TASK + LUN_RESET, a new TFO->abort_task() caller is
necessary in order to give fabric drivers a chance to unmap
hardware / software resources before the se_cmd descriptor is
released via the normal TFO->release_cmd() codepath.
This patch adds TFO->aborted_task() in core_tmr_abort_task()
in place of the original transport_send_task_abort(), and
also updates all fabric drivers to implement this caller.
The fabric drivers that include changes to perform cleanup
via ->aborted_task() are:
- iscsi-target
- iser-target
- srpt
- tcm_qla2xxx
The fabric drivers that currently set ->aborted_task() to
NOPs are:
- loopback
- tcm_fc
- usb-gadget
- sbp-target
- vhost-scsi
For the latter five, there appears to be no additional cleanup
required before invoking TFO->release_cmd() to release the
se_cmd descriptor.
v2 changes:
- Move ->aborted_task() call into transport_cmd_finish_abort (Alex)
Cc: Alex Leung <amleung21@yahoo.com>
Cc: Roland Dreier <roland@kernel.org>
Cc: Vu Pham <vu@mellanox.com>
Cc: Chris Boot <bootc@bootc.net>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Saurav Kashyap <saurav.kashyap@qlogic.com>
This patch changes percpu_ida_alloc() + callers to accept task state
bitmask for prepare_to_wait() for code like target/iscsi that needs
it for interruptible sleep, that is provided in a subsequent patch.
It now expects TASK_UNINTERRUPTIBLE when the caller is able to sleep
waiting for a new tag, or TASK_RUNNING when the caller cannot sleep,
and is forced to return a negative value when no tags are available.
v2 changes:
- Include blk-mq + tcm_fc + vhost/scsi + target/iscsi changes
- Drop signal_pending_state() call
v3 changes:
- Only call prepare_to_wait() + finish_wait() when != TASK_RUNNING
(PeterZ)
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: <stable@vger.kernel.org> #3.12+
Mark functions ft_tpg_alloc_fabric_acl(), ft_register_configfs() and
ft_deregister_configfs() as static in tcm_fc/tfc_conf.c because they are
not used outside this file.
This eliminates the following warnings in tcm_fc/tfc_conf.c:
drivers/target/tcm_fc/tfc_conf.c:270:21: warning: no previous prototype for ‘ft_tpg_alloc_fabric_acl’ [-Wmissing-prototypes]
drivers/target/tcm_fc/tfc_conf.c:555:5: warning: no previous prototype for ‘ft_register_configfs’ [-Wmissing-prototypes]
drivers/target/tcm_fc/tfc_conf.c:602:6: warning: no previous prototype for ‘ft_deregister_configfs’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Remove a lingering macro that just hid a dereference.
This patch converts tcm_fc to use transport_init_session_tags()
pre-allocation logic for struct ft_cmd descriptors using per-cpu
session tag pooling in order to effectively avoid memory allocation
+ release for each received I/O.
It adds percpu_ida_alloc() in ft_recv_cmd() to obtain an tag and
locate ft_cmd from se_sess->sess_cmd_map[], and percpu_ida_free()
in ft_free_cmd() to release the tag based upon se_cmd->map_tag id.
It also uses a TCM_FC_DEFAULT_TAGS value of 512, that puts the
per se_sess->sess_cmd_map allocation at ~360K on 64-bit.
v2 changes:
- Handle possible tag < 0 failure with GFP_ATOMIC
Cc: Kent Overstreet <kmo@daterainc.com>
Signed-off-by: Nicholas Bellinger <nab@daterainc.com>
The usage of strict_strtoul() and strict_strtoull() is not preferred,
because strict_strtoul() and strict_strtoull() are obsolete. Thus,
kstrtoul() and kstrtoull() should be used.
v2: Fix incorrect return in ft_add_tpg (Fengguang)
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The return value wasn't checked by any of the callers. Assuming this is
correct behaviour, we can simplify some code by not bothering to
generate it.
nab: Add srpt_queue_data_in() + srpt_queue_tm_rsp() nops around
srpt_queue_response() void return
Signed-off-by: Joern Engel <joern@logfs.org>
Three have been checked for but were never set. Remove the dead code.
Also renumbers the remaining ones to a) get rid of the holes after the
removal and b) avoid a collision between TMR_FUNCTION_COMPLETE==0 and
the uninitialized case. If we failed to set a code, we should rather
fall into the default case then return success.
