commit ee291e63293146db64668e8d65eb35c97e8324f4 upstream.
When creating network portals rapidly, such as when restoring a
configuration, LIO's code to reuse existing portals can return a false
negative if the thread hasn't run yet and set np_thread_state to
ISCSI_NP_THREAD_ACTIVE. This causes an error in the network stack
when attempting to bind to the same address/port.
This patch sets NP_THREAD_ACTIVE before the np is placed on g_np_list,
so even if the thread hasn't run yet, iscsit_get_np will return the
existing np.
Also, convert np_lock -> np_mutex + hold across adding new net portal
to g_np_list to prevent a race where two threads may attempt to create
the same network portal, resulting in one of them failing.
(nab: Add missing mutex_unlocks in iscsit_add_np failure paths)
(DanC: Fix incorrect spin_unlock -> spin_unlock_bh)
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 4a4caa29f1abcb14377e05d57c0793d338fb945d upstream.
This patch addresses an traditional iscsi-target fabric ack starvation
issue where iscsit_allocate_cmd() -> percpu_ida_alloc_state() ends up
hitting slow path percpu-ida code, because iscsit_ack_from_expstatsn()
is expected to free ack'ed tags after tag allocation.
This is done to take into account the tags waiting to be acknowledged
and released in iscsit_ack_from_expstatsn(), but who's number are not
directly limited by the CmdSN Window queue_depth being enforced by
the target.
So that said, this patch bumps up the pre-allocated number of
per session tags to:
(max(queue_depth, ISCSIT_MIN_TAGS) * 2) + ISCSIT_EXTRA_TAGS
for good measure to avoid the percpu_ida_alloc_state() slow path.
lun->lun_ref is also initialized in core_tpg_post_addlun, so it doesn't
need to be done in core_tpg_setup_virtual_lun0.
(nab: Drop left-over percpu_ref_cancel_init in failure path)
This patch allows FILEIO to update hw_max_sectors based on the current
max_bytes_per_io. This is required because vfs_[writev,readv]() can accept
a maximum of 2048 iovecs per call, so the enforced hw_max_sectors really
needs to be calculated based on block_size.
This addresses a >= v3.5 bug where block_size=512 was rejecting > 1M
sized I/O requests, because FD_MAX_SECTORS was hardcoded to 2048 for
the block_size=4096 case.
(v2: Use max_bytes_per_io instead of ->update_hw_max_sectors)
Reported-by: Henrik Goldman <hg@x-formation.com>
Cc: <stable@vger.kernel.org> #3.5+
When shutting down a target there is a race condition between
iscsit_del_np() and __iscsi_target_login_thread().
The latter sets the thread pointer to NULL, and the former
tries to issue kthread_stop() on that pointer without any
synchronization.
This patch moves the np->np_thread NULL assignment into
iscsit_del_np(), after kthread_stop() has completed. It also
removes the signal_pending() + np_state check, and only
exits when kthread_should_stop() is true.
Reported-by: Hannes Reinecke <hare@suse.de>
Cc: <stable@vger.kernel.org> #3.12+
This patch changes special case handling for ISCSI_OP_SCSI_CMD
where an initiator sends a zero length Expected Data Transfer
Length (EDTL), but still sets the WRITE and/or READ flag bits
when no payload transfer is requested.
Many, many moons ago two special cases where added for an ancient
version of ESX that has long since been fixed, so instead of adding
a new special case for the reported bug with a Broadcom 57800 NIC,
go ahead and always strip off the incorrect WRITE + READ flag bits.
Also, avoid sending a reject here, as RFC-3720 does mandate this
case be handled without protocol error.
Reported-by: Witold Bazakbal <865perl@wp.pl>
Tested-by: Witold Bazakbal <865perl@wp.pl>
Cc: <stable@vger.kernel.org> #3.1+
Commit 04f3b31bff72 ("iscsi-target: Convert iscsi_session statistics to
atomic_long_t") removed the updating of these fields in iscsi (the only
fabric driver that ever touched these counters), and the core has no way
to report or otherwise use the values. Remove the last remnants of
these counters.
Signed-off-by: Roland Dreier <roland@purestorage.com>
The iSCSI CHAP auth parameters are already copied with respect for
the destination buffer size. Return -EINVAL instead of silently
truncating the input.
Signed-off-by: Eric Seppanen <eric@purestorage.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Things have been quiet this round with mostly bugfixes, percpu
conversions, and other minor iscsi-target conformance testing changes.
The highlights include:
- Add demo_mode_discovery attribute for iscsi-target (Thomas)
- Convert tcm_fc(FCoE) to use percpu-ida pre-allocation
- Add send completion interrupt coalescing for ib_isert
- Convert target-core to use percpu-refcounting for se_lun
- Fix mutex_trylock usage bug in iscsit_increment_maxcmdsn
- tcm_loop updates (Hannes)
- target-core ALUA cleanups + prep for v3.14 SCSI Referrals support (Hannes)
v3.14 is currently shaping to be a busy development cycle in target
land, with initial support for T10 Referrals and T10 DIF currently on
the roadmap"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (40 commits)
iscsi-target: chap auth shouldn't match username with trailing garbage
iscsi-target: fix extract_param to handle buffer length corner case
iscsi-target: Expose default_erl as TPG attribute
target_core_configfs: split up ALUA supported states
target_core_alua: Make supported states configurable
target_core_alua: Store supported ALUA states
target_core_alua: Rename ALUA_ACCESS_STATE_OPTIMIZED
target_core_alua: spellcheck
target core: rename (ex,im)plict -> (ex,im)plicit
percpu-refcount: Add percpu-refcount.o to obj-y
iscsi-target: Do not reject non-immediate CmdSNs exceeding MaxCmdSN
iscsi-target: Convert iscsi_session statistics to atomic_long_t
target: Convert se_device statistics to atomic_long_t
target: Fix delayed Task Aborted Status (TAS) handling bug
iscsi-target: Reject unsupported multi PDU text command sequence
ib_isert: Avoid duplicate iscsit_increment_maxcmdsn call
iscsi-target: Fix mutex_trylock usage in iscsit_increment_maxcmdsn
target: Core does not need blkdev.h
target: Pass through I/O topology for block backstores
iser-target: Avoid using FRMR for single dma entry requests
In iSCSI negotiations with initiator CHAP enabled, usernames with
trailing garbage are permitted, because the string comparison only
checks the strlen of the configured username.
e.g. "usernameXXXXX" will be permitted to match "username".
Just check one more byte so the trailing null char is also matched.
extract_param() is called with max_length set to the total size of the
output buffer. It's not safe to allow a parameter length equal to the
buffer size as the terminating null would be written one byte past the
end of the output buffer.
This patch exposes default_erl as a TPG attribute so that it may be
set TPG wide in demo-mode, but still allow the existing NodeACL
attribute to be overridden on a per initiator basis.
Reported-by: Arshad Hussain <arshad.hussain@calsoftinc.com>
Split up the various ALUA states into individual attributes to
make parsing easier and adhere to the one value per attribute
sysfs principle.
(nab: Convert strict_strtoul -> kstrtoul usage)
Signed-off-by: Hannes Reinecke <hare@suse.de>
The supported ALUA states might be different for individual
devices, so store it in a separate field.
(nab: Remove unnecessary line continuation)
Rename ALUA_ACCESS_STATE_OPTMIZED to
ALUA_ACCESS_STATE_OPTIMIZED.
This patch changes iscsit_sequence_cmd() logic to no longer reject
non-immediate CmdSNs that exceed MaxCmdSN with a protocol error,
but instead silently ignore them.
This is done to correctly follow RFC-3720 Section 3.2.2.1:
For non-immediate commands, the CmdSN field can take any
value from ExpCmdSN to MaxCmdSN inclusive. The target MUST silently
ignore any non-immediate command outside of this range or non-
immediate duplicates within the range.
Reported-by: Santosh Kulkarni <santosh.kulkarni@calsoftinc.com>
This patch converts a handful of iscsi_session statistics to type
atomic_long_t, instead of using iscsi_session->session_stats_lock
when incrementing these values.
More importantly, go ahead and drop the spinlock usage within
iscsit_setup_scsi_cmd(), iscsit_check_dataout_hdr(),
iscsit_send_datain(), and iscsit_build_rsp_pdu() fast-path code.
(Squash in Roland's target: Remove write-only stats fields and lock
from struct se_node_acl)
This patch converts the handful of se_device statistics to type
atomic_long_t, instead of using se_device->stats_lock when
transport_lookup_cmd_lun() fast-path code.
This patch fixes a bug in delayed Task Aborted Status (TAS) handling,
where transport_send_task_abort() was not returning for the case
when the se_tfo->write_pending() callback indicated that last fabric
specific WRITE PDU had not yet been received.
It also adds an explicit cmd->scsi_status = SAM_STAT_TASK_ABORTED
assignment within transport_check_aborted_status() to avoid the case
where se_tfo->queue_status() is called when the SAM_STAT_TASK_ABORTED
assignment + ->queue_status() in transport_send_task_abort() does not
occur once SCF_SENT_DELAYED_TAS has been set.
Cc: <stable@vger.kernel.org> #3.2+
This patch adds a check to reject text commands with F_BIT=0 ||
C_BIT=1, as multi PDU text command sequences are currently
unsupported.
This avoids the case where a text command received with F_BIT=0,
was generating a text response with F_BIT=1 which is a protocol
error according to RFC-3720 Section 10.11.1.
This patch fixes a >= v3.10 regression bug with mutex_trylock() usage
within iscsit_increment_maxcmdsn(), that was originally added to allow
for a special case where ->cmdsn_mutex was already held from the
iscsit_execute_cmd() exception path for ib_isert.
When !mutex_trylock() was occuring under contention during normal RX/TX
process context codepaths, the bug was manifesting itself as the following
protocol error:
Received CmdSN: 0x000fcbb7 is greater than MaxCmdSN: 0x000fcbb6, protocol error.
Received CmdSN: 0x000fcbb8 is greater than MaxCmdSN: 0x000fcbb6, protocol error.
This patch simply avoids the direct ib_isert callback in lio_queue_status()
for the special iscsi_execute_cmd() exception cases, that allows the problematic
mutex_trylock() usage in iscsit_increment_maxcmdsn() to go away.
Reported-by: Moussa Ba <moussaba@micron.com>
Tested-by: Moussa Ba <moussaba@micron.com>
Cc: <stable@vger.kernel.org> # v3.10+
Target core does not depend on the block layer, only backstores that
use the block layer do.
In addition to block size (already implemented), passing through
alignment offset, logical-to-phys block exponent, I/O granularity and
optimal I/O length will allow initiators to properly handle layout on
LUNs with 4K block sizes.
Tested with various weird values via scsi_debug module.
One thing to look at with this patch is the new block limits values --
instead of granularity 1 optimal 8192, Lio will now be returning whatever
the block device says, which may affect performance.
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
This patch adds a se_device->xcopy_lun that is used for local
copy offload I/O, instead of allocating + initializing a pseudo
se_lun for each received EXTENDED_COPY operation.
Also, move declaration of struct se_lun + struct se_port_stat_grps
ahead of struct se_device.
Now with percpu refcounting for se_lun in place, go ahead and drop
the legacy per se_cmd accounting for se_lun shutdown.
This includes __transport_clear_lun_from_sessions(), the associated
transport_lun_wait_for_tasks() logic, along with a handful of now
unused se_cmd structure members and ->transport_state bits.
Cc: Kent Overstreet <kmo@daterainc.com>
This patch adds percpu refcounting for se_lun access that allows the
association of an se_lun + se_cmd in transport_lookup_cmd_lun() to
occur without an extra list_head for tracking outstanding I/O during
se_lun shutdown.
This effectively changes se_lun shutdown logic to wait for outstanding
I/O percpu references to complete in transport_lun_remove_cmd() using
se_lun->lun_ref_comp, instead of explicitly draining the per se_lun
command list and waiting for individual se_cmd descriptor processing
to complete.
This patch changes iscsit_check_dataout_hdr() to no longer generate
REJECTs for zero-length DataOUTs, and instead simply ignore these
requests.
This follows RFC-3720, Section 10.7.7. DataSegmentLength
"This is the data payload length of a SCSI Data-In or SCSI Data-Out PDU.
The sending of 0 length data segments should be avoided, but initiators
and targets MUST be able to properly receive 0 length data segments."
In case of error, the function scsi_host_lookup() returns NULL
pointer not ERR_PTR(). The IS_ERR() test in the return value check
should be replaced with NULL test.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This patch adds an explicit check + failure for XCOPY I/O to source +
destination devices with a non-matching block_size.
This limitiation is currently due to the fact that the scatterlist
memory allocated for the XCOPY READ operation is passed zero-copy
to the XCOPY WRITE operation.
Reported-by: Thomas Glanzmann <thomas@glanzmann.de>
Reported-by: Douglas Gilbert <dgilbert@interlog.com>
Cc: Thomas Glanzmann <thomas@glanzmann.de>
Cc: Douglas Gilbert <dgilbert@interlog.com>
This patch adds the missing non-zero se_cmd->scsi_status check required
for local XCOPY I/O within target_xcopy_issue_pt_cmd() to signal an
exception case failure.
This will trigger the generation of SAM_STAT_CHECK_CONDITION status
from within target_xcopy_do_work() process context code.
This patch adds the missing xcopy_pt_cmd->sense_buffer[] required for
correctly handling CHECK_CONDITION exceptions within the locally
generated XCOPY I/O path.
Also update target_xcopy_read_source() + target_xcopy_setup_pt_cmd()
to pass this buffer into transport_init_se_cmd() to correctly setup
se_cmd->sense_buffer.
If demo_mode_discovery=0 and generate_node_acls=0 (demo mode dislabed) do
not return TargetName+TargetAddress unless a NodeACL exists.
Signed-off-by: Thomas Glanzmann <thomas@glanzmann.de>
Export symbol core_tpg_check_initiator_node_acl and move prototype from the
private drivers/target/target_core_internal.h to the public
include/target/target_core_fabric.h
Add a new TPG attribute demo_mode_discovery which is enabled by default.
Implement target reset by resetting the transport status.
(nab: Remove unused ret in tcm_loop_target_reset)
Implement TCQ support, which enables us to do proper command
abort, too.
No functional change.
Add attribute 'transport_status' to simulate link failure.
These just want to return a pointer instead of a value, but are otherwise
the same.
ISCSI_TPG_LUN macro was unused.
These are all straightforward.
Remove a lingering macro that just hid a dereference.
Per SBC-3, since we report ANC_SUP==0 in VPD page B2h, we need to return
an error (ILLEGAL REQUEST/INVALID FIELD IN CDB) for all WRITE SAME
requests with ANCHOR==1.
This patch rejects EXTENDED_COPY when the emulate_3pc attribute has
been explicitly disabled for the receiving device.
It also adds a similar check in target_xcopy_locate_se_dev_e4() to
ignore these devices when doing a search based upon the identifier
WWN provided by EXTENDED_COPY parameter list target descriptors.
This patch changes target_do_xcopy() to allow processing of non-zero
ListIDs in EXTENDED_COPY parameter list data, instead of returning
CHECK_CONDITION status.
As the copy offload implementation reports SNLID=1 (Supports No ListID)
in OPERATING PARAMETERS, any ListID value presented by the client is
currently ignored.
Also, properly extract list_id_usage for informational purposes.
Cc: Hannes Reinecke <hare@suse.de>
This patch changes target_do_xcopy() to properly return
TCM_INVALID_PARAMETER_LIST instead of TCM_INVALID_CDB_FIELD
for failures related to the EXTENDED_COPY parameter list parsing.
Also, move struct xcopy_op allocation ahead of kmapping to
handle the special TCM_OUT_OF_RESOURCES case.
This patch bumps the default number of tags allocated per session by
iscsi-target via transport_alloc_session_tags() -> percpu_ida_init()
by another (tag_num / 2).
the target.
Using a larger value here is also useful to prevent percpu_ida_alloc()
from having to steal tags from other CPUs when no tags are available
on the local CPU, while waiting for unacknowledged tags to be released.
